Smart Sprinkler Zone Moisture Data for Efficient Watering
Detailed Sprinkler Zone Moisture Information Subscription for Efficient Watering
Efficient watering is essential for maintaining a healthy lawn and garden while conserving water. The Sprinkler Plus subscription service by Wyze offers advanced, hyper-local weather data and detailed zone moisture information to optimize your irrigation system. This service integrates seamlessly with the Wyze Sprinkler Controller, providing a smart, automated watering experience tailored to each zone's unique needs.
What is Sprinkler Plus?
Sprinkler Plus is an optional subscription service designed to enhance the Wyze Sprinkler Controller by adding intelligence and precision to your watering routine. It leverages hyper-local weather data, soil moisture levels, and zone-specific parameters to create Smart Schedules that automatically adjust watering times and durations.
"Sprinkler Plus brings a completely hands-free experience by calculating when and how much to water based on real-time weather and soil conditions."
Key Features of Sprinkler Plus
  • 5-Day Weather Forecast: View upcoming weather and watering activities directly in the Wyze app.
  • Smart Schedules: Automatically calculate watering needs for each zone based on soil type, crop type, spray head, and weather.
  • Weather Skips: Avoid watering during rain, cold, wind, or when soil moisture is sufficient.
  • Cycle/Soak: Break watering into multiple cycles to allow soil to absorb water efficiently.
  • Advanced Zone Details: Access exact moisture levels for each zone to ensure optimal plant health.
Sprinkler Plus subscription is included free for one year with the purchase of a Wyze Sprinkler Controller, making it easy to start smart watering right away.
How Sprinkler Plus Decides When to Water
Sprinkler Plus uses a sophisticated water balance model that measures:
  • Water In: Rainfall and irrigation applied.
  • Water Out: Evapotranspiration (water lost through evaporation and plant use).
  • Weather Forecast: Past and predicted weather conditions.
When the water balance in a zone reaches a preset depletion threshold (meaning the soil is drying out), Sprinkler Plus schedules watering to replenish moisture.
Zone Parameters That Influence Watering
To tailor watering precisely, Sprinkler Plus considers:
  • Soil Type: Determines water retention and available water.
  • Crop Type: Different plants have varying water needs.
  • Spray Head Type: Influences precipitation rate (e.g., drip line vs. fixed spray).
  • Sun Exposure: Affects evaporation rates.
  • Slope: Impacts water runoff and absorption.
  • Root Depth & Allowed Depletion: Advanced settings that fine-tune watering duration and frequency.
Adjusting these parameters in the Wyze app helps ensure your Smart Schedules deliver the right amount of water for each zone.
Managing Soil Moisture Accuracy
Sometimes, soil moisture readings may not perfectly reflect actual conditions. Sprinkler Plus allows you to override soil moisture levels manually in the app if you notice discrepancies. This feature helps prevent overwatering or underwatering by letting you calibrate the system based on your observations.
Troubleshooting Soil Moisture Issues
  • Verify that your zone settings (crop type, soil type, spray head) are accurate.
  • Use the override feature to adjust soil moisture levels if needed.
  • Ensure your Wyze Sprinkler Controller firmware and app are up to date.
  • Power cycle or factory reset the controller if persistent issues occur.
Benefits of Using Sprinkler Plus for Efficient Watering
  • Water Conservation: Avoid unnecessary watering during rain or cool weather.
  • Healthier Plants: Maintain optimal soil moisture tailored to each plant type.
  • Convenience: Automate watering schedules with minimal manual input.
  • Flexibility: Adjust schedules and zone parameters anytime via the Wyze app.
  • Insight: Access detailed moisture data and weather forecasts to make informed decisions.
Subscription and Usage Details
  • Sprinkler Plus requires an annual subscription, with one year included free upon Wyze Sprinkler Controller purchase.
  • Each controller requires its own subscription.
  • You can cancel anytime, but must do so 24 hours before the next billing cycle to avoid charges.
  • The service is currently available only in the United States.
  • Sprinkler Plus is intended for personal, household use and not for commercial or business irrigation.
Conclusion
For homeowners seeking a smart, data-driven approach to lawn and garden irrigation, the Sprinkler Plus subscription offers detailed zone moisture information and intelligent watering schedules that adapt to weather and soil conditions. By leveraging this service with the Wyze Sprinkler Controller, you can achieve efficient watering that saves water, protects your plants, and simplifies lawn care.
Lush green garden with smart sprinkler system in use
Efficient watering starts with smart data and automation.
What is Sprinkler Plus and how does it work with the Wyze Sprinkler Controller?Sprinkler Plus is an optional subscription service that enhances the Wyze Sprinkler Controller by providing advanced, hyper-local weather data and detailed zone moisture information. It uses real-time weather and soil conditions to create Smart Schedules, automatically adjusting watering times and durations for each zone to ensure efficient and healthy irrigation.
What features does the Sprinkler Plus subscription offer?Sprinkler Plus offers several advanced features, including a 5-day weather forecast, Smart Schedules based on soil and crop type, weather skips to avoid watering during rain or cold, cycle/soak watering to improve absorption, and access to exact moisture levels for each zone. These features help optimize watering and conserve water.
How does Sprinkler Plus determine when and how much to water each zone?Sprinkler Plus uses a sophisticated water balance model that measures rainfall, irrigation, evapotranspiration, and weather forecasts. When the soil moisture in a zone drops below a preset threshold, the system automatically schedules watering to replenish moisture, taking into account zone-specific parameters like soil type, crop type, spray head, sun exposure, slope, and root depth.
Can I manually adjust soil moisture levels in Sprinkler Plus?Yes, you can manually override soil moisture levels in the Wyze app if you notice discrepancies between the system's readings and actual soil conditions. This feature helps prevent overwatering or underwatering by allowing you to calibrate the system based on your observations.
What should I do if the soil moisture readings seem inaccurate?If soil moisture readings appear inaccurate, verify that your zone settings (such as crop type, soil type, and spray head) are correct. Use the override feature in the app to adjust moisture levels if needed. Also, ensure your Wyze Sprinkler Controller firmware and app are up to date, and try power cycling or factory resetting the controller if issues persist.
What are the benefits of using Sprinkler Plus for lawn and garden irrigation?Sprinkler Plus helps conserve water by avoiding unnecessary watering during rain or cool weather, maintains optimal soil moisture for healthier plants, automates watering schedules for convenience, allows flexible adjustments via the Wyze app, and provides detailed moisture data and weather forecasts for informed decision-making.
How much does Sprinkler Plus cost and what is included with the Wyze Sprinkler Controller?Sprinkler Plus requires an annual subscription, but one year of service is included free with the purchase of a Wyze Sprinkler Controller. After the first year, a separate subscription is required for each controller.
Can I cancel my Sprinkler Plus subscription at any time?Yes, you can cancel your Sprinkler Plus subscription at any time. To avoid being charged for the next billing cycle, you must cancel at least 24 hours before the renewal date.
Is Sprinkler Plus available outside the United States?No, Sprinkler Plus is currently available only in the United States.
Is Sprinkler Plus suitable for commercial or business irrigation systems?No, Sprinkler Plus is intended for personal, household use only and is not designed for commercial or business irrigation.
Can you explain how Sprinkler Plus decides when to water my plants?What are the key features of the Sprinkler Plus subscription?How can I manage soil moisture accuracy with the Sprinkler Plus service?
