Advanced Smart Surveillance Package for Modern Home Defense
Protecting your home with cutting-edge technology is essential in today’s world. This advanced smart surveillance package combines the best Wyze cameras designed for comprehensive home defense, offering crystal-clear video, intelligent motion detection, and seamless smart home integration. Whether you want to monitor indoors, outdoors, or your front door, these devices provide reliable, high-quality security solutions tailored for modern living.
Wyze Cam v4: Crystal-Clear Outdoor and Indoor Security
Experience unmatched security with the
Wyze Cam v4, a versatile camera perfect for both indoor and outdoor use. It delivers stunning 2.5K QHD resolution, ensuring every detail is captured with precision.
Key Features:
- 2.5K QHD Video Resolution for ultra-clear images day and night.
- Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) to illuminate dark areas vividly.
- Motion-Activated Spotlight & Built-in Siren to deter intruders instantly.
- Wi-Fi 6 Support for faster, more reliable connectivity.
- 24/7 Local Recording with microSD card support up to 512 GB.
- Smart Home Integration compatible with Alexa, Google Assistant, and IFTTT.
- Weather Resistant (IP65) to withstand harsh outdoor conditions.
- Multiple mounting options including stand, wall, ceiling, and magnetic mounts.
This camera’s wide field of view (115.8° diagonal) and CMOS Starlight Sensor ensure you never miss a moment, making it ideal for monitoring entrances, backyards, or living spaces.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Full Coverage
For dynamic surveillance, the
Wyze Cam Pan v3 offers a complete 360° horizontal pan and 180° vertical tilt, allowing you to cover every corner of your property with a single device.
Highlights:
- 1080p Full HD Video with smooth 20 FPS daytime and 15 FPS nighttime streaming.
- IP65 Weather Resistance for reliable outdoor use (requires separate outdoor power adapter).
- Fast Rotation Speed up to 110° per second for quick tracking of movement.
- 8x Digital Zoom to focus on distant objects.
- Two-Way Audio with Noise & Echo Cancellation for clear communication.
- Smart Alerts with push notifications for instant updates.
- Compatible with Alexa, Google Assistant, and IFTTT.
This camera is perfect for wide-area monitoring such as large yards, garages, or indoor spaces where you want flexible viewing angles.
Wyze Cam Pan v3 providing weather-resistant outdoor security
Wyze Battery Cam Pro: Wire-Free, Long-Lasting Security Anywhere
The
Wyze Battery Cam Pro is a wire-free, battery-powered camera designed for flexible placement without the hassle of wiring or hubs.
Features:
- 2.5K HDR Video Resolution for sharp, detailed footage.
- Integrated Spotlight & Siren for active deterrence.
- Radar + PIR Motion Detection for precise and reliable alerts.
- Removable Rechargeable Battery Packs with up to 6 months of battery life.
- Dual-Band Wi-Fi Support (2.4 & 5 GHz) for stable connections.
- IP65 Weatherproof for all-season outdoor use.
- Supports local microSD storage up to 256 GB.
- Two-way audio with built-in speaker and microphone.
Ideal for areas where power outlets are scarce, such as detached garages, sheds, or remote corners of your property.
Wyze Bulb Cam: 2-in-1 Smart LED Light and Security Camera
Combine lighting and security with the
Wyze Bulb Cam, a smart LED bulb that doubles as a 2K HD security camera with color night vision.
Advantages:
- 2K HD Video with Color Night Vision to see clearly even in low light.
- 160° Wide Field of View covers broad areas.
- Motion-Activated Light & Instant Alerts to brighten and notify you of activity.
- Up to 800 Lumens Brightness with 3000K warm light.
- Fits standard E26 light sockets for easy installation.
- Supports local microSD storage (up to 256 GB) and cloud storage.
- IP65 weather resistance for outdoor use.
- Two-way audio and 95 dB siren for security alerts.
This device is perfect for porches, garages, or any outdoor fixture where you want to add both illumination and surveillance.
Wyze Bulb Cam providing smart lighting and security
Wyze Video Doorbell v2: Clear, Smart Front Door Monitoring
Secure your entryway with the
Wyze Video Doorbell v2, offering crisp 2K video and essential doorbell features.
Features:
- 2K (2048 x 1536) Video Resolution for detailed front door monitoring.
- Wide 135° Horizontal Field of View to capture visitors and packages.
