HD Outdoor Security Cameras with Solar Panel—No Electrician Needed
HD Outdoor Security Cameras with No Electrician Needed and Solar Panel Options
Looking for a high-definition outdoor security camera that requires no electrician for installation and supports solar panel power? Wyze offers a range of smart, weather-resistant cameras designed for easy setup and reliable outdoor monitoring. Whether you want crystal-clear video, color night vision, or flexible mounting options, these Wyze cameras deliver advanced features with simple plug-in or wireless solutions.
Wyze Cam v4: The Ultimate Plug-In Outdoor Security Camera
Wyze Cam v4 is the clearest and most advanced Wyze camera yet, perfect for outdoor security without complicated wiring or electrician help.
Key Features:
  • 2.5K QHD Resolution: Capture stunningly detailed video with 2560x1440 clarity.
  • Enhanced Color Night Vision: See vibrant colors even in low light, thanks to an upgraded Starlight sensor and Wide Dynamic Range (WDR).
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
  • Easy Setup: Screw-free magnetic mount and Bluetooth® setup mean no power tools or electrician needed.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording without subscription.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
Why Choose Wyze Cam v4?
This camera is designed for hassle-free outdoor security. Its magnetic mount allows quick installation anywhere outside, and the included power adapter plugs into any standard outlet—no electrician required. While it is a wired camera, its simple plug-in design makes it accessible for DIY users.
"Wyze Cam v4 offers superhero vision with its enhanced color night vision and motion-activated spotlight, keeping your home safe day and night."
Wyze Cam v4 Outdoor Lifestyle Wyze Cam v4 installed outdoors for home security
Wyze Cam Pan v3: 360° Pan and Tilt Outdoor Security with Weatherproof Design
For those who want full coverage with a single camera, the Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, making it ideal for monitoring large outdoor areas.
Highlights:
  • Full 360° Pan & 180° Tilt: Covers every angle with smooth, quiet motorized movement.
  • IP65 Weather Resistant: Ready for rain, snow, or shine without additional protection.
  • Automatic Motion Tracking: The camera detects and follows moving objects automatically.
  • Color Night Vision: See clear, colorful images even in the dark.
  • Two-Way Audio: Speak and listen through the camera using the Wyze app.
  • Easy Installation: Magnetic mount and plug-in power adapter (sold separately) for outdoor use.
  • Custom Patrol Routes: Set up to 4 waypoints for automatic camera patrol.
Installation and Power:
While the Pan v3 requires the Wyze Outdoor Power Adapter for safe outdoor use, it still requires no electrician—just plug it into an outdoor outlet. For solar power, pairing with a compatible solar panel setup (not included) can provide continuous power without wiring hassles.
"Wyze Cam Pan v3 is your all-seeing eye outdoors, with weatherproof durability and smart tracking to keep your property secure."
Wyze Cam Pan v3 in Snowy Outdoor Setting Wyze Cam Pan v3 weather-resistant outdoor security camera
Wyze Cam OG: Reliable 1080p Outdoor Security with Built-In Spotlight
If you prefer a straightforward 1080p camera with solid outdoor features, the Wyze Cam OG is a great choice.
Features:
  • 1080p Full HD Video: Clear and smooth video streaming.
  • CMOS Starlight Sensor: Enhanced low-light performance.
  • Built-In 40 Lumen Spotlight: Illuminates dark areas to improve night vision.
  • 90 dB Siren: User-activated alarm for added security.
  • IP65 Weather Resistance: Durable for outdoor environments.
  • Two-Way Audio: Clear communication via built-in mic and speaker.
  • Supports up to 256GB microSD: Local storage for continuous recording.
  • Fast Live Streaming: 50% faster than previous Wyze models.
Power and Installation:
The Wyze Cam OG is a plug-in camera with a 6-foot power cable, making installation simple without the need for an electrician. While it does not come with a solar panel, it can be paired with third-party solar power solutions for off-grid setups.
Wyze Cam v4 Home Security Bundle: Complete Outdoor Protection
For those looking for a comprehensive security solution, the Wyze Cam v4 Home Security Bundle includes multiple cameras and accessories to cover your entire property.
Bundle Benefits:
  • Multiple Wyze Cam v4 Cameras: High-resolution 2.5K QHD video with color night vision.
  • 128GB microSD Card Included: Ample local storage for continuous recording.
  • Motion-Activated Spotlight & Siren: Enhanced deterrence features.
  • IP65 Weatherproof: Suitable for all outdoor conditions.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible placement.
  • Smart Home Compatibility: Works with Alexa and Google Assistant.
This bundle is ideal for users who want plug-and-play outdoor security with no electrician needed and the convenience of multiple cameras.
Summary: Why Choose Wyze for Your Outdoor Security Needs?
  • No Electrician Needed: All Wyze outdoor cameras are designed for easy DIY installation with plug-in power adapters.
  • Weather Resistant: IP65 rating ensures reliable operation in rain, snow, and extreme temperatures.
  • High Definition Video: From 1080p to 2.5K QHD, Wyze cameras provide crystal-clear footage.
