Track Temperature & Humidity with Wyze Cam v4 Smart Home
Tracking Temperature and Humidity with Wyze Smart Home Ecosystem Featuring Wyze Cam v4
When it comes to integrating temperature and humidity tracking into your smart home, Wyze offers a versatile ecosystem centered around the powerful Wyze Cam v4. Whether you want to monitor indoor or outdoor environments, Wyze’s smart cameras combined with their ecosystem provide reliable, high-quality video surveillance with smart features that can complement environmental sensors for a comprehensive smart home experience.
Wyze Cam v4: The Core of Smart Home Monitoring
Crystal-Clear 2.5K QHD Video Quality
The Wyze Cam v4 delivers stunning 2.5K QHD (2560x1440) resolution, ensuring every detail is captured with clarity. This makes it easier to visually monitor your home environment alongside temperature and humidity data from compatible Wyze sensors.
Enhanced Color Night Vision & Motion-Activated Spotlight
Equipped with 4 IR LEDs and 2 white spotlight LEDs, the Wyze Cam v4 offers enhanced color night vision, allowing you to see vivid colors even in low light. The motion-activated spotlight adds an extra layer of security and visibility during nighttime.
Robust Weather Resistance and Versatile Mounting
With an IP65 weather resistance rating, the Wyze Cam v4 is suitable for both indoor and outdoor use, operating reliably in temperatures from -4ºF to 122ºF (-20ºC to 50ºC). Multiple mounting options including stand, wall, ceiling, and magnetic mounts make installation flexible.
Smart Home Integration & Connectivity
Wyze Cam v4 supports Wi-Fi 6 and Bluetooth 5.2, ensuring fast and stable connections. It integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing you to create automated routines that can include temperature or humidity alerts from Wyze sensors.
“Wyze Cam v4 is not just a camera; it’s a smart home hub that enhances your home’s security and environmental awareness.”
Local and Cloud Storage Options
Store your video footage locally on a microSD card (up to 512GB) or opt for cloud storage with a subscription plan, ensuring you never miss important events.
Outdoor lifestyle with Wyze Cam v4 Experience enhanced outdoor security with Wyze Cam v4’s color night vision and spotlight.
Wyze Cam v4 Outdoor Bundle: Perfect for Environmental Monitoring Outside
All-in-One Outdoor Security and Monitoring
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card, making it ideal for continuous outdoor monitoring where temperature and humidity fluctuations are most critical.
24/7 Local Recording & Wi-Fi 6 Support
Continuous local recording ensures you have a complete log of your outdoor environment, while Wi-Fi 6 support guarantees smooth connectivity even in busy networks.
Motion and Sound Detection with Smart Alerts
The bundle supports motion detection zones and sound detection, which can be paired with temperature or humidity sensors to trigger alerts when environmental conditions change unexpectedly.
Compatibility with Alexa and Google Assistant
Control and monitor your outdoor environment hands-free, integrating temperature and humidity data into your smart home routines.
Wyze Cam v4 Home Security Bundle: Comprehensive Indoor and Outdoor Protection
Enhanced 2-Way Audio and Person Detection
This bundle upgrades your home security with improved two-way audio and person detection, allowing you to interact and respond to visitors or intruders while monitoring environmental conditions.
Motion-Activated Spotlight and Wide Dynamic Range
The motion-activated spotlight and wide dynamic range (WDR) technology ensure clear video in all lighting conditions, complementing your temperature and humidity sensors for a safer, smarter home.
Large Storage Capacity and Reliable Performance
Includes a 128GB Class 10 microSD card capable of storing up to 192 hours of HD video, ensuring you have ample footage to review alongside environmental data.
Wyze Cam v4 + FREE 32GB MicroSD Card: Value and Convenience
Ready to Use Out of the Box
This package includes the Wyze Cam v4 with a free 32GB microSD card, perfect for users who want to start monitoring their home environment immediately.
Key Features for Smart Home Integration
  • 2.5K QHD resolution
  • Color night vision
  • Motion-activated spotlight
  • Person detection
  • Smoke and CO alerts
  • Wi-Fi 6 support
These features make it easy to integrate temperature and humidity sensors into your Wyze smart home ecosystem, providing a holistic view of your home’s safety and comfort.
Indoor lifestyle with Wyze Cam v4 Wyze Cam v4 blends seamlessly into your indoor environment, enhancing security and smart home monitoring.
Why Choose Wyze for Temperature and Humidity Tracking?
While Wyze Cam v4 itself does not directly measure temperature or humidity, it acts as a central smart home device that integrates with Wyze’s range of environmental sensors. These sensors can track temperature and humidity levels and send alerts through the Wyze app, which also manages your Wyze Cam v4. This integration allows you to:
  • Receive real-time alerts for temperature or humidity changes
  • Automate camera recording or spotlight activation based on sensor triggers
  • Use voice assistants to check environmental conditions remotely
  • Create custom routines combining security and environmental monitoring
Wyze’s ecosystem is designed to be affordable, reliable, and easy to set up, making it an excellent choice for smart home enthusiasts looking to track temperature and humidity alongside home security.
