Indoor LED Accent Lighting Strip with Voice Control and Timer
Enhance your indoor spaces with vibrant, customizable LED accent lighting strips that respond to your voice and fit perfectly into your daily routines. Whether you want to set the mood for a cozy evening, sync lights to your favorite music, or automate your lighting schedule, Wyze offers smart lighting solutions designed to brighten your home with style and convenience.
Wyze Light Strip: Brilliant LED Accent Lighting Made Simple
Color your world with the
Wyze Light Strip, a versatile indoor LED strip that brings 16 million colors and tunable white light to any room. Perfect for accentuating furniture, backlighting TVs, or adding ambiance to your workspace, this strip is easy to install and control.
Key Features:
- 16 Million Colors & Tunable White: Choose from a full RGB spectrum or adjust to warm or cool white light.
- Music Mode: Lights sync to the beat of your music using the built-in microphone, turning any room into a party.
- Sun Match: Automatically adjusts color temperature to match the natural light cycle, helping you wake, work, and wind down naturally.
- Voice Control: Compatible with Alexa and Google Assistant for hands-free lighting commands.
- Timers & Automations: Set schedules or timers to turn your lights on/off automatically.
- Trimmable Design: Cut the strip at designated marks to fit any space perfectly.
- Easy Mounting: Adhesive backing and included clips make installation quick and secure.
Specifications:
- Available lengths: 16.4 feet and 32.8 feet
- Power: 12V adapter, 18W (16.4 ft) / 36W (32.8 ft)
- Indoor use only
- Life expectancy: 25,000 hours
The Wyze Light Strip is ideal for those who want vibrant, single-color zones with smart features and easy voice control.
Alt: Indoor LED accent lighting strip under kitchen cabinets creating ambient lighting
Wyze Light Strip Pro: Multi-Color Segment Control for Ultimate Customization
Take your indoor lighting to the next level with the
Wyze Light Strip Pro, featuring multi-color segment control that allows up to 16 different colors on the same strip. Perfect for creating dynamic lighting effects and personalized vibes in your living room, bedroom, or entertainment area.
Standout Features:
- Multi-Color Segment Control: Display up to 16 RGB colors simultaneously with advanced lighting effects.
- Protective Epoxy Coating: Durable, flexible design with a refined finish.
- Music Mode: Sync lights to music beats with the built-in microphone.
- Sun Match: Automatically adjusts color temperature throughout the day.
- Voice Control: Works seamlessly with Alexa and Google Assistant.
- Timers & Automations: Schedule your lighting to fit your lifestyle.
- Trimmable Design: Customize length by cutting at marked points.
- Grouping: Can be grouped with other Wyze Light Strips and Wyze Bulbs for unified control.
Specifications:
- Power: 12V adapter, 24W (16.4 ft) / 48W (32.8 ft)
- Indoor use only
The Wyze Light Strip Pro is perfect for users who want multi-color zones and advanced effects for a truly immersive lighting experience.
Alt: Multi-color LED light strip installed behind a sofa creating ambient living room lighting
Smart Control and Automation with Wyze Ecosystem
Both Wyze Light Strip and Light Strip Pro integrate seamlessly with voice assistants and the Wyze app, giving you full control over your indoor lighting environment.
Voice Control & Timer Features:
- Voice Commands: Use Alexa or Google Assistant to turn lights on/off, change colors, or adjust brightness.
- Timers & Automations: Set custom schedules or timers to automate your lighting, perfect for waking up gently or creating a cozy atmosphere at night.
- Vacation Mode: Simulate occupancy by scheduling lights to turn on/off while you’re away.
- Sleep Routines: Gradually brighten or dim lights to mimic sunrise and sunset for better sleep cycles.
Enhance Your Smart Home with Wyze Plug for Lighting Automation
To add even more convenience, pair your LED light strips with the
Wyze Plug - Smart In‑Wall Wi‑Fi Outlet. This smart plug lets you control any standard lamp or lighting fixture via the Wyze app or voice commands, adding flexibility to your indoor lighting setup.
Wyze Plug Highlights:
- Voice Control: Compatible with Alexa, Google Assistant, and IFTTT.
- Scheduling & Timers: Automate your devices to turn on/off at specific times.
- Compact Design: Fits easily into your existing outlets without blocking adjacent sockets.
- Indoor Use: Perfect for lamps, fans, or other home electronics.
- Easy Setup: Connects over 2.4GHz WiFi and works with Android and iOS devices.
Alt: Lifestyle image of smart plug controlling home lighting and appliances via app
Why Choose Wyze Indoor LED Accent Lighting?
