Wyze LED Bulbs: Sun-Match Automatic Color Tuning Smart Lights
Discover Wyze Smart LED Bulbs with Sun-Match Automatic Color Tuning
When it comes to smart lighting that adapts seamlessly to your environment, Wyze offers an impressive lineup of LED bulbs featuring automatic color tuning that mimics natural sunlight. Whether you want vibrant colors, warm whites, or a perfect daylight match, these bulbs intelligently adjust to create the ideal ambiance for any time of day or activity.
Wyze Bulb Color: The Ultimate 16 Million Color Smart Bulb
Brilliant Color and Sunlight Matching
The Wyze Bulb Color stands out as a premium smart bulb with 16 million colors and a wide color temperature range from 1800K to 6500K, allowing it to replicate the natural progression of sunlight throughout the day. This automatic color tuning feature ensures your lighting feels natural and comfortable, reducing eye strain and enhancing mood.
  • Brightness: Up to 1100 lumens for extra bright illumination
  • Dimmable: Yes, with fine control (though it "takes offense" if over-dimmed!)
  • Color Rendering Index: 90+ for vivid, true-to-life colors
  • Connectivity: Wi-Fi (802.11 b/g/n 2.4GHz) and Bluetooth
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice and automation control
  • Life Expectancy: 25,000 hours
  • Suitable for Damp Locations: Yes
This bulb is perfect for living rooms, bedrooms, or any space where you want dynamic lighting that adjusts automatically to your daily rhythm. Wyze Bulb Color in Living Room Experience vibrant, natural lighting with Wyze Bulb Color in your living space.
Wyze Bulb Color BR30: Smart Recessed Lighting with Color Tuning
Perfect for Recessed Fixtures
If you prefer recessed lighting, the Wyze Bulb Color BR30 offers the same advanced color tuning and smart features in a bulb designed to fit your existing fixtures. It delivers a wide lumen range from 30 to 950 lumens and supports the full spectrum of 16 million colors with a color temperature range of 1800K to 6500K.
  • Dimmable: Yes (note: not compatible with dimmer switches)
  • Smart Features: Custom lighting scenes, voice control, sleep routines, vacation and music modes
  • Color Rendering Index: 90+ for accurate color representation
  • Connectivity: Wi-Fi and Bluetooth
  • Base Type: E26, fits standard recessed sockets
This bulb is ideal for kitchens, hallways, or any recessed lighting setup where you want smart, tunable lighting that matches the natural sunlight cycle.
Wyze Bulb White: Tunable White LED Bulb for Natural Light
Simple, Smart White Lighting with Sunlight Matching
For those who prefer white light with automatic tuning, the Wyze Bulb White offers adjustable color temperatures between 2700K (warm white) and 6500K (cool daylight). This bulb automatically adjusts to mimic natural sunlight, helping to maintain your circadian rhythm and improve comfort throughout the day.
  • Brightness: Up to 800 lumens
  • Dimmable: Yes, with smooth control
  • Color Rendering Index: 90+ for clear, natural light
  • Compatibility: Alexa, Google Assistant, and IFTTT
Perfect for bedrooms, offices, or bathrooms, this bulb provides a clean, natural light that adjusts automatically to your environment. Wyze Bulb White in Bedroom Create a cozy, naturally lit bedroom with Wyze Bulb White’s tunable white light.
Why Choose Wyze Smart Bulbs with Automatic Color Tuning?
"Lighting that adapts to your life, not the other way around."
Wyze smart bulbs with sun-match automatic color tuning bring the benefits of natural light indoors, enhancing your well-being, productivity, and relaxation. Their integration with popular smart home ecosystems and intuitive app control make it easy to customize your lighting scenes or let the bulbs adjust automatically based on the time of day.
  • Energy Efficient: Low wattage with high lumen output saves energy
  • Long Lifespan: 25,000 hours of reliable use
  • Smart Automation: Set schedules, routines, and voice commands
  • Wide Compatibility: Works with Android and iOS devices
Summary of Wyze LED Bulbs with Sun-Match Color Tuning
ProductColor OptionsLumens RangeColor Temp RangeConnectivitySpecial Features
Wyze Bulb Color16 million colors30 - 1100 lumens1800K - 6500KWi-Fi, BluetoothDimmable, Alexa/Google/IFTTT
Wyze Bulb Color BR3016 million colors30 - 950 lumens1800K - 6500KWi-Fi, BluetoothRecessed fixture compatible
Wyze Bulb WhiteTunable white30 - 800 lumens2700K - 6500KWi-Fi, BluetoothDimmable, Alexa/Google/IFTTT
Embrace the future of home lighting with Wyze smart bulbs that automatically tune their color temperature to match the sun, creating a healthier, more vibrant living environment.
