Wyze Smart BR30 Bulb: Tunable White & Vibrant Color Lighting
Discover the Wyze Smart BR30 Bulb with Tunable White and Vibrant Colors
If you're searching for a smart BR30 bulb that offers tunable white light and a dazzling spectrum of vibrant colors, Wyze has you covered with its innovative Wyze Bulb Color BR30. Designed to fit standard recessed lighting fixtures, this smart bulb transforms your home lighting experience with 16 million colors, adjustable brightness, and advanced smart features. Alongside it, the Wyze Bulb Color (A19) offers a versatile option for other fixtures, while the Wyze Bulb White provides excellent tunable white light for simpler needs.
Wyze Bulb Color BR30: The Ultimate Smart BR30 Bulb
Brilliant Color and Brightness Control
The Wyze Bulb Color BR30 stands out with its ability to deliver up to 950 lumens, brighter than most BR30 bulbs on the market that max out at 650 lumens. It also dims down to as low as 30 lumens, giving you full control over the ambiance from bright task lighting to subtle mood lighting.
16 Million Ultra-Accurate Colors
With 16 million colors at your fingertips, you can set the perfect mood for any occasion—whether it's game day, a cozy wine night, or a lively party. The Wyze app lets you precisely control colors and create custom lighting scenes that you can save and switch between instantly.
Tunable White Light for Every Moment
Adjust the color temperature from warm to cool white (1800K to 6500K) to suit your activity. Whether you want to focus with cool daylight or relax with warm soft light, the Wyze Bulb Color BR30 adapts seamlessly.
Advanced Features for Smart Living
  • Sun Match: Automatically adjusts color temperature throughout the day to support your natural circadian rhythm.
  • 90+ CRI Rating: See colors more vividly and accurately, enhancing your home’s true colors.
  • Brilliant Notifications: Use color alerts for reminders or security notifications integrated with other Wyze devices.
  • Sleep Routines: Wake up or fall asleep with gradual light changes mimicking sunrise and sunset.
  • Music Mode: Sync your lights to the beat when grouped with Wyze Light Strip or Light Strip Pro.
Compatibility and Installation
  • Fits standard E26 recessed/can lighting sockets.
  • Not compatible with dimmer switches.
  • Works with Alexa and Google Assistant for voice control.
  • Connectivity via 2.4 GHz Wi-Fi and Bluetooth.
Wyze Bulb Color BR30 in Living Room Experience vibrant, tunable smart lighting in your living room
Wyze Bulb Color (A19): Versatile Smart Color Bulb for Everyday Use
Brightness and Color Range
The Wyze Bulb Color (A19) offers up to 1100 lumens, making it one of the brightest smart color bulbs available. It dims down to 30 lumens, allowing you to customize lighting intensity for any room or mood.
16 Million Colors and Tunable White
Enjoy the same vast color palette and tunable white light control (2700K to 6500K) as the BR30, perfect for bedrooms, offices, or accent lighting.
Smart Features
  • Create and save custom presets for quick scene changes.
  • 90+ CRI for true-to-life colors.
  • Notifications and automation with Wyze sensors.
  • Sleep routines and music sync capabilities.
  • Voice control with Alexa and Google Assistant.
Easy Installation
  • Standard E26 base fits most lamps and fixtures.
  • Compatible with Wyze app for seamless control.
Wyze Bulb Color in Bedroom Add vibrant color and smart control to your bedroom lighting
Wyze Bulb White: Simple, Bright, and Tunable White Lighting
Bright and Adjustable White Light
For those who prefer classic white lighting with smart features, the Wyze Bulb White offers a tunable white range from 2700K (warm) to 6500K (cool daylight) with brightness up to 800 lumens.
Key Features
  • Dimmable from 30 to 800 lumens.
  • 90+ CRI for accurate color rendering.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Supports sleep routines and vacation mode.
  • Suitable for damp locations and rated for 25,000 hours lifespan.
Ideal For
  • Living rooms, bedrooms, kitchens, and bathrooms.
  • Users who want simple, reliable smart white lighting without color.
Wyze Bulb White in Cozy Bedroom Warm and tunable white light perfect for relaxing spaces
Why Choose Wyze Smart Bulbs?
Wyze smart bulbs combine affordability, advanced features, and ease of use to bring smart lighting to every home. Whether you want the full spectrum of colors with the BR30 or A19 bulbs or prefer the simplicity of tunable white light, Wyze offers solutions that integrate seamlessly with your smart home ecosystem.
  • Wide Compatibility: Works with Alexa, Google Assistant, and Wyze app.
  • Customizable Scenes: Save and switch between lighting moods effortlessly.
  • Energy Efficient: Long-lasting bulbs with low power consumption.
  • Smart Automations: Integrate with Wyze sensors and devices for enhanced home automation.
Summary of Wyze Smart Bulbs for Tunable White and Vibrant Colors
ProductShape/BaseMax LumensColor OptionsWhite Temperature RangeSpecial Features
Wyze Bulb Color BR30BR30/E26950 lm16 million colors1800K - 6500KSun Match, Music Mode, 90+ CRI, Notifications
Wyze Bulb Color (A19)A19/E261100 lm16 million colors2700K - 6500KCustom presets, Sleep routines, 90+ CRI
Wyze Bulb WhiteA19/E26800 lmWhite only2700K - 6500KSimple dimming, Vacation mode, 90+ CRI
Enhance your home lighting with Wyze smart bulbs that offer tunable white and vibrant colors, perfect for any mood or occasion.
