Easy Setup Dual Band WiFi Battery Security Cameras with Night Vision
Looking for a reliable, easy-to-install security camera that supports dual-band WiFi, runs on battery power, and offers night vision? Wyze offers a range of cutting-edge battery-powered security cameras designed to keep your home safe day and night with seamless setup and advanced features. Below, explore the top Wyze products that perfectly match your needs.
Wyze Battery Cam Pro: Advanced Wireless Security with Dual Band WiFi
Experience crystal-clear 2.5K HDR video resolution with the
Wyze Battery Cam Pro, a wire-free security camera that requires no hub and supports both 2.4 GHz and 5 GHz WiFi bands for stable, fast connectivity.
Key Features:
- Video Quality: 2560 x 1440 (2.5K) HDR video with H.264 encoding for sharp, detailed footage.
- Wireless & Battery Powered: Removable, rechargeable 6200mAh battery packs provide up to 6 months of battery life on a single charge.
- Dual Band WiFi Support: Connects effortlessly to both 2.4 GHz and 5 GHz networks, reducing interference and improving streaming quality.
- Night Vision: Equipped with 2 IR LEDs (850 nm) and 2 powerful white LEDs (5500K, 187 lumens) for clear color night vision.
- Motion Detection: Radar + PIR motion sensors for accurate detection and fewer false alerts.
- Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security by deterring intruders.
- Weatherproof: IP65 rating ensures reliable outdoor performance in various weather conditions.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Local Storage: Supports up to 256 GB microSD cards for continuous local recording.
Dimensions & Design:
- Compact size (2.5 x 1.8 x 3.5 inches) with a matte finish and lightweight design (0.94 lbs).
- Includes a versatile 1/4” - 20 standard mounting method and wall mount.
The Wyze Battery Cam Pro is perfect for those who want a high-quality, wire-free security camera with easy setup and robust dual-band WiFi support.
Wyze Battery Cam Pro + Solar Panel: Extended Power for Continuous Security
For users seeking uninterrupted security without frequent recharging, the
Wyze Battery Cam Pro + Solar Panel bundle offers the same advanced features as the Battery Cam Pro with the added convenience of solar charging.
Highlights:
- Solar Charging: Keeps your camera powered continuously by harnessing solar energy, reducing the need for manual battery swaps.
- All Features of Battery Cam Pro: 2.5K HDR video, dual-band WiFi, integrated spotlight, siren, radar + PIR motion detection, and IP65 weatherproofing.
- Battery Life: Up to 6 months on battery alone, extended further with solar panel support.
- Easy Installation: Wire-free setup with included wall mount and solar panel for flexible placement.
This bundle is ideal for outdoor areas with good sunlight exposure, ensuring your security camera stays powered and connected at all times.
Wyze Duo Cam Battery Doorbell: Dual Camera Views with Battery Power and Night Vision
Enhance your home entry security with the
Wyze Duo Cam Battery Doorbell, a battery-powered video doorbell featuring dual cameras for comprehensive coverage.
Features:
- Dual Cameras: Front camera with 2K resolution (2048 x 1536) and bottom camera with 1080p for package and visitor monitoring.
- Dual Band WiFi: Supports both 2.4 GHz and 5 GHz WiFi for reliable connectivity.
- Battery Powered: Removable 6200mAh lithium-ion battery pack with USB-C charging.
- Night Vision: 6 IR LEDs (850 nm) provide clear black-and-white night vision.
- Motion-Activated Voice Deterrence: Plays a warning message ("Hi, you’re currently being recorded.") to deter unwanted visitors.
- Two-Way Audio & Siren: 90 dB siren and two-way talk for real-time communication.
- Local & Cloud Storage: Supports up to 256 GB microSD card and cloud storage via AWS.
- Weather Resistant: IP65 rating for outdoor durability.
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
Dimensions & Installation:
- Slim design (5.90in x 1.88in x 1.18in) weighing 0.92 lbs.
- Includes Wi-Fi chime, back plate, corner kit, and mounting accessories for easy setup.
The Wyze Duo Cam Battery Doorbell is perfect for those wanting a smart, battery-powered doorbell with dual camera views and night vision.
Why Choose Wyze for Your Security Needs?
Wyze security cameras combine easy setup, dual-band WiFi support, and long-lasting battery power with advanced night vision and smart home compatibility. Whether you want a standalone battery camera or a smart video doorbell, Wyze offers reliable, weatherproof solutions that keep your home safe around the clock.
Boost Your Home Network with Wyze Wi-Fi 6E Mesh Router Pro
To maximize the performance of your dual-band WiFi security cameras, consider the
Wyze Wi-Fi 6E Mesh Router Pro. This router delivers ultra-fast internet speeds and broad coverage, ensuring your cameras stay connected without interruption.
Router Highlights:
- Wi-Fi 6E Technology: Access the new 6 GHz band alongside 2.4 GHz and 5 GHz for less congestion and faster speeds.
- Speeds up to 2.5 Gbps: Stream high-resolution video smoothly.
- Coverage: Up to 2000 sq. ft. per router, supporting 75+ devices.
- Easy Setup: Simple provisioning with Bluetooth Low Energy 5.1.
- Parental Controls & Security: WPA3-PSK and other advanced wireless security protocols.
This router is ideal for homes with multiple smart devices and security cameras, providing seamless internet coverage and reducing dead zones.
