Refurbished Wired Smart Doorbells with Motion Voice Deterrence
Refurbished Wired Smart Doorbell with Motion Voice Deterrence
Looking for a reliable, affordable, and feature-packed wired smart doorbell with motion detection and voice deterrence? Discover the best options from Wyze, including a refurbished model that offers excellent value without compromising on quality. These smart doorbells provide crystal-clear video, two-way audio, and advanced security features to keep your home safe and connected.
Wyze Refurbished Video Doorbell (Wired)
Premium Features at a Great Price
The Wyze Refurbished Video Doorbell (Wired) is a like-new product, fully tested and guaranteed to work, now available at a significantly reduced price. This wired doorbell camera delivers full HD 1080p video quality with a 2K sensor (2048 x 1536), ensuring you never miss a detail at your doorstep.
  • Video Quality: 1080p HD with 8x digital zoom for close-up views
  • Field of View: 120° vertical by 88° horizontal, covering a wide area
  • Motion Detection: Real-time alerts with motion-activated voice deterrence to warn off unwanted visitors
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for clear communication
  • Night Vision: 6 LED fill lights and 4 infrared LEDs for clear nighttime visibility
  • Connectivity: Direct Wi-Fi connection (802.11 b/g/n, 2.4 GHz)
  • Weather Resistance: IP65 rating, suitable for all weather conditions
  • Easy Installation: Setup in under 20 minutes with included chime and accessories
This refurbished doorbell is perfect for homeowners who want smart security features without paying full price, backed by Wyze’s quality assurance.
Wyze Video Doorbell v2 – Wired with Enhanced Specs
Next-Level Clarity and Smart Features
For those seeking the latest wired smart doorbell technology, the Wyze Video Doorbell v2 offers superior 2K video resolution (2048 x 1536) with a CMOS Starlight sensor that captures vivid details day and night.
  • Video Resolution: 2K with H.264 video format and 20 FPS daytime frame rate
  • Wide Field of View: 135° horizontal and 103° vertical for comprehensive coverage
  • Motion-Activated Voice Deterrence: Automatically plays a warning message when motion is detected to deter potential intruders
  • Two-Way Audio: Electric condenser microphone and 1W speaker for crystal-clear conversations
  • Local Storage: Supports microSD cards up to 256GB for continuous recording without cloud dependency
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless automation
  • Durability: IP65 weather resistance and operating temperature range from -4°F to 122°F
  • Complete Kit: Includes chime controller, wall plate, wedge for angled mounting, and installation hardware
This model is ideal for users who want the clearest video and advanced deterrence features in a wired doorbell. Smart Doorbell in Use Experience smart home security with Wyze Video Doorbell v2
Perfect Angle for Maximum Coverage
To complement the Wyze Video Doorbell v2, the Wedge Kit accessory allows you to adjust the doorbell’s viewing angle, eliminating blind spots caused by angled door frames or stairs.
  • Adjustable Angles: Includes 15° horizontal and 7.5° vertical brackets
  • Weather Resistant: Durable plastic construction designed for outdoor use
  • Easy Installation: Quick setup with included screws and guide
  • Compatibility: Designed exclusively for Wyze Video Doorbell v2
  • Warranty: 1-year product warranty for peace of mind
This accessory ensures your wired smart doorbell captures the best possible view of your porch or entryway.
Why Choose a Wired Smart Doorbell with Motion Voice Deterrence?
Wired smart doorbells provide consistent power without the need for battery replacements, ensuring your security system is always active. Motion-activated voice deterrence adds an extra layer of protection by warning off suspicious activity before it escalates. Combined with high-resolution video and two-way audio, these doorbells offer comprehensive home security and convenience.
Summary of Featured Products
Product NameKey FeaturesPrice (USD)
Wyze Refurbished Video Doorbell1080p HD, motion voice deterrence, IP6524.98
Wyze Video Doorbell v22K video, local storage, wide FOV, voice deterrence44.98
Wyze Video Doorbell v2 Wedge KitAdjustable mounting angles, weather resistant8.99
Enhance your home security today with these wired smart doorbells that combine affordability, advanced technology, and reliable performance.
