Indoor Smart LED Strip with Music Sync & Timer Automation
Indoor Smart LED Strip with Reactive Music and Timer Automation
Transform your indoor spaces with vibrant, customizable lighting that reacts to your music and fits perfectly into your smart home automation. Discover the Wyze Light Strip, the ultimate smart LED strip designed for indoor use, offering brilliant colors, music synchronization, and timer automation to elevate your ambiance effortlessly.
Wyze Light Strip: Brilliant Smart LED Accent Lighting
Stunning Color Range and Customization
The Wyze Light Strip brings your indoor environment to life with 16 million colors to choose from. Whether you want a calming blue glow or a vibrant party atmosphere, this LED strip delivers rich, vivid lighting that can be tailored to your mood or occasion.
  • Available in two lengths: 16.4 feet and 32.8 feet to fit any room size.
  • Cuttable design allows you to customize the strip length precisely.
  • Adhesive backing for easy installation on walls, under cabinets, or behind furniture.
Reactive Music Feature
Bring your music to life with the built-in microphone that enables the light strip to react to your music in real-time. Whether you're hosting a party or enjoying a relaxing playlist, the lights pulse and change colors in sync with your beats, creating an immersive audio-visual experience.
Smart Timer and Automation
Set schedules and timers through the Wyze app to automate your lighting. Wake up gently with a sunrise simulation or turn off the lights automatically when you leave the room. The strip supports seamless integration with your smart home ecosystem via Wi-Fi and Bluetooth (802.11 b/g/n, 2.4 GHz).
Energy Efficient and Long-Lasting
  • Power adapter output: 12 Volts
  • Wattage: 18 watts for 16.4 ft, 36 watts for 32.8 ft
  • Life expectancy: 25,000 hours of vibrant lighting
  • Operating temperature range: -4°F to 122°F (-20°C to 50°C)
What’s in the Box?
  • Wyze Light Strip x1
  • Controller x1
  • Adhesive Clips x10
  • Power Adapter x1
  • Quick Start Guide x1
  • Alcohol Wipes x2
Perfect for indoor use only, the Wyze Light Strip is your go-to solution for smart, reactive lighting that enhances any room.
Wyze Light Strip in Living Room Create vibrant living room lighting with Wyze Light Strip
Enhance Your Smart Home Lighting with Wyze Plug
Smart Control and Automation for Your Devices
Pair your Wyze Light Strip with the Wyze Plug to gain full control over your lighting setup and other devices. The Wyze Plug turns any standard outlet into a smart outlet, allowing you to schedule, automate, and control your lights and appliances remotely.
  • Available in 2-pack and 4-pack options.
  • Supports voice commands via Alexa, Google Assistant, and IFTTT.
  • Operates on 2.4GHz Wi-Fi for reliable connectivity.
  • Compact design fits easily into any outlet without blocking adjacent sockets.
Features for Convenience and Safety
  • Max output: 15A
  • Indoor use only
  • Operating temperature: -4°F to 104°F (-20°C to 40°C)
  • ETL certified for safety and reliability
  • 1-year warranty included
Use the Wyze Plug to automate your Wyze Light Strip’s power, enabling timer automation and energy savings effortlessly. Wyze Plug controlling home devices Smart scheduling and voice control with Wyze Plug
Why Choose Wyze for Your Indoor Smart LED Strip Needs?
  • Seamless App Integration: Control your light strip and plugs from a single app, making automation and customization simple.
  • Reactive Music Sync: Unique built-in microphone technology lets your lights dance to your favorite tunes.
  • Flexible Installation: Cuttable strips with adhesive backing fit perfectly in any indoor space.
  • Energy Efficient: Low wattage with long life expectancy ensures bright lighting without high energy costs.
  • Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice and automation control.
Elevate your indoor ambiance with smart LED lighting that listens, adapts, and automates — all at an affordable price.
Summary of Relevant Products
  • Wyze Light Strip: Indoor smart LED strip with 16 million colors, music reactive feature, timer automation, and easy installation.
  • Wyze Plug: Smart plug for indoor use to automate and control your Wyze Light Strip and other devices with voice and app control.
