Affordable Home Climate Sensors for Temperature & Humidity
Affordable Climate Sensors for Home Temperature and Humidity Tracking
Keeping track of your home's temperature and humidity is essential for comfort, health, and energy efficiency. If you're looking for an affordable and reliable climate sensor to monitor these conditions, Wyze offers a smart solution designed specifically for home use. Below, we explore the Wyze Sense Climate Sensor and its supporting devices that make home climate monitoring easy and effective.
Wyze Sense Climate Sensor: Precise Indoor Temperature & Humidity Monitoring
Sleek, Compact, and Easy to Place
The Wyze Sense Climate Sensor is designed to blend seamlessly into any room with its sleek, matte white finish and compact size (1.4in x 1.4in x 0.5in). Whether placed on a shelf or mounted on a wall using the included peel-and-stick adhesive, it remains unobtrusive while continuously tracking your home's temperature and humidity.
Long-Range Wireless Connectivity
With a robust 500 ft wireless range using 915MHz RF communication, you can position the sensor in distant rooms, basements, or attics without worrying about connectivity issues. This flexibility ensures comprehensive coverage throughout your home.
Battery Life and Operating Conditions
Powered by a CR2032 battery, the sensor offers an impressive 1.5 years of battery life, minimizing maintenance. It operates reliably within a temperature range of 32°F to 104°F (0°C to 40°C) and humidity levels up to 85% at 86°F (30°C), making it ideal for typical indoor environments.
Integration with Wyze Ecosystem
The sensor works seamlessly with the Wyze Sense v2 system and requires the Wyze Sense Hub to function. Using the Wyze app, you can monitor real-time temperature and humidity data, set alerts, and optimize your home's climate control.
"Track temperature and humidity throughout your home with ease and accuracy."
Cozy living room with smart home devices Enhance your home's comfort with smart climate sensors.
Wyze Sense Hub: The Central Brain for Your Climate Sensors
Connect and Control Multiple Sensors
The Wyze Sense Hub acts as the central controller connecting all Wyze Sense sensors, including the Climate Sensor. It supports up to 100 sensors, allowing you to expand your home monitoring system as needed.
Reliable Communication and Alerts
Equipped with Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication, the hub ensures stable connections and timely alerts. It features a built-in rechargeable battery with 10 hours of backup power, so your monitoring continues even during brief power outages.
Compact and Stylish Design
Measuring 4.5” x 4” x 1”, the hub fits neatly into your home environment with a matte white base and grey speaker top. It is designed for indoor use and operates within the same temperature and humidity ranges as the sensors.
"The essential hub that keeps your home monitoring system connected and responsive."
Why Choose Wyze Climate Sensor for Your Home?
  • Affordable Pricing: Available in a 3-pack for $41.98, making it budget-friendly for whole-home coverage.
  • Easy Installation: Adhesive backing or optional screws for flexible mounting options.
  • Long Battery Life: Up to 1.5 years on a single CR2032 battery.
  • Wide Range: 500 ft wireless range covers large homes and multiple floors.
  • Seamless App Integration: Monitor and receive alerts via the Wyze app for convenient control.
Additional Wyze Home Monitoring Devices (Optional)
While the Wyze Sense Climate Sensor is perfect for temperature and humidity tracking, Wyze also offers other sensors to enhance your home monitoring system:
  • Wyze Sense Leak Sensor & Probe: Detect water leaks early to prevent damage.
  • Wyze Sense Motion Sensor: Monitor movement within your home.
  • Wyze Sense Keypad: Arm and disarm your security system remotely.
These devices also require the Wyze Sense Hub and integrate smoothly into the Wyze ecosystem for comprehensive home monitoring. Smart lock keypad on door Expand your smart home with additional Wyze monitoring devices.
Conclusion
For affordable, reliable, and easy-to-use home temperature and humidity tracking, the Wyze Sense Climate Sensor paired with the Wyze Sense Hub offers an excellent solution. Its long-range wireless connectivity, long battery life, and seamless app integration make it a top choice for homeowners seeking smart climate monitoring without breaking the bank. Start monitoring your home's climate today with Wyze and enjoy a more comfortable, energy-efficient living environment.
