Efficient Outdoor Power Solutions for Multiple Wyze Devices
Efficient Outdoor Power Arrangement for Multiple Wyze Devices
When managing multiple Wyze devices around your property, having a reliable and weather-resistant power solution is essential. Whether you are powering outdoor cameras, smart plugs, or bundled devices, Wyze offers a range of accessories designed to keep your smart home running smoothly rain or shine. This guide highlights the best Wyze products to create an efficient outdoor power setup tailored for your Wyze ecosystem.
Wyze Outdoor Power Adapter: The Backbone of Outdoor Power
Weather-Resistant and Durable Power Supply
The Wyze Outdoor Power Adapter is specifically engineered for outdoor use, boasting an IP67 weather resistance rating. This means it can withstand rain, snow, and extreme temperatures from -30°C to 50°C (-22°F to 122°F), making it perfect for powering your Wyze cameras and other compatible devices outside your home.
  • Compatibility: Works with Wyze Cam v3, Cam v4, Pan v3, and Battery Cam Pro (requires additional adapters).
  • Cable Lengths: 12.5 ft (3.8 m) total cable length ensures flexible installation options.
  • Power Output: 5V 2A output provides stable power for continuous operation.
  • Included Accessories: Comes with wire clips, screws, anchors, and weatherproof L-shaped Micro-USB adapter for secure and neat installation.
  • Certifications: FCC and UL certified for safety and reliability.
  • Warranty: 1-year limited warranty.
Ready for rain, snow, or shine, the Wyze Outdoor Power Adapter is your go-to solution for powering multiple Wyze cameras outdoors without worry.
Wyze Cam Pan v3 in snowy outdoor setting Reliable outdoor power for Wyze cameras in all weather conditions
Wyze Plug Outdoor: Smart Power Control for Your Outdoor Devices
Smart Outdoor Plug with App Control
The Wyze Plug Outdoor transforms your outdoor electrical outlets into smart, app-controlled power sources. Ideal for garden lights, holiday decorations, or any outdoor electronics, this plug offers convenience and energy monitoring right from your smartphone.
  • Weather Rating: IP64 rated to resist dust and water splashes.
  • Dual Outlets: Two independent outlets allow powering multiple devices simultaneously.
  • Connectivity: Connects via 2.4GHz WiFi and Bluetooth V4.2 with up to 300 feet WiFi range.
  • App Features: Schedule timers, monitor energy usage, and control devices remotely.
  • Voice Control: Compatible with Alexa for hands-free operation.
  • Operating Temperature: Works in temperatures from -20°C to 49°C (-4°F to 120°F).
Power your outdoor space with smart convenience and keep your devices running efficiently with the Wyze Plug Outdoor.
Wyze Cam Pan v3: Versatile Outdoor Camera Powered by Wyze Outdoor Adapter
360° Pan and 180° Tilt for Complete Coverage
The Wyze Cam Pan v3 is a powerful indoor/outdoor security camera designed to cover every angle of your property. When paired with the Wyze Outdoor Power Adapter, it becomes a weatherproof surveillance solution.
  • Weather Resistance: IP65 rating ensures protection against dust and water jets.
  • Field of View: 120° wide-angle lens with 360° horizontal and 180° vertical rotation.
  • Video Quality: Full HD 1080p resolution with night vision via 4 IR LEDs.
  • Audio: Two-way audio with built-in speaker and microphone.
  • Connectivity: 2.4GHz WiFi support.
  • Storage: Supports up to 256GB microSD card for local recording.
  • Operating Temperature: -20°C to 50°C (-4°F to 122°F).
  • Certifications: FCC, IC, UL, TSCA, IP65.
With the Wyze Cam Pan v3 and Outdoor Power Adapter, you get a seamless, weatherproof security system that keeps an eye on your property day and night.
Wyze Plug Outdoor in garden setting Smart outdoor plug controlling garden lights and devices
Creating a Complete Outdoor Power Setup
To efficiently power multiple Wyze devices outdoors, consider combining the Wyze Outdoor Power Adapter with the Wyze Plug Outdoor and compatible Wyze cameras like the Wyze Cam Pan v3. This combination offers:
  • Reliable, weatherproof power delivery for cameras and sensors.
  • Smart control and scheduling for outdoor electronics and lighting.
  • Flexible installation options with long cables and mounting accessories.
  • Energy monitoring and voice control for convenience and efficiency.
Whether securing your home with multiple cameras or automating your outdoor lighting, Wyze’s outdoor power solutions provide the durability and smart features you need.
Summary of Key Products for Outdoor Power
ProductKey FeaturesWeather ResistancePower/Connectivity
Wyze Outdoor Power AdapterIP67 rated, 12.5 ft cable, multiple adaptersIP675V 2A output, Micro USB connector
Wyze Plug OutdoorDual outlets, app control, energy monitoringIP6415A max output, WiFi & Bluetooth
Wyze Cam Pan v3360° pan, 1080p video, two-way audioIP65WiFi 2.4GHz, micro USB powered
By integrating these Wyze products, you can build a robust, efficient outdoor power arrangement that keeps your smart devices running smoothly and securely throughout the year.