  • Color Night Vision: See more details at night with enhanced sensors and spotlights.
  • Smart Features: Motion tracking, two-way audio, sirens, and smart assistant integration.
  • Expandable Storage: Support for microSD cards up to 256GB for local recording without monthly fees.
  • Solar Panel Compatibility: While not included, Wyze cameras can be paired with third-party solar panels for off-grid power solutions.
Protect your home effortlessly with Wyze’s HD outdoor security cameras—no electrician needed, easy setup, and smart features that keep you connected and secure day and night.
Product Images
Wyze Cam v4 Outdoor Lifestyle Wyze Cam v4 installed outdoors for home security Wyze Cam Pan v3 in Snowy Outdoor Setting Wyze Cam Pan v3 weather-resistant outdoor security camera Wyze Cam v4 Color Night Vision Vibrant color night vision with Wyze Cam v4
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam OGWyze Cam v4 Home Security Bundle
Video Resolution2.5K QHD (2560x1440)Not specified (assumed 1080p)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt120°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionEnhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs)Color Night Vision with Starlight Sensor4 IR LEDs (850nm), B&W Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
AudioEnhanced 2-way talk, 99dB siren, noise & echo cancellationTwo-way audioBuilt-in speaker & mic; noise & echo cancellationImproved 2-way audio, siren
Weather ResistanceIP65IP65IP65IP65
Power SourceWired (Indoor adapter included; outdoor adapter sold separately)Wired (Outdoor adapter sold separately)WiredWired
Local StoragemicroSD up to 512GB (sold separately)microSD support (up to 256GB)microSD up to 256GBmicroSD 128GB included
Wi-Fi Support2.4 GHz & Wi-Fi 6Not specified2.4 GHz (802.11 b/g/n)2.4 GHz & Wi-Fi 6
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Special FeaturesMotion-activated spotlight, AI auto-zoom & tracking, smoke & CO alerts, motion detection zones360° pan & 180° tilt, motion tracking, privacy mode, custom detection zones, smoke & CO alertsFaster live streaming, 3x faster notifications, built-in spotlightBundle includes 3 cameras, improved 2-way audio, motion-activated spotlight, smoke & CO alerts
Dimensions2in x 2in x 2 3/8inNot specified1.89in x 1.89in x 1.89in2in x 2in x 2 3/8in
Weight0.49 lb (222 g)Not specified4.1 oz (116 g)0.49 lb (222 g)
Price$35.98 (1 pack)$39.98 (1 pack)$29.98 (1 pack)$169.99 (bundle)
Do Wyze outdoor security cameras require an electrician for installation?No, Wyze outdoor security cameras are designed for easy DIY installation and do not require an electrician. They feature simple plug-in power adapters and magnetic mounts for hassle-free setup.
Are Wyze outdoor security cameras weatherproof?Yes, all Wyze outdoor security cameras have an IP65 weather resistance rating, making them suitable for use in rain, snow, and extreme outdoor conditions.
Can Wyze outdoor cameras be powered by solar panels?Wyze outdoor cameras can be paired with compatible third-party solar panels for off-grid power solutions, although solar panels are not included with the cameras.
What video quality do Wyze outdoor security cameras offer?Wyze outdoor security cameras offer high-definition video, ranging from 1080p Full HD (Wyze Cam OG) to 2.5K QHD (Wyze Cam v4), ensuring clear and detailed footage.
Do Wyze outdoor cameras have color night vision?Yes, Wyze outdoor cameras such as the Cam v4 and Cam Pan v3 feature enhanced color night vision, allowing you to see vibrant, detailed images even in low-light conditions.
Is local video storage available on Wyze outdoor cameras?Yes, Wyze outdoor cameras support local video storage with microSD cards up to 256GB, enabling continuous recording without the need for a subscription.
Can Wyze outdoor cameras integrate with smart home systems?Yes, Wyze outdoor cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration and voice control.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras, a 128GB microSD card for local storage, motion-activated spotlights and sirens, weatherproofing, and various mounting options for comprehensive outdoor protection.
How easy is it to install Wyze outdoor security cameras?Wyze outdoor security cameras are designed for easy installation with screw-free magnetic mounts and plug-in power adapters. No power tools or professional installation are required.
Do Wyze outdoor cameras have two-way audio?Yes, Wyze outdoor cameras such as the Cam Pan v3 and Cam OG feature two-way audio, allowing you to speak and listen through the camera using the Wyze app.
What smart features do Wyze outdoor security cameras offer?Wyze outdoor security cameras offer smart features such as motion tracking, motion-activated spotlights and sirens, two-way audio, custom patrol routes, and fast live streaming.
Can I use Wyze outdoor cameras for continuous 24/7 recording?Yes, Wyze outdoor cameras support continuous 24/7 recording when a microSD card is installed, providing round-the-clock security monitoring.
What are the key features of the Wyze Cam v4?Can the Wyze Cam Pan v3 be used for monitoring large outdoor areas?Do you have any deals, ongoing sales, discounts, or promotions for Wyze cameras?