FeatureWyze Sense Climate SensorWyze Sense Hub
TypeHome MonitoringHome Monitoring
PurposeTracks temperature and humidityConnects monitoring components and sends alerts
CompatibilityRequires Wyze Sense v2 and Wyze Home MonitoringCore of Wyze Home Monitoring System
Standalone FunctionalityNo, requires Wyze Sense HubYes
RangeUp to 500 ftNot specified
DesignSleek, white, unobtrusiveNot specified
MountingSet on surface or peel-and-stick adhesive backingNot specified
Pack Size3 PackSingle unit
Price$41.98 (3 Pack)$45.98
Use CaseMonitor climate in rooms, basements, atticsCentral hub for sensor connectivity and alerts
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Sense Climate Sensor and how does it work?The Wyze Sense Climate Sensor is a compact, wireless device designed to monitor indoor temperature and humidity in your home. It connects to the Wyze Sense Hub and transmits real-time data to the Wyze app, allowing you to track and manage your home's climate for comfort, health, and energy efficiency.
How do I install the Wyze Sense Climate Sensor in my home?The Wyze Sense Climate Sensor is easy to install. You can place it on a shelf or mount it on a wall using the included peel-and-stick adhesive or optional screws. Its compact size and sleek design allow it to blend seamlessly into any room.
What is the wireless range of the Wyze Sense Climate Sensor?The Wyze Sense Climate Sensor features a robust 500 ft wireless range using 915MHz RF communication. This allows you to position sensors in distant rooms, basements, or attics without worrying about connectivity issues.
How long does the battery last in the Wyze Sense Climate Sensor?The Wyze Sense Climate Sensor is powered by a CR2032 battery, which provides up to 1.5 years of battery life, minimizing the need for frequent replacements.
What are the operating temperature and humidity ranges for the Wyze Sense Climate Sensor?The Wyze Sense Climate Sensor operates reliably within a temperature range of 32°F to 104°F (0°C to 40°C) and can measure humidity levels up to 85% at 86°F (30°C), making it ideal for typical indoor environments.
Do I need the Wyze Sense Hub to use the Wyze Sense Climate Sensor?Yes, the Wyze Sense Climate Sensor requires the Wyze Sense Hub to function. The hub acts as the central controller, connecting all Wyze Sense sensors and enabling app integration and alerts.
How many Wyze Sense Climate Sensors can I connect to one Wyze Sense Hub?The Wyze Sense Hub supports up to 100 sensors, allowing you to expand your home monitoring system with multiple climate sensors and other Wyze devices.
Can I monitor temperature and humidity remotely with the Wyze app?Yes, you can monitor real-time temperature and humidity data from your Wyze Sense Climate Sensors using the Wyze app. The app also allows you to set alerts and optimize your home's climate control from anywhere.
What is the price of the Wyze Sense Climate Sensor?The Wyze Sense Climate Sensor is available in a 3-pack for $41.98, making it an affordable option for whole-home temperature and humidity monitoring.
Are there other Wyze sensors I can add to my home monitoring system?Yes, Wyze offers additional sensors such as the Wyze Sense Leak Sensor & Probe for water leak detection, the Wyze Sense Motion Sensor for movement monitoring, and the Wyze Sense Keypad for security system control. All these devices require the Wyze Sense Hub and integrate seamlessly into the Wyze ecosystem.
What happens if there is a power outage? Will my Wyze Sense Hub continue to work?The Wyze Sense Hub features a built-in rechargeable battery that provides up to 10 hours of backup power, ensuring your home monitoring system remains operational during brief power outages.
What features does the Wyze Sense Climate Sensor offer for monitoring indoor conditions?How does the Wyze Sense Hub enhance the functionality of the climate sensor?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Sense Climate Sensor?
