Flexible Power Outdoor Floodlight Cameras with Velcro Cable Strap
Flexible Power Outdoor Floodlight Cameras with Velcro Cable Strap Solutions
When it comes to securing your outdoor spaces with powerful lighting and smart surveillance, flexibility in power options and cable management is key. Whether you are a homeowner looking for easy installation or a renter wanting a no-fuss setup, Wyze offers a range of floodlight cameras and accessories designed to meet your needs — including flexible power solutions like plug-in mounts and cable straps for tidy, adaptable installations.
Wyze Cam Floodlight v2: Bright, Smart, and Easy to Install
Experience the perfect balance of power and convenience with the Wyze Cam Floodlight v2. This wired outdoor floodlight camera delivers:
  • 2800 Lumens of LED brightness to illuminate your yard or driveway with crystal-clear light.
  • 2K video resolution with Color Night Vision and a wide 160° field of view to capture every detail.
  • AI-Powered Light Control and Ambient Light Mode that keeps a low glow until motion triggers full brightness.
  • 24/7 local recording with microSD support (up to 256GB) — no subscription required.
  • Two-way talk and a loud 105dB siren for real-time communication and deterrence.
  • Dusk-to-dawn automation and IP65 weather resistance for reliable outdoor performance.
  • Flexible installation options, including a plug-in mount accessory (sold separately) that allows you to power the floodlight from a standard outdoor outlet without complex wiring.
This model is ideal for those who want a powerful floodlight camera with smart features and easy DIY setup. Wyze Cam Floodlight v2 illuminating a driveway at night Bright, motion-activated floodlight camera in action
Wyze Cam Floodlight Pro: The Ultimate in Coverage and Clarity
For those seeking top-tier security lighting, the Wyze Cam Floodlight Pro offers:
  • A 180° ultra-wide field of view to cover your entire yard with fewer blind spots.
  • Stunning 2.5K QHD video resolution with Color Night Vision for crisp, detailed footage day or night.
  • Onboard AI computer vision that intelligently detects people and vehicles, activating the lights only when needed.
  • Adjustable and dimmable 3000 lumen LEDs with three independently articulating panels for customizable light coverage.
  • Motion-activated voice deterrence and a built-in 105dB siren to ward off intruders.
  • Dual-band Wi-Fi support (2.4 & 5 GHz) for faster, more reliable connectivity.
  • Dusk-to-dawn automation and IP65 weatherproof rating for all-weather security.
  • Simple DIY installation with an optional plug-in mount for flexible power options without electrician help.
This floodlight camera is perfect for users who want professional-grade security lighting combined with smart AI features and flexible power solutions. Wyze Cam Floodlight Pro installed on a side door with a woman and dog nearby Advanced floodlight camera providing security and communication
Wyze Cam Floodlight Plug-In Mount: Flexible Power with Easy Cable Management
Say goodbye to complicated wiring and costly electrician visits with the Wyze Cam Floodlight Plug-In Mount. This accessory is designed to provide:
  • A 20-foot (6m) power cord with a durable SJTW-rated cable and 18 AWG wire for safe outdoor use.
  • Compatibility with Wyze Cam Floodlight v1, v2, and Floodlight Pro models.
  • Plug-and-play installation that lets you power your floodlight camera from any outdoor power outlet.
  • Outdoor-safe design rated for temperatures from -22°F to 122°F.
  • Included mounting hardware and foam tape for secure, weather-resistant setup.
  • A neat and flexible solution to manage power cables, often paired with velcro cable straps (not included) for tidy, adjustable cable organization.
This mount is ideal for renters or anyone who prefers a non-permanent, flexible power solution for their outdoor floodlight camera.
Why Choose Wyze Floodlight Cameras with Flexible Power Options?
"Flexible power solutions like plug-in mounts combined with powerful floodlight cameras give you the freedom to install smart security lighting anywhere outdoors — no electrician needed."
  • Easy DIY installation saves time and money.
  • Flexible cable management options, including velcro straps, keep your setup clean and adaptable.
  • Smart automation and AI detection enhance security without constant manual control.
  • Weatherproof and durable designs ensure long-lasting outdoor performance.
  • Seamless smart home integration with Alexa, Google Assistant, and IFTTT.
Additional Considerations for Your Outdoor Security Setup
  • Pair your floodlight camera with accessories like velcro cable straps to secure and organize power cords neatly along walls or eaves.
  • Use the plug-in mount to avoid junction box installation, perfect for renters or those with existing outdoor outlets.
  • Choose between the Wyze Cam Floodlight v2 for excellent value and features or the Floodlight Pro for premium coverage and AI-powered detection.
