Extend Your Wyze Cam Coverage with a 20ft USB Extension Cable
If you're looking to cover a wide backyard with your Wyze Cam, the
Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera's reach. This cable eliminates the frustration of short cables and allows you to position your Wyze Cam exactly where you need it for optimal surveillance.
Wyze Cam USB Extension Cable - 20ft: Freedom to Place Your Camera Anywhere
- Length: 20 feet of flexible USB extension cable
- Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto
- Ease of Use: Simply plug in to extend your existing USB power cable without any complicated setup
- Price: Affordable at $7.99, making it a cost-effective solution for expanding your camera coverage
With this cable, you can easily position your Wyze Cam to cover large outdoor areas such as wide backyards, gardens, or driveways without worrying about power outlet proximity.
Wyze Cam v4: Advanced Security with Flexible Installation
The
Wyze Cam v4 is an excellent choice for backyard surveillance, especially when paired with the 20ft USB extension cable for extended reach.
Key Features of Wyze Cam v4
- Video Quality: Crisp 2.5K QHD (2560x1440) resolution for clear, detailed footage
- Field of View: Wide 115.8° diagonal field of view to cover more area
- Night Vision: Color night vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) for clear images even in the dark
- Weather Resistance: Rated IP65, perfect for outdoor use in various weather conditions
- Mounting Options: Versatile mounting including stand, wall, ceiling, and magnetic adhesive mounts
- Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6 for reliable streaming
- Audio: Built-in 99dB waterproof speaker with two-way talk and siren for enhanced security
- Power: Comes with a 6-foot flat micro USB to USB-A cable, which can be extended with the 20ft USB extension cable for wider placement
This camera’s robust features combined with the extended cable length make it ideal for monitoring large outdoor spaces effectively.
Enhance Outdoor Power Options with Pan v3 + Lamp Socket v2 Bundle
For those using the
Wyze Cam Pan v3 or looking for a smart power solution without relying on traditional outlets, the
Pan v3 + Lamp Socket v2 Bundle offers a unique way to power your camera.
Why Choose the Pan v3 + Lamp Socket v2 Bundle?
- No Outlet Needed: Powers your Wyze Cam Pan v3 directly from an outdoor lamp socket, eliminating the need for extra wiring or extension cables
- Smart Lighting Integration: Turns your existing outdoor light fixture into a smart light controlled via the Wyze app
- Motion-Activated Lights: Lights can be set to turn on automatically when motion is detected by the camera, enhancing security and convenience
- Easy Installation: Simply screw the lamp socket in place like a lightbulb, no electrician required
- Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, OG Telephoto, and Pan v3 models
This bundle is perfect for users who want a clean, wire-free setup while adding smart lighting features to their outdoor security system.
Summary: Perfect Solutions for Wide Backyard Coverage
To cover a wide backyard effectively with your Wyze Cam, the
Wyze Cam USB Extension Cable - 20ft is an essential accessory that provides the extra cable length needed for flexible camera placement. Pair it with the
Wyze Cam v4 for high-resolution, weather-resistant surveillance or consider the
Pan v3 + Lamp Socket v2 Bundle for a smart, outlet-free power solution with integrated lighting control.
These products together ensure you have the freedom, power, and technology to secure your outdoor spaces with ease and efficiency.
Product Highlights
- Wyze Cam USB Extension Cable - 20ft
- Wyze Cam v4
- Pan v3 + Lamp Socket v2 Bundle
"Extend your Wyze Cam’s reach effortlessly and secure every corner of your backyard with the right accessories."
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to position your camera further from a power outlet. This is ideal for covering large outdoor areas like backyards, gardens, or driveways.Which Wyze Cam models are compatible with the 20ft USB Extension Cable?
The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.How do I install the Wyze Cam USB Extension Cable?
Installation is simple—just plug the extension cable into your existing Wyze Cam USB power cable. No complicated setup or tools are required.What is the price of the Wyze Cam USB Extension Cable - 20ft?
The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99, making it a cost-effective solution for expanding your camera’s coverage.What are the key features of the Wyze Cam v4 for outdoor security?
The Wyze Cam v4 offers 2.5K QHD resolution, a wide 115.8° field of view, color night vision with IR and spotlight LEDs, IP65 weather resistance, versatile mounting options, support for 2.4 GHz Wi-Fi and Wi-Fi 6, two-way audio with a 99dB waterproof speaker, and comes with a 6-foot power cable that can be extended with the 20ft USB extension cable.Can I use the Wyze Cam v4 outdoors?
Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for outdoor use in various weather conditions.How can I power my Wyze Cam Pan v3 without an outdoor outlet?
You can use the Pan v3 + Lamp Socket v2 Bundle, which allows you to power your Wyze Cam Pan v3 directly from an outdoor lamp socket, eliminating the need for extra wiring or extension cables.What are the benefits of the Pan v3 + Lamp Socket v2 Bundle?
The bundle powers your Wyze Cam Pan v3 from a lamp socket, adds smart lighting control via the Wyze app, enables motion-activated lights, and is easy to install without an electrician. It also works with several Wyze Cam models.Does the Pan v3 + Lamp Socket v2 Bundle work with other Wyze Cam models?
Yes, the Pan v3 + Lamp Socket v2 Bundle is compatible with Wyze Cam v3, v3 Pro, v4, OG, OG Telephoto, and Pan v3 models.What is the best way to cover a wide backyard with Wyze Cam products?
For wide backyard coverage, use the Wyze Cam USB Extension Cable - 20ft to extend your camera’s reach, pair it with the high-resolution, weather-resistant Wyze Cam v4, or opt for the Pan v3 + Lamp Socket v2 Bundle for a smart, outlet-free power solution with integrated lighting.