FeatureWyze Light StripWyze Plug
TypeConnected Home - LED Accent LightingConnected Home - Smart Outlet
Variants16.4 Feet ($19.99, Sold Out), 32.8 Feet ($35.99, Sold Out)2 Pack ($24.98, Sold Out), 4 Pack ($39.98, Sold Out)
DescriptionColor your world with brilliant LED accent lightingMake your normal devices smart; control any outlet remotely
Key Features- 16 million colors- Remote on/off control
- Music Mode with built-in microphone- Scheduling and automation
- Sun Match (syncs with natural light)- Voice control (Alexa, Google)
- Voice control (Alexa, Google Assistant)- Vacation Mode (random on/off)
- Vacation Mode- No hub required
- Sleep Routines- Group control of multiple plugs
- Timers & Automations
ConnectivityWiFi 2.4 GHz, BluetoothWiFi 2.4 GHz
Power SourceCorded ElectricStandard electrical outlet
Indoor/Outdoor UseIndoor onlyIndoor only
WarrantyNot specified30-day hassle-free returns
App ControlWyze appWyze app
Voice Assistant SupportAlexa, Google AssistantAlexa, Google Assistant
Price Range$19.99 - $35.99$24.98 - $39.98
What is the Wyze Light Strip and how does it enhance indoor lighting?The Wyze Light Strip is a smart LED strip designed for indoor use, offering 16 million customizable colors, music synchronization, and timer automation. It enhances your indoor ambiance by providing vibrant, reactive lighting that can be tailored to any mood or occasion.
How does the music reactive feature work on the Wyze Light Strip?The Wyze Light Strip features a built-in microphone that allows the lights to react in real-time to your music. The strip pulses and changes colors in sync with your beats, creating an immersive audio-visual experience for parties or relaxation.
Can I control the Wyze Light Strip with my smartphone?Yes, you can control the Wyze Light Strip using the Wyze app. The app allows you to customize colors, set schedules, automate lighting, and integrate the strip with your smart home ecosystem via Wi-Fi and Bluetooth.
Is the Wyze Light Strip compatible with voice assistants?Yes, the Wyze Light Strip is compatible with popular voice assistants such as Alexa and Google Assistant, as well as IFTTT, allowing for convenient voice and automation control.
What lengths are available for the Wyze Light Strip and can it be customized?The Wyze Light Strip is available in two lengths: 16.4 feet and 32.8 feet. It features a cuttable design, allowing you to customize the strip length to fit your specific indoor space.
How do I install the Wyze Light Strip?The Wyze Light Strip comes with adhesive backing and adhesive clips for easy installation on walls, under cabinets, or behind furniture. Simply peel and stick the strip to your desired surface and use the included clips for extra support.
What is included in the Wyze Light Strip package?The Wyze Light Strip package includes: 1 Wyze Light Strip, 1 controller, 10 adhesive clips, 1 power adapter, 1 quick start guide, and 2 alcohol wipes for surface preparation.
Is the Wyze Light Strip energy efficient and long-lasting?Yes, the Wyze Light Strip is energy efficient, with a power adapter output of 12 volts and wattage of 18 watts (16.4 ft) or 36 watts (32.8 ft). It has a life expectancy of 25,000 hours, providing long-lasting, vibrant lighting.
Can the Wyze Light Strip be used outdoors?No, the Wyze Light Strip is designed for indoor use only. Using it outdoors may damage the product and void the warranty.
What is the Wyze Plug and how does it work with the Wyze Light Strip?The Wyze Plug is a smart plug that turns any standard outlet into a smart outlet. It allows you to schedule, automate, and control your Wyze Light Strip and other devices remotely via the Wyze app or voice assistants.
Does the Wyze Plug support voice control?Yes, the Wyze Plug supports voice commands through Alexa, Google Assistant, and IFTTT, making it easy to control your devices hands-free.
Is the Wyze Plug safe and reliable for indoor use?Yes, the Wyze Plug is ETL certified for safety and reliability, supports a maximum output of 15A, and comes with a 1-year warranty. It is designed for indoor use only.
What are the main benefits of choosing Wyze for smart indoor LED lighting?Wyze offers seamless app integration, music reactive lighting, flexible installation, energy efficiency, and compatibility with major smart home platforms, all at an affordable price.
Can you tell me more about the customization options for the Wyze Light Strip?How does the reactive music feature work with the Wyze Light Strip?Do you have any ongoing sales or promotions for the Wyze Light Strip?
