Wyze High Speed MicroSD Cards for Full HD Video Recording
High Speed Memory Cards for Full HD Video Recording on Wyze Devices
When it comes to recording Full HD video on your Wyze devices, having a reliable, high-speed memory card is essential. Wyze offers a dedicated Wyze MicroSD Card designed specifically to unlock continuous recording and time lapse features on Wyze Cams. Paired with the advanced Wyze Cam v4, which supports 2.5K QHD resolution and 24/7 local recording, this combination ensures you never miss a moment with crystal-clear video quality.
Wyze MicroSD Card: The Perfect Storage Solution for Wyze Cameras
Reliable Continuous Recording and Time Lapse Support
The Wyze MicroSD Card is engineered to provide seamless local storage for your Wyze cameras, enabling continuous video recording without interruptions. Whether you want to capture every second of activity or create stunning time lapse videos, this memory card supports it all with no monthly fees or subscriptions.
Multiple Storage Capacities to Fit Your Needs
Choose from three storage sizes to match your recording demands:
  • 32GB microSDHC Card – Ideal for basic continuous recording and time lapse.
  • 128GB microSDXC Card – Perfect for extended recording sessions and more footage.
  • 256GB microSDXC Card – Best for heavy users who want maximum storage capacity.
Easy Setup and Playback
Simply insert the Wyze MicroSD Card into your compatible Wyze Cam, configure your recording settings in the Wyze app, and start capturing. Playback is accessible directly through the app or by removing the card to view files on your computer.
Unlock powerful camera features like timeline controls, calendar view, and motion-triggered recording with this dedicated memory card.
Wyze Cam v4 + FREE 32GB MicroSD Card: Ultimate Video Quality and Storage
Wyze Cam v4 mounted outdoors
Crystal-Clear 2.5K QHD Resolution with Enhanced Color Night Vision
The Wyze Cam v4 is the clearest Wyze camera ever made, capturing video in stunning 2.5K Quad HD resolution. Its enhanced color night vision lets you see vibrant details even in low-light conditions, surpassing traditional night vision capabilities.
24/7 Local Recording with Included 32GB MicroSD Card
This bundle includes a free 32GB Wyze MicroSD Card, enabling continuous local recording right out of the box. Record all day and night without worrying about cloud subscription fees.
Advanced Features for Smart Home Security
  • Wi-Fi 6 Support for stronger, more reliable connections.
  • Motion and Sound Detection with customizable detection zones.
  • Smoke & CO Alarm Alerts that trigger instant video recording.
  • Compatibility with Alexa and Google Assistant for voice control.
The Wyze Cam v4 paired with the Wyze MicroSD Card is a powerful duo for anyone looking to capture high-quality Full HD video with reliable local storage.
Why Choose Wyze Memory Cards for Your Wyze Devices?
  • Optimized Compatibility: Designed specifically for Wyze cameras to ensure smooth, uninterrupted recording.
  • No Extra Fees: Local storage means no monthly subscription costs.
  • Flexible Storage Options: From 32GB to 256GB, choose the size that fits your security needs.
  • Easy to Use: Simple installation and playback through the Wyze app or computer.
Enhance Your Wyze Setup with Accessories
While the Wyze MicroSD Card and Wyze Cam v4 are the core essentials for high-quality video recording, consider complementing your setup with accessories like the Wyze Cam Floodlight Plug-In Mount or Wyze Lamp Socket for versatile mounting and power options. Wyze Cam Floodlight lifestyle
Summary
For recording Full HD video on Wyze devices, the Wyze MicroSD Card is the ideal high-speed memory card that unlocks continuous recording and time lapse features. When combined with the Wyze Cam v4 + FREE 32GB MicroSD Card bundle, you get unmatched video clarity, enhanced night vision, and reliable local storage—all designed to keep your home safe and monitored with ease.
FeatureWyze MicroSD CardWyze Cam v4 + FREE 32GB MicroSD Card
Product TypeAccessory (MicroSD Card)Camera Bundle (Wyze Cam v4 + 32GB MicroSD Card)
Storage Options32GB microSDHC, 128GB microSDXC, 256GB microSDXCIncludes 32GB MicroSD Card
Price$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$35.98
ResolutionN/A2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night Vision
RecordingEnables continuous local recording and timelapse on Wyze Cams24/7 local recording with included 32GB MicroSD Card
Wi-Fi SupportN/AWi-Fi 6
CompatibilityCompatible with Wyze Cams with microSD slotWyze Cam v4 compatible with Alexa, Google Assistant
FeaturesContinuous recording, timelapse, no subscription feesMotion-activated spotlight, motion & sound detection, smoke & CO alerts
Local Storage CapacityUp to 256GB (depending on variant)32GB included, supports up to 512GB microSD card
Return Policy30-day hassle-free returns30-day hassle-free returns
Additional NotesUsed to unlock advanced camera featuresWired camera, requires microSD card for local recording
What is the best memory card for continuous recording on Wyze cameras?The Wyze MicroSD Card is specifically designed for Wyze cameras, providing reliable, high-speed local storage for continuous recording and time lapse features without interruptions.
Which Wyze MicroSD Card size should I choose for my camera?Wyze offers three MicroSD Card sizes: 32GB for basic continuous recording and time lapse, 128GB for extended recording sessions, and 256GB for maximum storage capacity and heavy usage.
Does the Wyze Cam v4 come with a memory card included?Yes, the Wyze Cam v4 bundle includes a free 32GB Wyze MicroSD Card, allowing you to start continuous local recording right out of the box.
How do I set up and use a Wyze MicroSD Card with my Wyze camera?Simply insert the Wyze MicroSD Card into your compatible Wyze Cam, configure your recording settings in the Wyze app, and start capturing video. You can access playback directly through the app or by removing the card to view files on your computer.
What are the benefits of using a Wyze MicroSD Card over other memory cards?Wyze MicroSD Cards are optimized for Wyze cameras, ensuring smooth, uninterrupted recording. They offer flexible storage options, easy installation, and eliminate the need for monthly subscription fees by providing local storage.
What advanced features does the Wyze Cam v4 offer?The Wyze Cam v4 features 2.5K QHD resolution, enhanced color night vision, Wi-Fi 6 support, motion and sound detection with customizable zones, smoke and CO alarm alerts, and compatibility with Alexa and Google Assistant.
Can I use the Wyze MicroSD Card for time lapse videos?Yes, the Wyze MicroSD Card supports time lapse video creation on compatible Wyze cameras, allowing you to capture stunning time lapse footage without any extra fees.
Are there any monthly fees for using Wyze MicroSD Cards for video storage?No, using a Wyze MicroSD Card for local video storage does not require any monthly subscription fees or additional costs.
How can I enhance my Wyze camera setup?You can enhance your Wyze camera setup with accessories like the Wyze Cam Floodlight Plug-In Mount or Wyze Lamp Socket for versatile mounting and power options.
What are the different storage capacities available for the Wyze MicroSD Card?How do I set up the Wyze MicroSD Card with my Wyze Cam?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze MicroSD Card?
