Easy-Install Home Monitoring Sensors for Apartments & Condos
Easy Installation Home Monitoring Sensors for Apartments and Condos
When it comes to securing your apartment or condo, ease of installation and reliable performance are key. Wyze offers a comprehensive range of home monitoring sensors designed specifically for compact living spaces like apartments and condos. These sensors are simple to set up, require minimal tools, and integrate seamlessly with the Wyze Sense Hub to provide you with real-time alerts and peace of mind.
The Heart of Your System: Wyze Sense Hub
The Wyze Sense Hub acts as the central brain of your home monitoring system. It connects all your sensors and sends instant alerts to your smartphone, ensuring you stay informed no matter where you are.
  • Color & Design: White base with a sleek grey speaker top, blending unobtrusively into any home décor.
  • Functionality: Connects multiple sensors for comprehensive monitoring.
  • Price: $45.98 USD
The Wyze Sense Hub is essential for activating and managing all other Wyze Sense sensors, making it the perfect foundation for your apartment or condo security setup.
Modern apartment living with smart home devices
Versatile Sensors for Every Need
Wyze Sense Entry Sensor: Monitor Doors and Windows
Keep track of when doors or windows open or close with the Wyze Sense Entry Sensor. Ideal for apartments and condos, this sensor helps you monitor entry points effortlessly.
  • Detection: Alerts you immediately when doors or windows are opened.
  • Installation: Peel-and-stick adhesive backing for quick, no-drill setup.
  • Range: Works seamlessly with Wyze Sense Hub.
  • Pack Size: Available in convenient 3-packs.
  • Price: $41.98 USD
Wyze Sense Motion Sensor: Detect Movement with Precision
The Wyze Sense Motion Sensor detects motion within a 25-foot range and a 120° field of view, perfect for monitoring hallways, entryways, or common areas in your apartment.
  • Adjustable Sensitivity: Customize detection to avoid false alarms.
  • Installation: Easy adhesive backing or optional screws for added security.
  • Compatibility: Requires Wyze Sense Hub.
  • Price: $20.98 USD
Wyze Sense Climate Sensor: Track Temperature and Humidity
Maintain comfort and protect your belongings by monitoring temperature and humidity levels throughout your apartment or condo.
  • Range: Up to 500 feet, suitable for larger or multi-room spaces.
  • Design: Sleek white sensor that blends into any room.
  • Placement: Set on surfaces or mount with peel-and-stick adhesive.
  • Pack Size: Available in 3-packs.
  • Price: $41.98 USD
Specialized Sensors for Enhanced Protection
Wyze Sense Leak Sensor & Probe: Early Water Leak Detection
Protect your home from water damage with the Wyze Sense Leak Sensor & Probe. Ideal for kitchens, bathrooms, or laundry areas in apartments and condos.
  • Notification: Instant alerts when leaks are detected.
  • Operating Range: Works effectively in temperatures from 32°F to 104°F.
  • Sensor Range: Up to 500 feet.
  • Variants: Choose between 2 probes or 3 sensors with 1 probe.
  • Price: Starting at $13.98 USD
Wyze Sense Keypad: Arm and Disarm Remotely
Control your home security system with ease using the Wyze Sense Keypad. Perfect for quick arming or disarming without needing your phone.
  • Functionality: Arm/disarm system and send first responders.
  • Indoor Use: Designed for indoor environments.
  • Requirement: Works with Wyze Sense Hub.
  • Price: $27.98 USD
Secure your condo with smart keypad
Why Choose Wyze Sense Sensors for Your Apartment or Condo?
Wyze Sense sensors are designed with simplicity and efficiency in mind, making them ideal for renters and condo owners who want a hassle-free security solution. Their adhesive installation means no drilling or permanent modifications, perfect for leased spaces. Plus, the compact and sleek designs ensure they blend seamlessly into your living environment without clutter.
With a robust range of sensors covering entry points, motion, climate, and leaks, Wyze Sense offers a complete monitoring system that keeps your apartment or condo safe and comfortable. Comfortable smart home living
Summary of Wyze Sense Home Monitoring Sensors
ProductKey FeaturesPrice (USD)
Wyze Sense HubCentral hub, connects all sensors$45.98
Wyze Sense Entry SensorDoor/window open-close detection$41.98 (3-pack)
Wyze Sense Motion SensorMotion detection, adjustable$20.98
Wyze Sense Climate SensorTemperature & humidity tracking$41.98 (3-pack)
Wyze Sense Leak Sensor & ProbeLeak detection, multiple probesFrom $13.98
Wyze Sense KeypadRemote arm/disarm$27.98
Equip your apartment or condo with Wyze Sense sensors for an easy-to-install, reliable home monitoring system that fits your lifestyle and space.