Feature(Refurbished) Wyze Video Doorbell (Wired)Wyze Video Doorbell v2Wyze Video Doorbell v2 Wedge Kit
TypeRefurbished Wired DoorbellWired Doorbell v2Accessory (Wedge Kit)
Video Resolution1080p Full HD2K (2048 x 1536)N/A
Aspect Ratio4:3Not specified (wider field of view)N/A
Field of View120° Vertical x 88° Horizontal135° Horizontal, 103° Vertical, 166.8° DiagonalN/A
Night Vision4 x 940nm Infrared LED6 x 940nm IR lights, Color Night VisionN/A
AudioBuilt-in Speaker & Microphone (2-way audio, noise/echo cancellation)Two-way audioN/A
Motion DetectionYesYesN/A
Motion-Activated LEDYesNot specifiedN/A
Voice DeterrenceNoYes (motion-activated voice deterrence, requires subscription)N/A
Local StorageNot specifiedmicroSD slot (up to 256GB FAT32)N/A
Cloud StorageOptional with Wyze Security PlanOptional with Wyze Security Plan + Cam PlusN/A
ConnectivityWiFi 2.4GHz (802.11 b/g/n)WiFi 2.4GHz (IEEE802.11 b/g/n)N/A
PowerHardwired (Wired)Hardwired (16V-24V AC, ≥10VA)N/A
Weather ResistanceIP65IP65Yes (weather resistant)
DimensionsNot specified4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm)N/A
InstallationDIY, replaces existing wired doorbellDIY, includes chime controllerQuick installation
Included ItemsDoorbell, Wall Plate, Wedge (30°), Wire Caps, Screws, Extension Wires, Fuse, Quick Start GuideDoorbell v2, Chime Controller, Wall Plate, Wedge (30°), Installation Kit, Wire Caps, Extension Wires, Screws, Wall Anchors, Quick Start Guide1x 15° Horizontal Bracket, 2x 7.5° Vertical Brackets, Screws, Quick Start Guide
WarrantyNot specified1 Year1 Year
Price (Refurbished/New)$24.98 (Refurbished) vs $44.98 (New)$44.98 (New), $29.98 (Refurbished)$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge Kit)
Special FeaturesMotion-activated LED, Alexa & Google Assistant integration, multiple chime sounds2K video, pre-roll recording, motion-activated voice deterrence, Alexa & Google Assistant integration, 30° corner kit included, custom detection zonesAdjusts viewing angle for Doorbell v2, eliminates blind spots
CompatibilityWired doorbell systemsWired doorbell systemsCompatible with Doorbell v2 only
What is the Wyze Refurbished Video Doorbell (Wired)?The Wyze Refurbished Video Doorbell (Wired) is a like-new, fully tested smart doorbell camera offered at a reduced price. It features 1080p HD video quality, motion detection with voice deterrence, two-way audio, night vision, and IP65 weather resistance, making it an affordable and reliable choice for home security.
What features does the Wyze Refurbished Video Doorbell (Wired) offer?The Wyze Refurbished Video Doorbell (Wired) offers 1080p HD video with 8x digital zoom, a 120° vertical by 88° horizontal field of view, real-time motion detection with voice deterrence, two-way audio with noise and echo cancellation, night vision, direct Wi-Fi connectivity, IP65 weather resistance, and easy installation with included accessories.
How does motion-activated voice deterrence work on Wyze smart doorbells?Motion-activated voice deterrence automatically plays a warning message when motion is detected near your door, helping to deter unwanted visitors or potential intruders before they approach your home.
What is the difference between Wyze Video Doorbell v2 and the refurbished model?The Wyze Video Doorbell v2 offers enhanced 2K video resolution with a CMOS Starlight sensor for vivid day and night footage, a wider field of view (135° horizontal, 103° vertical), local microSD card storage up to 256GB, and advanced smart home integration. The refurbished model provides 1080p HD video and essential smart features at a lower price.
Does the Wyze Video Doorbell v2 support local storage?Yes, the Wyze Video Doorbell v2 supports local storage with microSD cards up to 256GB, allowing for continuous video recording without relying on cloud services.
Is the Wyze Video Doorbell v2 compatible with smart home systems?Yes, the Wyze Video Doorbell v2 is compatible with Alexa, Google Assistant, and IFTTT, enabling seamless integration with your smart home devices and automation routines.
What is included with the Wyze Video Doorbell v2 purchase?The Wyze Video Doorbell v2 comes with a chime controller, wall plate, wedge for angled mounting, and all necessary installation hardware for a complete setup.
What is the Wyze Video Doorbell v2 Wedge Kit and why do I need it?The Wyze Video Doorbell v2 Wedge Kit is an accessory that allows you to adjust the doorbell’s viewing angle by 15° horizontally and 7.5° vertically. It helps eliminate blind spots caused by angled door frames or stairs, ensuring optimal coverage of your entryway.
Are Wyze wired smart doorbells weather resistant?Yes, both the Wyze Refurbished Video Doorbell (Wired) and Wyze Video Doorbell v2 have an IP65 weather resistance rating, making them suitable for use in all weather conditions.
How easy is it to install a Wyze wired smart doorbell?Wyze wired smart doorbells are designed for easy installation, typically taking less than 20 minutes. Each product includes all necessary accessories and a step-by-step guide to help you set up quickly.
Why should I choose a wired smart doorbell with motion voice deterrence?A wired smart doorbell with motion voice deterrence provides consistent power without battery changes, real-time motion alerts, and proactive voice warnings to deter suspicious activity. Combined with high-resolution video and two-way audio, it offers comprehensive home security and peace of mind.
What are the key features of the Wyze Video Doorbell v2?How does the motion-activated voice deterrence work on the smart doorbells?What is the warranty policy for the Wyze Video Doorbell products?
