Easy Install Budget Smart and Refurbished Sprinkler Controllers for Indoor and Lawn Irrigation
Looking for an affordable, smart, and easy-to-install sprinkler controller that can efficiently manage your indoor and outdoor irrigation needs? Discover the Wyze Sprinkler Controller and its complementary Weatherproof Sprinkler Controller Box — a perfect combination for smart lawn care that saves water, time, and money.
Wyze Sprinkler Controller: Smart, Simple, and Green Irrigation
Smarter Lawn Watering at Your Fingertips
The Wyze Sprinkler Controller offers an 8-zone WiFi-enabled smart irrigation system that lets you control your lawn watering remotely from anywhere using the Wyze app. Say goodbye to manual timers and unnecessary watering during rain.
- 8 customizable irrigation zones: Tailor watering schedules for different parts of your lawn or garden.
- Personalized schedules: Create weekly routines that fit your lifestyle with easy start/stop controls.
- Remote control via app: Manage watering from your smartphone anytime, anywhere.
- WeatherSense certified: Uses EPA WaterSense technology to optimize watering based on local weather, helping conserve water.
- Sprinkler Plus subscription included: One year free access to weather-based watering, moisture level insights, and intelligent weather skips.
Easy DIY Installation
Replace your existing sprinkler controller in under 20 minutes with a straightforward setup process. The system automatically generates a watering schedule after installation, making it ideal for budget-conscious homeowners who want smart irrigation without hassle.
"Affordably priced smart sprinkler controller" - DigitalTrends
"#1 Affordable Smart Sprinkler Controller" - ZDNet
Control your lawn watering smartly and remotely with Wyze Sprinkler Controller.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
Mount Anywhere, Worry-Free
The Wyze Weatherproof Sprinkler Controller Box is designed to protect your sprinkler controller from the elements with an IP65 rating, making it fully weatherproof for outdoor use.
- Robust construction: Features 4 clasps and a gridded cover for extra durability.
- Flexible power options: Supports hardwire or outdoor outlet power.
- Compatible exclusively with Wyze Sprinkler Controller: Ensures seamless integration and protection.
- Ideal for outdoor installation: Safeguard your smart irrigation system from rain, dust, and debris.
This accessory is perfect for those who want to install their sprinkler controller outdoors without worrying about weather damage, extending the life and reliability of your smart irrigation system.
Easy outdoor installation with weatherproof protection.
Why Choose Wyze Smart Sprinkler Solutions?
Budget-Friendly and Eco-Conscious
Wyze offers one of the most affordable smart sprinkler controllers on the market, combining advanced features with a price point that fits tight budgets. The WaterSense certification and Sprinkler Plus weather-based watering help reduce water waste, saving you money on your water bill while protecting the environment.
User-Friendly App Experience
The Wyze app provides a seamless interface to monitor and control your irrigation system. You can:
- View live watering status and receive notifications.
- Set unique names and photos for each irrigation zone.
- Access historical and forecasted moisture data.
- Skip watering automatically during rain or unfavorable weather.
Refurbished and Sustainable Options
Wyze also offers B-grade and refurbished units, providing an eco-friendly choice for smart home enthusiasts who want to reduce waste without sacrificing quality or performance.
Summary of Key Features
Feature | Wyze Sprinkler Controller | Weatherproof Controller Box |
Zones Controlled | 8 customizable zones | N/A |
Connectivity | WiFi-enabled, app control | N/A |
Weather Protection | Indoor use | IP65 weatherproof for outdoor use |
Installation | DIY, under 20 minutes | Easy mounting anywhere outdoors |
WaterSense Certified | Yes, with Sprinkler Plus subscription | N/A |
Power Options | Standard power outlet | Hardwire or outdoor outlet compatible |
Price | $59.99 (controller), $39.99 (box) | $39.99 |
Conclusion
For those seeking an easy-to-install, budget-friendly, and smart irrigation solution, the Wyze Sprinkler Controller paired with the Weatherproof Sprinkler Controller Box offers an unbeatable combination. Enjoy the convenience of remote watering control, water-saving technology, and durable outdoor protection — all designed to keep your lawn and garden healthy with minimal effort.
What is the Wyze Sprinkler Controller and how does it work?
The Wyze Sprinkler Controller is an 8-zone WiFi-enabled smart irrigation system that allows you to control your lawn and garden watering remotely using the Wyze app. It features customizable schedules, remote app control, and EPA WaterSense technology to optimize watering based on local weather conditions.How many zones can the Wyze Sprinkler Controller manage?
The Wyze Sprinkler Controller can manage up to 8 customizable irrigation zones, allowing you to tailor watering schedules for different areas of your lawn or garden.Is the Wyze Sprinkler Controller easy to install?
Yes, the Wyze Sprinkler Controller is designed for easy DIY installation and can typically replace your existing sprinkler controller in under 20 minutes.Can I control the Wyze Sprinkler Controller remotely?
Yes, you can control the Wyze Sprinkler Controller remotely from anywhere using the Wyze app on your smartphone. This allows you to start, stop, or adjust watering schedules at any time.What is the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from rain, dust, and debris, making it ideal for outdoor installations.Is the Weatherproof Sprinkler Controller Box compatible with other sprinkler controllers?
No, the Wyze Weatherproof Sprinkler Controller Box is designed exclusively for use with the Wyze Sprinkler Controller to ensure seamless integration and protection.What power options are available for the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box supports both hardwire and outdoor outlet power options, providing flexibility for different installation needs.Does the Wyze Sprinkler Controller help save water?
Yes, the Wyze Sprinkler Controller uses EPA WaterSense-certified technology and weather-based watering through the Sprinkler Plus subscription to optimize irrigation and reduce water waste.What is included with the Sprinkler Plus subscription?
The Sprinkler Plus subscription, included free for one year, provides weather-based watering, moisture level insights, and intelligent weather skips to further enhance water savings and efficiency.Are there refurbished or budget options available for the Wyze Sprinkler Controller?
Yes, Wyze offers B-grade and refurbished units of the Sprinkler Controller, providing an eco-friendly and budget-conscious option for smart home enthusiasts.How much do the Wyze Sprinkler Controller and Weatherproof Controller Box cost?
The Wyze Sprinkler Controller is priced at $59.99, and the Weatherproof Sprinkler Controller Box is available for $39.99.What features does the Wyze app offer for sprinkler control?
The Wyze app allows you to view live watering status, receive notifications, set unique names and photos for each irrigation zone, access historical and forecasted moisture data, and automatically skip watering during rain or unfavorable weather.
