Room-Specific Vacuum Cleaners & Smart Cleaning Solutions by Wyze
Room-Specific Cleaning with Wyze Vacuum Solutions
When it comes to keeping your home spotless, having the right vacuum cleaner tailored for specific room needs makes all the difference. Whether you want to clean pet hair from your living room sofa, tackle hardwood floors, or maintain a dust-free bedroom, Wyze offers innovative vacuum products and accessories designed to optimize your cleaning experience room by room.
Wyze Cordless Vacuum S: Lightweight Power for Every Room
The Wyze Cordless Vacuum S is engineered for versatile, room-specific cleaning with its impressive suction power and lightweight design.
Key Features:
  • Suction Power: Up to 20,000 Pa in Turbo Mode, with adjustable settings (ECO, Medium, Turbo) to suit different floor types and mess sizes.
  • Weight: Only 2.8 lbs for the main unit, making it easy to maneuver around furniture and reach tight spaces.
  • Battery Life: Up to 40 minutes in ECO mode, perfect for cleaning multiple rooms without interruption.
  • Filtration: 3-stage filtration system including a HEPA filter to trap fine dust and allergens.
  • Attachments: Comes with a crevice tool and floor brush for targeted cleaning in corners, upholstery, and hard floors.
  • LED Lights: Six daylight-bright LEDs on the brush head illuminate dark areas under furniture or in closets.
This vacuum is ideal for living rooms with pets, bedrooms, and kitchens where different floor surfaces require adaptable suction and tools.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." — Wyze
Wyze Cordless Vacuum S in use cleaning a living room with a dog nearby Effortless cleaning around pets and furniture
Wyze Switch: Smart Lighting Control for Room-Specific Cleaning
While not a vacuum, the Wyze Switch complements your cleaning routine by enabling smart control of lighting in any room. Proper lighting is essential for effective cleaning, especially in dim corners or under furniture.
Highlights:
  • Turn any room’s lights into smart lights controllable from anywhere via the Wyze app.
  • Multi-tap functionality to control other Wyze devices, including robot vacuums.
  • Create custom schedules and automations to ensure rooms are well-lit during cleaning times.
  • Vacation mode and power loss recovery keep your home looking occupied and lights functioning reliably.
Use the Wyze Switch to brighten bedrooms, living rooms, or kitchens exactly when you need to clean, enhancing visibility and efficiency. Wyze Switch installed in a modern kitchen with voice assistant Smart lighting control for every room
Essential Accessories for Maintaining Peak Cleaning Performance
To keep your Wyze vacuum performing at its best for room-specific cleaning, consider these essential replacement parts:
Wyze Handheld Vacuum Filter
  • Designed exclusively for the Wyze Handheld Vacuum.
  • Replace regularly to maintain optimal suction and air quality.
Wyze Cordless Vacuum - HEPA Filter
  • Specifically for the Wyze Cordless Vacuum.
  • Comes in convenient 2-pack sizes to ensure you always have a fresh filter on hand.
Wyze Cordless Vacuum S - Battery Pack
  • Need extra cleaning time? This battery pack is designed to extend your vacuum’s runtime.
  • Perfect for larger homes or multiple room cleaning sessions without waiting for recharge.
Regular maintenance with these accessories ensures your vacuum stays powerful and efficient, no matter the room or cleaning challenge.
Why Choose Wyze for Room-Specific Cleaning?
Wyze products combine smart technology, powerful performance, and user-friendly design to make cleaning tailored to each room easier than ever. From the lightweight and powerful Cordless Vacuum S to smart lighting control with the Wyze Switch, you can customize your cleaning routine to fit your home’s unique needs.
Experience the freedom of cordless cleaning with smart home integration that keeps your entire living space fresh and spotless.
Summary of Featured Products
ProductPurposeKey Benefit
Wyze Cordless Vacuum SVersatile vacuum for all roomsPowerful, lightweight, cordless
Wyze SwitchSmart lighting controlAutomate and control lights
Wyze Handheld Vacuum FilterVacuum maintenanceKeeps suction and filtration optimal
Wyze Cordless Vacuum S BatteryExtended vacuum runtimeExtra power for longer cleaning
Wyze Cordless Vacuum HEPA FilterFilter replacementMaintains air quality and suction
Optimize your home cleaning with Wyze’s room-specific vacuum solutions and smart accessories — making every corner shine effortlessly.