FeatureWyze Bulb Color BR30Wyze Bulb Color
Bulb ShapeBR30Standard (A19)
Base TypeE26E26
Lumen Output30 lm (dim) to 950 lm (max)30 lm (dim) to 1100 lm (max)
Wattage75W equivalent75W equivalent
Color Options16 million colors16 million colors
DimmableYes (Not for use with dimmer switches)Yes (but "takes offense" if used)
White Light Temperature ControlYesYes
Color Rendering Index (CRI)90+90+
ConnectivityWi-Fi (2.4 GHz), BluetoothWi-Fi (2.4 GHz), Bluetooth
Voice ControlAlexa, Google AssistantAlexa, Google Assistant
Special FeaturesSun Match, Brilliant notifications, Sleep routines, Music Mode (with Wyze Light Strip)Brilliant notifications, Sleep routines, Music Mode (with Wyze Light Strip)
Compatible FixturesRecessed/can lighting fixturesStandard fixtures
Not Compatible WithDimmer switchesNot specified
Packs Available2-Pack ($27.98), 4-Pack ($49.98)2-Pack ($26.26), 4-Pack ($44.44), 6-Pack ($64.98)
App ControlWyze appWyze app
GroupingYesYes
Vacation ModeYesYes
What is the Wyze Bulb Color BR30 and what makes it unique?The Wyze Bulb Color BR30 is a smart BR30 bulb designed for standard recessed lighting fixtures. It offers 16 million vibrant colors, tunable white light (1800K to 6500K), and up to 950 lumens of brightness—brighter than most BR30 bulbs. Advanced features include Sun Match, music sync, sleep routines, and integration with Alexa and Google Assistant.
How do I control the Wyze smart bulbs?Wyze smart bulbs can be controlled using the Wyze app, which allows you to adjust brightness, color, and create custom lighting scenes. They are also compatible with voice assistants like Alexa and Google Assistant for hands-free control.
What is the difference between Wyze Bulb Color BR30 and Wyze Bulb Color (A19)?The Wyze Bulb Color BR30 is designed for recessed/can lighting with a BR30 shape and offers up to 950 lumens and a color temperature range of 1800K to 6500K. The Wyze Bulb Color (A19) fits most lamps and fixtures with an A19 shape, provides up to 1100 lumens, and a color temperature range of 2700K to 6500K. Both offer 16 million colors and advanced smart features.
Can Wyze smart bulbs be used with dimmer switches?No, Wyze smart bulbs are not compatible with dimmer switches. Dimming and brightness adjustments should be made through the Wyze app or via voice control.
What is the color rendering index (CRI) of Wyze smart bulbs?All Wyze smart bulbs feature a 90+ CRI rating, ensuring vivid and accurate color rendering for true-to-life lighting in your home.
What is Sun Match and how does it work?Sun Match is a feature available on the Wyze Bulb Color BR30 that automatically adjusts the bulb’s color temperature throughout the day to support your natural circadian rhythm, helping you stay energized during the day and relaxed at night.
Are Wyze smart bulbs energy efficient and long-lasting?Yes, Wyze smart bulbs are energy efficient and designed for long-lasting performance. For example, the Wyze Bulb White is rated for up to 25,000 hours of use.
What is the brightness range of Wyze smart bulbs?The Wyze Bulb Color BR30 offers brightness from 30 to 950 lumens, the Wyze Bulb Color (A19) from 30 to 1100 lumens, and the Wyze Bulb White from 30 to 800 lumens. All bulbs are fully dimmable via the Wyze app.
Can I use Wyze smart bulbs in damp locations?Yes, the Wyze Bulb White is suitable for damp locations, making it ideal for use in bathrooms and kitchens.
What smart home platforms are Wyze bulbs compatible with?Wyze smart bulbs work with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home ecosystem.
What is the difference between Wyze Bulb Color and Wyze Bulb White?Wyze Bulb Color (BR30 and A19) offers 16 million colors and tunable white light, while Wyze Bulb White provides only tunable white light (2700K to 6500K) without color options. Both offer smart features like dimming, routines, and voice control.
How do I install Wyze smart bulbs?Wyze smart bulbs have a standard E26 base and can be installed in most lamps and fixtures. Simply screw in the bulb, connect it to your 2.4 GHz Wi-Fi network using the Wyze app, and follow the setup instructions.
Can I automate Wyze smart bulbs with other Wyze devices?Yes, Wyze smart bulbs can be automated and integrated with other Wyze devices, such as sensors, for enhanced home automation and notifications.
What is the tunable white range for Wyze smart bulbs?The Wyze Bulb Color BR30 offers a tunable white range from 1800K to 6500K, while the Wyze Bulb Color (A19) and Wyze Bulb White offer a range from 2700K to 6500K.
Do Wyze smart bulbs support music sync?Yes, both Wyze Bulb Color BR30 and A19 support music sync when grouped with Wyze Light Strip or Light Strip Pro, allowing your lights to pulse to the beat of your music.
Can you tell me more about the advanced features of the Wyze Bulb Color BR30?How does the Sun Match feature work in the Wyze Bulb Color BR30?Do you have any ongoing sales or discounts for the Wyze Bulb Color BR30?
