LED Accent Lighting Strips: Easy Install & Smart Automation
LED Accent Lighting Strips with Easy Installation and Automation Control
Transform your living space with vibrant, customizable LED accent lighting that’s simple to install and smart to control. Whether you want to brighten up your entertainment area, highlight architectural features, or create the perfect ambiance, these LED light strips offer brilliant colors, seamless automation, and effortless setup.
Wyze Light Strip: Brilliant Colors, Simple Setup, Smart Control
The Wyze Light Strip is your go-to solution for adding vivid LED accent lighting anywhere in your home. Available in two lengths—16.4 feet and 32.8 feet—this strip lets you color your world with 16 million colors, perfect for backlighting TVs, framing headboards, or illuminating dark corners.
  • Easy Installation: Just peel, stick, and plug in. No complicated wiring or tools needed.
  • Smart Automation: Use the Wyze app to set timers, create custom lighting routines, or automate your lights to sync with the natural daylight cycle using Sun Match.
  • Music Mode: Lights dance to your favorite tunes with a built-in microphone that syncs colors to the beat.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free lighting commands.
  • Vacation Mode: Simulate occupancy by scheduling lights to turn on and off while you’re away.
  • Flexible Lengths: Choose between 16.4 feet or 32.8 feet to fit your space perfectly.
Add a splash of color and smart convenience to your home with the Wyze Light Strip’s easy peel-and-stick design and powerful automation features.
Wyze Light Strip in cozy living room setting Alt text: Wyze Light Strip installed under kitchen cabinets creating warm accent lighting
Smart Lighting Automation with Wyze Lamp Socket v2 Bundles
For those looking to integrate smart lighting with outdoor or existing fixtures, the Cam v4 + Lamp Socket v2 Bundle and Pan v3 + Lamp Socket v2 Bundle offer a perfect combination of smart cameras and automated lighting control.
  • Easy Installation: The Lamp Socket v2 installs just like a lightbulb—no wiring or outlets required.
  • Smart Power: Powers Wyze Cam v4 or Pan v3 cameras directly from your outdoor light fixture.
  • Motion-Activated Lighting: Lights turn on automatically when the camera detects motion, enhancing security and convenience.
  • Group Control: Link multiple lamp sockets and control them all via the Wyze app.
  • Dusk to Dawn Automation: Lights automatically turn on at dusk and off at dawn, saving energy and providing consistent illumination.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 cameras.
  • Recommended Bulbs: Use CFL or LED bulbs under 20W for optimal performance.
Upgrade your exterior lighting to smart, automated illumination with a simple screw-in installation that powers your Wyze cameras and lights simultaneously.
Why Choose Wyze for Your LED Accent Lighting and Automation?
Wyze products combine affordability, ease of use, and powerful smart home features. The Wyze Light Strip stands out for its:
  • Vibrant Color Range: 16 million colors to customize your mood and décor.
  • Seamless App Integration: Control all your lighting and cameras from one intuitive app.
  • Voice Assistant Compatibility: Works with Alexa and Google Assistant for effortless voice commands.
  • Automation Routines: Set schedules, timers, and routines that fit your lifestyle.
  • Music Sync: Bring your parties and relaxation time to life with lights that move to your music.
With Wyze’s smart lighting solutions, you get more than just illumination—you get a dynamic, automated experience that enhances your home’s ambiance and security. Wyze Cam v4 mounted outdoors with smart lighting Alt text: Wyze Cam v4 mounted outdoors with smart lighting for home security
Summary of Featured Products
Wyze Light Strip Peel-and-stick LED strip with 16 million colors, music sync, voice control, and automation. Available in 16.4 ft and 32.8 ft lengths. Cam v4 + Lamp Socket v2 Bundle Powers Wyze Cam v4 from outdoor light fixtures, enabling motion-activated lighting and smart control without extra wiring. Pan v3 + Lamp Socket v2 Bundle Similar to the Cam v4 bundle but designed for Wyze Cam Pan v3, offering flexible smart lighting and camera power solutions.
Enhance your home with LED accent lighting strips that are easy to install and packed with smart automation features. Wyze’s connected lighting and camera bundles provide a seamless way to brighten your space and secure your home with intelligent control at your fingertips.