ProductTypePrice (USD)CompatibilityKey FeaturesVariants/SizeReturn Policy
Wyze Cordless Vacuum SConnected Home139.99N/A20,000 Pa suction, 40-min interchangeable battery, 2 motors, 2.8 lbs weight, LED displayDefault Title30-day hassle-free returns
Wyze SwitchConnected Home14.99 (1 Pack), 41.98 (3 Pack)N/ASmart WiFi light switch, multi-tap controls, integrates with Wyze devices, timers, schedules1 Pack, 3 Pack30-day hassle-free returns
Wyze Handheld Vacuum FilterAccessories13.99 (1 Pack), 9.99 (3 Pack)Wyze Handheld VacuumReplacement filter, washable, maintain vacuum efficiency1 Pack, 3 PackNot specified
Wyze Cordless Vacuum S - Battery PackAccessories59.99Wyze Cordless Vacuum SExtra interchangeable battery for extended useDefault Title30-day hassle-free returns
Wyze Cordless Vacuum - HEPA FilterAccessories15.99Wyze Cordless Vacuum3-stage filtration, HEPA filter removes 95% of particles <0.3 µm2 PackNot specified
What makes the Wyze Cordless Vacuum S ideal for room-specific cleaning?The Wyze Cordless Vacuum S is designed for versatile, room-specific cleaning with powerful suction up to 20,000 Pa, lightweight construction (only 2.8 lbs), and multiple cleaning modes (ECO, Medium, Turbo). Its attachments, such as the crevice tool and floor brush, allow for targeted cleaning in living rooms, bedrooms, kitchens, and more. The built-in LED lights help illuminate dark areas, making it easy to clean under furniture and in tight spaces.
How long does the Wyze Cordless Vacuum S battery last?The Wyze Cordless Vacuum S offers up to 40 minutes of cleaning time in ECO mode, allowing you to clean multiple rooms without interruption. For extended cleaning sessions, you can use the Wyze Cordless Vacuum S Battery Pack to increase runtime.
What type of filtration does the Wyze Cordless Vacuum S use?The Wyze Cordless Vacuum S features a 3-stage filtration system, including a HEPA filter, which effectively traps fine dust and allergens. This ensures cleaner air quality in your home while maintaining strong suction performance.
Which accessories are essential for maintaining my Wyze vacuum’s performance?To keep your Wyze vacuum performing at its best, use the Wyze Handheld Vacuum Filter for the handheld model, the Wyze Cordless Vacuum HEPA Filter for the Cordless Vacuum S, and the Wyze Cordless Vacuum S Battery Pack for extended runtime. Regularly replacing filters and maintaining the battery ensures optimal suction and air quality.
How does the Wyze Switch enhance room-specific cleaning?The Wyze Switch enables smart lighting control in any room, making it easier to see and clean dim corners or under furniture. You can control lights remotely via the Wyze app, set custom schedules, and even automate lighting to coincide with your cleaning routine. The switch also supports multi-tap functionality to control other Wyze devices, including robot vacuums.
Can I automate my cleaning routine with Wyze products?Yes, Wyze products like the Wyze Switch allow you to automate lighting and control other Wyze smart devices, including robot vacuums. You can create custom schedules and automations to ensure your rooms are well-lit and ready for cleaning at any time.
Why should I choose Wyze for room-specific vacuum solutions?Wyze offers innovative, user-friendly products that combine smart technology with powerful cleaning performance. The Wyze Cordless Vacuum S is lightweight, cordless, and adaptable for different rooms and surfaces, while the Wyze Switch provides smart lighting control to enhance your cleaning efficiency. Essential accessories and replacement parts help maintain peak performance for a spotless home.
How often should I replace the filters in my Wyze vacuum?For optimal suction and air quality, it’s recommended to replace the Wyze Handheld Vacuum Filter and Wyze Cordless Vacuum HEPA Filter regularly, depending on usage and manufacturer guidelines. Keeping fresh filters on hand ensures your vacuum continues to perform efficiently in every room.
Is the Wyze Cordless Vacuum S suitable for homes with pets?Yes, the Wyze Cordless Vacuum S is ideal for homes with pets. Its powerful suction and specialized attachments make it easy to remove pet hair from sofas, carpets, and hard floors, while the HEPA filtration system helps trap allergens and fine dust.
What are the key features of the Wyze Cordless Vacuum S?How does the 3-stage filtration system in the Wyze Cordless Vacuum S work?Do you have any deals, ongoing sales, discounts, or promotions for Wyze products?