Wyze Wi-Fi 6E Mesh Router Pro delivering seamless home coverage
Summary of Recommended Products
Product Name | Video Resolution | Battery Powered | Dual Band WiFi | Night Vision Type | Weatherproof | Special Features |
Wyze Battery Cam Pro | 2.5K HDR | Yes | Yes (2.4 & 5 GHz) | IR + White LEDs (Color NV) | IP65 | Radar + PIR motion, Spotlight, Siren |
Wyze Battery Cam Pro + Solar | 2.5K HDR | Yes + Solar | Yes (2.4 & 5 GHz) | IR + White LEDs (Color NV) | IP65 | Solar charging, same as Battery Cam Pro |
Wyze Duo Cam Battery Doorbell | Front 2K + Bottom 1080p | Yes | Yes (2.4 & 5 GHz) | IR LEDs (Black & White NV) | IP65 | Dual cameras, voice deterrence, siren |
Wyze Wi-Fi 6E Mesh Router Pro | N/A | N/A | Tri-band (2.4, 5, 6 GHz) | N/A | Indoor | High speed, wide coverage, easy setup |
Conclusion
For an easy setup, dual band WiFi battery security camera with night vision, Wyze offers some of the best options on the market. The
Wyze Battery Cam Pro and its solar-powered variant provide excellent video quality, long battery life, and smart features. The
Wyze Duo Cam Battery Doorbell adds dual camera views and voice deterrence for entryway security. Pair these with the
Wyze Wi-Fi 6E Mesh Router Pro to ensure your home network supports all your devices with fast, reliable internet.
Secure your home effortlessly with Wyze’s innovative, wireless, and weatherproof security solutions.
Wyze Battery Cam Pro providing clear night vision and security
Wyze Duo Cam Battery Doorbell with dual camera views for enhanced security
What are the key features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro offers 2.5K HDR video resolution, dual-band WiFi support (2.4 GHz and 5 GHz), up to 6 months of battery life, color night vision with IR and white LEDs, radar + PIR motion detection, an integrated spotlight and 100 dB siren, IP65 weatherproofing, smart home integration with Alexa, Google Assistant, and IFTTT, and local storage support for up to 256 GB microSD cards.Does the Wyze Battery Cam Pro support dual-band WiFi?
Yes, the Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi bands, ensuring stable and fast connectivity with reduced interference and improved streaming quality.How long does the battery last on Wyze battery-powered security cameras?
Wyze battery-powered security cameras, such as the Wyze Battery Cam Pro and Wyze Duo Cam Battery Doorbell, feature removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and settings.Can I extend the battery life of my Wyze Battery Cam Pro?
Yes, you can extend the battery life of your Wyze Battery Cam Pro by using the Wyze Battery Cam Pro + Solar Panel bundle, which harnesses solar energy to keep your camera powered continuously, reducing the need for manual recharging.What type of night vision do Wyze security cameras offer?
Wyze security cameras provide advanced night vision. The Wyze Battery Cam Pro features color night vision using IR and white LEDs, while the Wyze Duo Cam Battery Doorbell uses 6 IR LEDs for clear black-and-white night vision.Are Wyze security cameras weatherproof?
Yes, Wyze security cameras such as the Wyze Battery Cam Pro and Wyze Duo Cam Battery Doorbell are IP65 weatherproof, making them suitable for reliable outdoor use in various weather conditions.What is the Wyze Duo Cam Battery Doorbell and what makes it unique?
The Wyze Duo Cam Battery Doorbell is a battery-powered video doorbell featuring dual cameras—a front-facing 2K camera and a bottom 1080p camera—for comprehensive entryway and package monitoring. It also offers dual-band WiFi, night vision, motion-activated voice deterrence, two-way audio, a 90 dB siren, and both local and cloud storage options.Do Wyze security cameras support local storage?
Yes, Wyze security cameras support local storage with microSD cards up to 256 GB, allowing for continuous local recording and playback.Are Wyze security cameras compatible with smart home systems?
Yes, Wyze security cameras are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT, enabling voice control and automation.How easy is it to install Wyze battery-powered security cameras?
Wyze battery-powered security cameras are designed for easy, wire-free installation. They come with mounting accessories and support flexible placement, making setup quick and straightforward without the need for a hub.What is the benefit of using the Wyze Wi-Fi 6E Mesh Router Pro with Wyze security cameras?
The Wyze Wi-Fi 6E Mesh Router Pro provides ultra-fast internet speeds, tri-band support (2.4 GHz, 5 GHz, and 6 GHz), and wide coverage up to 2000 sq. ft. per router. This ensures your Wyze security cameras maintain strong, reliable connections for smooth video streaming and reduced dead zones, especially in homes with multiple smart devices.Can Wyze security cameras be used both indoors and outdoors?
Yes, Wyze security cameras like the Wyze Battery Cam Pro and Wyze Duo Cam Battery Doorbell are weatherproof and suitable for both indoor and outdoor use, providing flexible security solutions for your home.What storage options are available for Wyze security cameras?
Wyze security cameras offer both local storage via microSD cards (up to 256 GB) and cloud storage through AWS, giving users flexible options for recording and accessing footage.What is included with the Wyze Duo Cam Battery Doorbell?
The Wyze Duo Cam Battery Doorbell package includes the doorbell unit, a Wi-Fi chime, back plate, corner kit, and mounting accessories for easy installation.