- Motion-Activated Voice Deterrence to warn off unwanted guests.
- Two-Way Audio for real-time communication.
- Local microSD storage up to 256 GB and optional cloud storage.
- IP65 weather resistance for all-weather durability.
This wired doorbell is easy to install and includes a chime controller, wall plate, and installation kit for a seamless setup.
Why Choose This Advanced Smart Surveillance Package?
"Modern home defense demands smart, reliable, and versatile security solutions. This package combines high-resolution cameras, flexible installation options, and smart integrations to keep your home safe 24/7."
- Comprehensive Coverage: Indoor, outdoor, front door, and remote areas all protected.
- Smart Home Integration: Works effortlessly with Alexa, Google Assistant, and IFTTT.
- Weatherproof and Durable: IP65-rated devices built to withstand harsh conditions.
- Flexible Storage Options: Local microSD and cloud storage for your convenience.
- Two-Way Audio & Sirens: Communicate and deter intruders instantly.
Upgrade your home security with this thoughtfully curated package designed for modern homeowners who demand the best in surveillance technology.
What is included in the Advanced Smart Surveillance Package for home defense?
The Advanced Smart Surveillance Package includes a selection of Wyze cameras and devices: Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Video Doorbell v2. These devices offer comprehensive indoor, outdoor, and front door security with features like high-resolution video, motion detection, smart home integration, and weather resistance.What are the key features of the Wyze Cam v4 for home security?
The Wyze Cam v4 offers 2.5K QHD video resolution, enhanced color night vision, motion-activated spotlight, built-in siren, Wi-Fi 6 support, 24/7 local recording with microSD card support up to 512 GB, smart home integration with Alexa, Google Assistant, and IFTTT, IP65 weather resistance, and multiple mounting options.How does the Wyze Cam Pan v3 provide full coverage surveillance?
The Wyze Cam Pan v3 features 360° horizontal pan and 180° vertical tilt, 1080p Full HD video, fast rotation speed, 8x digital zoom, two-way audio with noise and echo cancellation, smart alerts, and IP65 weather resistance, making it ideal for monitoring large areas both indoors and outdoors.What makes the Wyze Battery Cam Pro suitable for flexible security placement?
The Wyze Battery Cam Pro is wire-free and battery-powered, allowing for easy placement anywhere without wiring or hubs. It features 2.5K HDR video, integrated spotlight and siren, radar and PIR motion detection, removable rechargeable battery packs with up to 6 months of battery life, dual-band Wi-Fi, IP65 weatherproofing, and local microSD storage up to 256 GB.How does the Wyze Bulb Cam combine lighting and security?
The Wyze Bulb Cam is a 2-in-1 smart LED bulb and security camera. It offers 2K HD video with color night vision, a 160° wide field of view, motion-activated light, instant alerts, up to 800 lumens brightness, easy installation in standard E26 sockets, IP65 weather resistance, two-way audio, a 95 dB siren, and supports both local and cloud storage.What are the benefits of the Wyze Video Doorbell v2 for front door monitoring?
The Wyze Video Doorbell v2 provides 2K video resolution, a wide 135° horizontal field of view, motion-activated voice deterrence, two-way audio, local microSD and optional cloud storage, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT. It comes with a chime controller, wall plate, and installation kit for easy setup.Are the Wyze security cameras weatherproof for outdoor use?
Yes, the Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Video Doorbell v2 all feature IP65 weather resistance, making them suitable for reliable outdoor use in various weather conditions.Can I integrate Wyze cameras with my smart home system?
Absolutely. All devices in the Advanced Smart Surveillance Package are compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration with your existing smart home ecosystem.What storage options are available for Wyze security cameras?
Wyze cameras support local storage via microSD cards (up to 256 GB or 512 GB depending on the model) and offer optional cloud storage for video recordings, giving you flexible options for saving and accessing your footage.Do Wyze cameras offer two-way audio and siren features?
Yes, most Wyze cameras in this package, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Video Doorbell v2, feature two-way audio for real-time communication and built-in sirens or voice deterrence to help deter intruders.Why should I choose this Advanced Smart Surveillance Package for my home?
This package offers comprehensive coverage for all areas of your home, advanced features like high-resolution video, smart motion detection, weatherproof durability, flexible storage, and seamless smart home integration. It is designed for modern homeowners seeking reliable, versatile, and easy-to-use security solutions.