FeatureWyze Sense HubWyze Sense Climate SensorWyze Sense Motion SensorWyze Sense KeypadWyze Sense Leak Sensor & ProbeWyze Sense Entry Sensor
DescriptionConnects monitoring components and sends alerts. Core of Wyze Home Monitoring System.Tracks temperature and humidity. Requires Wyze Sense Hub.Detects motion. Requires Wyze Sense Hub.Disarm home security remotely. Requires Wyze Sense Hub.Notifies of leaks. Requires Wyze Sense Hub.Detects when things open/close. Requires Wyze Sense Hub.
Requires Wyze Sense HubYesYesYesYesYesYes
CompatibilityWyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home Monitoring
Standalone FunctionalityYesNoNoNoNoNo
Detection/FunctionConnects sensors and sends alertsTemperature and humidity monitoringMotion detection (25 ft range, 120° FOV)Arm/disarm system, emergency buttonLeak detectionOpen/close detection
InstallationN/APlace on surface or peel-and-stick adhesiveAdhesive back or screwsPermanent adhesiveN/AN/A
RangeN/A500 ft25 ftN/AUp to 500 ftN/A
Battery LifeN/AN/AUp to 18 monthsN/AN/AN/A
Indoor UseYesYesYesYesYesYes
Emergency ButtonNoNoNoYesNoNo
Adjustable SensitivityN/AN/AYesN/AN/AN/A
Price (USD)$45.98$41.98 (3 Pack)$20.98 (1 Pack)$27.98$13.98 (2 Probes) / $55.98 (3 Sensors + 1 Probe)$41.98 (3 Pack)
What makes Wyze home monitoring sensors ideal for apartments and condos?Wyze home monitoring sensors are specifically designed for compact living spaces like apartments and condos. They feature easy, adhesive installation that requires no drilling or permanent modifications, making them perfect for renters and condo owners. Their sleek, compact design blends seamlessly into any décor, providing reliable security without clutter.
How do I install Wyze Sense sensors in my apartment or condo?Wyze Sense sensors are designed for simple, tool-free installation. Most sensors use peel-and-stick adhesive backing, allowing you to mount them on doors, windows, walls, or surfaces without drilling. This makes them ideal for leased spaces where permanent modifications are not allowed.
What is the Wyze Sense Hub and why is it essential?The Wyze Sense Hub is the central brain of your Wyze home monitoring system. It connects all your Wyze sensors and sends instant alerts to your smartphone, ensuring you stay informed about your home’s security. The hub is required to activate and manage all other Wyze Sense sensors.
Which Wyze sensors are available for home monitoring?Wyze offers a comprehensive range of sensors for home monitoring, including the Wyze Sense Entry Sensor (for doors and windows), Wyze Sense Motion Sensor (for detecting movement), Wyze Sense Climate Sensor (for temperature and humidity monitoring), Wyze Sense Leak Sensor & Probe (for water leak detection), and the Wyze Sense Keypad (for arming and disarming your system).
How does the Wyze Sense Entry Sensor work?The Wyze Sense Entry Sensor monitors doors and windows, sending instant alerts to your phone when they are opened or closed. It uses a peel-and-stick adhesive for quick, no-drill installation and works seamlessly with the Wyze Sense Hub.
Can I monitor temperature and humidity in my apartment with Wyze?Yes, the Wyze Sense Climate Sensor allows you to track temperature and humidity levels throughout your apartment or condo. It has a range of up to 500 feet and can be placed on surfaces or mounted with adhesive, helping you maintain comfort and protect your belongings.
How does the Wyze Sense Motion Sensor enhance security?The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view, making it ideal for monitoring hallways, entryways, or common areas. It features adjustable sensitivity to reduce false alarms and can be installed with adhesive or screws.
What is the Wyze Sense Leak Sensor & Probe used for?The Wyze Sense Leak Sensor & Probe provides early detection of water leaks in areas like kitchens, bathrooms, or laundry rooms. It sends instant alerts when leaks are detected, helping you prevent water damage in your apartment or condo.
How can I arm or disarm my Wyze home monitoring system?You can easily arm or disarm your Wyze home monitoring system using the Wyze Sense Keypad. The keypad allows for quick control without needing your phone and is designed for indoor use. It also enables you to send first responders if needed.
Are Wyze Sense sensors suitable for renters?Yes, Wyze Sense sensors are perfect for renters because they require no drilling or permanent installation. The adhesive mounting makes them easy to install and remove without damaging walls or surfaces, ensuring you can maintain your apartment or condo’s condition.
What is the price range for Wyze Sense home monitoring sensors?Wyze Sense home monitoring sensors are affordably priced: the Wyze Sense Hub is $45.98, Entry Sensor 3-pack is $41.98, Motion Sensor is $20.98, Climate Sensor 3-pack is $41.98, Leak Sensor & Probe starts at $13.98, and the Keypad is $27.98.
Do Wyze Sense sensors require a subscription to work?The content does not specify a required subscription for basic sensor functionality. However, all sensors require the Wyze Sense Hub for operation and management. For advanced features or professional monitoring, check Wyze’s official website for subscription details.
What are the key features of the Wyze Sense Hub?How does the Wyze Sense Hub connect with other sensors?Do you have any deals, ongoing sales, discounts, or promotions?
