How to Set Up Wyze Sense Climate Sensors in Your Home
Wyze Sense Climate Sensor is an essential device for monitoring the temperature and humidity levels throughout your home. Designed to work seamlessly with Wyze Sense v2 and Wyze Home Monitoring, this sensor helps you maintain a comfortable and safe environment by providing real-time climate data directly to your Wyze app.
The Wyze Sense Climate Sensor is perfect for placing in any room, basement, attic, or even distant areas of your home thanks to its impressive 500 ft wireless range.
What You Need Before Setup
  • Wyze Sense Climate Sensor (available in 3-pack for multiple rooms)
  • Wyze Sense Hub (required for sensor operation; the sensor will not work standalone or with Wyze Sense v1)
  • Wyze App installed on your smartphone
Step-by-Step Setup Guide
1. Install the Wyze Sense Hub Ensure your Wyze Sense Hub is connected and set up through the Wyze app. This hub acts as the central controller for all Wyze Sense sensors. 2. Power On the Climate Sensor Remove the sensor from its packaging and insert the included battery if necessary. The sensor will power on automatically. 3. Add the Sensor in the Wyze App Open the Wyze app, navigate to the Home Monitoring section, and select “Add Device.” Choose “Wyze Sense Climate Sensor” from the list. 4. Place the Sensor in Your Desired Location The sensor’s sleek, white design blends unobtrusively into any room. You can place it on a flat surface or use the peel-and-stick adhesive backing to mount it on walls. 5. Verify Connection and Calibration Once added, the sensor will start transmitting temperature and humidity data. Check the app to confirm the sensor is reporting accurate readings.
Ideal Placement Tips
  • Place sensors in rooms where temperature and humidity fluctuate, such as living rooms, bedrooms, basements, or attics.
  • Avoid placing sensors near direct heat sources or vents to ensure accurate readings.
  • Use multiple sensors in different rooms to get a comprehensive view of your home's climate.
Cozy living room with smart home devices Monitor your home's environment effortlessly with Wyze Sense Climate Sensors.
Features and Benefits of Wyze Sense Climate Sensor
  • Accurate Temperature & Humidity Tracking: Keep tabs on your home’s climate conditions in real-time.
  • Long Wireless Range: Up to 500 feet range allows placement in distant or hard-to-reach areas.
  • Sleek, Minimalist Design: White, compact sensor fits seamlessly into any home décor.
  • Easy Installation: Place on surfaces or mount with adhesive backing—no tools required.
  • Integration with Wyze App: View data, receive alerts, and manage sensors remotely.
Other Wyze Sense Devices to Complement Your Climate Sensors
While setting up your Wyze Sense Climate Sensors, consider enhancing your home monitoring system with these additional Wyze Sense products:
Wyze Sense Motion Sensor
Detects motion within a 25 ft range and 120° field of view. Ideal for security and automation, it integrates with the Wyze Sense Hub and app to notify you of movement in your home.
Protect your home from water damage by getting instant alerts when leaks are detected. Compatible with Wyze Sense v2 and Home Monitoring, it’s perfect for basements, kitchens, or bathrooms.
Wyze Sense Entry Sensor
Monitors doors and windows to detect when they open or close, enhancing your home security setup.
Wyze Sense Keypad
Allows you to arm or disarm your Wyze Home Monitoring system remotely with ease, featuring an emergency button for quick response.
Wyze Lock Keypad lifestyle Secure your home with Wyze Sense Keypad and other smart devices.
Final Tips for a Smart Climate Monitoring Setup
  • Always ensure your Wyze Sense Hub firmware and Wyze app are up to date for the best performance.
  • Use multiple climate sensors to monitor different zones in your home for a detailed overview.
  • Combine climate sensors with other Wyze Sense devices for a comprehensive smart home security and automation system.
By following these steps and tips, you can easily set up Wyze Sense Climate Sensors to maintain a comfortable and safe environment throughout your home.
