20ft Flexible USB Extension Cable for Wyze Cam Bird Feeder Setup
Flexible USB Cable for Wyze Cam Positioning Near Bird Feeders
When setting up your Wyze Cam near a bird feeder, having the right accessories is crucial for optimal placement and uninterrupted power. A flexible USB extension cable, especially a 20ft length, allows you to position your Wyze Cam exactly where you want it—close to your bird feeder for the best viewing angles—without worrying about limited cable reach. Below, we explore the best Wyze products tailored for birdwatching setups, including the essential 20ft Wyze Cam USB Extension Cable that enhances your camera placement flexibility.
Wyze Cam USB Extension Cable - 20ft: Ultimate Flexibility for Birdwatching
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze cameras, making it perfect for positioning your camera near a bird feeder without being restricted by short cables.
Key Features:
  • Length: 20 feet of flexible USB cable for extended reach.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v3 Pro, v4, Cam Pan v2/v3, OG Standard, and OG Telephoto.
  • Durability: Rated IP67 weatherproof, suitable for outdoor use in various weather conditions.
  • Connector Type: USB Type A Male to Female for easy plug-and-play.
  • Operating Temperature: From -22°F to 122°F, ideal for outdoor environments.
  • Power Output: Supports 5V 2A power delivery ensuring stable camera operation.
This cable is a must-have accessory for anyone wanting to place their Wyze Cam near a bird feeder without worrying about power source proximity.
Wyze Bird Feeder: Designed for the Ultimate Birdwatching Experience
The Wyze Bird Feeder is more than just a feeder—it's a birdwatching hub designed to attract a variety of birds while providing a perfect mounting spot for your Wyze Cam.
Highlights:
  • Weather-Resistant: Built with durable polycarbonate and rated IP65 weatherproof, it withstands rain, sun, and snow.
  • Vibrant Design: Features a bright blue body with an orange top to attract diverse bird species.
  • Multiple Mounting Options: Install on walls, trees, poles, cords, or suction cups for versatile placement.
  • Compatible Cameras: Supports Wyze Cam Outdoor v1/v2, Battery Cam Pro, Cam v3/v4, and more.
  • Macro Lens Adapter Included: Ensures crystal-clear close-up views of your feathered visitors.
  • Capacity: Holds 1 liter of bird seed, enough to keep your visitors coming.
This feeder is perfect for bird lovers who want to combine feeding with live video monitoring.
Bird Feeder Plug-in Cam v4 Bundle: All-in-One Birdwatching Setup
For those who want a ready-to-go solution, the Bird Feeder Plug-in Cam v4 Bundle includes everything you need:
  • Wyze Bird Feeder (Blue or Brown)
  • Wyze Cam v4
  • Wyze Outdoor Power Adapter
Why Choose This Bundle?
  • Plug-in Power: No battery worries with the included outdoor power adapter.
  • High-Quality Video: Wyze Cam v4 offers 2.5K QHD resolution and enhanced color night vision.
  • Easy Installation: Multiple mounting options for the feeder and camera.
  • Weatherproof Setup: Both feeder and camera are designed to withstand outdoor conditions.
  • Live Streaming & Notifications: Use the Wyze app to watch birds live and get alerts.
This bundle is ideal for users who want a seamless, wired setup with extended camera placement options—especially when paired with the 20ft USB extension cable.
Bird Feeder Wireless Camera Bundle: Freedom with Battery Power and Solar Support
If you prefer a wireless setup, the Bird Feeder Wireless Camera Bundle offers:
  • Wyze Battery Cam Pro (Black or White)
  • Wyze Solar Panel
Benefits:
  • Wireless Convenience: No cables needed, perfect for remote or hard-to-reach locations.
  • Solar Panel Support: Minimizes battery recharging for continuous birdwatching.
  • Bird Detection: Smart notifications for every feathered visitor.
  • Macro Lens Adapter: Included for sharp close-ups.
  • Multiple Mounting Options: Flexible installation on trees, poles, or walls.
This bundle is perfect for bird enthusiasts who want a cable-free experience but still desire high-quality video and smart features.
Wyze Cam v4 Outdoor Bundle: Enhanced Security and Birdwatching
The Wyze Cam v4 Outdoor Bundle is a versatile option for those who want a high-performance camera with outdoor durability.
Features:
  • 2.5K QHD Resolution: Crystal-clear video quality.
  • Enhanced Color Night Vision: See birds even in low light.
  • Motion-Activated Spotlight: Illuminates your bird feeder area.
