Best Class 10 MicroSD Cards for Wyze Camera Night Vision
Ideal Class 10 Solution for Capturing Wyze Camera Night Vision Footage with Wyze MicroSD Card
When it comes to capturing high-quality night vision footage from your Wyze cameras, pairing the right camera with a reliable Class 10 microSD card is essential. Wyze offers a range of cameras equipped with advanced night vision capabilities, and their official Wyze MicroSD Cards provide seamless local storage solutions to unlock continuous recording and timelapse features. This guide highlights the best Wyze products optimized for night vision recording and the ideal microSD cards to ensure your footage is stored securely and efficiently.
Wyze MicroSD Card: The Perfect Storage Companion
Wyze MicroSD Cards are designed specifically to complement Wyze cameras, offering local storage options that unlock continuous recording and timelapse functionalities. Available in 32GB, 128GB, and 256GB sizes, these cards are Class 10 rated, ensuring fast write speeds necessary for smooth video capture, especially during night vision recording.
Key Features:
  • Local Recording: Store footage directly on the card without relying solely on cloud subscriptions.
  • Timeline Controls & Calendar View: Easily navigate through recorded footage.
  • Continuous Local Recording: Capture 24/7 video without interruption.
  • Timelapse Support: Create time-lapse videos effortlessly.
Choosing a Wyze MicroSD Card guarantees compatibility and reliability, making it the ideal choice for capturing detailed night vision footage from your Wyze cameras.
Wyze Cam v4: Advanced Night Vision with 2.5K QHD Resolution
The Wyze Cam v4 stands out as a top choice for night vision security, featuring enhanced color night vision and a motion-activated spotlight to illuminate dark areas. Its CMOS Starlight Sensor and 4 IR LEDs combined with 2 white spotlight LEDs deliver crisp, clear footage even in complete darkness.
Specifications:
  • Video Resolution: 2.5K QHD (2560x1440) for crystal-clear images.
  • Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens) with color night vision.
  • Field of View: Wide 115.8° diagonal, 98.5° horizontal, and 53.1° vertical.
  • Local Storage: Supports microSD cards up to 512GB.
  • Connectivity: Wi-Fi 6 support for faster, more reliable streaming.
  • Audio: 99dB waterproof speaker with two-way talk and built-in siren.
  • Mounting Options: Stand, wall, ceiling, or magnetic adhesive mounts.
  • Weather Resistance: IP65 rating for outdoor durability.
  • Operating Temperature: -4°F to 122°F (-20°C to 50°C).
This camera is perfect for users who want detailed night vision footage stored locally on a Class 10 microSD card, ensuring no moment is missed.
Available Variants:
  • Single Wyze Cam v4 in multiple colors.
  • Wyze Cam v4 + FREE 32GB MicroSD Card bundle for immediate local recording.
  • Wyze Cam v4 Outdoor Bundle including the camera, outdoor power adapter, and 128GB Wyze MicroSD Card.
The Outdoor Bundle is especially ideal for those seeking a complete setup for capturing night vision footage with reliable local storage.
Wyze Bulb Cam installed in outdoor light fixture Wyze Bulb Cam providing security and lighting in outdoor settings
Wyze Bulb Cam: 2-in-1 Outdoor Security and Smart Lighting
For those looking to combine security with smart lighting, the Wyze Bulb Cam offers a unique solution. This device functions as both a 2K HD security camera and a smart LED light bulb, featuring color night vision and motion-activated lighting.
Highlights:
  • Video Resolution: 2K (2304 x 1296) with color night vision.
  • Field of View: Ultra-wide 160° for broad coverage.
  • Night Vision: 4 IR LEDs (850 nm) plus color night vision.
  • Local Storage: Supports up to 256GB microSD cards in exFAT format.
  • Lighting: Up to 800 lumens brightness with 3000K color temperature.
  • Controls: Manual, motion-activated, ambient light, scheduling, and Wyze Automations.
  • Audio: Built-in digital microphone and two-way audio.
  • Weather Resistance: IP65 rated for outdoor use.
  • Power: Standard E26 socket, 120V AC.
This camera is perfect for outdoor areas like porches, garages, or backyards where lighting and security are both priorities. The ability to store footage locally on a Class 10 microSD card ensures your night vision videos are saved without subscription fees. Wyze Bulb Cam monitoring garage at night Wyze Bulb Cam capturing motion detection footage in a garage at night
Why Choose Wyze for Night Vision and Local Storage?
Wyze cameras combined with Wyze MicroSD Cards provide a seamless, cost-effective solution for capturing and storing high-quality night vision footage. Whether you need indoor or outdoor security, the advanced sensors, color night vision, and wide dynamic range ensure clear video in low-light conditions. The local storage options with Class 10 microSD cards guarantee smooth recording without lag or dropped frames.
Summary of Benefits:
  • High-Resolution Night Vision: Capture detailed footage with color and IR LEDs.
  • Reliable Local Storage: Use Wyze MicroSD Cards optimized for continuous recording.
  • Versatile Mounting & Installation: Indoor, outdoor, wired, or wireless setups.
  • Smart Features: Motion detection zones, two-way audio, Alexa/Google Assistant integration.
  • Weatherproof Designs: IP65-rated cameras for all-weather protection.
