Upgrade Wyze Cam Storage to 128GB for Longer Playback
Upgrade Your Wyze Cam Storage to 128GB for Extended Playback History
If you're looking to maximize your Wyze Cam's recording capabilities and enjoy longer playback history without worrying about running out of storage, upgrading to a 128GB Wyze MicroSD Card is the perfect solution. This upgrade unlocks continuous local recording, allowing you to capture every moment with ease and access your footage anytime directly from your camera or by removing the card.
Wyze MicroSD Card: The Ideal Storage Upgrade for Wyze Cams
Reliable and Compatible Storage Options
The Wyze MicroSD Card is designed specifically to work seamlessly with Wyze Cams, including the latest Wyze Cam v4. Available in multiple sizes, the 128GB microSDXC variant strikes the perfect balance between ample storage and affordability.
  • Capacity: 128GB microSDXC Card
  • Price: $16.99
  • Compatibility: Supports continuous recording and time lapse features on Wyze Cams
  • Easy Setup: Simply insert the card into your Wyze Cam’s built-in microSD slot and configure recording settings in the Wyze app
  • No Monthly Fees: Local recording is free and does not require any subscription
Benefits of Upgrading to 128GB Storage
  • Extended Playback History: Store days of continuous footage without overwriting important moments
  • Continuous Local Recording: Capture every second of activity 24/7 without interruption
  • Timelapse and Event Recording: Create stunning timelapse videos and save motion-triggered clips effortlessly
  • Easy Access: Playback footage directly from the Wyze app or remove the card to view files on your computer
Unlock powerful camera features and enjoy peace of mind knowing your home is monitored around the clock with no hidden fees.
Wyze Cam v4: The Perfect Camera to Pair with Your 128GB MicroSD Card
Wyze Cam v4 in Home Setting Alt text: Wyze Cam v4 installed indoors capturing home security footage
Advanced Features for Superior Security
The Wyze Cam v4 is a top-tier smart camera that complements the 128GB Wyze MicroSD Card perfectly, enabling you to maximize your local storage and recording capabilities.
  • Resolution: Crystal-clear 2.5K Quad HD (2560x1440) for detailed video quality
  • Color Night Vision: Enhanced hardware reveals vibrant colors even in low-light conditions
  • Wide Dynamic Range (WDR): Captures rich, vibrant colors and balanced lighting in every scene
  • Weather Resistant: IP65 rating allows outdoor placement in any weather
  • Integrated Spotlight & Siren: Motion-activated spotlight and 99dB siren for added security
  • Wi-Fi 6 Support: Stronger, more reliable connection for uninterrupted streaming and recording
  • Local Storage Support: Compatible with microSD cards up to 512GB, including the 128GB Wyze MicroSD Card
Easy Installation and Smart Home Integration
  • Screw-Free Magnetic Mount: Quick and tool-free setup on walls, ceilings, or metal surfaces
  • Bluetooth Setup: Hassle-free initial setup without scanning QR codes
  • Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice control and automation
  • Two-Way Talk: Clear audio communication with noise and echo cancellation
With the Wyze Cam v4 and a 128GB microSD card, you get a powerful, reliable security system that records continuously and stores your footage locally for easy access.
Why Choose Wyze for Your Home Security Storage Needs?
Wyze offers a complete ecosystem designed to work together seamlessly. Upgrading your Wyze Cam with a 128GB Wyze MicroSD Card ensures you never miss a moment, whether it’s monitoring your home, pets, or outdoor spaces.
  • Affordable Storage Upgrade: Get more recording time without breaking the bank
  • No Subscription Required: Local storage means no ongoing fees for playback access
  • Easy to Use: Simple installation and app-based controls make managing your footage effortless
  • Trusted Brand: Wyze is known for delivering high-quality smart home products with excellent value
Summary
Upgrading your Wyze Cam storage to a 128GB Wyze MicroSD Card is the smartest way to extend your playback history and enjoy continuous local recording. Paired with the advanced Wyze Cam v4, you get crystal-clear 2.5K video, enhanced color night vision, and robust weather resistance — all backed by easy setup and smart home compatibility. Invest in the Wyze MicroSD Card 128GB and Wyze Cam v4 today to secure your home with confidence and convenience.
