Best Wyze MicroSD Card for Nighttime Security Footage
Best Memory Card for Nighttime Security Footage with Wyze Cameras
When it comes to capturing clear and reliable nighttime security footage with Wyze cameras, choosing the right memory card is essential. Wyze offers a dedicated Wyze MicroSD Card designed specifically to unlock continuous local recording and advanced features for Wyze Cams. Paired with the latest Wyze Cam v4, this combination ensures you never miss a moment, day or night.
Wyze MicroSD Card: The Perfect Storage Solution for Wyze Cameras
Reliable Continuous Recording and Playback
The Wyze MicroSD Card is engineered to support 24/7 local recording on Wyze cameras, including the Wyze Cam v4. This means your camera can continuously save footage directly to the card without relying on cloud subscriptions or internet connectivity.
  • Available in 32GB, 128GB, and 256GB sizes to fit your storage needs.
  • Supports time lapse and continuous recording modes.
  • No monthly fees or subscriptions required.
  • Easy access to footage via the Wyze app or by removing the card for computer playback.
Optimized for Nighttime Security
Wyze MicroSD Cards are built to handle the high write speeds and durability needed for security footage, especially during nighttime when cameras use enhanced night vision modes that generate more data.
  • Compatible with all Wyze cameras that have a microSD slot.
  • Supports up to 256GB for extended recording without interruption.
  • Ensures smooth, lag-free video capture even in low-light conditions.
Wyze Cam v4: Advanced Nighttime Security Camera
Crystal-Clear 2.5K QHD Resolution with Enhanced Color Night Vision
The Wyze Cam v4 is the clearest Wyze camera yet, offering 2.5K Quad HD resolution that captures stunning detail both day and night. Its Enhanced Color Night Vision technology uses advanced hardware to reveal vibrant colors in low-light environments, making nighttime footage more informative and visually rich.
"It's like giving your camera superhero vision!"
Motion-Activated Spotlight and Siren for Added Security
  • Integrated motion-activated spotlight brightens dark areas instantly.
  • Built-in 99 dB siren deters intruders effectively.
  • Enhanced two-way talk with crystal-clear audio for real-time communication.
Robust Local Storage and Connectivity
  • Supports microSD cards up to 256GB for continuous local recording.
  • Compatible with the Wyze MicroSD Card for seamless integration.
  • Features Wi-Fi 6 support for faster, more reliable connections.
  • Works with Alexa and Google Assistant for smart home integration.
Weather-Resistant and Easy to Mount
  • Rated IP65 weather-resistant, suitable for indoor and outdoor use.
  • Screw-free magnetic mount for quick and flexible installation.
Wyze Cam v4 + FREE 32GB MicroSD Card Bundle
For those looking for an all-in-one solution, the Wyze Cam v4 + FREE 32GB MicroSD Card bundle offers unbeatable value. This package includes the latest Wyze Cam v4 with all its advanced features plus a 32GB Wyze MicroSD Card pre-installed, so you can start recording immediately.
  • Perfect for users who want hassle-free setup.
  • Ensures you have enough storage for several days of continuous recording.
  • Ideal for capturing detailed nighttime footage with enhanced color night vision.
Why Choose Wyze MicroSD Cards for Nighttime Security?
Using the official Wyze MicroSD Card with your Wyze cameras guarantees compatibility and optimal performance. Unlike generic cards, Wyze’s memory cards are tested to handle the specific demands of continuous video recording, especially in challenging nighttime conditions.
  • No risk of corrupted files or dropped frames.
  • Designed to work flawlessly with Wyze’s advanced camera features.
  • Backed by Wyze’s 30-day hassle-free return policy.
Summary: The Ultimate Nighttime Security Setup
ProductKey FeaturesPrice Range
Wyze MicroSD CardContinuous recording, up to 256GB, no fees$8.99 - $29.99
Wyze Cam v42.5K QHD, Enhanced Color Night Vision, IP65$35.98
Wyze Cam v4 + 32GB CardBundle with free microSD card, ready to record$35.98
Together, these products provide a powerful, reliable, and cost-effective solution for capturing high-quality nighttime security footage with your Wyze cameras.
Wyze Cam v4 Night Security Wyze Cam v4 capturing vibrant nighttime footage with enhanced color night vision. Home Security Setup Secure your home day and night with Wyze Cam v4 and Wyze MicroSD Card. Wyze MicroSD Card Closeup Wyze MicroSD Card ensures continuous local recording for Wyze cameras.