  • Wi-Fi 6 Support: Reliable and fast connectivity.
  • 24/7 Local Recording: Continuous video storage with included 128GB microSD card.
  • Compatibility: Works with Alexa and Google Assistant.
Pair this camera with the Wyze Bird Feeder and the 20ft USB extension cable for a wired, high-quality birdwatching setup.
Power Your Wyze Cam with the Cam v4 + Lamp Socket v2 Bundle
For flexible power options without relying on wall outlets, the Cam v4 + Lamp Socket v2 Bundle lets you power your Wyze Cam through an existing lamp socket.
Advantages:
  • No Outlet Needed: Powers Wyze Cam v4 and other compatible models via E26 lamp sockets.
  • Motion-Activated Lights: Adds security lighting to your setup.
  • Dusk to Dawn Scheduling: Automate lighting based on time.
  • Compact and Easy to Install: Fits standard lamp sockets.
This is a smart solution for positioning your Wyze Cam near a bird feeder where power outlets are scarce.
Conclusion: Perfect Setup for Birdwatching with Wyze
To position your Wyze Cam near a bird feeder effectively, the Wyze Cam USB Extension Cable - 20ft is an essential accessory that provides the flexibility you need. Combine it with the Wyze Bird Feeder and either the Plug-in Cam v4 Bundle or the Wireless Camera Bundle depending on your power preferences. For enhanced power options, consider the Lamp Socket v2 Bundle. With these products, you can enjoy crystal-clear live streams, easy installation, and reliable power solutions to capture every feathered visitor at your bird feeder.
Birdwatching with Wyze Cam Experience birdwatching on easy mode with Wyze Cam and Bird Feeder. Flexible USB Cable Setup Extend your Wyze Cam placement with the 20ft USB extension cable. Wireless Bird Feeder Camera Wireless Bird Feeder Bundle with Battery Cam Pro and Solar Panel for hassle-free setup.
Product Summary
Wyze Bird Feeder Bird Feeder Plug-in Cam v4 Bundle Bird Feeder Wireless Camera Bundle Wyze Cam USB Extension Cable - 20ft Wyze Cam v4 Outdoor Bundle Cam v4 + Lamp Socket v2 Bundle
Equip your birdwatching setup with these Wyze essentials and enjoy flexible, high-quality monitoring of your feathered friends!
FeatureWyze Cam USB Extension Cable - 20ftBird Feeder Plug-in Cam v4 BundleBird Feeder Wireless Camera BundleWyze Cam v4 Outdoor BundleCam v4 + Lamp Socket v2 BundleWyze Bird Feeder
TypeAccessoryBundleBundleBundleBundleAccessory
Price$7.99$89.98$139.98 - $154.96$69.99$49.96$39.99
Included Items20ft USB extension cableWyze Bird Feeder, Wyze Cam v4, Wyze Outdoor Power AdapterWyze Bird Feeder, Wyze Battery Cam Pro, Wyze Solar PanelWyze Cam v4, Wyze Outdoor Power Adapter, MicroSD Card 128GBWyze Cam v4, Lamp Socket v2Wyze Bird Feeder and mounting accessories
Compatible CamerasWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard/TelephotoWyze Cam v4Wyze Battery Cam ProWyze Cam v4Wyze Cam v3, v3 Pro, v4, OG, Pan v3Wyze Cam Outdoor v1/v2, Battery Cam Pro, Cam v3/v4
Cable Length20 ftN/AN/A6 ft micro USB to USB-AN/AN/A
Camera ResolutionN/A2.5K QHD (Wyze Cam v4)2.5K QHD (Battery Cam Pro)2.5K QHDN/AN/A
Weather ResistanceN/AWyze Bird Feeder: IP65 WeatherproofWyze Bird Feeder: IP65 WeatherproofIP65Not weatherproof, suitable for damp locationsIP65 Weatherproof
Power SourceUSBWired (Wyze Cam v4), Plug-inWire-free (Battery Cam Pro + Solar Panel)WiredPowered via lamp socket (E26)N/A
FeaturesExtends USB cable lengthBird feeder with camera, Macro Lens Adapter, Weather-resistantBird feeder with wireless camera, Macro Lens Adapter, Solar PanelEnhanced Color Night Vision, Motion-activated spotlightMotion-activated lights, Dusk to Dawn schedulingBird feeder with Macro Lens Adapter, multiple mounts
Mounting OptionsN/AWall, tree, pole, cord, suction cupStandard 1/4" - 20 mountStand, wall, ceiling, magnetic mountLamp socket (E26)Multiple mounting options included
Dimensions (Bird Feeder)N/A7.48" x 10.12" x 8.58"7.48" x 10.12" x 8.58"2" x 2" x 2.2" (lamp socket), Cam v4: 2" x 2" x 2 3/8"56.5mm x 56.5mm x 65mm (lamp socket)7.48" x 10.12" x 8.58"
