Fast Shipping Refurbished Wired Video Doorbells with Two-Way Communication
Looking for a reliable, fast-shipping refurbished wired video doorbell that offers seamless two-way communication? Discover top-tier Wyze video doorbells designed to enhance your home security with crystal-clear video, real-time alerts, and easy installation. Whether you want a standalone wired doorbell or a complete front porch security bundle, these options deliver exceptional value and performance.
Wyze Video Doorbell v2: Clear 2K Wired Video Doorbell with Two-Way Audio
Experience the clearest wired video doorbell from Wyze with the
Wyze Video Doorbell v2. This refurbished model offers:
- 2K Video Resolution (2048 x 1536) for sharp, detailed footage day and night.
- Two-Way Audio with built-in microphone and speaker, enabling you to answer your door from anywhere.
- Local microSD Storage support up to 256GB, plus optional cloud storage with Wyze Security Plan.
- Wide Field of View: 135° horizontal and 103° vertical coverage to catch every visitor.
- Motion-Activated Voice Deterrence to help keep unwanted guests away.
- Weather Resistant (IP65) for reliable outdoor use in temperatures from -4°F to 122°F.
- Easy Wired Installation powered by 16V-24V AC.
Included with the doorbell are essential accessories like a chime controller, wall plate, wedge for angled mounting, wire caps, and installation kit for a smooth setup.
Perfect for homeowners who want high-resolution wired video doorbell security with robust two-way communication and fast shipping.
Enhance your front porch security with Wyze Video Doorbell v2
The Front Porch Security Bundle: Complete Wired Doorbell and Smart Lock Solution
For those seeking an all-in-one security upgrade, the
Front Porch Security Bundle combines:
- Wyze Video Doorbell and Chime with 1080p HD video and two-way audio.
- Wyze Lock for remote locking/unlocking and lock history monitoring via the Wyze app.
- Motion Event Alerts and integration with Alexa and Google Assistant.
- Weather-Resistant Doorbell (IP65) with 120° vertical x 88° horizontal field of view.
- Multiple Chime Sounds and easy installation.
This bundle is ideal for users who want wired video doorbell functionality paired with smart access control, all managed conveniently from one app.
Enjoy peace of mind with a smart home security system that covers both your doorbell and door lock.
Wyze Video Doorbell (Wired): Compact 1080p Full HD Doorbell with Two-Way Communication
If you prefer a straightforward wired doorbell with proven performance, the
Wyze Video Doorbell (Wired) is a compact and affordable choice featuring:
- 1080p Full HD Video with 8x digital zoom.
- Two-Way Audio with noise and echo cancellation.
- Motion Detection and real-time alerts.
- IP65 Weather Resistance for all-season durability.
- Wide Field of View: 120° vertical by 88° horizontal.
- Wired Power ensures continuous operation without battery worries.
This model includes a wall plate, wedge for angled mounting, wire caps, and installation hardware for quick setup.
A budget-friendly wired doorbell with essential two-way communication and dependable video quality.
Why Choose Refurbished Wyze Wired Video Doorbells?
Refurbished Wyze wired video doorbells offer the perfect balance of affordability, quality, and fast shipping. Each unit is tested and certified to meet high standards, ensuring you get a reliable product with all the features you need for home security.
- Fast Shipping: Get your doorbell quickly to secure your home without delay.
- Two-Way Communication: Speak directly with visitors or delivery personnel from your smartphone.
- Wired Power: Enjoy uninterrupted operation without battery replacements.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Weatherproof Design: Built to withstand outdoor elements year-round.
Enhance Your Setup with Accessories
For optimal installation and coverage, consider the
Wyze Video Doorbell v2 Wedge Kit accessory. It allows you to adjust the doorbell angle to eliminate blind spots, especially useful for angled door frames or porches with stairs.
- Includes horizontal and vertical brackets for flexible mounting.
- Weather-resistant and easy to install.
- Extends your doorbell’s field of view for superior security.