Summary of Wyze Cam v4 Products for Smart Home Temperature and Humidity Tracking
Product NameKey FeaturesPrice (USD)
Wyze Cam v42.5K QHD, color night vision, IP65, Wi-Fi 6, Alexa/Google integration$100.00
Wyze Cam v4 Outdoor BundleIncludes outdoor power adapter, 128GB microSD, 24/7 recording, Wi-Fi 6$69.99
Wyze Cam v4 Home Security BundleEnhanced audio, person detection, motion spotlight, 128GB microSD included$169.99
Wyze Cam v4 + FREE 32GB MicroSDReady to use, motion detection, smoke/CO alerts, Wi-Fi 6$35.98
By choosing Wyze Cam v4 and its bundles, you can build a smart home ecosystem that not only secures your property but also keeps you informed about your home’s temperature and humidity conditions through seamless integration with Wyze sensors.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 (Regular)Wyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$35.98 (1 Pack)$69.99$100.00$169.99$35.98
Color OptionsBlack, Clear (sold out), Grey, WhiteBlack, Grey, WhiteWhite, GreyNot specifiedBlack, Grey, White
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
SpotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlight
SirenYes (99 dB)YesYesYesYes
AudioEnhanced Two-Way TalkEnhanced Two-Way TalkEnhanced Two-Way TalkImproved 2-way audioEnhanced Two-Way Talk
Weather ResistanceIP65IP65IP65IP65IP65
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Local RecordingmicroSD card up to 512GB (sold separately)Includes 128GB microSD cardmicroSD card up to 512GB (sold separately)Includes 128GB microSD cardmicroSD card up to 512GB (sold separately)
Continuous 24/7 RecordingYesYesYesYesYes
Outdoor UseRequires Outdoor Power Adapter (sold separately)Includes Wyze Outdoor Power AdapterRequires Outdoor Power Adapter (sold separately)Indoor/Outdoor with IP65 ratingRequires Outdoor Power Adapter (sold separately)
Motion & Sound DetectionYesYesYesYesYes
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)115.9° (D) x 98.5° (H) x 53.1° (V)115.8° (D) x 98.5° (H) x 53.1° (V)115.8° (D) x 98.5° (H) x 53.1° (V)Not specified
Digital Zoom8x8x8x8xNot specified
Wide Dynamic Range (WDR)YesYesYesYesYes
Smoke & CO AlertsYesYesYesYesYes
Mounting OptionsStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticNot specified
Warranty1 Year1 Year1 Year1 YearNot specified
Included AccessoriesUSB Power Adapter, Mounting Kit, CableOutdoor Power Adapter, 128GB microSD cardUSB Power Adapter, Mounting Kit, CableUSB Power Adapter, Mounting Kit, CableUSB Power Adapter, Mounting Kit, Cable
Bundle ContentsSingle camera kitCamera + Outdoor Power Adapter + 128GB microSDSingle camera kitHome Security Bundle (multiple cameras likely)Single camera + free 32GB microSD card
Does the Wyze Cam v4 track temperature and humidity directly?No, the Wyze Cam v4 does not directly measure temperature or humidity. However, it integrates seamlessly with Wyze environmental sensors, allowing you to monitor temperature and humidity levels through the Wyze app.
How can I monitor temperature and humidity with Wyze products?You can monitor temperature and humidity by pairing Wyze environmental sensors with your Wyze Cam v4. The sensors track environmental conditions and send real-time alerts to your Wyze app, which also manages your camera.
What are the key features of the Wyze Cam v4 for smart home monitoring?The Wyze Cam v4 offers 2.5K QHD video quality, color night vision, motion-activated spotlight, IP65 weather resistance, Wi-Fi 6 and Bluetooth 5.2 support, and compatibility with Alexa, Google Assistant, and IFTTT for smart home integration.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is IP65 weather resistant and operates reliably in temperatures from -4ºF to 122ºF (-20ºC to 50ºC), making it suitable for both indoor and outdoor environments.
What storage options are available for Wyze Cam v4?Wyze Cam v4 supports local storage via microSD cards up to 512GB and offers cloud storage through a subscription plan, ensuring you never miss important events.
How does Wyze Cam v4 integrate with smart home systems?Wyze Cam v4 integrates with Alexa, Google Assistant, and IFTTT, allowing you to create automated routines, receive voice alerts, and control your devices hands-free, including temperature and humidity monitoring.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card, making it ideal for continuous outdoor monitoring and environmental tracking.
What are the benefits of the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle offers enhanced two-way audio, person detection, a motion-activated spotlight, wide dynamic range, and a 128GB microSD card for comprehensive indoor and outdoor protection.
Can I automate camera actions based on temperature or humidity changes?Yes, you can automate Wyze Cam v4 actions such as recording or spotlight activation based on triggers from Wyze temperature or humidity sensors using the Wyze app and smart home routines.
Is Wyze Cam v4 easy to install and set up?Yes, Wyze Cam v4 offers multiple mounting options including stand, wall, ceiling, and magnetic mounts, and is designed for easy setup and integration into your smart home ecosystem.
What makes Wyze a good choice for smart home temperature and humidity tracking?Wyze offers an affordable, reliable, and easy-to-use ecosystem that integrates security cameras with environmental sensors, providing real-time alerts, automation, and comprehensive monitoring for your home.
What is included with the Wyze Cam v4 + FREE 32GB MicroSD Card package?This package includes the Wyze Cam v4 and a free 32GB microSD card, allowing you to start monitoring your home environment immediately with features like motion detection, smoke and CO alerts, and Wi-Fi 6 support.
How does the Wyze Cam v4 integrate with other Wyze sensors for temperature and humidity tracking?Can I receive alerts on my phone for temperature or humidity changes using the Wyze app?Are there any ongoing promotions or discounts available for the Wyze Cam v4?