Summary of Featured Products
ProductKey FeaturesPrice Range
Wyze Cam Floodlight v22800 lumens, 2K video, 160° view, IP65, plug-in mount compatible$89.98
Wyze Cam Floodlight Pro3000 lumens, 2.5K QHD, 180° view, AI detection, dual-band Wi-Fi$149.98
Wyze Cam Floodlight Plug-In Mount20 ft cable, outdoor safe, easy plug-in power for floodlights$19.98
Conclusion
For a flexible power outdoor floodlight camera setup with easy cable management, Wyze offers the perfect combination of smart floodlight cameras and plug-in mounts. Whether you want the advanced AI and wide coverage of the Floodlight Pro or the reliable, bright Floodlight v2, adding the plug-in mount accessory lets you install your security lighting hassle-free. Organize your cables with velcro straps for a clean, professional look and enjoy peace of mind with smart, powerful outdoor security lighting.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight Plug-In MountWyze Cam Floodlight Pro
Price$89.98$19.98$149.98
Color VariantsBlack, WhiteBlack, WhiteBlack, White
Video Resolution2K HD (2304 x 1296)N/A2.5K QHD (2560 x 1440)
Field of View160° wide-angleN/A180° diagonal (170° horizontal, 95° vertical)
LED Lighting2 floodlight heads, 2800 lumensN/A (Power solution for floodlights)3 dimmable light panels, 3000 lumens total
Night VisionColor Night VisionN/AColor Night Vision
Motion DetectionAdvanced motion detection, 270° PIR sensorN/AAI computer vision with selectable object detection
AudioTwo-way talk, 105dB sirenN/ATwo-way talk, 105dB siren
Power SupplyHardwired 110-120V ACPlug-in mount with 20ft cable, no junction boxHardwired 110-120V AC
InstallationHardwired, DIY possible with Plug-In MountEasy plug-n-play installation, no junction boxHardwired
Local Storage24/7 local recording via microSD (up to 256GB)N/AUp to 256GB microSD card
Wi-Fi Compatibility2.4 GHzN/ADual-band 2.4 & 5 GHz
Weather ResistanceIP65N/AIP65
Smart Assistant IntegrationAlexa, Google AssistantN/AAlexa, Google Assistant, IFTTT
Ambient Light ModeYesN/AYes
Dusk-to-Dawn AutomationYesN/AYes
Cable Length (Plug-In Mount)N/A20 ft cable with velcro strapN/A
WeightNot specifiedNot specified2.9 lbs (1.32 kg)
DimensionsNot specifiedNot specified10.2 in x 9.1 in x 7.8 in (25.91 x 23.11 x 19.81 cm)
Warranty1 Year1 Year1 Year
What are the main benefits of Wyze outdoor floodlight cameras with flexible power options?Wyze outdoor floodlight cameras with flexible power options offer easy DIY installation, no need for an electrician, and adaptable cable management. With plug-in mounts and accessories like velcro cable straps, you can set up your security lighting anywhere outdoors, keeping your installation neat and hassle-free.
What is the difference between Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro?Wyze Cam Floodlight v2 features 2800 lumens of LED brightness, 2K video resolution, a 160° field of view, and is compatible with plug-in mounts for flexible installation. Wyze Cam Floodlight Pro offers a wider 180° field of view, higher 2.5K QHD video resolution, 3000 lumens of adjustable lighting, onboard AI detection, dual-band Wi-Fi, and advanced motion-activated features for professional-grade security.
How does the Wyze Cam Floodlight Plug-In Mount work?The Wyze Cam Floodlight Plug-In Mount provides a 20-foot outdoor-safe power cord, allowing you to power your Wyze floodlight camera from any standard outdoor outlet. It supports Wyze Cam Floodlight v1, v2, and Pro models, and includes mounting hardware and foam tape for secure, weather-resistant installation. This accessory eliminates the need for complex wiring or electrician services.
Are Wyze floodlight cameras suitable for renters?Yes, Wyze floodlight cameras are ideal for renters. The plug-in mount accessory allows for non-permanent installation using existing outdoor outlets, so you can set up and remove your security lighting without altering the property or requiring professional installation.
Can I use velcro cable straps with Wyze floodlight cameras?Yes, velcro cable straps are recommended for organizing and securing power cords when installing Wyze floodlight cameras. They help keep cables tidy and adjustable along walls or eaves, creating a clean and professional-looking setup.
Are Wyze floodlight cameras weatherproof?Yes, both Wyze Cam Floodlight v2 and Floodlight Pro are rated IP65 weather resistant, ensuring reliable performance in various outdoor conditions, including rain, snow, and extreme temperatures.
Do Wyze floodlight cameras require a subscription for 24/7 recording?No, Wyze Cam Floodlight v2 supports 24/7 local recording with a microSD card (up to 256GB) and does not require a subscription for continuous video storage.
What smart home integrations are available with Wyze floodlight cameras?Wyze floodlight cameras integrate seamlessly with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT, allowing for voice control and automation within your smart home ecosystem.
What is included with the Wyze Cam Floodlight Plug-In Mount?The Wyze Cam Floodlight Plug-In Mount includes a 20-foot SJTW-rated power cord, mounting hardware, and foam tape for secure, weather-resistant installation. Velcro cable straps are not included but can be purchased separately for additional cable management.
Which Wyze floodlight camera is best for wide area coverage?The Wyze Cam Floodlight Pro is best for wide area coverage, offering a 180° ultra-wide field of view, 2.5K QHD video resolution, and three independently adjustable LED panels for customizable lighting across large outdoor spaces.
What are the key features of the Wyze Cam Floodlight v2?Can you tell me more about the installation process for the Wyze Cam Floodlight Pro?Do you have any deals, ongoing sales, discounts, or promotions?
