How to Mount Wyze Cam v3 With a Longer Cable: Best Options
How to Mount Wyze Cam v3 with a Longer Cable Option
If you're looking to mount your Wyze Cam v3 and want the flexibility of a longer cable for better placement, the Wyze Cam Mounting Kit is the perfect accessory. This kit is designed specifically for Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro, providing everything you need to securely mount your camera while extending its reach with a longer Micro USB cable.
Wyze Cam Mounting Kit: The Ideal Solution for Extended Cable Needs
What’s Included?
  • Mounting bracket for secure installation
  • Strong adhesive for easy wall or ceiling mounting
  • Longer Micro USB cable to extend your camera’s power source connection
This kit allows you to position your Wyze Cam v3 exactly where you want it, even if the nearest power outlet is farther away. The longer cable ensures your camera stays powered without the hassle of unsightly extension cords or limited placement options.
Why Choose the Wyze Cam Mounting Kit?
  • Compatible with Wyze Cam v2, v3, and v3 Pro
  • Easy to install with adhesive or screws
  • Provides a neat, professional look with cable management
  • Affordable at just $5.99, making it a cost-effective upgrade
Mount your Wyze Cam v3 anywhere in your home or office with confidence, thanks to the extended cable and reliable mounting hardware included in this kit.
Understanding Wyze Cam v3 and v4 Mounting Options
While the Wyze Cam Mounting Kit is perfect for the v3 series, it’s helpful to know about the latest Wyze Cam v4, which comes with its own mounting accessories and cable.
Wyze Cam v4 Highlights
  • Comes with a 6-foot flat micro USB to USB-A cable included
  • Multiple mounting options: stand, wall mount, ceiling mount, and magnetic adhesive mount
  • Weather-resistant design (IP65 rating) for indoor or outdoor use
  • High-resolution 2.5K QHD video with color night vision
The Wyze Cam v4’s included cable length is similar to the extended cable in the mounting kit for v3, but if you want to power your camera in unique locations, consider the Cam v4 + Lamp Socket v2 Bundle.
Powering Your Wyze Cam with the Cam v4 + Lamp Socket v2 Bundle
For those who want to mount their Wyze Cam v3 or v4 without relying on a nearby outlet, the Cam v4 + Lamp Socket v2 Bundle offers a smart solution.
Features:
  • Powers Wyze Cam v3, v3 Pro, v4, and other compatible models directly from a lamp socket
  • Motion-activated lights add extra security and convenience
  • Dusk to dawn scheduling for automatic lighting control
  • Easy installation with standard E26 lamp socket compatibility
This bundle is ideal for outdoor or hard-to-reach indoor locations where running cables is inconvenient. It provides a clean, integrated power source that blends seamlessly with your existing lighting fixtures.
Tips for Mounting Your Wyze Cam v3 with a Longer Cable
  • Choose the right mounting location: Use the mounting bracket and adhesive to place your camera where it has a clear view and good Wi-Fi signal.
  • Manage the cable neatly: The longer Micro USB cable included in the mounting kit helps avoid tension or damage. Use cable clips or ties to keep it tidy.
  • Consider power options: If no outlet is nearby, the lamp socket bundle can power your camera without extra wiring.
  • Weatherproofing: For outdoor use, ensure your camera and cables are protected from the elements or use accessories designed for outdoor durability.
Summary
For mounting your Wyze Cam v3 with a longer cable, the Wyze Cam Mounting Kit is the best choice, providing a mounting bracket, adhesive, and an extended Micro USB cable for flexible placement. If you want to power your camera from a lamp socket, the Cam v4 + Lamp Socket v2 Bundle supports Wyze Cam v3 and v4 models, offering a convenient and smart power solution. By combining these accessories, you can achieve the perfect setup for your Wyze Cam v3, ensuring optimal coverage and reliable power without compromise.
