Extension Cable Solutions for Wyze Cameras
When it comes to extending the reach of your Wyze cameras, having the right extension cable or adapter is essential. Whether you need a longer USB cable for flexible placement or a specialized adapter for outdoor setups, Wyze offers a variety of extension cables and accessories designed to keep your smart home cameras powered and connected without hassle.
Wyze Cam USB Extension Cable - 20ft
Long Reach for Ultimate Flexibility
Say goodbye to the limitations of short cables with the
Wyze Cam USB Extension Cable - 20ft. This white 20-foot cable provides ample length to position your Wyze Cam v2, v3, v4, or Pan models exactly where you want them, without worrying about proximity to power outlets.
- Compatible with Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and original Wyze Cam models.
- Durable and flexible design for easy installation.
- Ideal for indoor or sheltered outdoor use where longer cable runs are needed.
This extension cable is perfect for users who want to maximize camera placement options for better coverage and security.
Enhance your home security with flexible camera placement
Wyze Cam v2 Extension USB Cable
Affordable Replacement and Extension
For those using the Wyze Cam v2, the
Wyze Cam v2 Extension USB Cable offers a simple and cost-effective solution to extend or replace your existing cable. Priced economically, it ensures your camera stays powered without interruption.
- Designed specifically for Wyze Cam v2.
- Perfect as a replacement or to extend cable length.
- Compact and easy to use.
This cable is a practical choice for maintaining your Wyze Cam v2 setup without investing in longer or more complex cables.
Wyze Cam Pan v3 USB Cable
Dedicated Cable for Pan v3 Models
The
Wyze Cam Pan v3 USB Cable is a replacement part tailored for the Wyze Cam Pan v3. If you need a fresh cable or a slight extension, this product ensures compatibility and reliable power delivery.
- Compatible exclusively with Wyze Cam Pan v3.
- Replacement or extension cable option.
- Maintains optimal performance for pan-and-tilt cameras.
Wyze L-Shaped Micro USB Adapter
Perfect Fit for Outdoor and Tight Spaces
The
Wyze L-Shaped Micro USB Adapter is a smart accessory that works with the Wyze Outdoor Power Adapter v1 or other Micro USB cables. It enables seamless connection with Wyze Cam Pan v3 or Cam v3 Pro, especially in tight or awkward spaces where a straight cable might not fit well.
- Compatible with Wyze Cam Pan v3, Cam v3 Pro, and Wyze Outdoor Adapter v1.
- Helps reduce cable strain and improves cable management.
- Essential for outdoor camera setups requiring weather-resistant power solutions.
Why Choose Wyze Extension Cables?
"Extending your Wyze camera’s reach has never been easier or more reliable."
Wyze extension cables and adapters are designed with your smart home needs in mind. They ensure your cameras stay powered and connected, whether indoors or outdoors, without compromising on durability or compatibility. From the ultra-long 20ft USB extension to specialized L-shaped adapters, Wyze provides the perfect cable solution for every camera model and installation scenario.
Summary of Wyze Extension Cable Options
Product | Compatibility | Length/Type | Price (USD) |
Wyze Cam USB Extension Cable | Wyze Cam v2/v3/v4, Pan v2/v3 | 20ft USB extension | 7.99 |
Wyze Cam v2 Extension USB Cable | Wyze Cam v2 | USB extension | 1.99 |
Wyze Cam Pan v3 USB Cable | Wyze Cam Pan v3 | USB replacement | 1.99 |
Wyze L-Shaped Micro USB Adapter | Pan v3, v3 Pro, Outdoor Adapter v1 | L-shaped adapter | 5.99 |
Optimize your Wyze camera setup today with the right extension cable or adapter to ensure seamless power and connectivity wherever you need it.
Product Tags Recap
- Wyze Cam USB Extension Cable - 20ft:
- Wyze Cam v2 Extension USB Cable:
- Wyze L-Shaped Micro USB Adapter:
- Wyze Cam Pan v3 USB Cable:
What extension cable options are available for Wyze cameras?
Wyze offers several extension cable solutions, including the Wyze Cam USB Extension Cable - 20ft, Wyze Cam v2 Extension USB Cable, Wyze Cam Pan v3 USB Cable, and the Wyze L-Shaped Micro USB Adapter. Each is designed for specific Wyze camera models to ensure reliable power and flexible placement.Which Wyze cameras are compatible with the 20ft USB Extension Cable?
The Wyze Cam USB Extension Cable - 20ft is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2, Pan v3, and original Wyze Cam models. It provides ample length for flexible camera placement indoors or in sheltered outdoor areas.Is there a dedicated extension cable for Wyze Cam v2?
Yes, the Wyze Cam v2 Extension USB Cable is designed specifically for the Wyze Cam v2. It serves as an affordable replacement or extension to keep your camera powered and connected.What cable should I use for Wyze Cam Pan v3?
For the Wyze Cam Pan v3, use the Wyze Cam Pan v3 USB Cable. This cable is tailored for the Pan v3 model, ensuring optimal performance and compatibility as a replacement or slight extension.What is the Wyze L-Shaped Micro USB Adapter used for?
The Wyze L-Shaped Micro USB Adapter is designed to work with the Wyze Outdoor Power Adapter v1 or other Micro USB cables. It is ideal for connecting Wyze Cam Pan v3 or Cam v3 Pro in tight or outdoor spaces, reducing cable strain and improving cable management.Are Wyze extension cables suitable for outdoor use?
Wyze extension cables, such as the 20ft USB Extension Cable and the L-Shaped Micro USB Adapter, are suitable for indoor or sheltered outdoor use. For fully outdoor setups, ensure you use weather-resistant adapters and proper cable management.Why should I choose official Wyze extension cables and adapters?
Official Wyze extension cables and adapters are designed for maximum compatibility, durability, and reliable power delivery. They help ensure your Wyze cameras remain powered and connected, whether installed indoors or outdoors.How long is the Wyze Cam USB Extension Cable?
The Wyze Cam USB Extension Cable is 20 feet long, providing extended reach for flexible camera placement and improved home security coverage.Can I use the Wyze L-Shaped Micro USB Adapter with any Wyze camera?
The Wyze L-Shaped Micro USB Adapter is compatible with Wyze Cam Pan v3, Cam v3 Pro, and the Wyze Outdoor Adapter v1. It is not designed for all Wyze camera models, so check compatibility before purchasing.
