Wyze Cam 20ft USB Extension: Flexible Studio & Workspace Setup
Flexible Placement Solutions for Wyze Cam in Your Art Studio or Workspace
Creating the perfect surveillance setup in an art studio or workspace requires flexibility and convenience. Whether you want to monitor your creative process, safeguard your valuable materials, or keep an eye on your workspace remotely, Wyze offers versatile camera options and accessories designed to fit your unique environment.
Wyze Cam USB Extension Cable - 20ft: Extend Your Reach with Ease
One of the biggest challenges in setting up cameras in an art studio or workspace is the limited length of power cables. The Wyze Cam USB Extension Cable - 20ft solves this problem by providing a generous 20-foot extension, allowing you to position your Wyze Cam exactly where you need it without worrying about proximity to power outlets.
  • Compatibility: Works seamlessly with Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Freedom of Placement: Ideal for large studios or workspaces where power sources are not conveniently located.
  • Affordable and Reliable: At just $7.99, it’s a cost-effective way to enhance your camera setup.
Say goodbye to short cables and enjoy the freedom to place your Wyze Cam in the perfect spot to capture every angle of your creative space.
Wyze Cam OG: Next-Generation Security with Spotlight and Weather Resistance
The Wyze Cam OG is a powerful wired camera option perfect for both indoor and outdoor use, making it a great choice for art studios that may have open windows, doors, or outdoor work areas.
  • 120° Wide Field of View: Capture a broad perspective of your workspace or studio.
  • Built-in Spotlight & Mini-Siren: Deter intruders with a 40-lumen spotlight and a 90-decibel siren.
  • 3X Faster Notifications: Stay instantly informed with rapid motion alerts.
  • Improved Two-Way Audio: Communicate clearly through the camera’s upgraded microphone and speaker.
  • IP65 Weatherproof: Durable enough to withstand rain or dust, suitable for outdoor or semi-exposed studio areas.
  • Custom Detection Zones: Focus the camera’s attention on specific areas to reduce false alerts.
This camera is perfect for artists who want to monitor both indoor and outdoor creative spaces with a reliable, weather-resistant device.
Wyze Cam v4: Crystal Clear 2.5K QHD Resolution with Enhanced Night Vision
For those seeking the latest in camera technology, the Wyze Cam v4 offers unmatched clarity and smart features that make it ideal for detailed monitoring in an art studio or workspace.
  • 2.5K QHD Video Resolution: Capture every brushstroke and detail with crystal-clear video.
  • Enhanced Color Night Vision: See your workspace clearly even in low light or at night.
  • Motion-Activated Spotlight: Automatically lights up your studio when motion is detected.
  • Wi-Fi 6 Support: Ensures fast and stable connectivity for smooth live streaming.
  • Multiple Mounting Options: Stand, wall mount, ceiling mount, or magnetic adhesive mount for flexible placement.
  • IP65 Weather Resistance: Suitable for indoor and outdoor use.
  • Built-in Siren and Two-Way Talk: Communicate or deter intruders with ease.
  • Local and Cloud Storage: Save footage locally on microSD cards up to 512GB or opt for cloud storage with subscription.
The Wyze Cam v4 is perfect for artists and creators who want high-resolution monitoring with smart features and flexible installation options.
Why Use Wyze Cam USB Extension Cable in Your Studio?
Art studios and workspaces often have unique layouts with limited power outlets. The Wyze Cam USB Extension Cable - 20ft allows you to:
  • Place your camera in the optimal position for coverage without being restricted by cable length.
  • Avoid unsightly or hazardous cable runs by neatly extending power to your camera.
  • Combine with magnetic or wall mounts on Wyze Cams for versatile, secure placement anywhere in your studio.
This accessory is essential for anyone looking to maximize the flexibility of their Wyze Cam setup.
Conclusion: Perfect Monitoring Setup for Your Creative Space
Combining the Wyze Cam USB Extension Cable - 20ft with either the Wyze Cam OG or the Wyze Cam v4 gives you the ultimate flexibility and performance for monitoring your art studio or workspace. Whether you need weatherproof durability, crystal-clear video, or extended cable length for flexible placement, Wyze has you covered.
Protect your creative environment with smart, adaptable Wyze Cam solutions designed to fit your unique needs.