FeatureWyze Bulb ColorWyze Bulb Color BR30Wyze Bulb White
TypeSmart LightingConnected HomeConnected Home
ShapeA19BR30A19
Base TypeE26E26E26
Lumen Output30 lm (dim) - 1100 lm (bright)30 lm (dim) - 950 lm (bright)30 lm - 800 lm
Wattage Equivalent75W75W9.5W
Color Options16 million colors16 million colorsWhite light only
Color Temperature Range1800K - 6500K (tunable white)Tunable white with Sun Match2700K - 6500K
CRI Rating90+90+90+
DimmableYes (takes offense if used)Yes (not for use with dimmer switches)Yes
ConnectivityWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Special FeaturesCustom presets, notifications, sleep routines, music modeSun Match, custom scenes, notifications, sleep routines, music modeDimmable, simple white light control
Compatible AppWyze appWyze appWyze app
Pack Variants & Prices2 Pack ($26.26), 4 Pack ($44.44), 6 Pack ($64.98)2 Pack ($27.98), 4 Pack ($49.98)2 Pack ($23.99), 4 Pack ($39.99), 6 Pack ($59.99)
Suitable for Damp LocationsYesYesYes
Life Expectancy25,000 hours (implied)25,000 hours (implied)25,000 hours
What is Sun-Match automatic color tuning in Wyze smart LED bulbs?Sun-Match automatic color tuning is a feature in Wyze smart LED bulbs that automatically adjusts the color temperature of your lighting to mimic the natural progression of sunlight throughout the day. This helps create a comfortable, natural ambiance and supports your circadian rhythm.
What are the main differences between Wyze Bulb Color, Wyze Bulb Color BR30, and Wyze Bulb White?Wyze Bulb Color offers 16 million colors and a color temperature range of 1800K to 6500K, suitable for standard fixtures. Wyze Bulb Color BR30 provides the same color features but is designed for recessed lighting with an E26 base. Wyze Bulb White offers tunable white light from 2700K to 6500K, focusing on natural white lighting rather than full color.
Are Wyze smart bulbs compatible with Alexa and Google Assistant?Yes, all Wyze smart bulbs, including Wyze Bulb Color, Wyze Bulb Color BR30, and Wyze Bulb White, are compatible with Alexa, Google Assistant, and IFTTT for convenient voice control and smart home automation.
Can Wyze smart bulbs be used in damp locations like bathrooms?Yes, Wyze Bulb Color and Wyze Bulb White are suitable for damp locations, making them ideal for use in bathrooms and other areas with higher humidity.
How long do Wyze smart LED bulbs last?Wyze smart LED bulbs have a long lifespan of up to 25,000 hours, providing years of reliable and energy-efficient lighting.
Do Wyze smart bulbs support dimming?Yes, all Wyze smart bulbs are dimmable with smooth, fine control. However, the Wyze Bulb Color BR30 is not compatible with traditional dimmer switches and should be dimmed via the Wyze app or voice assistants.
What is the brightness range of Wyze smart bulbs?Wyze Bulb Color offers up to 1100 lumens, Wyze Bulb Color BR30 up to 950 lumens, and Wyze Bulb White up to 800 lumens. All bulbs support a wide range of brightness levels for customizable lighting.
What connectivity options do Wyze smart bulbs offer?Wyze smart bulbs connect via Wi-Fi (2.4GHz) and Bluetooth, allowing for easy setup and control through the Wyze app on Android and iOS devices.
Can I set schedules and routines with Wyze smart bulbs?Yes, Wyze smart bulbs support smart automation features, including custom schedules, routines, and lighting scenes. You can also use vacation and music modes for added convenience.
Are Wyze smart bulbs energy efficient?Yes, Wyze smart bulbs are designed to be energy efficient, offering high lumen output with low wattage consumption, helping you save on energy costs.
What is the Color Rendering Index (CRI) of Wyze smart bulbs?All Wyze smart bulbs have a high Color Rendering Index (CRI) of 90+, ensuring vivid, true-to-life colors and clear, natural light in your home.
Can Wyze Bulb Color BR30 be used with dimmer switches?No, Wyze Bulb Color BR30 is not compatible with traditional dimmer switches. Dimming should be controlled through the Wyze app or compatible voice assistants.
Can you tell me more about the smart features of the Wyze Bulb Color BR30?How does the automatic color tuning feature work in the Wyze Bulb White?Do you have any deals, ongoing sales, discounts, or promotions for Wyze products?
