20ft Durable USB Extension Cable for Wyze Cam Outdoor Patio
Durable USB Extension Cable for Wyze Cam: 20ft Outdoor Patio Solution
When setting up your Wyze Cam in an outdoor patio, having a reliable and durable USB extension cable is essential. The Wyze Cam USB Extension Cable - 20ft is designed to extend your camera’s reach without compromising power or connectivity, making it the perfect accessory for outdoor installations.
Wyze Cam USB Extension Cable - 20ft: Extend Your Outdoor Reach
Key Features:
  • Length: 20 feet of flexible, durable USB cable to reach distant power sources.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Outdoor Use: Ideal for outdoor patios where power outlets may be far from the camera location.
  • Easy Setup: Simply plug in to extend your camera’s power cable without any complicated installation.
Say goodbye to short cables limiting your camera placement. This 20ft extension cable gives you the freedom to position your Wyze Cam exactly where you need it for optimal coverage.
Wyze Cam v4: The Ultimate Outdoor Camera Companion
Why Choose Wyze Cam v4 for Your Patio?
  • Weather Resistance: Rated IP65, the Wyze Cam v4 withstands rain, dust, and harsh outdoor conditions.
  • High-Resolution Video: Capture stunning 2.5K Quad HD video with vibrant colors and wide dynamic range.
  • Color Night Vision: See clear, colorful footage even in low-light or nighttime settings.
  • Integrated Spotlight & Siren: Motion-activated spotlight and siren enhance security and deter intruders.
  • Easy Mounting: Screw-free magnetic mount allows quick and secure installation on any patio surface.
  • Bluetooth Setup: Hassle-free setup without scanning QR codes.
Outdoor Power Ready
Pair the Wyze Cam v4 with the 20ft USB extension cable to place your camera exactly where you want it on your patio, even if the power outlet is far away. This combination ensures continuous power and reliable outdoor surveillance. Outdoor patio with Wyze Cam v4 installed Enhance your patio security with Wyze Cam v4 and a 20ft USB extension cable.
Wyze Cam OG: Reliable and Compact Outdoor Security
Features for Outdoor Use:
  • IP65 Weatherproof: Designed to handle outdoor environments including patios.
  • 1080p HD Video: Clear and smooth video streaming with 120° field of view.
  • Built-in Spotlight & Siren: 40 lumens spotlight and 90-decibel siren for added security.
  • Fast Live Streaming: 50% faster than previous Wyze models for real-time monitoring.
  • Two-Way Audio: Enhanced microphone and speaker for clear communication.
The Wyze Cam OG paired with the 20ft USB extension cable is a cost-effective, durable solution for outdoor patio monitoring, providing reliable power and flexible placement.
Why Use a 20ft USB Extension Cable for Your Wyze Cam Outdoors?
  • Flexible Placement: Extend your camera’s power source up to 20 feet, perfect for patios with limited outlet access.
  • Durability: Designed to maintain stable power and data transmission outdoors.
  • Compatibility: Works with multiple Wyze Cam models, ensuring versatility.
  • Enhanced Security: Position your camera for the best field of view without worrying about cable length.
For outdoor patio setups, the Wyze Cam USB Extension Cable - 20ft is an essential accessory that enhances your camera’s functionality and placement options.
