Easy Install Refurbished Wired Video Doorbells for Home Security Upgrades
Upgrading your home security has never been easier with refurbished wired video doorbells that combine high-quality video, smart features, and simple installation. Whether you want crystal-clear video, two-way communication, or seamless integration with your existing home setup, these Wyze products offer reliable and affordable solutions to enhance your front porch security.
Wyze Video Doorbell v2: Clear 2K Wired Video Doorbell with Local Storage
Experience the clearest wired video doorbell with the
Wyze Video Doorbell v2, designed for easy installation and powerful home security upgrades.
Key Features:
- 2K HD Video Quality: Capture every detail with stunning 2048 x 1536 resolution, providing a head-to-toe view of your porch.
- Local MicroSD Storage: Continuous 24/7 recording with onboard microSD card slot means you never miss a moment before or after the doorbell rings.
- Works with Existing Chime: Includes a chime controller so you can keep your traditional doorbell sound without bypassing it.
- Two-Way Audio: Speak directly to visitors from anywhere using the Wyze app.
- Motion-Activated Voice Deterrence: Automatically warns visitors they are being recorded, enhancing security.
- Pre-Roll Motion Recording: Wired power enables 3-6 seconds of pre-roll video before motion events.
- Weatherproof (IP65): Built to withstand rain, snow, and harsh weather conditions.
- Night Vision: Award-winning starlight sensor delivers clear color night vision.
- Smart Home Integration: Compatible with Alexa and Google Home for voice commands and live feed viewing.
- 30° Corner Kit Included: Adjust your doorbell angle for perfect coverage, eliminating blind spots.
This doorbell is perfect for homeowners looking for a wired solution that’s easy to install and packed with advanced features for comprehensive porch security.
Enhance your front porch security with Wyze Video Doorbell v2
The Front Porch Security Bundle: Complete Wired Video Doorbell & Smart Lock Solution
For a full home security upgrade, the
Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock, giving you control over both your front door and porch security.
Bundle Highlights:
- 1080p HD Video Doorbell: View your front porch in crisp 1080p with two-way audio to greet visitors.
- Remote Lock/Unlock: Control your Wyze Lock remotely and monitor lock history via the Wyze app.
- Motion Event & Lock History: Stay informed with notifications about porch activity and door lock status.
- Works with Alexa & Google Assistant: Voice control your doorbell and lock for hands-free convenience.
- Weather-Resistant & Durable: Doorbell rated IP65 for outdoor use, lock designed for indoor installation.
- Multiple Chime Sounds: Choose from 5 modern, 4 classic, animal sounds, and more for your doorbell chime.
- Compact & Lightweight: Doorbell measures 1.5" x 3.25" x 0.625" and weighs just 1.7 oz.
This bundle is ideal for those wanting a wired video doorbell paired with smart lock capabilities for enhanced front door security and convenience.
Wyze Bulb Cam: Easy Install Wired Security Camera with Smart LED Light
If you want a wired video doorbell alternative that doubles as a smart light, the
Wyze Bulb Cam is a unique 2-in-1 outdoor security camera and LED bulb that fits most light fixtures.
Why Choose Wyze Bulb Cam?
- 2K HD Video with Color Night Vision: See clearly day or night with 2304 x 1296 resolution and vibrant color night vision.
- Wide 160° Field of View: Covers more area than traditional doorbells, perfect for porches, garages, and yards.
- Easy Installation: Simply screw into any standard E26 light socket—no wiring hassle.
- Dimmable 800 Lumen LED Bulb: Provides bright, adjustable lighting controlled via the Wyze app.
- Local MicroSD Storage: Supports up to 256GB microSD card for continuous recording without subscription fees.
- Two-Way Audio & Siren: Talk to visitors or scare off intruders with a built-in 95 dB siren and two-way communication.
- Motion-Activated Lighting & Alerts: Lights up and sends instant alerts when motion is detected.
- Expandable Lighting: Connect up to 5 Wyze Accessory Bulbs for full coverage smart lighting.
- Weatherproof (IP65): Designed to withstand outdoor conditions.
This product is perfect for homeowners seeking an easy-to-install wired security camera that also enhances outdoor lighting.
Wyze Bulb Cam blends security and lighting effortlessly
Wyze Video Doorbell v2 Wedge Kit: Perfect Angle for Maximum Coverage
To complement the Wyze Video Doorbell v2, the
Wedge Kit accessory allows you to adjust the doorbell’s viewing angle for optimal coverage, especially useful for angled door frames or porches with stairs.
Features:
- Includes 1x 15° horizontal bracket and 2x 7.5° vertical brackets.
