Wyze Cordless Vacuum S: Best Value for Budget Families
Value Cordless Vacuum for Budget-Conscious Families: Wyze Cordless Vacuum S
For families seeking a powerful yet budget-friendly cordless vacuum, the Wyze Cordless Vacuum S stands out as an exceptional choice. Designed to deliver high suction power, long battery life, and lightweight convenience, this vacuum is perfect for everyday cleaning needs without breaking the bank.
Wyze Cordless Vacuum S: Powerful Cleaning Meets Affordability
Exceptional Suction Power for Deep Cleaning
The Wyze Cordless Vacuum S boasts an impressive suction power of up to 20,000 Pa in Turbo Mode, ensuring even the most stubborn dirt and pet hair are effortlessly removed. It offers multiple suction modes to suit your cleaning needs:
  • Turbo Mode: 20,000 Pa (10 minutes runtime)
  • Medium Mode: 9,000 Pa (23 minutes runtime)
  • ECO Mode: 6,000 Pa (40 minutes runtime)
This versatility allows budget-conscious families to balance power and battery life depending on the cleaning task.
Ultra-Lightweight and Ergonomic Design
Weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is as light as 2.8 pounds of feathers. This makes it easy to maneuver around furniture, stairs, and tight spaces without fatigue, ideal for families with kids or elderly members.
Long-Lasting Interchangeable Battery
Equipped with a 6-cell lithium-ion battery (2,000mAh*6), the vacuum provides up to 40 minutes of runtime in ECO mode. The battery is interchangeable, allowing you to swap in a fresh pack for extended cleaning sessions without waiting for a recharge.
Smart Features and Attachments
  • LED screen for easy mode and battery monitoring
  • Dual motors for enhanced suction and efficiency
  • 3-stage filtration system including a HEPA filter to trap allergens and dust
  • 6 daylight-bright LED lights on the brush head to illuminate dark corners
  • Comes with essential attachments: Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, and Standard Tube
This combination of features ensures thorough cleaning on all floor types, from hardwood to carpets, making it a versatile tool for busy households. Family cleaning with Wyze Cordless Vacuum S Lightweight and pet-friendly vacuuming for family homes
Extend Your Cleaning Power with Wyze Accessories
Wyze Cordless Vacuum S - Battery Pack
For families who need extra cleaning time, the Wyze Cordless Vacuum S Battery Pack is a perfect companion. Designed specifically for the vacuum, this replacement battery pack allows you to double your runtime and clean larger areas without interruption.
  • Price: $59.99
  • Hassle-free 30-day return policy
  • Compatible only with Wyze Cordless Vacuum S
Wyze Cordless Vacuum S - Charger
Keep your vacuum ready to go with the Wyze Cordless Vacuum S Charger. This replacement charger ensures you always have a reliable power source for your vacuum’s battery.
  • Price: $4.99
  • Compatible with Wyze Cordless Vacuum S
  • 30-day hassle-free returns
Why Choose Wyze Cordless Vacuum S for Your Family?
The Wyze Cordless Vacuum S combines powerful suction, lightweight design, and smart features at an unbeatable price point. It’s ideal for budget-conscious families who want a reliable vacuum that can handle pet hair, dust, and everyday messes with ease.
  • Affordable price: $139.99 (compared to $193.99 MSRP)
  • Long battery life: Up to 40 minutes on a single charge
  • Lightweight: Easy to carry and use around the home
  • Smart filtration: Keeps your home allergen-free
  • Multiple attachments: Versatile cleaning options
Wyze Cordless Vacuum S lifestyle cleaning Effortless cleaning with Wyze Cordless Vacuum S
Product Specifications at a Glance
FeatureSpecification
Suction Power100 AW / 20,000 Pa (Turbo Mode)
Weight2.8 lbs (main unit), 4.9 lbs (assembled)
Battery Type6-cell lithium-ion
Battery Capacity2,000mAh*6
Runtime40 min (ECO), 23 min (Medium), 10 min (Turbo)
Charging Time4-6 hours
Dust Cup Volume0.7 L
Noise Level65 dBA (Turbo Mode)
Dimensions12.4 x 4.5 x 8.7 in (main unit)
ColorSteel grey with Wyze green accents
Filtration3-stage with HEPA filter
Included AttachmentsCrevice Tool, Floor Brush, HEPA Filter, Dust Cap, Standard Tube
Conclusion
For families looking to invest in a value-packed cordless vacuum, the Wyze Cordless Vacuum S offers unbeatable performance, convenience, and affordability. Its powerful suction, long battery life, and lightweight design make it a smart choice for keeping your home clean and allergen-free without stretching your budget.
