Heavy Rain Protection for Wyze Cam Power on Pergolas
Heavy Rain Protection for Wyze Cam Power Connection on a Backyard Pergola
When installing your Wyze Cam outdoors, especially on a backyard pergola, protecting the power connection from heavy rain is crucial. The Wyze Outdoor Power Adapter is specifically designed to provide a weather-resistant power solution that keeps your camera running safely and reliably through rain, snow, or shine.
Wyze Outdoor Power Adapter: Ultimate Weather-Resistant Power Solution
Designed for Harsh Outdoor Conditions
The Wyze Outdoor Power Adapter is IP67 rated, meaning it is fully dust-tight and can withstand immersion in water up to 1 meter deep for 30 minutes. This makes it ideal for protecting your Wyze Cam’s power connection from heavy rain and other harsh weather conditions on your pergola.
  • Weather Resistance: IP67 rating ensures protection against rain, snow, and dust.
  • Operating Temperature: Works reliably in temperatures from -30°C to 50°C (-22°F to 122°F).
  • Cable Lengths: Includes a 12.5 ft (3.8 m) cable to reach your camera comfortably, plus a 3.9 ft (1.2 m) AC cable and 8.5 ft (2.6 m) DC cable.
  • Compatibility: Supports Wyze Cam v3, v4, Pan v3, Battery Cam Pro (with appropriate adapters).
  • Included Accessories: Comes with wire clips, screws, anchors, and a weatherproof L-shaped Micro-USB adapter to secure and protect your connections.
Why Choose the Wyze Outdoor Power Adapter?
Ready for rain, snow, or shine, this adapter ensures your Wyze Cam stays powered without risk of water damage, making it perfect for outdoor setups like pergolas, patios, or garden areas.
Wyze Cam Pan v3: Perfect Outdoor Camera with Weather-Resistant Power
360° Pan and 180° Tilt with Weatherproof Design
The Wyze Cam Pan v3 is a versatile indoor/outdoor security camera with a matte polycarbonate body and IP65 weather resistance. For outdoor use, pairing it with the Wyze Outdoor Power Adapter guarantees a fully protected power connection.
  • Video Quality: 1080p HD resolution with 120° field of view.
  • Pan & Tilt: 360° horizontal and 180° vertical rotation for full coverage.
  • Night Vision: 4 IR LEDs for clear night monitoring.
  • Audio: Built-in speaker and microphone with 2-way audio and noise cancellation.
  • Connectivity: 2.4 GHz Wi-Fi support.
  • Operating Temperature: -20°C to 50°C (-4°F to 122°F).
  • Power: Requires the Wyze Outdoor Power Adapter for safe outdoor use.
Ideal for Backyard Pergolas
Mounted on a pergola, the Pan v3 combined with the Outdoor Power Adapter offers reliable surveillance with a weatherproof power connection, ensuring your camera stays operational even during heavy rain. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 with weather-resistant power adapter in outdoor conditions
Bundles Featuring Wyze Outdoor Power Adapter
Pan v3 Security Bundle
This bundle includes two Wyze Cam Pan v3 cameras, power adapters, mounting kits, and 32GB microSD cards, providing a comprehensive outdoor security solution. The included Outdoor Power Adapters ensure your cameras remain protected from rain and moisture.
  • Complete Setup: Cameras, power adapters, mounts, and storage.
  • Weatherproof: Cameras are IP65 rated; power adapters are IP67 rated.
  • Easy Installation: Mount on pergolas, walls, or poles with included hardware.
For nature lovers, this bundle combines the Wyze Bird Feeder with a Wyze Cam v4 and the Outdoor Power Adapter. The adapter ensures the camera’s power connection is safe from rain, perfect for mounting on pergolas or garden structures.
  • Weather-Resistant: Camera and power adapter built for outdoor use.
  • Versatile Mounting: Options include walls, trees, poles, or pergolas.
  • Birdwatching Made Easy: Capture every feathered visitor with clear video.
Additional Outdoor Power Solutions: Wyze Plug Outdoor
While the Wyze Outdoor Power Adapter is designed specifically for Wyze cameras, the Wyze Plug Outdoor offers smart control for other outdoor devices like garden lights or inflatables. It features an IP64 weather rating and supports voice commands via Alexa.
  • Weather Rating: IP64 for rain protection.
  • Smart Control: Schedule and monitor outdoor devices via app.
  • Connectivity: 2.4 GHz Wi-Fi and Bluetooth V4.2.
