Easy Install Home Security System with Peel and Stick Sensors
Easy Install Home Security Monitoring System with Peel and Stick Sensors
Looking for a hassle-free, easy-to-install home security monitoring system? Discover the Wyze Sense lineup, designed to provide comprehensive home protection with simple peel-and-stick sensors and smart automation. Whether you want to monitor doors, detect motion, track climate, or get leak alerts, Wyze Sense offers a seamless setup with reliable performance.
Core of Your Security: Wyze Sense Hub
At the heart of the Wyze home security system is the Wyze Sense Hub — the essential brain that connects all your sensors and devices. This hub ensures instant alerts and smooth communication between components, making your home monitoring system responsive and reliable.
  • Price: $45.98
Key Features:
  • Connects all Wyze Sense sensors
  • Sends real-time alerts to your phone
  • Designed as the core for every Wyze Home Monitoring setup
  • Easy plug-and-play installation
The Wyze Sense Hub is indispensable for activating and managing your entire security system, ensuring all sensors work in harmony.
Wyze Sense Hub Lifestyle Wyze Sense Hub seamlessly integrates your home security system
Peel and Stick Sensors for Effortless Installation
Wyze Sense Entry Sensor
Detects when doors or windows open and close, providing instant notifications to keep you informed of any activity.
  • Installation: Peel-and-stick adhesive backing for quick mounting
  • Compatibility: Requires Wyze Sense Hub and Wyze Sense v2
  • Pack Size: 3-pack for multiple entry points
  • Price: $41.98
  • Use Case: Ideal for monitoring entryways without drilling or complicated setup
Wyze Sense Motion Sensor
Keep an eye on movement inside your home with this compact sensor.
  • Detection Range: Up to 25 feet with a 120° field of view
  • Installation: Peel-and-stick or screws for added security
  • Battery Life: Up to 18 months
  • Price: $20.98
  • Compatibility: Works with Wyze Sense Hub and Wyze Home Monitoring
Wyze Sense Climate Sensor
Monitor temperature and humidity in any room to maintain a comfortable and safe environment.
  • Installation: Peel-and-stick adhesive or optional screws
  • Range: Up to 500 feet from the hub
  • Battery Life: 1.5 years (CR2032 battery)
  • Price: $41.98 (3-pack)
  • Design: Sleek, unobtrusive white matte finish blends into any room
These sensors are designed for easy peel-and-stick installation, making setup quick and tool-free — perfect for renters or anyone wanting a no-fuss security upgrade.
Additional Security and Safety Features
Protect your home from water damage by detecting leaks early.
  • Installation: Peel-and-stick sensor with probe for precise leak detection
  • Price: $13.98 for 2 probes, $55.98 for 3 sensors + 1 probe pack
  • Use Case: Ideal for basements, kitchens, or near water heaters
Wyze Sense Keypad
Arm or disarm your system quickly from anywhere in your home.
  • Features: On-device emergency button for first responders
  • Installation: Place anywhere with no wiring needed
  • Price: $27.98
  • Requirement: Must be used with Wyze Home Monitoring and Wyze Sense Hub
Wyze Sense Keypad Lifestyle Wyze Sense Keypad offers quick, remote control of your home security
Why Choose Wyze Sense for Your Home Security?
Wyze Sense sensors combine smart technology with user-friendly installation. The peel-and-stick design means no tools, no drilling, and no hassle — just secure your home in minutes. With a robust hub connecting all devices, you get real-time alerts and peace of mind, whether you're home or away.
  • Flexible Placement: Sensors can be placed on doors, windows, walls, or any flat surface
  • Long Battery Life: Up to 18 months on motion sensors and 1.5 years on climate sensors
  • Wide Compatibility: Works with Wyze Home Monitoring and Wyze Sense v2 for full system integration
  • Affordable Pricing: High-quality security without breaking the bank
Summary of Wyze Sense Products for Easy Install Home Security
ProductKey FeaturePriceInstallation Type
Wyze Sense HubCentral control hub$45.98Plug-in
Wyze Sense Entry SensorDetects open/close events$41.98Peel-and-stick
Wyze Sense Motion SensorMotion detection$20.98Peel-and-stick or screws
Wyze Sense Climate SensorTemperature & humidity tracking$41.98Peel-and-stick or screws
Wyze Sense Leak SensorLeak detection$13.98+Peel-and-stick
Wyze Sense KeypadArm/disarm & emergency button$27.98Place anywhere
Secure your home effortlessly with Wyze Sense — the easy install home security monitoring system featuring peel-and-stick sensors for quick setup and reliable protection.
