Expandable Home Security System with Wyze Sensor Hub and Keypad
When it comes to securing your home, flexibility and comprehensive coverage are key. Wyze offers an expandable home security system that integrates a powerful sensor hub and an intuitive keypad, allowing you to customize your security setup to fit your unique needs. Whether you're starting fresh or enhancing your existing system, Wyze’s range of products ensures your home stays protected with smart technology and seamless control.
Wyze Home Monitoring Core Starter Kit: The Foundation of Your Security
The
Wyze Home Monitoring Core Starter Kit is the perfect entry point for anyone looking to establish a reliable home security system. This kit includes the essential components to monitor your home effectively:
- Wyze Sense Hub: Acts as the central brain, connecting all sensors and sending real-time alerts.
- Wyze Entry Sensors (2x): Wireless sensors that detect door and window openings, with 18-month battery life.
- Wyze Motion Sensor: Covers a 25-foot detection range to monitor movement inside your home.
- Wyze Keypad: Wireless with backlit keys and an emergency button for quick access to disarm or alert.
Key Features:
- Supports up to 100 sensors, making it highly expandable.
- Built-in backup battery with 10 hours of power to keep your system running during outages.
- Indoor use with a compact design (4.5" x 4" x 1").
- Siren with 88db volume to deter intruders.
- Easy installation with no tools required.
This kit is ideal for those who want a smart, connected system that can grow with their security needs.
"Keep your home safe with 24/7 monitoring and easy control."
Wyze sensors installed on doors for seamless home security.
Wyze Sense Hub: The Central Command for Your Security Network
The
Wyze Sense Hub is the essential hub that powers your Wyze security sensors and keypad. It ensures all components communicate efficiently and alerts are sent promptly.
Hub Highlights:
- Supports up to 100 sensors, allowing you to expand your system extensively.
- Multiple communication methods: Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF.
- Built-in rechargeable battery with 10 hours of backup power.
- Indoor use with a sleek matte white and grey design.
- Loud 88db siren to alert you and deter intruders.
The hub is the backbone of your expandable system, ensuring all devices work in harmony for maximum protection.
Wyze Sense Keypad: Convenient and Secure Control at Your Fingertips
The
Wyze Sense Keypad offers a user-friendly way to arm and disarm your home security system remotely. It requires the Wyze Home Monitoring system and the Wyze Sense Hub to function.
Keypad Features:
- Wireless and easy to mount indoors with permanent adhesive.
- Backlit keys for easy use in low light.
- Emergency button for quick alerts.
- Supports up to 100 accessories, making it perfect for large or growing systems.
- Enables remote disarming and can send first responder alerts.
This keypad adds an extra layer of convenience and security, allowing you to control your system effortlessly.
Wyze Sense Keypad mounted near the door for quick access.
Wyze Whole Home Security Starter Kit: All-in-One Security Solution
For those looking for a comprehensive starter bundle, the
Wyze Whole Home Security Starter Kit combines essential cameras and monitoring devices:
- Wyze Cam v4: Crystal-clear 2.5K QHD resolution with enhanced color night vision.
- Wyze Video Doorbell v2: Keep an eye on your front door with motion detection and two-way audio.
- Wyze Home Monitoring Starter Kit: Includes sensors and keypad for full home monitoring.
Why Choose This Kit?
- Covers both indoor and outdoor security needs.
- Easy to install and manage via the Wyze app.
- Provides a solid foundation for an expandable system.
- Available in multiple colors to blend with your home décor.
This kit is perfect for homeowners who want a balanced mix of video surveillance and sensor-based monitoring.
Wyze Cam v4 Home Security Bundle: Advanced Camera Protection
The
Wyze Cam v4 Home Security Bundle is designed for those who want high-quality video surveillance as part of their security system.
Camera Features:
- 2.5K QHD (2560x1440) resolution for crystal-clear images.
- Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs.
- Motion-activated spotlight and person detection for precise alerts.