FeatureWyze Sense Climate SensorWyze Sense Motion SensorWyze Sense Leak Sensor & ProbeWyze Sense Entry SensorWyze Sense Keypad
PurposeTracks temperature and humidityDetects motionNotifies of leaksDetects open/close statusDisarm home security remotely
Requires Wyze Sense HubYesYesYesYesYes
Compatible WithWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Home Monitoring
Standalone FunctionalityNoNoNoNoNo
RangeUp to 500 ftDetects motion up to 25 ft within 120° FOVUp to 500 ftNot specifiedNot specified
InstallationPlace on surface or peel-and-stick adhesiveAdhesive back or screws for wallsNot specifiedNot specifiedIndoor use, permanent adhesive
DesignSleek, white, unobtrusiveSmall sensor with adhesive backNot specifiedNot specifiedIndoor keypad with emergency button
Size/Pack Options3 Pack1 Pack2 Probes or 3 Sensors + 1 Probe3 PackSingle unit
Price$41.98 (3 Pack)$20.98 (1 Pack)$13.98 (2 Probes), $55.98 (3 Sensors + 1 Probe)$41.98 (3 Pack)$27.98
Additional FeaturesTracks temperature & humidity via appAdjustable sensitivity, pet-friendly modeIndoor use only, operating temp 32-104°FDetects open/close eventsArm/disarm system, emergency button
Indoor/Outdoor UseIndoor onlyIndoor onlyIndoor onlyIndoor onlyIndoor only
What is the Wyze Sense Climate Sensor and how does it work?The Wyze Sense Climate Sensor is a smart device designed to monitor temperature and humidity levels in your home. It works with the Wyze Sense v2 system and Wyze Home Monitoring, providing real-time climate data directly to your Wyze app for easy monitoring and alerts.
What do I need to set up the Wyze Sense Climate Sensor?To set up the Wyze Sense Climate Sensor, you need the sensor itself (available in a 3-pack for multiple rooms), a Wyze Sense Hub (required for operation), and the Wyze app installed on your smartphone. The sensor is not compatible with Wyze Sense v1 and cannot operate standalone.
How do I install and set up the Wyze Sense Climate Sensor?First, ensure your Wyze Sense Hub is connected and set up through the Wyze app. Power on the climate sensor by inserting the included battery. In the Wyze app, go to the Home Monitoring section, select 'Add Device,' and choose 'Wyze Sense Climate Sensor.' Place the sensor in your desired location and verify its connection and calibration in the app.
Where should I place my Wyze Sense Climate Sensors for best results?For optimal performance, place Wyze Sense Climate Sensors in rooms where temperature and humidity fluctuate, such as living rooms, bedrooms, basements, or attics. Avoid placing them near direct heat sources or vents to ensure accurate readings. Using multiple sensors in different rooms provides a comprehensive view of your home's climate.
What is the wireless range of the Wyze Sense Climate Sensor?The Wyze Sense Climate Sensor has an impressive wireless range of up to 500 feet, allowing you to place it in distant or hard-to-reach areas of your home, such as basements or attics.
Can I use the Wyze Sense Climate Sensor without the Wyze Sense Hub?No, the Wyze Sense Climate Sensor requires the Wyze Sense Hub for operation. It is not compatible with Wyze Sense v1 and cannot function as a standalone device.
How do I view and manage climate data from my Wyze Sense Climate Sensors?You can view real-time temperature and humidity data, receive alerts, and manage your sensors remotely through the Wyze app. The app allows you to monitor multiple sensors and get a detailed overview of your home's climate conditions.
What are the main features and benefits of the Wyze Sense Climate Sensor?Key features include accurate temperature and humidity tracking, a long 500 ft wireless range, a sleek and minimalist design, easy installation with adhesive backing, and seamless integration with the Wyze app for remote monitoring and alerts.
What other Wyze Sense devices can I use with my climate sensors?You can enhance your home monitoring system with additional Wyze Sense devices such as the Wyze Sense Motion Sensor, Wyze Sense Leak Sensor & Probe, Wyze Sense Entry Sensor, and Wyze Sense Keypad. These devices integrate with the Wyze Sense Hub and app for comprehensive home security and automation.
How can I ensure the best performance from my Wyze Sense Climate Sensors?To ensure optimal performance, always keep your Wyze Sense Hub firmware and Wyze app up to date. Use multiple climate sensors to monitor different zones in your home, and consider combining them with other Wyze Sense devices for a complete smart home setup.
What are the ideal locations to place the Wyze Sense Climate Sensors in my home?Can I use multiple Wyze Sense Climate Sensors at the same time?How do I verify the connection and calibration of the Wyze Sense Climate Sensor?