Artist working in studio with camera monitoring Flexible Wyze Cam placement in an art studio Workspace with Wyze Cam and extended USB cable Wyze Cam USB extension cable enables flexible camera placement Creative workspace monitored by Wyze Cam v4 High-resolution Wyze Cam v4 monitoring an art workspace
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam OGWyze Cam v4
TypeAccessoryCameraCamera
Price$7.99$29.98 (1 Pack)$35.98 (1 Pack)
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraStandalone camera
Cable Length20 ft USB extension6 ft power cable6 ft flat micro USB to USB-A cable
Video ResolutionN/A1080p (1920 x 1080)2.5K QHD (2560 x 1440)
Field of ViewN/A120°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionN/A4 IR LEDs (850 nm)4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
Color Night VisionN/ANoYes
AudioN/ABuilt-in speaker & microphone, noise & echo cancellation99dB waterproof speaker, improved 2-way audio
Two-Way AudioN/AYesYes
Built-in SpotlightN/A40 LumensMotion-activated spotlight
Weather ResistanceN/AIP65IP65
Local Storage SupportN/AmicroSD up to 256 GBmicroSD up to 512 GB
Wireless ConnectivityN/A802.11 b/g/n 2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 6
WeightN/A4.1 oz (116 g)0.49 lb (222 g)
DimensionsN/A1.89 in x 1.89 in x 1.89 in2 in x 2 in x 2 3/8 in
Warranty30-day hassle-free returns1 Year1 Year
What are the best Wyze Cam solutions for monitoring an art studio or workspace?The best Wyze Cam solutions for art studios or workspaces are the Wyze Cam OG and Wyze Cam v4. Both offer flexible placement, weather resistance, and advanced features like motion detection, two-way audio, and high-resolution video. Pairing these cameras with the Wyze Cam USB Extension Cable - 20ft allows you to position your camera exactly where you need it, regardless of power outlet locations.
How does the Wyze Cam USB Extension Cable - 20ft improve camera placement in studios?The Wyze Cam USB Extension Cable - 20ft extends your camera’s reach by 20 feet, making it easy to place your Wyze Cam in the optimal position for monitoring your studio or workspace. This is especially useful in large or uniquely laid out spaces where power outlets may not be conveniently located.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The Wyze Cam USB Extension Cable - 20ft is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2, v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
Is the Wyze Cam OG suitable for outdoor use in art studios?Yes, the Wyze Cam OG is IP65 weatherproof, making it suitable for both indoor and outdoor use. It’s ideal for art studios with open windows, doors, or outdoor work areas, providing reliable monitoring in various environments.
What features make the Wyze Cam v4 ideal for creative workspaces?The Wyze Cam v4 offers 2.5K QHD video resolution for crystal-clear footage, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support for fast connectivity, multiple mounting options, IP65 weather resistance, built-in siren, two-way talk, and both local and cloud storage options. These features make it perfect for detailed and flexible monitoring in creative workspaces.
Can I use Wyze Cam accessories to mount cameras in different positions?Yes, Wyze Cams offer multiple mounting options including stand, wall mount, ceiling mount, and magnetic adhesive mount. Combined with the USB Extension Cable, you can securely and flexibly place your camera anywhere in your studio or workspace.
How does the Wyze Cam OG help deter intruders in a studio?The Wyze Cam OG features a built-in 40-lumen spotlight and a 90-decibel mini-siren, which can be activated to deter intruders. It also provides rapid motion alerts and improved two-way audio for instant communication.
What storage options are available for Wyze Cam v4 footage?The Wyze Cam v4 supports local storage on microSD cards up to 512GB and offers cloud storage options with a subscription, allowing you to choose the best method for saving and accessing your footage.
Why is the Wyze Cam USB Extension Cable essential for art studios?Art studios often have limited or inconveniently placed power outlets. The Wyze Cam USB Extension Cable - 20ft allows you to place your camera in the best position for coverage, avoid hazardous cable runs, and maximize the flexibility of your Wyze Cam setup.
Are Wyze Cam solutions affordable for artists and creators?Yes, Wyze Cam products and accessories like the USB Extension Cable are cost-effective. For example, the 20ft extension cable is priced at just $7.99, making it an affordable way to enhance your camera setup and security.
What are the benefits of using the Wyze Cam USB Extension Cable in my studio?Can the Wyze Cam USB Extension Cable be used with all Wyze Cam models?Do you have any deals, ongoing sales, discounts, or promotions available?