Conclusion
For capturing Wyze camera night vision footage with an ideal Class 10 microSD card, the Wyze MicroSD Card paired with Wyze Cam v4 or Wyze Bulb Cam offers the best performance and reliability. Whether you choose the standalone camera, a bundle with included microSD card, or the innovative Bulb Cam, you can trust Wyze to deliver clear, continuous night vision recording with easy local storage management.
Product Highlights Recap
  • Wyze MicroSD Card: Local recording, continuous capture, timelapse support.
  • Wyze Cam v4: 2.5K QHD, enhanced color night vision, motion spotlight, Wi-Fi 6.
  • Wyze Cam v4 + FREE 32GB MicroSD Card: Ready-to-use bundle for local storage.
  • Wyze Cam v4 Outdoor Bundle: Includes outdoor power adapter and 128GB microSD card.
  • Wyze Bulb Cam: 2K HD, color night vision, smart LED light, wide field of view.
Choose the right combination to secure your home day and night with Wyze’s trusted technology.
# End of Page
FeatureWyze MicroSD CardWyze Cam v4Wyze Cam v4 + FREE 32GB MicroSD CardWyze Cam v4 Outdoor BundleWyze Bulb Cam
TypeAccessoryCameraCamera + AccessoryCamera BundleCamera
Storage Options32GB, 128GB, 256GB microSDSupports microSD up to 256GB (sold separately)Includes free 32GB microSD cardIncludes 128GB microSD cardSupports microSD up to 256GB (sold separately)
Price$8.99 - $29.99$35.98$35.98$69.99$49.98
ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2K (2304x1296)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionColor Night Vision + IR Night Vision
Local RecordingEnables continuous local recording24/7 local recording with microSD card24/7 local recording with microSD card24/7 local recording with microSD cardSupports local storage (microSD up to 256GB)
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 6Wi-Fi 62.4 GHz Wi-Fi
Motion-Activated SpotlightN/AYesYesYesNo
Weather ResistanceN/AIP65IP65IP65IP65
CompatibilityWyze Cams with microSD slotAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant
Power SourceN/AWiredWiredWiredStandard E26 Socket (120V AC)
Additional FeaturesEnables time lapse and continuous recordingMotion & sound detection, smoke & CO alerts, AI auto-zoomSame as Wyze Cam v4Same as Wyze Cam v4 + Outdoor Power Adapter2-in-1 camera and smart LED bulb, motion-activated light, siren
Included ItemsMicroSD card onlyCamera, power adapter, mounts, cableCamera + free 32GB microSD cardCamera, outdoor power adapter, 128GB microSD cardBulb Cam only
What is the best microSD card for capturing Wyze camera night vision footage?The Wyze MicroSD Card is the ideal choice for capturing night vision footage with Wyze cameras. It is Class 10 rated for fast write speeds and is available in 32GB, 128GB, and 256GB sizes, ensuring smooth, continuous recording and timelapse support.
Why should I use a Wyze MicroSD Card with my Wyze camera?Wyze MicroSD Cards are specifically designed for Wyze cameras, guaranteeing compatibility and reliability. They enable local storage, continuous 24/7 recording, timelapse features, and easy navigation through recorded footage without relying solely on cloud subscriptions.
Which Wyze camera is best for night vision recording?The Wyze Cam v4 is a top choice for night vision recording, featuring 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, and support for microSD cards up to 512GB. It delivers clear footage even in complete darkness.
Does the Wyze Cam v4 support local storage for night vision footage?Yes, the Wyze Cam v4 supports local storage with microSD cards up to 512GB, allowing you to capture and store high-quality night vision footage directly on the device.
What are the benefits of using a Class 10 microSD card with Wyze cameras?A Class 10 microSD card ensures fast write speeds, which are essential for smooth video capture, especially during continuous and night vision recording. This prevents lag, dropped frames, and ensures reliable storage of your security footage.
What is the Wyze Bulb Cam and how does it enhance outdoor security?The Wyze Bulb Cam is a 2-in-1 device that combines a 2K HD security camera with a smart LED light bulb. It features color night vision, motion-activated lighting, and supports up to 256GB microSD cards for local storage, making it perfect for outdoor areas like porches and garages.
Can I use Wyze cameras outdoors for night vision recording?Yes, both the Wyze Cam v4 and Wyze Bulb Cam are IP65 rated for weather resistance, making them suitable for outdoor use. They provide advanced night vision capabilities and reliable local storage options.
What are the available Wyze Cam v4 bundles for night vision and local storage?Wyze offers several Cam v4 bundles, including a single camera in multiple colors, a bundle with a FREE 32GB MicroSD Card, and an Outdoor Bundle that includes the camera, outdoor power adapter, and a 128GB Wyze MicroSD Card for immediate local recording.
How does local storage with Wyze MicroSD Cards work?Local storage with Wyze MicroSD Cards allows you to record and save footage directly on the card inserted into your Wyze camera. This enables continuous recording, timelapse creation, and easy access to your video history without monthly subscription fees.
What are the key features of Wyze cameras for night vision security?Wyze cameras offer high-resolution night vision with color and IR LEDs, reliable local storage with Class 10 microSD cards, versatile mounting options, smart features like motion detection and two-way audio, and weatherproof designs for indoor and outdoor use.
What are the different sizes available for the Wyze MicroSD Card?Can the Wyze MicroSD Card be used with other brands of cameras?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze MicroSD Card?