FeatureWyze MicroSD CardWyze Cam v4
Product TypeAccessories (Memory Card)Camera
PurposeContinuous recording and time lapses for Wyze CamsHome security camera with video recording
Storage Capacity Variants32GB microSDHC, 128GB microSDXC, 256GB microSDXCSupports microSD cards up to 512GB
Price Range$8.99 - $29.99$35.98 - $100 (varies by bundle and options)
Video ResolutionN/A2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night Vision
Recording TypeLocal continuous recording24/7 local recording with microSD card
Subscription RequiredNoNo for local recording; subscription for cloud features
CompatibilityCompatible with Wyze Cams with microSD slotWyze Cam v4 and other Wyze cameras
FeaturesEnables timeline controls, timelapse, playback via appMotion-activated spotlight, siren, two-way talk, AI tracking, Wi-Fi 6 support
Weather ResistanceN/AIP65 rated (indoor/outdoor use)
ConnectivityN/A2.4 GHz Wi-Fi, Wi-Fi 6, Bluetooth 5.2
Dimensions & WeightN/A2in x 2in x 2 3/8in; 0.49 lb (222 g)
Warranty30-day hassle-free returns1-Year warranty
What are the benefits of upgrading my Wyze Cam storage to a 128GB MicroSD card?Upgrading your Wyze Cam storage to a 128GB MicroSD card allows for extended playback history, continuous 24/7 local recording, and the ability to store days of footage without overwriting important moments. It also enables features like timelapse and event recording, all without any monthly subscription fees.
Is the Wyze 128GB MicroSD card compatible with all Wyze Cams?Yes, the Wyze 128GB MicroSD card is designed to work seamlessly with all Wyze Cams, including the latest Wyze Cam v4. It supports continuous recording and timelapse features, making it an ideal storage upgrade for your Wyze security camera.
How do I install and set up the Wyze 128GB MicroSD card in my camera?To install the Wyze 128GB MicroSD card, simply insert it into your Wyze Cam’s built-in microSD slot. Then, configure your recording settings in the Wyze app to enable continuous or event-based recording. No tools or technical expertise are required.
Do I need a subscription to use local storage with my Wyze Cam?No, you do not need a subscription to use local storage with your Wyze Cam. All footage recorded to the Wyze 128GB MicroSD card is accessible for free, with no ongoing fees or hidden costs.
How can I access and playback footage stored on the Wyze 128GB MicroSD card?You can playback footage directly from the Wyze app on your smartphone or tablet. Alternatively, you can remove the MicroSD card from your camera and view the files on your computer for easy access and backup.
What advanced features does the Wyze Cam v4 offer when paired with a 128GB MicroSD card?When paired with a 128GB MicroSD card, the Wyze Cam v4 offers crystal-clear 2.5K Quad HD video, color night vision, wide dynamic range, weather resistance (IP65), integrated spotlight and siren, Wi-Fi 6 support, and compatibility with smart assistants like Alexa and Google Assistant.
How much does the Wyze 128GB MicroSD card cost?The Wyze 128GB MicroSD card is priced at $16.99, offering an affordable way to significantly increase your Wyze Cam’s recording capacity.
Can the Wyze Cam v4 support MicroSD cards larger than 128GB?Yes, the Wyze Cam v4 supports MicroSD cards up to 512GB, including the 128GB Wyze MicroSD card, allowing for even more extended local storage if needed.
What makes Wyze a trusted choice for home security storage solutions?Wyze is known for delivering high-quality, affordable smart home products that work seamlessly together. Their MicroSD cards and cameras are easy to use, require no subscription for local storage, and offer excellent value for reliable home security.
How do I set up the 128GB Wyze MicroSD Card in my Wyze Cam?What features does the Wyze Cam v4 offer that enhance security?Do you have any deals, ongoing sales, discounts, or promotions?
