Gun Safe with Multiple Unlock Options & Bluetooth Connectivity
Gun Safe with Multiple Unlock Options and Bluetooth Connectivity
When it comes to securing your firearms and valuables, having a gun safe that offers versatile unlocking methods and smart connectivity is essential. The Wyze Gun Safe stands out as a top choice, combining rugged physical security with modern Bluetooth technology and multiple access options. Alongside, the Wyze Lock Bolt complements your home security with a smart deadbolt lock featuring ultra-fast fingerprint access and Bluetooth control.
Wyze Gun Safe: Smart Access Meets Rugged Security
Four Convenient Unlock Methods
The Wyze Gun Safe offers unparalleled flexibility with four distinct ways to unlock your safe, ensuring quick and secure access whenever you need it:
  • Ultra-fast biometric fingerprint scanner that unlocks in just 0.8 seconds.
  • Backlit traditional keypad combo for easy code entry, even in the dark.
  • Secure Bluetooth unlock via the Wyze app, allowing remote control and monitoring.
  • Physical key as a reliable backup.
This multi-option access system ensures you can choose the method that best fits your situation, whether you prefer biometric security or app-based convenience.
Certified Rugged Construction
Built with a 12-gauge steel frame, the Wyze Gun Safe is third-party certified to meet California DOJ impact and tool-attack standards. Its design includes:
  • Interior-mounted hinges to prevent prying.
  • Beefed-up internal metal plating to resist latch or motor manipulation.
  • Anti-impact latch for drop resistance.
  • Reinforced anti-pry construction for maximum durability.
Spacious and Compact Design
With 195 cubic inches of interior space (10.6" x 6.2" x 2.95"), this safe can hold one or two handguns, or other valuables like passports, jewelry, and collectibles. Its compact size allows it to fit discreetly in nightstands, desk drawers, or shelves, and it comes with prefabricated bolt holes for mounting.
Wyze App Integration
The Wyze app enhances your control and security by providing:
  • Bluetooth-only, password-protected safe unlocking.
  • Personalized access with unique codes and fingerprint profiles.
  • Real-time tracking of who accessed the safe and when.
  • Battery life monitoring to avoid unexpected lockouts.
"Old school tough meets 21st century tech" perfectly describes the Wyze Gun Safe, blending traditional physical security with smart home convenience.
Wyze Gun Safe Lifestyle
Wyze Lock Bolt: Bluetooth Smart Lock with Fingerprint Access
Ultra-Fast Fingerprint and Keypad Access
The Wyze Lock Bolt replaces your existing deadbolt with a smart lock that offers:
  • Ultra-fast fingerprint sensor for instant unlocking.
  • Backlit keypad with anti-peep technology to enter codes securely.
  • Auto-lock function that locks the door automatically if you forget.
  • Emergency one-time codes for guest access.
Robust Bluetooth Connectivity
Equipped with Bluetooth 5.0, the lock communicates securely with the Wyze app within a 16-foot range, allowing you to lock or unlock your door remotely and monitor lock history.
Durable and Weather-Resistant
Designed for both indoor and outdoor use, the lock features:
  • IPX5 weather resistance to withstand rain and dust.
  • Operating temperature range from -13°F to 122°F for keypad use.
  • Built-in alarm for jam detection to alert you of tampering.
Easy Installation and Stylish Design
The Wyze Lock Bolt fits standard door thicknesses (1-3/8" to 1-3/4") and backsets (2-3/8" or 2-3/4"). Available in Matte Black and Satin Nickel finishes, it blends seamlessly with your home’s exterior. Wyze Lock Bolt Lifestyle
Enhance Your Home Security with Wyze Smart Cameras
While the Wyze Gun Safe and Lock Bolt secure your firearms and entry points, complement your setup with Wyze’s smart cameras for comprehensive home monitoring.
Wyze Cam v4: Crystal-Clear Security with Bluetooth Setup
  • 2.5K QHD resolution with enhanced color night vision.
  • Motion-activated spotlight and 99 dB siren for deterrence.
  • Bluetooth-enabled easy setup and integration with Alexa and Google Assistant.
  • 24/7 local recording with microSD card support.
  • IP65 weather resistance for indoor/outdoor use.
Wyze Cam v4 Outdoor Bundle
Includes the Wyze Cam v4, outdoor power adapter, and 128GB microSD card for continuous recording and reliable outdoor surveillance.
Together, these devices create a smart, connected home security ecosystem that keeps your valuables safe and your home monitored.
Wyze Cam v4 Outdoor Lifestyle
Why Choose Wyze for Your Gun Safe and Smart Lock Needs?
  • Multiple unlock options for convenience and security.
  • Bluetooth connectivity for smart control and monitoring.
  • Certified rugged construction to protect against physical attacks.
  • Compact and stylish designs that fit seamlessly into your home.