- Quick and easy installation with included screws.
- Weather-resistant plastic construction.
- Ensures no blind spots for superior home security.
- 1-year product warranty.
This accessory is a must-have for anyone wanting to customize their wired video doorbell installation for the best possible view.
Why Choose Refurbished Wired Video Doorbells for Your Home?
Refurbished wired video doorbells offer a cost-effective way to upgrade your home security without compromising on quality or features. They come tested and certified, ensuring reliable performance with the latest technology.
- Easy Installation: Most wired doorbells and cameras come with clear instructions and compatible hardware for quick setup.
- Advanced Features: Enjoy high-resolution video, two-way audio, motion detection, and smart home integration.
- Local & Cloud Storage Options: Choose between local microSD storage or cloud subscriptions for video recording.
- Weatherproof Designs: Built to withstand outdoor elements for year-round protection.
- Smart Alerts & Voice Control: Stay connected with real-time notifications and control devices with Alexa or Google Assistant.
Upgrade your home security today with these easy install refurbished wired video doorbells and smart cameras from Wyze. Protect your front porch, monitor visitors, and control your home access—all with reliable, affordable technology designed for modern living.
Product Summary
Wyze Bulb Cam
Seamless integration with Alexa and Google Assistant for smart home control
What are the benefits of choosing a refurbished wired video doorbell for home security?
Refurbished wired video doorbells offer a cost-effective way to upgrade your home security without sacrificing quality or features. They are tested and certified for reliable performance, come with advanced features like high-resolution video, two-way audio, motion detection, and smart home integration, and are built to withstand outdoor elements.How easy is it to install a Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 is designed for easy installation. It comes with clear instructions, compatible hardware, and a 30° corner kit to help you achieve the perfect viewing angle. Most homeowners can install it quickly using their existing doorbell wiring.What video quality does the Wyze Video Doorbell v2 provide?
The Wyze Video Doorbell v2 delivers stunning 2K HD video quality with a resolution of 2048 x 1536, offering a clear, head-to-toe view of your porch and visitors.Does the Wyze Video Doorbell v2 support local video storage?
Yes, the Wyze Video Doorbell v2 features a microSD card slot for continuous 24/7 local recording, so you never miss a moment before or after the doorbell rings.Can I use my existing doorbell chime with the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 includes a chime controller, allowing you to keep your traditional doorbell sound without bypassing your existing chime.Is the Wyze Video Doorbell v2 weatherproof?
Absolutely. The Wyze Video Doorbell v2 is rated IP65, making it weatherproof and capable of withstanding rain, snow, and harsh outdoor conditions.What smart home integrations are available with Wyze video doorbells and locks?
Wyze video doorbells and locks are compatible with Alexa and Google Home, allowing you to use voice commands and view live feeds for hands-free smart home control.What is included in the Front Porch Security Bundle?
The Front Porch Security Bundle includes a Wyze Video Doorbell with 1080p HD video and two-way audio, plus a Wyze Lock that you can control remotely via the Wyze app. The bundle offers motion event notifications, lock history, and works with Alexa and Google Assistant.How does the Wyze Bulb Cam differ from a traditional video doorbell?
The Wyze Bulb Cam is a 2-in-1 device that functions as both a wired security camera and a smart LED bulb. It offers 2K HD video, color night vision, a wide 160° field of view, and easy installation by screwing into a standard E26 light socket—no wiring required.Does the Wyze Bulb Cam support local storage?
Yes, the Wyze Bulb Cam supports up to a 256GB microSD card for continuous local video recording, eliminating the need for subscription fees.What is the purpose of the Wyze Video Doorbell v2 Wedge Kit?
The Wyze Video Doorbell v2 Wedge Kit allows you to adjust the doorbell’s viewing angle for optimal coverage, especially useful for angled door frames or porches with stairs. It includes horizontal and vertical brackets for easy installation and maximum security coverage.Are Wyze wired video doorbells and cameras suitable for outdoor use?
Yes, Wyze wired video doorbells and cameras are designed with weatherproof (IP65) construction, making them suitable for year-round outdoor use.Do Wyze video doorbells and cameras offer two-way audio?
Yes, both the Wyze Video Doorbell v2 and Wyze Bulb Cam feature two-way audio, allowing you to speak directly to visitors from anywhere using the Wyze app.Can I receive motion alerts and notifications with Wyze security products?
Yes, Wyze security products provide real-time motion alerts and notifications to your smartphone, keeping you informed about activity at your front door or around your home.What storage options are available for Wyze video doorbells and cameras?
Wyze video doorbells and cameras offer both local microSD storage for continuous recording and optional cloud subscription services for video storage and playback.