FeatureWyze Sense Entry SensorWyze Sense HubWyze Sense Motion SensorWyze Sense Climate SensorWyze Sense KeypadWyze Sense Leak Sensor & Probe
DescriptionDetects when things open/closeConnects monitoring components, sends alertsDetects motionTracks temperature and humidityDisarm home security remotelyNotifies of leaks
RequiresWyze Sense HubN/AWyze Sense HubWyze Sense HubWyze Sense HubWyze Sense Hub
CompatibilityWyze Sense v2, Wyze Home MonitoringCore of Wyze Home Monitoring SystemWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Home MonitoringWyze Sense v2, Wyze Home Monitoring
Standalone FunctionalityNoYesNoNoNoNo
Detection RangeN/AN/A25 ft500 ftN/AUp to 500 ft
Field of ViewN/AN/A120°N/AN/AN/A
Sensitivity SettingsN/AN/AAdjustableN/AN/AN/A
Battery LifeNot specifiedNot specifiedUp to 18 months1.5 yearsNot specifiedNot specified
Indoor UseYesYesYesYesYesYes
Weather ResistanceNot specifiedNot specifiedNot specifiedIndoor use onlyNot weatherproofIndoor use only
Mounting MethodNot specifiedNot specifiedAdhesive back, screwsAdhesive back, optional screwsPermanent adhesiveNot specified
Size/Pack Options3 PackSingle unit1 Pack3 PackSingle unit2 Probes or 3 Sensors + 1 Probe
Price$41.98$45.98$20.98$41.98$27.98$13.98 (2 Probes), $55.98 (3 Sensors + 1 Probe)
Additional FeaturesInstant discount with Wyze Home Monitoring Annual planCentral hub for all sensors and alertsMax 100 sensors per hubTracks temperature & humidityArm/disarm system, emergency buttonLeak detection
What is the Wyze Sense Home Security Monitoring System?The Wyze Sense Home Security Monitoring System is an easy-to-install, comprehensive home protection solution featuring peel-and-stick sensors and smart automation. It allows you to monitor doors, detect motion, track climate, and receive leak alerts, all managed through the Wyze Sense Hub for seamless integration and real-time notifications.
How easy is it to install Wyze Sense sensors?Wyze Sense sensors are designed for effortless installation with peel-and-stick adhesive backing. This tool-free setup makes it perfect for renters or anyone looking for a quick, no-drill security upgrade. Some sensors also offer optional screw mounting for added security.
What is the Wyze Sense Hub and why is it important?The Wyze Sense Hub is the central control unit that connects all Wyze Sense sensors and devices. It ensures instant alerts, smooth communication between components, and is essential for activating and managing your entire Wyze home security system.
Which Wyze Sense sensors are available and what do they do?Wyze Sense offers several sensors: Entry Sensors detect when doors or windows open and close; Motion Sensors monitor movement inside your home; Climate Sensors track temperature and humidity; Leak Sensors detect water leaks; and the Wyze Sense Keypad allows you to arm or disarm your system and includes an emergency button.
Do I need the Wyze Sense Hub for all sensors to work?Yes, the Wyze Sense Hub is required for all Wyze Sense sensors to function properly. It acts as the brain of the system, connecting and managing all devices for real-time alerts and reliable performance.
How long do the batteries last in Wyze Sense sensors?Wyze Sense Motion Sensors have a battery life of up to 18 months, while Climate Sensors last up to 1.5 years on a single CR2032 battery. This ensures long-term, low-maintenance operation.
Are Wyze Sense sensors compatible with Wyze Home Monitoring?Yes, Wyze Sense sensors are fully compatible with Wyze Home Monitoring and Wyze Sense v2, allowing for complete system integration and enhanced home security.
Can I use Wyze Sense sensors in any room or area of my home?Absolutely. Wyze Sense sensors feature flexible placement and can be installed on doors, windows, walls, or any flat surface. The wireless design and long range from the hub make them suitable for any room, basement, kitchen, or near water heaters.
What is the price range for Wyze Sense products?Wyze Sense products are affordably priced: the Wyze Sense Hub is $45.98, Entry Sensor 3-pack is $41.98, Motion Sensor is $20.98, Climate Sensor 3-pack is $41.98, Leak Sensor starts at $13.98, and the Keypad is $27.98.
What makes Wyze Sense a good choice for home security?Wyze Sense combines smart technology with user-friendly, peel-and-stick installation, long battery life, wide compatibility, and affordable pricing. It offers reliable, real-time alerts and flexible placement, making it an excellent choice for hassle-free home security.
Can you tell me more about the Wyze Sense Hub and its features?How does the Wyze Sense Entry Sensor work for monitoring doors and windows?Do you have any deals, ongoing sales, discounts, or promotions?