Enhance your home security today with the best memory card and camera combo designed specifically for Wyze devices. Capture every detail, even in the darkest hours, with Wyze MicroSD Cards and Wyze Cam v4.
FeatureWyze MicroSD CardWyze Cam v4Wyze Cam v4 + FREE 32GB MicroSD Card
TypeAccessory (Memory Card)CameraCamera + Accessory (32GB MicroSD Card)
Storage Capacity Options32GB, 128GB, 256GBSupports microSD up to 256GBIncludes 32GB microSD card
Price$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$35.98 (single camera)$35.98 (single camera with free 32GB card)
ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Continuous Local RecordingYes (with Wyze Cam)Yes, supports 24/7 local recording to microSDYes, supports 24/7 local recording to microSD
Motion-Activated SpotlightN/AYesYes
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 6
CompatibilityWyze Cams with microSD slotAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Weather ResistanceN/AIP65 ratedIP65 rated
Motion & Sound DetectionN/AYesYes
Motion Detection ZonesN/AYesYes
Smoke & CO AlertsN/AYesYes
Power SourceN/AWiredWired
Subscription RequiredNoNoNo
Included ItemsmicroSD Card onlyWyze Cam v4, power adapter, mounts, cable, guideWyze Cam v4, 32GB microSD Card, power adapter, mounts, cable, guide
WarrantyNot specified1 Year1 Year
What is the best memory card for nighttime security footage with Wyze cameras?The best memory card for nighttime security footage with Wyze cameras is the official Wyze MicroSD Card. It is specifically designed for continuous local recording and optimized to handle the high data demands of enhanced night vision modes, ensuring reliable and clear footage even in low-light conditions.
What sizes are available for the Wyze MicroSD Card?The Wyze MicroSD Card is available in 32GB, 128GB, and 256GB sizes, allowing you to choose the storage capacity that best fits your security needs.
Is the Wyze MicroSD Card compatible with all Wyze cameras?Yes, the Wyze MicroSD Card is compatible with all Wyze cameras that have a microSD slot, including the latest Wyze Cam v4.
Does the Wyze MicroSD Card support continuous recording and time lapse?Yes, the Wyze MicroSD Card supports both continuous recording and time lapse modes, enabling you to capture every moment or create time-lapse videos as needed.
Do I need a subscription to use local recording with Wyze MicroSD Cards?No, you do not need a subscription or pay any monthly fees to use local recording with Wyze MicroSD Cards. All footage is stored directly on the card for easy access.
How do I access footage stored on the Wyze MicroSD Card?You can access footage stored on the Wyze MicroSD Card through the Wyze app or by removing the card from the camera and playing it back on your computer.
What makes the Wyze MicroSD Card ideal for nighttime security?The Wyze MicroSD Card is engineered for high write speeds and durability, making it ideal for recording high-quality nighttime security footage, especially when using enhanced night vision features that generate more data.
What are the key features of the Wyze Cam v4 for nighttime security?The Wyze Cam v4 features 2.5K Quad HD resolution, Enhanced Color Night Vision for vibrant low-light footage, a motion-activated spotlight, a 99 dB siren, two-way talk, Wi-Fi 6 support, and IP65 weather resistance for both indoor and outdoor use.
Does the Wyze Cam v4 support microSD cards up to 256GB?Yes, the Wyze Cam v4 supports microSD cards up to 256GB, allowing for extended periods of continuous local recording.
Is there a bundle available with the Wyze Cam v4 and a microSD card?Yes, Wyze offers a bundle that includes the Wyze Cam v4 and a FREE 32GB Wyze MicroSD Card, providing an all-in-one solution for immediate setup and recording.
Why should I choose the official Wyze MicroSD Card over generic memory cards?The official Wyze MicroSD Card is tested for compatibility and optimal performance with Wyze cameras, reducing the risk of corrupted files or dropped frames and ensuring smooth operation, especially during continuous and nighttime recording.
Is the Wyze MicroSD Card covered by a warranty or return policy?Yes, the Wyze MicroSD Card is backed by Wyze’s 30-day hassle-free return policy, giving you peace of mind with your purchase.
Can I use the Wyze Cam v4 outdoors?Yes, the Wyze Cam v4 is rated IP65 weather-resistant, making it suitable for both indoor and outdoor security applications.
How easy is it to install the Wyze Cam v4?The Wyze Cam v4 features a screw-free magnetic mount, allowing for quick and flexible installation in various locations around your home or property.
What are the different storage sizes available for the Wyze MicroSD Card?How does the Wyze MicroSD Card ensure reliable continuous recording?Is there a warranty for the Wyze MicroSD Card?