FeatureWyze Cordless Vacuum SWyze Cordless Vacuum S - Battery PackWyze Cordless Vacuum S - Charger
TypeConnected HomeAccessoriesReplacement Parts
Price$139.99 (Compare at $193.99)$59.99$4.99
DescriptionCordless vacuum with 20,000 Pa suction power, 40-minute interchangeable lithium-ion battery, two motors, weighs 2.8 lbsExtra battery pack for extended useReplacement charger for Wyze Cordless Vacuum S
Suction PowerUp to 20,000 PaN/AN/A
Battery LifeUp to 40 minutesN/A (provides additional battery)N/A
Weight2.8 poundsN/AN/A
CompatibilityWyze Cordless Vacuum SWyze Cordless Vacuum SWyze Cordless Vacuum S
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
Stock StatusIn stockLow stock (36 left)Available
What makes the Wyze Cordless Vacuum S a good choice for budget-conscious families?The Wyze Cordless Vacuum S offers powerful suction, long battery life, and a lightweight design at an affordable price of $139.99. It’s ideal for families who want reliable cleaning performance without overspending.
How powerful is the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode, making it effective at removing stubborn dirt, dust, and pet hair from various floor types.
What are the different suction modes and runtimes available on the Wyze Cordless Vacuum S?The vacuum offers three suction modes: Turbo Mode (20,000 Pa, 10 minutes runtime), Medium Mode (9,000 Pa, 23 minutes runtime), and ECO Mode (6,000 Pa, 40 minutes runtime), allowing you to balance cleaning power and battery life.
How lightweight is the Wyze Cordless Vacuum S?The main unit weighs only 2.8 lbs, and the fully assembled vacuum weighs 4.9 lbs, making it easy to maneuver around furniture, stairs, and tight spaces.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode on a single charge.
Is the battery on the Wyze Cordless Vacuum S interchangeable?Yes, the vacuum features an interchangeable 6-cell lithium-ion battery, allowing you to swap in a fresh battery pack for extended cleaning sessions.
What attachments and accessories come with the Wyze Cordless Vacuum S?The vacuum includes a Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, and Standard Tube. Additional accessories like a replacement battery pack and charger are also available.
Does the Wyze Cordless Vacuum S have a HEPA filter?Yes, it features a 3-stage filtration system with a HEPA filter to trap allergens and dust, helping to keep your home allergen-free.
How do I monitor the battery and suction mode on the Wyze Cordless Vacuum S?The vacuum is equipped with an LED screen that displays the current suction mode and battery level for easy monitoring.
What is the dust cup capacity of the Wyze Cordless Vacuum S?The dust cup has a capacity of 0.7 liters, allowing for efficient cleaning with fewer interruptions to empty the bin.
How loud is the Wyze Cordless Vacuum S during operation?The vacuum operates at a noise level of 65 dBA in Turbo Mode, making it relatively quiet for a high-suction cordless vacuum.
Are there any special features for cleaning dark or hard-to-reach areas?Yes, the Wyze Cordless Vacuum S has 6 daylight-bright LED lights on the brush head to illuminate dark corners and under furniture.
What is the price of the Wyze Cordless Vacuum S and its accessories?The Wyze Cordless Vacuum S is priced at $139.99 (compared to a $193.99 MSRP). The replacement battery pack costs $59.99, and the charger is $4.99.
Is there a return policy for the Wyze Cordless Vacuum S and its accessories?Yes, both the vacuum and its accessories come with a hassle-free 30-day return policy.
What are the dimensions and color of the Wyze Cordless Vacuum S?The main unit measures 12.4 x 4.5 x 8.7 inches and comes in steel grey with Wyze green accents.
What are the different suction modes available on the Wyze Cordless Vacuum S?How long does it take to charge the Wyze Cordless Vacuum S?Does the Wyze Cordless Vacuum S have a warranty?