Summary
For a durable, long-reach USB extension solution tailored for Wyze Cams in outdoor patios, the Wyze Cam USB Extension Cable - 20ft is your go-to accessory. Pair it with the Wyze Cam v4 for the best weather-resistant, high-definition outdoor security or the Wyze Cam OG for a reliable and budget-friendly option. Together, they provide flexible, powerful, and clear surveillance coverage for your outdoor spaces.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Wyze Cam OG
TypeAccessoryCameraCamera
Price$7.99$100 (standard), $35.98 (with 32GB MicroSD card)$29.98 (1 pack)
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraStandalone camera
ResolutionN/A2.5K QHD (2560x1440)1080p (1920x1080)
Field of ViewN/ADFOV 115.8°, HFOV 98.5°, VFOV 53.1°120°
Night VisionN/AEnhanced Color Night Vision + 4 IR LEDs (850 nm)4 IR LEDs (850 nm)
AudioN/AEnhanced Two-Way Talk, 99dB sirenBuilt-in Speaker & Microphone; Noise & Echo Cancellation
SpotlightN/AMotion-activated spotlight (2 white LEDs, 72 lumens)Built-in spotlight (40 lumens)
Weather ResistanceN/AIP65IP65
Local Storage SupportN/AmicroSD card up to 512 GBmicroSD up to 256 GB (exFAT)
ConnectivityUSB extension cable2.4 GHz Wi-Fi, Wi-Fi 6, Bluetooth 5.2802.11 b/g/n, 2.4 GHz Wi-Fi
Power SourceUSBWired (5V/1A)Wired (5V/1A)
DimensionsN/A2in x 2in x 2 3/8in1.89in x 1.89in x 1.89in
WeightN/A0.49 lb (222 g)4.1 oz (116 g)
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic mountStand, Wall mount, Ceiling mount
Additional FeaturesExtends USB cable length by 20ftWi-Fi 6 support, AI Auto-Zoom, Smoke & CO alerts, Person detection, Wide Dynamic Range (WDR)3X faster notifications, improved 2-way audio, 8x digital zoom
Warranty30-day hassle-free returns1 Year1 Year
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power source, making it ideal for outdoor patio installations where power outlets may be far from the camera location. It ensures reliable power and connectivity for your camera.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models, providing versatile support for various Wyze cameras.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable - 20ft is designed for outdoor use, making it perfect for patios and other outdoor areas where you need to extend your camera’s power source.
How easy is it to install the Wyze Cam USB Extension Cable?Installation is simple and straightforward. Just plug the extension cable into your Wyze Cam’s power cable to extend its reach—no complicated setup or tools required.
Why should I use a 20ft USB extension cable for my Wyze Cam outdoors?A 20ft USB extension cable allows you to place your Wyze Cam in the optimal position for surveillance, even if the nearest power outlet is far away. It provides flexible placement, stable power, and enhanced security coverage for your outdoor spaces.
What are the key features of the Wyze Cam v4 for outdoor patio security?The Wyze Cam v4 offers IP65 weather resistance, 2.5K Quad HD video, color night vision, an integrated spotlight and siren, easy screw-free magnetic mounting, and Bluetooth setup, making it an excellent choice for outdoor patio security.
How does the Wyze Cam OG perform for outdoor patio monitoring?The Wyze Cam OG is IP65 weatherproof, streams 1080p HD video with a 120° field of view, features a built-in 40 lumens spotlight and 90-decibel siren, offers fast live streaming, and includes two-way audio for clear communication, making it reliable for outdoor patio monitoring.
Can I use the Wyze Cam USB Extension Cable with both Wyze Cam v4 and OG models?Yes, the Wyze Cam USB Extension Cable - 20ft is fully compatible with both Wyze Cam v4 and Wyze Cam OG models, allowing you to extend their power source for flexible outdoor placement.
Does the 20ft USB extension cable affect the power or video quality of my Wyze Cam?No, the Wyze Cam USB Extension Cable - 20ft is designed to maintain stable power and data transmission, ensuring your camera operates reliably without compromising video quality or connectivity.
What are the benefits of pairing the Wyze Cam v4 with the 20ft USB extension cable?Pairing the Wyze Cam v4 with the 20ft USB extension cable allows you to position your camera exactly where you need it on your patio, regardless of outlet location. This combination ensures continuous power, reliable outdoor surveillance, and optimal security coverage.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Is the Wyze Cam USB Extension Cable compatible with all Wyze Cam models?What is the warranty policy for the Wyze Cam USB Extension Cable?