  • Integration with Wyze app for personalized access and real-time alerts.
  • Affordable pricing without compromising on quality or features.
Secure your firearms and home with the Wyze Gun Safe and Wyze Lock Bolt — the perfect combination of traditional security and modern smart technology.
Product Tags Summary
FeatureWyze Gun SafeWyze Lock Bolt
Product TypeConnected HomeConnected Home
Price$154.99 (Sold out)$79.98 (New), $59.98 (Refurbished)
Unlock Methods1. Biometric fingerprint (0.8 sec)1. Fingerprint sensor (ultra-fast)
2. Backlit traditional keypad2. Backlit keypad with anti-peep tech
3. Bluetooth unlock via Wyze app3. Bluetooth unlock via Wyze app
4. Physical key4. Physical key (replaces deadbolt)
Construction12-gauge steel, certified to CA DOJ specsSolid metal exterior, pick-proof
Security FeaturesAnti-pry, anti-impact latch, internal hingesHardware encryption, two-factor auth
Size / Capacity195 cubic inches (10.6 x 6.2 x 2.95 in)Fits standard exterior doors
Intended UseSecure storage for firearms and valuablesSmart deadbolt replacement for doors
MountingPrefabricated bolt holes for mountingReplaces existing deadbolt, installs in ~20 min
App FeaturesUnlock history, battery status, user combos/fingerprintsLock/unlock history, access codes, fingerprints, emergency codes
Battery LifeNot specifiedUp to 12 months (4x AA batteries)
Weather ResistanceNot specifiedIPX5 weatherproof
Auto-lock FeatureNoYes
Additional FeaturesSmall enough for nightstand or drawerAnti-peep keypad, one-touch lock, emergency one-time codes
Setup TimeUnder 5 minutes via Wyze appAbout 20 minutes installation
What unlock methods does the Wyze Gun Safe offer?The Wyze Gun Safe provides four convenient unlock options: an ultra-fast biometric fingerprint scanner, a backlit traditional keypad combo, secure Bluetooth unlock via the Wyze app, and a physical key as a backup. This ensures flexible and secure access to your firearms and valuables.
Is the Wyze Gun Safe secure and certified?Yes, the Wyze Gun Safe is built with a 12-gauge steel frame and is third-party certified to meet California DOJ impact and tool-attack standards. It features interior-mounted hinges, reinforced anti-pry construction, beefed-up internal metal plating, and an anti-impact latch for maximum security.
How much can the Wyze Gun Safe hold and where can I install it?The Wyze Gun Safe offers 195 cubic inches of interior space (10.6" x 6.2" x 2.95"), suitable for one or two handguns or valuables like passports and jewelry. Its compact design fits discreetly in nightstands, desk drawers, or shelves, and it includes prefabricated bolt holes for secure mounting.
How does the Wyze app enhance the Wyze Gun Safe experience?The Wyze app allows Bluetooth-only, password-protected unlocking, personalized access with unique codes and fingerprint profiles, real-time tracking of safe access, and battery life monitoring to prevent unexpected lockouts.
What features does the Wyze Lock Bolt smart lock offer?The Wyze Lock Bolt features an ultra-fast fingerprint sensor, a backlit keypad with anti-peep technology, auto-lock functionality, emergency one-time codes for guest access, and robust Bluetooth 5.0 connectivity for secure app control and lock history monitoring.
Is the Wyze Lock Bolt suitable for outdoor use?Yes, the Wyze Lock Bolt is designed for both indoor and outdoor use. It has IPX5 weather resistance, operates in temperatures from -13°F to 122°F, and includes a built-in alarm for jam detection and tamper alerts.
How easy is it to install the Wyze Lock Bolt?The Wyze Lock Bolt is easy to install and fits standard door thicknesses (1-3/8" to 1-3/4") and backsets (2-3/8" or 2-3/4"). It is available in Matte Black and Satin Nickel finishes to match your home’s style.
What are the benefits of integrating Wyze smart cameras with the Wyze Gun Safe and Lock Bolt?Integrating Wyze smart cameras, such as the Wyze Cam v4, with your Wyze Gun Safe and Lock Bolt provides comprehensive home security. Features include 2.5K QHD resolution, color night vision, motion-activated spotlight, 99 dB siren, Bluetooth-enabled setup, and 24/7 local recording for both indoor and outdoor monitoring.
Why should I choose Wyze for my gun safe and smart lock needs?Wyze offers multiple unlock options, Bluetooth connectivity, certified rugged construction, compact and stylish designs, seamless Wyze app integration, and affordable pricing without compromising on quality or features, making it a top choice for home and firearm security.
What are the different unlock methods available for the Wyze Gun Safe?Can you tell me more about the Bluetooth connectivity features of the Wyze Gun Safe?Do you have any deals, ongoing sales, discounts, or promotions?