Summary: Protect Your Wyze Cam Power Connection Outdoors
For heavy rain protection on your backyard pergola, the Wyze Outdoor Power Adapter is the best choice to keep your Wyze Cam powered safely. Its IP67 rating, long cables, and included weatherproof adapters ensure your camera’s power connection is shielded from the elements. Pair it with the Wyze Cam Pan v3 or other compatible Wyze cameras for a reliable, weatherproof outdoor security setup. Outdoor lifestyle with Wyze Cam Pan v3 Secure your outdoor space with weather-resistant Wyze Cam and power adapter
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Pan v3 Security Bundle
TypeAccessoryCameraCamera Bundle
Weather ResistanceIP67IP65IP65
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Indoor/outdoor, 360° pan, 180° tilt cameraIncludes 2x Wyze Cam Pan v3
Power Adapter RequiredYes (for outdoor use of compatible cameras)Requires Wyze Outdoor Power Adapter for outdoor useIncluded (2 power adapters)
Price$14.99 - $19.99 (depending on variant)$39.98 (1 pack)$82.99
DimensionsNot specified124mm (H) x 60mm (W) x 63mm (D)Same as Wyze Cam Pan v3 (x2)
WeightNot specified11.29 oz (320 g)Same as Wyze Cam Pan v3 (x2)
Video ResolutionN/A1920 x 1080 (1080p)Same as Wyze Cam Pan v3 (x2)
Pan & Tilt RangeN/A360° horizontal, 180° verticalSame as Wyze Cam Pan v3 (x2)
Night VisionN/AColor Night Vision, 4 IR LEDs (850 nm)Same as Wyze Cam Pan v3 (x2)
AudioN/ABuilt-in speaker and microphone, 2-way audioSame as Wyze Cam Pan v3 (x2)
ConnectivityN/A802.11 b/g/n, 2.4GHz Wi-FiSame as Wyze Cam Pan v3 (x2)
Storage SupportN/AUp to 256 GB microSD (ExFAT)Same as Wyze Cam Pan v3 (x2)
Included ItemsOutdoor Power Adapter and adapters depending on variant1x Wyze Cam Pan v3, 1x 6' micro USB Cable, 1x Power Adapter, 1x Mounting Kit, 1x Quick Start Guide2x Wyze Cam Pan v3, 2x 6' micro USB Cable, 2x Power Adapter, 2x Mounting Kit, 2x 32GB MicroSD Cards, Quick Start Guide
Operating TemperatureNot specified-20°C to 50°C (-4°F to 122°F)Same as Wyze Cam Pan v3 (x2)
WarrantyNot specified1-Year1-Year
How do I protect my Wyze Cam power connection from heavy rain on a backyard pergola?To protect your Wyze Cam power connection from heavy rain on a backyard pergola, use the Wyze Outdoor Power Adapter. It is IP67 rated for weather resistance, ensuring your camera stays powered and safe from water damage in rain, snow, or dust.
What is the IP67 rating of the Wyze Outdoor Power Adapter?The IP67 rating means the Wyze Outdoor Power Adapter is fully dust-tight and can withstand immersion in water up to 1 meter deep for 30 minutes. This makes it ideal for protecting your Wyze Cam’s power connection from heavy rain and harsh outdoor conditions.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with appropriate adapters). Always check compatibility before installation.
Can I use the Wyze Cam Pan v3 outdoors on a pergola?Yes, the Wyze Cam Pan v3 is designed for both indoor and outdoor use with an IP65 weather-resistant body. For outdoor installations, especially on a pergola, it should be paired with the Wyze Outdoor Power Adapter to ensure a weatherproof power connection.
What accessories are included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 12.5 ft (3.8 m) cable, a 3.9 ft (1.2 m) AC cable, an 8.5 ft (2.6 m) DC cable, wire clips, screws, anchors, and a weatherproof L-shaped Micro-USB adapter to secure and protect your camera’s power connection.
What is the operating temperature range for the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter operates reliably in temperatures from -30°C to 50°C (-22°F to 122°F), making it suitable for a wide range of outdoor environments.
Are there any bundles that include the Wyze Outdoor Power Adapter?Yes, the Pan v3 Security Bundle and the Bird Feeder Plug-in Cam v4 Bundle both include the Wyze Outdoor Power Adapter, along with cameras, mounting kits, and other accessories for a complete outdoor security or birdwatching setup.
What is the difference between the Wyze Outdoor Power Adapter and Wyze Plug Outdoor?The Wyze Outdoor Power Adapter is specifically designed to provide weather-resistant power to Wyze cameras, with an IP67 rating. The Wyze Plug Outdoor, with an IP64 rating, is intended for smart control of other outdoor devices like garden lights or inflatables and supports voice commands via Alexa.
How long is the cable included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter includes a 12.5 ft (3.8 m) cable, a 3.9 ft (1.2 m) AC cable, and an 8.5 ft (2.6 m) DC cable, providing flexibility for mounting your camera in various outdoor locations.
Why should I use the Wyze Outdoor Power Adapter for my outdoor Wyze Cam setup?Using the Wyze Outdoor Power Adapter ensures your Wyze Cam’s power connection is protected from rain, snow, and dust, thanks to its IP67 weather resistance. This keeps your camera running safely and reliably in outdoor environments like pergolas, patios, or gardens.
What are the specific features of the Wyze Outdoor Power Adapter that make it suitable for outdoor use?Can the Wyze Outdoor Power Adapter be used with other Wyze camera models besides the Pan v3?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