Wyze Cam Mounted Outdoors Securely mounted Wyze Cam v3 with extended cable for flexible placement Home Security Setup Wyze Cam v3 installed indoors with neat cable management Smart Lamp Socket Power Power your Wyze Cam using the Lamp Socket v2 Bundle for hassle-free installation
FeatureWyze Cam Mounting KitWyze Cam v4Cam v4 + Lamp Socket v2 Bundle
TypeAccessoriesCamerasCameras Bundle
Price$5.99 USD$100.00 USD (single), $35.98 USD (discounted)$49.96 USD
DescriptionMounting kit for Wyze Cam v2/v3/v3 Pro. Includes mounting bracket, adhesive, longer Micro USB cable.2.5K QHD resolution, Enhanced Color Night Vision, motion-activated spotlight, 24/7 local recording, Wi-Fi 6, Alexa & Google Assistant compatible.Powers Cam v4 without outlet using latest lamp socket. Includes Wyze Cam v4 and Lamp Socket v2.
CompatibilityWyze Cam v2, v3, v3 ProN/AWyze Cam v4
Included ItemsWall Plate x1, USB Extension Cable 5ft x1, Adhesive Tape x1, Screw Set x1N/AWyze Cam v4, Lamp Socket v2
Color OptionsN/AWhite, Grey, Black, ClearWhite
Mounting AccessoriesYesNoNo
Power SourceN/APlug-inPowered via Lamp Socket (no outlet needed)
Weather ResistanceN/AIP65IP65 (via Cam v4)
Field of ViewN/ADFOV 115.8°, HFOV 98.5°, VFOV 53.1°Same as Cam v4
SensorN/ACMOS Starlight SensorSame as Cam v4
How can I mount my Wyze Cam v3 with a longer cable?You can mount your Wyze Cam v3 with a longer cable by using the Wyze Cam Mounting Kit. This kit includes a mounting bracket, strong adhesive, and an extended Micro USB cable, allowing you to place your camera farther from a power outlet for optimal placement.
What is included in the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit comes with a secure mounting bracket, strong adhesive for wall or ceiling installation, and a longer Micro USB cable to extend your camera’s power source connection.
Is the Wyze Cam Mounting Kit compatible with all Wyze Cam models?The Wyze Cam Mounting Kit is compatible with Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro. For Wyze Cam v4, the camera comes with its own mounting accessories and cable.
How long is the cable included in the Wyze Cam v4?The Wyze Cam v4 includes a 6-foot flat micro USB to USB-A cable, which is similar in length to the extended cable provided in the Wyze Cam Mounting Kit for v3.
What are the mounting options for Wyze Cam v4?Wyze Cam v4 offers multiple mounting options, including stand, wall mount, ceiling mount, and magnetic adhesive mount. It also features a weather-resistant design for both indoor and outdoor use.
How can I power my Wyze Cam v3 or v4 if there is no nearby outlet?You can use the Cam v4 + Lamp Socket v2 Bundle to power your Wyze Cam v3, v3 Pro, or v4 directly from a standard E26 lamp socket. This bundle provides a clean and convenient power solution, especially for outdoor or hard-to-reach locations.
What are the benefits of the Cam v4 + Lamp Socket v2 Bundle?The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam directly from a lamp socket, features motion-activated lights for added security, supports dusk to dawn scheduling, and is easy to install with standard E26 lamp sockets.
How do I manage the cable when mounting my Wyze Cam v3?Use the longer Micro USB cable included in the mounting kit to avoid tension or damage. For a neat and professional look, use cable clips or ties to keep the cable tidy and out of sight.
Is the Wyze Cam Mounting Kit suitable for outdoor use?Yes, the Wyze Cam Mounting Kit can be used outdoors. However, ensure that your camera and cables are protected from the elements or use additional weatherproof accessories for outdoor durability.
How much does the Wyze Cam Mounting Kit cost?The Wyze Cam Mounting Kit is affordably priced at just $5.99, making it a cost-effective solution for mounting your Wyze Cam with an extended cable.