"Transform your indoor spaces with smart, customizable LED lighting that listens to your voice and fits your schedule."
- Vibrant Color Options: 16 million colors to match any mood or décor.
- Smart Features: Voice control, music sync, timers, and automations.
- Easy Installation: Peel-and-stick adhesive with trimmable design.
- Energy Efficient: Low wattage with long life expectancy.
- Indoor Safety: Designed specifically for indoor use with reliable connectivity.
Summary of Products Mentioned
- Wyze Light Strip
- Wyze Light Strip Pro
- Wyze Plug - Smart In‑Wall Wi‑Fi Outlet
Elevate your home ambiance with Wyze’s indoor LED accent lighting strips featuring voice control and timer functions. Whether you prefer the classic single-color zones of the Wyze Light Strip or the advanced multi-color segments of the Wyze Light Strip Pro, you’ll enjoy effortless customization and smart automation that fits your lifestyle perfectly. Pair with Wyze smart plugs for even greater control and convenience. Illuminate your world the smart way!
What is the Wyze Light Strip and how does it enhance indoor lighting?
The Wyze Light Strip is a versatile indoor LED accent lighting strip that offers 16 million colors and tunable white light. It enhances indoor spaces by providing customizable lighting for accentuating furniture, backlighting TVs, or adding ambiance to workspaces. With features like music sync, voice control, timers, and easy installation, it brings style and convenience to your home.What are the main differences between Wyze Light Strip and Wyze Light Strip Pro?
The Wyze Light Strip offers vibrant single-color zones and tunable white light, while the Wyze Light Strip Pro features multi-color segment control, allowing up to 16 different colors on the same strip for advanced lighting effects. The Pro version also has a protective epoxy coating and supports grouping with other Wyze lighting products for unified control.How does voice control work with Wyze LED light strips?
Wyze LED light strips are compatible with Alexa and Google Assistant, allowing you to control your lights hands-free. You can use voice commands to turn lights on or off, change colors, adjust brightness, and activate different lighting modes for a seamless smart home experience.Can I automate my Wyze Light Strip with timers and schedules?
Yes, both Wyze Light Strip and Light Strip Pro support timers and automations. You can set custom schedules to turn your lights on or off automatically, create routines for waking up or winding down, and even use vacation mode to simulate occupancy while you’re away.What is the Sun Match feature on Wyze Light Strips?
The Sun Match feature automatically adjusts the color temperature of your Wyze Light Strip throughout the day to match the natural light cycle. This helps you wake up, work, and wind down naturally by mimicking sunrise and sunset lighting indoors.How do I install Wyze Light Strips?
Wyze Light Strips are designed for easy installation with a peel-and-stick adhesive backing and included mounting clips. The strips are trimmable at designated marks, allowing you to customize the length to fit any space perfectly.Are Wyze Light Strips suitable for outdoor use?
No, Wyze Light Strips and Light Strip Pro are designed specifically for indoor use only. Using them outdoors may damage the product and void the warranty.What is the lifespan of Wyze LED Light Strips?
Both Wyze Light Strip and Light Strip Pro have a life expectancy of 25,000 hours, ensuring long-lasting and energy-efficient lighting for your indoor spaces.What lengths are available for Wyze Light Strips?
Wyze Light Strips and Light Strip Pro are available in two lengths: 16.4 feet and 32.8 feet, allowing you to choose the best fit for your room or project.Can I control multiple Wyze Light Strips together?
Yes, with the Wyze Light Strip Pro, you can group multiple strips and Wyze Bulbs together for unified control through the Wyze app, making it easy to manage your smart lighting setup.How does the Wyze Plug enhance indoor lighting automation?
The Wyze Plug is a smart in-wall Wi-Fi outlet that lets you control standard lamps and lighting fixtures via the Wyze app or voice commands. It supports scheduling, timers, and works with Alexa, Google Assistant, and IFTTT, adding flexibility and convenience to your indoor lighting automation.Is the Wyze Plug easy to set up and use?
Yes, the Wyze Plug features a compact design that fits easily into existing outlets without blocking adjacent sockets. It connects over 2.4GHz WiFi and is compatible with both Android and iOS devices for quick and easy setup.What are the energy efficiency benefits of Wyze LED Light Strips?
Wyze LED Light Strips are energy efficient, operating at low wattage (18W or 36W for Light Strip, 24W or 48W for Light Strip Pro) and offering a long lifespan of 25,000 hours, making them a cost-effective and eco-friendly lighting solution for your home.
