Environmentally Friendly Cordless Vacuum: Wyze Cordless Vacuum S
Looking for an
environmentally friendly cordless vacuum with an
energy-efficient motor? The
Wyze Cordless Vacuum S is designed to deliver powerful cleaning performance while being lightweight and eco-conscious. This vacuum combines advanced technology with smart design to make your home cleaning effortless and sustainable.
Why Choose Wyze Cordless Vacuum S?
Powerful Suction with Energy Efficiency
The Wyze Cordless Vacuum S boasts an impressive
20,000 Pa suction power in Turbo Mode, ensuring deep cleaning on all surfaces. It offers three suction modes to balance power and battery life:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
This flexibility allows you to optimize energy use depending on your cleaning needs, making it an energy-efficient choice for everyday use.
Lightweight and Ergonomic Design
Weighing only
2.8 lbs for the main unit and
4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is incredibly easy to maneuver. Its compact size (12.4 x 4.5 x 8.7 inches main unit) and ergonomic design reduce fatigue during cleaning, encouraging more frequent use and less energy waste.
Long-Lasting Lithium-Ion Battery
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), this vacuum offers up to
40 minutes of runtime in ECO mode. The battery charges fully in
4-6 hours via AC charging, providing a reliable and sustainable power source without frequent replacements.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Advanced Features for Cleaner, Healthier Homes
Dual Motors and 3-Stage Filtration
The Wyze Cordless Vacuum S features
two powerful motors that enhance suction efficiency while maintaining low energy consumption. Its
3-stage filtration system, including a HEPA filter, traps fine dust and allergens, promoting healthier indoor air quality.
LED Screen and Brush Head Lights
Stay informed with the built-in
LED screen that displays battery life and suction mode. The vacuum’s brush head includes
6 daylight-bright LED lights, illuminating hidden dust and debris for thorough cleaning in dark corners.
Versatile Attachments Included
The vacuum comes with multiple attachments to tackle various cleaning tasks:
- Crevice Tool for tight spaces
- Floor Brush for hard floors and carpets
- Dust Cap and HEPA Filter for easy maintenance
- Standard Tube for extended reach
Enhance Your Wyze Vacuum Experience with Accessories
To keep your Wyze Cordless Vacuum S running at peak performance and adapt it to your cleaning needs, consider these compatible accessories:
Wyze Cordless Vacuum S - Battery Pack
Need extra cleaning time? The
Battery Pack is designed specifically for the Wyze Cordless Vacuum S, providing additional runtime to cover larger areas without interruption.
Wyze Cordless Vacuum S - Charger
Keep your vacuum powered with a replacement
charger compatible with the Wyze Cordless Vacuum S, ensuring you never run out of juice.
This
foldable tube bends for easier cleaning in hard-to-reach areas, reducing strain and improving efficiency.
Wyze Cordless Vacuum - HEPA Filter
Replace your HEPA filters regularly with this
2-pack to maintain optimal filtration and air quality.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Perfect for cleaning
car seats and sofas, this mini brush head attachment is designed exclusively for the Wyze Cordless Vacuum.
Eco-Friendly Cleaning with Wyze Cordless Vacuum S
The Wyze Cordless Vacuum S is not only powerful and versatile but also designed with sustainability in mind. Its energy-efficient motor, long-lasting battery, and reusable filters help reduce waste and energy consumption. Lightweight and easy to use, it encourages regular cleaning, contributing to a healthier home environment.
Enjoy pet-friendly cleaning with the Wyze Cordless Vacuum S
Lightweight and powerful cordless vacuum for every home
Specifications at a Glance
Feature | Specification |
Suction Power | 100 AW; 20,000 Pa (Turbo Mode) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | 40 min (ECO), 23 min (Medium), 10 min (Turbo) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo Mode) |
Dimensions | 12.4 x 4.5 x 8.7 in (main unit) |
Color | Steel grey with Wyze green accents |
Operating Temperature | -4ºF to 169ºF |
Experience the perfect blend of
power, efficiency, and eco-friendliness with the Wyze Cordless Vacuum S — your smart choice for a cleaner, greener home.
What makes the Wyze Cordless Vacuum S environmentally friendly?
The Wyze Cordless Vacuum S is designed with an energy-efficient motor, a long-lasting lithium-ion battery, and reusable HEPA filters. These features help reduce energy consumption and waste, making it an eco-friendly choice for sustainable home cleaning.How powerful is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode, ensuring deep cleaning on all surfaces. It offers three suction modes—Turbo, Medium, and ECO—to balance cleaning power and battery life.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features a 6-cell lithium-ion battery that provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery fully charges in 4-6 hours.Is the Wyze Cordless Vacuum S lightweight and easy to use?
Yes, the Wyze Cordless Vacuum S weighs only 2.8 lbs for the main unit and 4.9 lbs when fully assembled. Its ergonomic and compact design makes it easy to maneuver and reduces fatigue during cleaning.What filtration system does the Wyze Cordless Vacuum S use?
The Wyze Cordless Vacuum S uses a 3-stage filtration system, including a HEPA filter, to trap fine dust and allergens. This promotes healthier indoor air quality and is ideal for allergy sufferers.What attachments are included with the Wyze Cordless Vacuum S?
The vacuum comes with several versatile attachments: a crevice tool for tight spaces, a floor brush for hard floors and carpets, a dust cap, a HEPA filter, and a standard tube for extended reach.Does the Wyze Cordless Vacuum S have any smart features?
Yes, the Wyze Cordless Vacuum S features a built-in LED screen that displays battery life and suction mode. The brush head also includes 6 daylight-bright LED lights to illuminate hidden dust and debris.Are there accessories available for the Wyze Cordless Vacuum S?
Yes, you can enhance your cleaning experience with compatible accessories such as a battery pack for extended runtime, a replacement charger, a foldable vacuum tube for hard-to-reach areas, a 2-pack HEPA filter, and a mini motorized brush head for car seats and sofas.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing for efficient cleaning with fewer interruptions to empty the bin.How loud is the Wyze Cordless Vacuum S during operation?
The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, making it relatively quiet compared to many other cordless vacuums.What are the dimensions and color of the Wyze Cordless Vacuum S?
The main unit of the Wyze Cordless Vacuum S measures 12.4 x 4.5 x 8.7 inches and comes in a stylish steel grey color with Wyze green accents.Is the Wyze Cordless Vacuum S suitable for pet owners?
Yes, the Wyze Cordless Vacuum S is pet-friendly, offering powerful suction and a HEPA filtration system that effectively captures pet hair and dander, making it ideal for homes with pets.