Weight (Bird Feeder)N/A2.5 lb net, 3.42 lb gross2.5 lb net, 3.42 lb gross0.49 lb (Cam v4) + lamp socket 80g80 g (lamp socket)2.5 lb net, 3.42 lb gross
WarrantyNot specified1 year1 year1 year1 year1 year
Special NotesCompatible with multiple Wyze Cam modelsIncludes Wyze Outdoor Power AdapterIncludes Wyze Solar Panel for battery cam setupsWi-Fi 6 support, 24/7 local recordingNot weatherproof, recommended CFL/LED bulbs under 20WIncludes mounting hardware and accessories
What is the Wyze Cam USB Extension Cable - 20ft and why is it ideal for bird feeder setups?The Wyze Cam USB Extension Cable - 20ft is a flexible, weatherproof USB cable designed to extend the reach of your Wyze cameras. It allows you to position your Wyze Cam near a bird feeder for optimal viewing angles without being limited by short cables. Its 20-foot length and IP67 weatherproof rating make it perfect for outdoor birdwatching setups.
Which Wyze cameras are compatible with the 20ft USB Extension Cable?The 20ft Wyze Cam USB Extension Cable is compatible with Wyze Cam v2, v3, v3 Pro, v4, Cam Pan v2/v3, OG Standard, and OG Telephoto models.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable is rated IP67 weatherproof, making it suitable for outdoor use in various weather conditions, including rain, snow, and sun.
What are the key features of the Wyze Bird Feeder?The Wyze Bird Feeder features a weather-resistant polycarbonate build (IP65 rated), a vibrant blue and orange design to attract birds, multiple mounting options (walls, trees, poles, cords, suction cups), a macro lens adapter for close-up views, and a 1-liter seed capacity. It is designed to work seamlessly with Wyze cameras for live birdwatching.
What is included in the Bird Feeder Plug-in Cam v4 Bundle?The Bird Feeder Plug-in Cam v4 Bundle includes a Wyze Bird Feeder (available in blue or brown), a Wyze Cam v4, and a Wyze Outdoor Power Adapter. This bundle provides a seamless, wired birdwatching setup with high-quality video and easy installation.
What are the benefits of the Bird Feeder Wireless Camera Bundle?The Bird Feeder Wireless Camera Bundle offers a cable-free birdwatching experience with a Wyze Bird Feeder, Wyze Battery Cam Pro, and a Wyze Solar Panel. Benefits include wireless convenience, solar-powered battery support, smart bird detection notifications, a macro lens adapter for close-ups, and flexible mounting options.
How does the Wyze Cam v4 Outdoor Bundle enhance birdwatching and security?The Wyze Cam v4 Outdoor Bundle provides 2.5K QHD video resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, and 24/7 local recording with a 128GB microSD card. It is weatherproof and compatible with Alexa and Google Assistant, making it ideal for both birdwatching and outdoor security.
Can I power my Wyze Cam near a bird feeder without a wall outlet?Yes, the Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 and other compatible models using a standard E26 lamp socket. This solution is perfect for locations where power outlets are not easily accessible.
What mounting options are available for the Wyze Bird Feeder?The Wyze Bird Feeder can be mounted on walls, trees, poles, cords, or with suction cups, providing versatile placement options to suit your birdwatching needs.
How can I ensure continuous power for my Wyze Cam in a wireless bird feeder setup?In a wireless setup, the Wyze Battery Cam Pro can be paired with the Wyze Solar Panel to minimize battery recharging and provide continuous power for uninterrupted birdwatching.
What are the advantages of using a macro lens adapter with the Wyze Bird Feeder?The included macro lens adapter with the Wyze Bird Feeder allows for crystal-clear close-up views of birds, enhancing your birdwatching experience by capturing detailed images and videos of your feathered visitors.
Can you tell me more about the Wyze Bird Feeder and its features?What are the benefits of the Bird Feeder Plug-in Cam v4 Bundle?Do you have any ongoing sales or discounts for the Wyze Bird Feeder or camera bundles?