FeatureWyze Light StripCam v4 + Lamp Socket v2 BundlePan v3 + Lamp Socket v2 Bundle
Product TypeConnected Home LightingCamera BundleCamera Bundle
Included ProductsWyze Light Strip (16.4 ft or 32.8 ft)Wyze Cam v4 + Lamp Socket v2Wyze Cam Pan v3 + Lamp Socket v2
Price Range$19.99 - $35.99$49.96$53.96
Colors Available16 million colorsCam v4: Black, Grey, WhitePan v3: Black, White
Power SourceCorded ElectricPowered via Lamp Socket v2 (no outlet needed)Powered via Lamp Socket v2 (no outlet needed)
Lamp Socket CompatibilityN/AWorks with Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Cam Pan v3Works with Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Cam Pan v3
Lighting FeaturesLED accent lighting, single color zonesMotion-activated lights via Wyze appMotion-activated lights via Wyze app
InstallationAdhesive backing, cuttableScrew-in lamp socket installationScrew-in lamp socket installation
UsageIndoor onlyOutdoor compatible with lamp socketOutdoor compatible with lamp socket
Connectivity802.11 b/g/n 2.4 GHz, Bluetooth802.11 b/g/n 2.4 GHz, Bluetooth802.11 b/g/n 2.4 GHz, Bluetooth
ControlWyze appWyze appWyze app
Motion DetectionNoYes (camera detects motion to trigger lights)Yes (camera detects motion to trigger lights)
Dusk to Dawn AutomationNoYesYes
WarrantyNot specifiedNot specifiedNot specified
Note on BulbsN/AIncandescent bulbs not recommended; use CFL or LED under 20WIncandescent bulbs not recommended; use CFL or LED under 20W
What is the Wyze Light Strip and how can it enhance my home?The Wyze Light Strip is a peel-and-stick LED accent lighting solution that offers 16 million customizable colors. It can be used to brighten entertainment areas, highlight architectural features, or create the perfect ambiance in any room. With easy installation and smart automation features, it enhances your home’s atmosphere and convenience.
How do I install the Wyze Light Strip?Installing the Wyze Light Strip is simple—just peel off the adhesive backing, stick the strip to your desired surface, and plug it in. No complicated wiring or tools are required, making it a hassle-free DIY project.
What smart features does the Wyze Light Strip offer?The Wyze Light Strip offers smart automation through the Wyze app, allowing you to set timers, create custom lighting routines, and automate your lights to sync with the natural daylight cycle using Sun Match. It also features music mode, voice control with Alexa and Google Assistant, and vacation mode for added security.
Can the Wyze Light Strip sync with music?Yes, the Wyze Light Strip features a built-in microphone that enables Music Mode, allowing the lights to dance and change colors in sync with your favorite tunes.
What lengths are available for the Wyze Light Strip?The Wyze Light Strip is available in two flexible lengths: 16.4 feet and 32.8 feet, making it easy to fit a variety of spaces and applications.
Is the Wyze Light Strip compatible with voice assistants?Yes, the Wyze Light Strip works with both Alexa and Google Assistant, allowing you to control your lighting with simple voice commands.
What is the Wyze Lamp Socket v2 and how does it work?The Wyze Lamp Socket v2 is a smart socket that installs like a regular lightbulb, requiring no wiring or outlets. It powers Wyze Cam v4 or Pan v3 cameras directly from your light fixture and enables smart, motion-activated lighting control through the Wyze app.
How does motion-activated lighting work with Wyze Lamp Socket v2 bundles?When paired with a compatible Wyze camera, the Lamp Socket v2 automatically turns on the connected light when motion is detected, enhancing both security and convenience.
Can I control multiple Wyze Lamp Sockets together?Yes, you can link multiple Wyze Lamp Sockets and control them as a group using the Wyze app, making it easy to manage your smart lighting setup.
What types of bulbs are recommended for use with Wyze Lamp Socket v2?For optimal performance, it is recommended to use CFL or LED bulbs under 20W with the Wyze Lamp Socket v2.
Which Wyze cameras are compatible with the Lamp Socket v2?The Wyze Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 cameras.
What automation features are available with Wyze smart lighting products?Wyze smart lighting products offer automation features such as scheduling, timers, routines, dusk-to-dawn automation, and vacation mode. These features can be managed through the Wyze app for a seamless smart home experience.
Why should I choose Wyze for LED accent lighting and smart home automation?Wyze offers affordable, easy-to-use smart lighting solutions with powerful features like vibrant color customization, seamless app integration, voice assistant compatibility, and advanced automation routines. Wyze products enhance your home’s ambiance and security with intelligent, connected control.
Can you tell me more about the smart automation features of the Wyze Light Strip?How does the music mode work with the LED accent lighting?Do you have any ongoing sales or discounts for the Wyze Light Strip?
