Easy Install Waterproof Wyze Outdoor Power Adapter for Harsh Weather
Easy Install Waterproof Adapter for Wyze Security Cameras in Harsh Weather
When it comes to securing your home or outdoor spaces with Wyze security cameras, having a reliable power source that withstands harsh weather is essential. The Wyze Outdoor Power Adapter is designed specifically for this purpose, offering an easy-to-install, waterproof solution that keeps your Wyze cameras running rain or shine. Whether you own a Wyze Cam v3 Pro, Pan v3, or Battery Cam Pro, this adapter ensures your devices stay powered and protected outdoors.
Wyze Outdoor Power Adapter: Durable and Weather-Resistant
Built for Harsh Weather Conditions
The Wyze Outdoor Power Adapter boasts an IP67 weather-resistant rating, making it fully capable of withstanding rain, snow, and dust. This means you can confidently install your Wyze cameras outside without worrying about power interruptions caused by the elements.
  • Compatibility: Works with Wyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (requires L-shaped MicroUSB Adapter), and Wyze Battery Cam Pro (requires USB-C adapter).
  • Easy Installation: Simply connect the adapter to your camera and plug it into an outdoor outlet.
  • Safe and Reliable: Designed to protect your camera’s power connection from moisture and debris.
"Ready for rain, snow, or shine." – Wyze Outdoor Power Adapter
Product Variants and Pricing
  • Outdoor Adapter + L-shaped Adapter + USB-C Adapter – $19.99 (Available)
  • L-shaped Micro USB Adapter (Only) – $5.99 (Available)
Note: Adapters will NOT work with the OG Stack Kit.
Wyze Cam Pan v3 in Snowy Outdoor Setting Wyze Cam Pan v3 powered by the Outdoor Power Adapter, ready for harsh weather
Wyze Cam Pan v3: The Perfect Outdoor Companion
360° Pan and 180° Tilt with Weather Resistance
The Wyze Cam Pan v3 is a versatile indoor/outdoor security camera featuring a full 360° horizontal pan and 180° vertical tilt. Its IP65 weather resistance rating means it can handle outdoor environments when paired with the Wyze Outdoor Power Adapter.
  • Video Quality: 1080p HD resolution with H.264 encoding.
  • Night Vision: 4 IR LEDs (850 nm) for clear night monitoring.
  • Audio: Built-in speaker and microphone with two-way audio and noise cancellation.
  • Smart Features: Automatic motion tracking and push notifications.
  • Connectivity: 2.4 GHz Wi-Fi support.
  • Operating Temperature: -20°C to 50°C (-4°F to 122°F).
This camera is ideal for monitoring large outdoor areas, providing comprehensive coverage with smooth pan and tilt functionality.
Bird Feeder Plug-in Cam v4 Bundle: Outdoor Monitoring Made Easy
Integrated Outdoor Power and Birdwatching
For nature lovers, the Bird Feeder Plug-in Cam v4 Bundle combines the Wyze Bird Feeder with the Wyze Cam v4 and the Wyze Outdoor Power Adapter. This bundle offers a seamless way to monitor your feathered visitors while ensuring your camera stays powered outdoors.
  • Weather-Resistant Design: Durable polycarbonate bird feeder and IP67-rated outdoor power adapter.
  • Easy Installation: Multiple mounting options including wall, tree, pole, cord, and suction cup.
  • Camera Compatibility: Supports Wyze Battery Cam Pro, Cam v3/v4, and Cam Outdoor v1/v2.
  • Macro Lens Adapter: Included for clear close-up views of birds.
  • Live Streaming & Notifications: View and record bird activity via the Wyze app.
This bundle is perfect for anyone wanting to combine outdoor security with wildlife observation.
Why Choose Wyze Outdoor Power Adapter for Your Cameras?
  • Seamless Integration: Designed specifically for Wyze cameras, ensuring compatibility and optimal performance.
  • Weatherproof: IP67 rating protects against water and dust ingress.
  • Versatile Use: Supports multiple Wyze camera models with appropriate adapters.
  • Hassle-Free Installation: Plug-and-play design for quick setup.
  • Reliable Power Supply: Keeps your cameras running continuously in all weather conditions.
