20ft Flexible USB Extension Cable for Wyze Cam Bird Feeder Setup
Flexible USB Cable for Wyze Cam Positioning Near Bird Feeders
When setting up your Wyze Cam near a bird feeder, having the right accessories is essential to capture every feathered visitor in perfect detail. A flexible USB extension cable allows you to position your Wyze Cam exactly where you want it—close to the bird feeder—without worrying about limited cable length or inconvenient power sources.
Wyze Cam USB Extension Cable - 20ft: Extend Your Reach with Ease
The Wyze Cam USB Extension Cable - 20ft is the perfect solution for extending your camera’s placement flexibility. Whether you have a Wyze Cam v2, v3, v4, or other compatible models, this cable gives you the freedom to position your camera near your bird feeder without being restricted by short cables.
  • Length: 20 feet of flexible USB extension for versatile placement
  • Compatibility: Works with Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and original Wyze Cam models
  • Convenience: Say goodbye to short cables and awkward setups; easily route the cable around corners, trees, or poles
  • Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your birdwatching setup
Position your Wyze Cam exactly where the birds gather, ensuring crystal-clear footage and live streaming without compromise.
Wyze Bird Feeder and Camera Bundles: The Ultimate Birdwatching Setup
For bird enthusiasts looking for an all-in-one solution, Wyze offers specialized bird feeder bundles that combine the feeder, camera, and power options to make birdwatching effortless and enjoyable.
This bundle includes the Wyze Bird Feeder, Wyze Cam v4, and the Wyze Outdoor Power Adapter—everything you need to start birdwatching right away.
  • Wyze Bird Feeder: Vibrant blue body with an orange top designed to attract a variety of birds
  • Weather-Resistant: Durable polycarbonate construction with IP65 weatherproof rating, suitable for all seasons
  • Easy Installation: Multiple mounting options including wall, tree, pole, cord, and suction cup
  • Camera Compatibility: Wyze Cam v4 included, optimized for clear live video and recording of bird visitors
  • Power: Plug-in power adapter ensures continuous operation without battery worries
This bundle is ideal if you want a reliable, wired setup with a high-quality camera and feeder designed to work seamlessly together.
Bird Feeder Wireless Camera Bundle
For a wire-free experience, the Bird Feeder Wireless Camera Bundle pairs the Wyze Bird Feeder with the Wyze Battery Cam Pro and a Wyze Solar Panel.
  • Wireless Convenience: No cables needed; the battery-powered camera combined with solar charging offers freedom in placement
  • High-Resolution Video: 2.5K (2560 x 1440) video resolution for stunning bird footage
  • Weatherproof: Both the feeder and camera are built to withstand outdoor conditions (IP65 rating)
  • Macro Lens Adapter: Included to ensure sharp close-up views of birds feeding
  • Smart Features: Integrates with Alexa, Google Assistant, and IFTTT for smart home compatibility
  • Mounting: Standard 1/4” - 20 mount included for versatile installation
This bundle is perfect for those who want a clean, wireless setup with advanced camera features and solar power support.
Wyze Bird Feeder Accessory: Enhance Your Birdwatching Experience
If you already own a Wyze Cam and want to add a dedicated bird feeder, the Wyze Bird Feeder accessory is a great choice.
