Improve Your Wyze Cam Setup with the 20ft USB Extension Cable
If you’re looking to enhance your Wyze Cam’s vantage point and gain more flexibility in camera placement, the
Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This extended USB cable allows you to position your Wyze Cam farther from power outlets, giving you the freedom to capture wider angles and better coverage without being limited by short cables.
Why Choose the Wyze Cam USB Extension Cable - 20ft?
- Extended Reach: Say goodbye to cramped camera setups. The 20-foot length lets you place your Wyze Cam in optimal locations, whether indoors or outdoors.
- Wide Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
- Easy to Use: Simply plug the extension cable between your camera and power source—no complicated installation required.
- Affordable Solution: At just $7.99, it’s a cost-effective way to improve your home security setup.
Extend your camera’s reach and improve your home monitoring with this simple yet powerful accessory.
Elevate Your Security with Wyze Cam v4
The
Wyze Cam v4 is a state-of-the-art smart camera designed for both indoor and outdoor use, offering crystal-clear 2.5K QHD video resolution and advanced night vision capabilities.
Key Features of Wyze Cam v4
- High-Resolution Video: Capture every detail with 2560x1440 QHD clarity.
- Color Night Vision: See in full color even in low light, thanks to 4 IR LEDs and 2 white spotlight LEDs.
- Weather Resistant: Rated IP65, perfect for outdoor placement.
- Multiple Mounting Options: Wall, ceiling, magnetic mounts, or stand for versatile installation.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
- Two-Way Audio & Siren: Communicate through the camera and deter intruders with a built-in siren.
- Flexible Power Options: Comes with a 6-foot USB cable, but can be extended with the 20ft USB extension cable for better placement.
Using the 20ft USB extension cable with the Wyze Cam v4 means you can position your camera exactly where you need it—high up on a wall, tucked under eaves, or in hard-to-reach corners—without worrying about power outlet proximity.
Alt text: Wyze Cam v4 mounted outdoors on a porch for enhanced home security
Power Your Wyze Cam Smarter with Lamp Socket v2 Bundles
For those wanting to eliminate the need for nearby power outlets altogether, Wyze offers innovative
Lamp Socket v2 Bundles that power your Wyze Cam directly from existing outdoor light fixtures.
Cam v4 + Lamp Socket v2 Bundle
- No Outlet Needed: Powers your Wyze Cam v4 using your outdoor lamp socket.
- Smart Lighting Integration: Control your outdoor lights via the Wyze app, turning them on/off or setting schedules.
- Motion-Activated Lighting: Lights can automatically illuminate when your Wyze Cam detects motion, enhancing security.
- Easy Installation: Just screw the lamp socket in like a lightbulb—no wiring or electrician needed.
- Compatible with Multiple Wyze Cams: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
Pan v3 + Lamp Socket v2 Bundle
- Offers the same smart power and lighting features as the Cam v4 bundle.
- Available in white or black to match your outdoor decor.
- Perfect for users with Wyze Cam Pan v3 who want hassle-free power and smart lighting.
These bundles transform your outdoor lighting into a smart security system, powered and controlled effortlessly.
Alt text: Outdoor porch light with Wyze Cam powered by lamp socket for smart lighting and security
Summary: Maximize Your Wyze Cam’s Potential
By combining the
Wyze Cam USB Extension Cable - 20ft with the
Wyze Cam v4 or the
Lamp Socket v2 Bundles, you unlock new possibilities for camera placement and power solutions. Whether you want to extend your camera’s reach with a long USB cable or power it smartly through your outdoor light fixture, these accessories help you create a more effective and flexible home security system.
Product Highlights
Wyze Cam v4
Enhance your Wyze Cam experience today with these essential accessories and bundles for improved vantage points, smarter power options, and ultimate home security flexibility.
What is the Wyze Cam USB Extension Cable - 20ft and how does it improve my camera setup?
The Wyze Cam USB Extension Cable - 20ft is a long USB cable designed to extend the reach of your Wyze Cam, allowing you to place your camera farther from power outlets. This gives you more flexibility in camera placement, enabling you to capture wider angles and improve your home security coverage.Which Wyze Cam models are compatible with the 20ft USB Extension Cable?
The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2, Pan v3, OG Standard, and OG Telephoto models.Is the Wyze Cam USB Extension Cable easy to install?
Yes, the Wyze Cam USB Extension Cable is very easy to use. Simply plug the extension cable between your Wyze Cam and the power source—no complicated installation or tools required.How much does the Wyze Cam USB Extension Cable - 20ft cost?
The Wyze Cam USB Extension Cable - 20ft is affordably priced at just $7.99, making it a cost-effective way to enhance your home security setup.What are the key features of the Wyze Cam v4?
The Wyze Cam v4 offers 2.5K QHD video resolution (2560x1440), color night vision with 4 IR LEDs and 2 white spotlight LEDs, IP65 weather resistance for outdoor use, multiple mounting options, smart integrations with Alexa, Google Assistant, and IFTTT, two-way audio, a built-in siren, and flexible power options.Can I use the 20ft USB extension cable with the Wyze Cam v4?
Yes, the 20ft USB extension cable is fully compatible with the Wyze Cam v4, allowing you to position your camera in hard-to-reach or optimal locations without worrying about the distance to a power outlet.What is the Wyze Lamp Socket v2 Bundle and how does it work?
The Wyze Lamp Socket v2 Bundle allows you to power your Wyze Cam directly from an existing outdoor light fixture, eliminating the need for a nearby power outlet. It also enables smart lighting control through the Wyze app, including motion-activated lighting and scheduling.Which Wyze Cam models are compatible with the Lamp Socket v2 Bundle?
The Lamp Socket v2 Bundle is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.How do I install the Wyze Lamp Socket v2 Bundle?
Installation is simple—just screw the lamp socket into your existing outdoor light fixture like a regular lightbulb. No wiring or electrician is needed.What are the benefits of using the Cam v4 + Lamp Socket v2 Bundle?
The Cam v4 + Lamp Socket v2 Bundle powers your Wyze Cam v4 directly from your outdoor lamp socket, offers smart lighting integration and control via the Wyze app, and provides motion-activated lighting for enhanced security.Is the Pan v3 + Lamp Socket v2 Bundle available in different colors?
Yes, the Pan v3 + Lamp Socket v2 Bundle is available in both white and black to match your outdoor decor.How can I maximize my Wyze Cam’s potential with these accessories?
By using the Wyze Cam USB Extension Cable - 20ft and the Lamp Socket v2 Bundles, you can extend your camera’s reach, enjoy flexible placement options, and power your camera smartly through outdoor light fixtures, creating a more effective and versatile home security system.