Summary
For anyone looking to secure their outdoor spaces with Wyze cameras, the Wyze Outdoor Power Adapter is an essential accessory. Its robust weatherproof design and easy installation make it the perfect companion for Wyze Cam Pan v3, Cam v3 Pro, and Battery Cam Pro models. Additionally, the Bird Feeder Plug-in Cam v4 Bundle offers a unique way to combine outdoor security with birdwatching, powered reliably by the same outdoor adapter. Invest in the Wyze Outdoor Power Adapter today to ensure your Wyze cameras stay powered and protected, no matter the weather. Wyze Cam v4 Monitoring Indoors Wyze Cam v4 delivering clear, reliable monitoring indoors and outdoors
Product Tags Recap
  • Wyze Outdoor Power Adapter:
  • Wyze Cam Pan v3:
  • Bird Feeder Plug-in Cam v4 Bundle:
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Bird Feeder Plug-in Cam v4 Bundle
TypeAccessoryCameraBundle (Bird Feeder + Cam v4 + Outdoor Power Adapter)
Weather ResistanceIP67IP65Weather-resistant for all seasons
CompatibilityWorks with Cam v3/v3 Pro, Cam Pan v3, Cam v4, OG series, Battery Cam Pro (with adapters)Indoor/outdoor camera, requires Outdoor Power Adapter for outdoor useCompatible with Battery Cam Pro, Cam v3, Cam v4, Cam Outdoor v1 & v2
Power Adapter IncludedYesNo (sold separately)Yes
Camera FeaturesN/A360° pan, 180° tilt, automatic motion tracking, color night vision, two-way audioWyze Cam v4 included: live video, remote birdwatching
Additional Items IncludedVariants may include L-shaped Micro USB and USB-C adapters1x 6' micro USB Cable, Power Adapter, Mounting KitWyze Bird Feeder (blue or brown), Macro Lens Adapter, Outdoor Power Adapter
Mounting OptionsN/AScrew mount (1/4" - 20)Wall, tree, pole, cord, suction cup
Price$5.99 - $19.99 (depending on variant)$39.98 (1 pack) to $114.94 (3 pack)$89.98
Dimensions78.7 mm x 62.5 mm x 29.4 mm (adapter)124 mm (H) x 60 mm (W) x 63 mm (D)Not specified
Weight235 g (adapter)11.29 oz (320 g)Not specified
Video ResolutionN/A1920 x 1080 (1080p)Wyze Cam v4 included (1080p)
StorageN/ASupports up to 256 GB microSDN/A
ConnectivityN/A802.11 b/g/n, 2.4 GHz Wi-FiN/A
Special FeaturesIP67 weather resistance for outdoor powerPrivacy Mode, Pan Scan™, Smoke & CO alerts, Cam Plus supportBird feeder designed to attract birds, easy install
Warranty1-Year1-YearNot specified
What is the Wyze Outdoor Power Adapter and what does it do?The Wyze Outdoor Power Adapter is a weatherproof, easy-to-install power solution designed specifically for Wyze security cameras. It provides a reliable power source for your cameras outdoors, ensuring they remain operational in rain, snow, or harsh weather conditions.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (requires L-shaped MicroUSB Adapter), and Wyze Battery Cam Pro (requires USB-C adapter). Please note that it is not compatible with the OG Stack Kit.
Is the Wyze Outdoor Power Adapter waterproof?Yes, the Wyze Outdoor Power Adapter has an IP67 weather-resistant rating, making it waterproof and capable of withstanding rain, snow, and dust for reliable outdoor use.
How easy is it to install the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is designed for hassle-free installation. Simply connect the adapter to your Wyze camera and plug it into an outdoor outlet. No special tools or technical skills are required.
What are the available product variants and prices for the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is available in two variants: the Outdoor Adapter + L-shaped Adapter + USB-C Adapter for $19.99, and the L-shaped Micro USB Adapter (only) for $5.99.
Can I use the Wyze Outdoor Power Adapter with the Bird Feeder Plug-in Cam v4 Bundle?Yes, the Bird Feeder Plug-in Cam v4 Bundle includes the Wyze Outdoor Power Adapter, making it easy to power your Wyze Cam v4 or compatible models while monitoring birds outdoors.
What makes the Wyze Cam Pan v3 suitable for outdoor use?The Wyze Cam Pan v3 features an IP65 weather resistance rating, 360° pan and 180° tilt, 1080p HD video, night vision, two-way audio, and smart motion tracking. When paired with the Wyze Outdoor Power Adapter, it is ideal for comprehensive outdoor monitoring.
Does the Wyze Outdoor Power Adapter provide continuous power in all weather conditions?Yes, the Wyze Outdoor Power Adapter is designed to deliver a reliable and continuous power supply to your Wyze cameras, ensuring they stay powered and protected in all weather conditions.
What are the benefits of using the Wyze Outdoor Power Adapter for my security cameras?The Wyze Outdoor Power Adapter offers seamless integration with Wyze cameras, weatherproof protection (IP67), support for multiple camera models, easy plug-and-play installation, and a reliable power supply for uninterrupted outdoor security.
Is the Wyze Outdoor Power Adapter safe to use outdoors?Yes, the Wyze Outdoor Power Adapter is specifically designed for outdoor use, protecting your camera’s power connection from moisture and debris to ensure safe and reliable operation.
What are the installation steps for the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with all Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions?