Summary of Featured Products
Product Name | Video Resolution | Power Type | Two-Way Audio | Weather Resistance | Special Features |
Wyze Video Doorbell v2 | 2K (2048x1536) | Wired | Yes | IP65 | Local microSD storage, voice deterrence |
Front Porch Security Bundle | 1080p HD | Wired | Yes | IP65 | Includes Wyze Lock, chime, app control |
Wyze Video Doorbell (Wired) | 1080p Full HD | Wired | Yes | IP65 | Compact design, 8x digital zoom |
Conclusion
Choosing a refurbished wired video doorbell with two-way communication from Wyze means investing in trusted home security with fast shipping and smart features. Whether you want the advanced 2K clarity of the Wyze Video Doorbell v2, the comprehensive Front Porch Security Bundle, or the compact Wyze Video Doorbell (Wired), you’ll enjoy seamless communication, reliable wired power, and weatherproof durability.
Secure your home today with these top-rated wired video doorbells designed for easy installation and smart home integration.
What are the benefits of choosing a refurbished Wyze wired video doorbell?
Refurbished Wyze wired video doorbells offer affordability, quality, and fast shipping. Each unit is tested and certified to meet high standards, ensuring reliable performance. You get all the essential features for home security, including two-way communication, smart integrations, and weatherproof design, at a lower price.How does two-way communication work on Wyze wired video doorbells?
Wyze wired video doorbells feature built-in microphones and speakers, allowing you to speak directly with visitors or delivery personnel through your smartphone. This seamless two-way audio ensures you can answer your door from anywhere, enhancing your home security and convenience.What video resolution do Wyze wired video doorbells offer?
Wyze offers several wired video doorbell models with different video resolutions. The Wyze Video Doorbell v2 provides sharp 2K (2048 x 1536) video, while the Wyze Video Doorbell (Wired) and the Front Porch Security Bundle offer 1080p Full HD video for clear and detailed footage.Are Wyze wired video doorbells weather resistant?
Yes, all featured Wyze wired video doorbells are IP65 weather resistant, making them suitable for reliable outdoor use in various weather conditions, including temperatures from -4°F to 122°F.What is included with the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 comes with a chime controller, wall plate, wedge for angled mounting, wire caps, and an installation kit. These accessories ensure a smooth and easy setup process.Can I store video footage locally with Wyze wired video doorbells?
Yes, the Wyze Video Doorbell v2 supports local microSD storage up to 256GB, allowing you to save video footage directly on the device. There is also an option for cloud storage with a Wyze Security Plan.What smart home integrations are available with Wyze wired video doorbells?
Wyze wired video doorbells are compatible with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation for enhanced convenience and security.What is the Front Porch Security Bundle?
The Front Porch Security Bundle combines a Wyze Video Doorbell and Chime with a Wyze Lock, offering 1080p HD video, two-way audio, remote locking/unlocking, lock history monitoring, and smart home integration—all managed from the Wyze app.How easy is it to install a Wyze wired video doorbell?
Wyze wired video doorbells are designed for easy installation. Each model includes necessary accessories such as wall plates, wedges for angled mounting, wire caps, and installation hardware to ensure a quick and straightforward setup.What is the purpose of the Wyze Video Doorbell v2 Wedge Kit?
The Wyze Video Doorbell v2 Wedge Kit allows you to adjust the angle of your doorbell for optimal coverage, eliminating blind spots. It includes horizontal and vertical brackets, is weather-resistant, and is easy to install, making it ideal for angled door frames or porches with stairs.Do Wyze wired video doorbells require batteries?
No, Wyze wired video doorbells are powered by a wired connection (16V-24V AC), ensuring continuous operation without the need for battery replacements.What motion detection features are available on Wyze wired video doorbells?
Wyze wired video doorbells offer motion detection with real-time alerts. The Wyze Video Doorbell v2 also features motion-activated voice deterrence to help keep unwanted guests away.What field of view do Wyze wired video doorbells provide?
The Wyze Video Doorbell v2 offers a 135° horizontal and 103° vertical field of view, while the Wyze Video Doorbell (Wired) and the Front Porch Security Bundle provide a 120° vertical by 88° horizontal field of view, ensuring comprehensive coverage of your front porch.How quickly can I receive my refurbished Wyze wired video doorbell?
Refurbished Wyze wired video doorbells are available with fast shipping, so you can secure your home without delay.