FeatureWyze Outdoor Power AdapterWyze Plug OutdoorWyze Cam Pan v3
Product TypeAccessoriesConnected HomeCameras
Weather ResistanceIP67 (waterproof, dustproof)IP64 (weather resistant: rain, dust, dirt, snow)IP65 (weather resistant)
PurposePower adapter for outdoor Wyze camerasOutdoor smart plug for controlling devicesIndoor/outdoor 360° pan & 180° tilt security camera
Compatible DevicesWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Any outdoor device/plugs (e.g., garden lights, inflatables)Standalone camera device
Power Output5V/2000mA15 AMP output with overload protection5V/2000mA (via micro USB)
ConnectivityN/AWi-Fi 802.11 b/g/n 2.4GHz (300 ft range)Wi-Fi 802.11 b/g/n 2.4GHz (5GHz not supported)
ControlN/AApp control, voice commands (Alexa)App control, push notifications, 2-way audio
FeaturesWeatherproof power supply for camerasEnergy monitoring, scheduling, 2 independent outlets360° horizontal pan, 180° vertical tilt, motion tracking, color night vision, 2-way audio
Price$19.99 (Outdoor Adapter + L-shaped + USB-C Adapter)$15.99 (1 Pack), $34.98 (2 Pack)$114.94 (1 Pack), $39.98 (2 Pack), $77.96 (3 Pack)
Dimensions/WeightNot specifiedNot specified124mm x 60mm x 63mm; 11.29 oz (320 g)
Operating TemperatureNot specifiedNot specified-20°C to 50°C (-4°F to 122°F)
WarrantyNot specifiedNot specified1-Year
Additional NotesRequired for outdoor use of certain Wyze camerasSuitable for outdoor use with weather resistanceRequires Outdoor Power Adapter for outdoor use
What is the best way to power multiple Wyze devices outdoors?The most efficient way to power multiple Wyze devices outdoors is by using the Wyze Outdoor Power Adapter, which is weather-resistant and designed for outdoor use. Pairing it with the Wyze Plug Outdoor and compatible Wyze cameras like the Wyze Cam Pan v3 ensures reliable, weatherproof power delivery and smart control for your outdoor devices.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is IP67 rated, making it highly weather-resistant. It can withstand rain, snow, and extreme temperatures from -30°C to 50°C (-22°F to 122°F), ensuring reliable outdoor power for your Wyze devices year-round.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, Cam v4, Pan v3, and Battery Cam Pro (with additional adapters). This makes it a versatile solution for powering various Wyze cameras outdoors.
How long is the cable on the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 12.5 ft (3.8 m) total cable length, providing flexible installation options for your outdoor Wyze devices.
What smart features does the Wyze Plug Outdoor offer?The Wyze Plug Outdoor features dual independent outlets, app control for scheduling and energy monitoring, voice control compatibility with Alexa, and a WiFi range of up to 300 feet. It is also IP64 rated for dust and water resistance.
Can I control my outdoor devices remotely with Wyze Plug Outdoor?Yes, the Wyze Plug Outdoor allows you to control your outdoor devices remotely through the Wyze app. You can schedule timers, monitor energy usage, and operate devices from anywhere using your smartphone.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is IP65 rated for weather resistance, making it suitable for both indoor and outdoor use. When paired with the Wyze Outdoor Power Adapter, it provides a weatherproof surveillance solution with 360° pan and 180° tilt coverage.
What is the operating temperature range for Wyze outdoor products?The Wyze Outdoor Power Adapter operates from -30°C to 50°C (-22°F to 122°F), the Wyze Plug Outdoor from -20°C to 49°C (-4°F to 120°F), and the Wyze Cam Pan v3 from -20°C to 50°C (-4°F to 122°F), ensuring reliable performance in various weather conditions.
Do Wyze outdoor power products come with a warranty?Yes, all the featured Wyze outdoor power products, including the Wyze Outdoor Power Adapter, Wyze Plug Outdoor, and Wyze Cam Pan v3, come with a 1-year limited warranty for added peace of mind.
How can I create a complete outdoor power setup for my Wyze devices?To create a complete outdoor power setup, combine the Wyze Outdoor Power Adapter for reliable power delivery, the Wyze Plug Outdoor for smart control and scheduling, and compatible Wyze cameras like the Cam Pan v3 for comprehensive security coverage. This setup ensures durability, flexibility, and smart features for your outdoor Wyze ecosystem.
Can you tell me more about the compatibility of the Wyze Outdoor Power Adapter with other Wyze devices?What are the installation options available for the Wyze Outdoor Power Adapter?Do you have any deals, ongoing sales, discounts, or promotions for Wyze products?