  • Attractive Design: Bright blue or brown color options with an orange top to attract birds
  • Durable & Weather-Resistant: Polycarbonate material with IP65 weatherproof rating
  • Capacity: Holds up to 1 liter of bird seed, enough to keep your feathered friends fed for days
  • Multiple Mounting Options: Includes wall, tree, pole, suction cup, and cord mounts for flexible placement
  • Compatible Cameras: Works with Wyze Cam Outdoor v1/v2, Battery Cam Pro, Cam v3, and Cam v4
  • Macro Lens Adapter Included: Ensures your Wyze Cam captures crisp, close-up footage of birds
FeatureWyze Cam USB Extension Cable - 20ftBird Feeder Plug-in Cam v4 BundleBird Feeder Wireless Camera BundleWyze Bird Feeder
Product TypeAccessoryBundleBundleAccessory
Price$7.99$89.98$139.98 / $154.96$39.99
Includes20ft USB extension cableWyze Bird Feeder, Wyze Cam v4, Wyze Outdoor Power AdapterWyze Bird Feeder, Wyze Battery Cam Pro, Wyze Solar PanelWyze Bird Feeder only
Bird Feeder Color OptionsN/ABlue, BrownBlue, BrownBlue, Brown
Bird Feeder MaterialN/APolycarbonatePolycarbonatePolycarbonate
Bird Feeder DimensionsN/A7.48 in x 10.12 in x 8.58 in7.48 in x 10.12 in x 8.58 in7.48 in x 10.12 in x 8.58 in
Bird Seed CapacityN/A1 Liter1 Liter1 Liter
Weather ResistanceN/AIP65 WeatherproofIP65 WeatherproofIP65 Weatherproof
Operating TemperatureN/A-4°F to 122°F-4°F to 122°F-4°F to 122°F
Compatible CamerasWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Battery Cam Pro, Cam v3/v4, Cam Outdoor v1/v2Wyze Battery Cam ProWyze Cam Outdoor v1/v2, Battery Cam Pro, Cam v3/v4
Camera IncludedNoYes (Wyze Cam v4)Yes (Wyze Battery Cam Pro)No
Camera FeaturesN/AWyze Cam v4 features (2.5K QHD, color night vision, etc.)Battery Cam Pro features (2.5K HDR, wire-free, spotlight)N/A
Power Adapter IncludedN/AWyze Outdoor Power AdapterWyze Solar Panel includedN/A
Macro Lens Adapter IncludedN/AYesYesYes
Mounting OptionsN/AMultiple (wall, tree, pole, cord, suction cup)N/AMultiple (wall, tree, pole, cord, suction cup)
WarrantyNot specifiedNot specified1 year1 year
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returnsNot specified
What is the best way to position my Wyze Cam near a bird feeder?Using a flexible USB extension cable, such as the Wyze Cam USB Extension Cable - 20ft, allows you to position your Wyze Cam exactly where you want it near your bird feeder. This ensures you capture every bird visitor in perfect detail without being limited by short cables or inconvenient power sources.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The Wyze Cam USB Extension Cable - 20ft is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and original Wyze Cam models.
How long is the Wyze Cam USB extension cable and what are its benefits?The Wyze Cam USB extension cable is 20 feet long, providing versatile placement options. It allows you to easily route the cable around corners, trees, or poles, making it convenient to set up your camera exactly where you need it.
What is included in the Wyze Bird Feeder Plug-in Cam v4 Bundle?The Wyze Bird Feeder Plug-in Cam v4 Bundle includes a Wyze Bird Feeder, Wyze Cam v4, and a Wyze Outdoor Power Adapter. This bundle provides everything you need for a reliable, wired birdwatching setup.
Is the Wyze Bird Feeder weatherproof?Yes, the Wyze Bird Feeder is made from durable polycarbonate and has an IP65 weatherproof rating, making it suitable for all seasons and outdoor conditions.
What are the mounting options for the Wyze Bird Feeder?The Wyze Bird Feeder offers multiple mounting options, including wall, tree, pole, cord, and suction cup mounts, allowing for flexible and easy installation.
What is the difference between the Wyze Bird Feeder Plug-in Cam v4 Bundle and the Bird Feeder Wireless Camera Bundle?The Wyze Bird Feeder Plug-in Cam v4 Bundle includes a wired camera setup with continuous power, while the Bird Feeder Wireless Camera Bundle features a battery-powered Wyze Battery Cam Pro and a Wyze Solar Panel for a completely wireless, solar-charged experience.
Does the Bird Feeder Wireless Camera Bundle support smart home integration?Yes, the Bird Feeder Wireless Camera Bundle integrates with Alexa, Google Assistant, and IFTTT, allowing for smart home compatibility and automation.
What video resolution does the Wyze Battery Cam Pro offer in the wireless bundle?The Wyze Battery Cam Pro included in the Bird Feeder Wireless Camera Bundle offers high-resolution 2.5K (2560 x 1440) video for stunning bird footage.
Can I buy the Wyze Bird Feeder as a standalone accessory?Yes, the Wyze Bird Feeder is available as a standalone accessory and is compatible with Wyze Cam Outdoor v1/v2, Battery Cam Pro, Cam v3, and Cam v4.
What is the seed capacity of the Wyze Bird Feeder?The Wyze Bird Feeder can hold up to 1 liter of bird seed, providing enough food to keep your feathered friends fed for days.
Does the Wyze Bird Feeder come with a macro lens adapter?Yes, the Wyze Bird Feeder includes a macro lens adapter to ensure your Wyze Cam captures crisp, close-up footage of birds feeding.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at just $7.99, making it a cost-effective way to enhance your birdwatching camera setup.