- Weather-resistant (IP65) for indoor/outdoor use.
- Supports 24/7 local recording with up to 128GB microSD card.
- Compatible with Alexa and Google Assistant for voice control.
This camera bundle is ideal for expanding your home security with smart video monitoring.
Wyze Cam v4 mounted outdoors, providing vigilant home security.
Why Choose Wyze for Your Expandable Home Security?
Wyze’s ecosystem is designed to be flexible, affordable, and easy to use. With the combination of the
Wyze Sense Hub,
Keypad, and various sensor and camera kits, you can build a security system tailored to your home’s size and your security preferences. The system supports a large number of accessories, ensuring you can add more sensors, cameras, or smart devices as your needs evolve.
"Expand your home security effortlessly with Wyze’s smart, connected devices."
Summary of Products for Expandable Home Security
- Wyze Home Monitoring Core Starter Kit: Essential sensors, hub, and keypad for a customizable system.
- Wyze Sense Hub: Central controller connecting all sensors and devices.
- Wyze Sense Keypad: Convenient wireless keypad for arming/disarming and emergency alerts.
- Wyze Whole Home Security Starter Kit: Combines cameras and monitoring sensors for full coverage.
- Wyze Cam v4 Home Security Bundle: High-resolution cameras with advanced night vision and spotlight.
Build your expandable home security system today with Wyze and enjoy peace of mind knowing your home is protected by smart, reliable technology.
What is included in the Wyze Home Monitoring Core Starter Kit?
The Wyze Home Monitoring Core Starter Kit includes the Wyze Sense Hub, two Wyze Entry Sensors, one Wyze Motion Sensor, and a Wyze Keypad. This kit provides the essential components to start monitoring your home effectively.How many sensors can the Wyze Sense Hub support?
The Wyze Sense Hub supports up to 100 sensors, making it highly expandable for homes of any size.What are the key features of the Wyze Sense Hub?
The Wyze Sense Hub features support for up to 100 sensors, multiple communication methods (Ethernet, WiFi, Bluetooth, and RF), a built-in rechargeable battery with 10 hours of backup power, an 88db siren, and a compact indoor design.How does the Wyze Sense Keypad enhance home security?
The Wyze Sense Keypad allows you to arm and disarm your security system easily, features backlit keys for low-light use, includes an emergency button for quick alerts, and supports up to 100 accessories for large or growing systems.Is the Wyze security system easy to install?
Yes, the Wyze security system is designed for easy installation with no tools required. Components like the keypad can be mounted indoors using permanent adhesive.What is the Wyze Whole Home Security Starter Kit?
The Wyze Whole Home Security Starter Kit is an all-in-one bundle that includes the Wyze Cam v4, Wyze Video Doorbell v2, and the Wyze Home Monitoring Starter Kit, providing both video surveillance and sensor-based monitoring for comprehensive home security.What are the features of the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle offers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, person detection, weather resistance (IP65), 24/7 local recording with microSD support, and compatibility with Alexa and Google Assistant.Can I expand my Wyze home security system over time?
Yes, Wyze’s home security system is highly expandable. You can add up to 100 sensors, additional cameras, and other smart devices as your security needs grow.Does the Wyze security system work during power outages?
Yes, the Wyze Sense Hub has a built-in backup battery that provides up to 10 hours of power to keep your security system running during outages.Is the Wyze security system suitable for both indoor and outdoor use?
Wyze offers products for both indoor and outdoor security. The Wyze Cam v4 is weather-resistant and suitable for outdoor use, while sensors and the hub are designed for indoor installation.How do I control and monitor my Wyze home security system?
You can control and monitor your Wyze home security system using the Wyze app, which allows for easy management, real-time alerts, and seamless integration with other Wyze devices.What makes Wyze a good choice for expandable home security?
Wyze offers a flexible, affordable, and easy-to-use ecosystem. With support for a large number of accessories and seamless integration between sensors, cameras, and smart devices, Wyze allows you to build a customized security system that grows with your needs.
