Durable Long USB Extension Cable for Wyze Cam
When it comes to protecting your Wyze Cam from power interruptions, having a durable, long USB extension cable is essential. The
Wyze Cam USB Extension Cable - 20ft is designed specifically to extend the reach of your Wyze cameras, ensuring uninterrupted power supply and flexible installation options. Whether you have indoor or outdoor Wyze cameras, this cable provides the durability and length you need to keep your security system running smoothly.
Wyze Cam USB Extension Cable - 20ft: Reliable Power Extension
Key Features:
- Length: 20 feet, providing ample reach to connect your Wyze Cam to power sources far away.
- Compatibility: Works seamlessly with Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, OG Standard, and OG Telephoto models.
- Durability: Rated IP67 weatherproof, this cable withstands harsh outdoor conditions, from rain to snow, ensuring reliable power delivery.
- Build Quality: Features AWG 18# wire for stable 5V 2A output power, minimizing voltage drops over long distances.
- Connector Type: USB Type A Male to Female for easy plug-and-play connection.
Protect your Wyze Cam from power interruptions with a cable that’s built to last and designed for flexibility.
Compatible Wyze Cameras for Extended Power Solutions
Wyze Cam v4: Advanced Wired Security Camera
- Resolution: Crystal-clear 2.5K QHD (2560x1440) for sharp video quality.
- Night Vision: Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens).
- Connectivity: Supports Wi-Fi 6 and 2.4 GHz Wi-Fi for faster, more reliable streaming.
- Storage: Local microSD card support up to 512GB plus cloud storage options.
- Weatherproof: IP65 rating for outdoor use.
- Power: Comes with a 6-foot flat micro USB to USB-A cable; extendable with the 20ft USB extension cable.
- Smart Features: Alexa, Google Assistant, and IFTTT integrations.
The Wyze Cam v4 is perfect for users who want high-resolution wired cameras with flexible mounting and power options. Using the 20ft USB extension cable allows you to position the camera exactly where you need it without worrying about proximity to power outlets.
Wyze Cam OG: The Next Generation Wired Camera
- Field of View: Wide 120° for comprehensive coverage.
- Built-in Spotlight & Siren: 40-lumen spotlight and 90-decibel siren to deter intruders.
- Weather Resistance: IP65 rating for reliable outdoor use.
- Performance: 3X faster notifications and improved 2-way audio.
- Power: Wired connection with USB power; extendable with the 20ft USB extension cable.
- Versatility: Suitable for indoor and outdoor use.
The Wyze Cam OG offers a great balance of wired reliability and smart features, enhanced by the ability to extend power cables for flexible installation.
Wyze Battery Cam Pro: Wireless Freedom with Optional Solar Power
- Resolution: 2.5K HDR video for crystal-clear images.
- Power Options: Wire-free with removable rechargeable batteries; can be converted to solar power with Wyze Solar Panel.
- Weatherproof: IP65 rating for all-weather durability.
- Motion Detection: Radar + PIR sensors for precise alerts.
- Spotlight & Siren: Integrated 150-lumen spotlight and siren for active deterrence.
- Local Storage: Supports microSD cards for local recording.
- Extension Cable Use: While primarily wireless, the Wyze Battery Cam Pro can benefit from accessories like the USB extension cable when used with charging docks or solar panels.
This camera is ideal for users who want wireless flexibility but also want options to maintain power continuity through accessories.
Why Choose the Wyze Cam USB Extension Cable?
- Avoid Power Interruptions: Long cable length means you can connect your camera to a stable power source even if it’s far from the camera location.
- Weatherproof Design: IP67 rating ensures the cable withstands outdoor elements, making it perfect for outdoor cameras.
- Universal Compatibility: Works with a wide range of Wyze cameras, making it a versatile accessory.
- Easy Installation: USB Type A Male to Female connectors allow simple plug-and-play setup without technical hassle.
Enhance Your Wyze Cam Setup with Reliable Power
Using the
Wyze Cam USB Extension Cable - 20ft ensures your Wyze cameras stay powered without interruption, especially in outdoor or hard-to-reach locations. Pair it with your Wyze Cam v4, Wyze Cam OG, or even the Wyze Battery Cam Pro accessories to maximize your home security system’s reliability and coverage.
Wyze Cam Pan v3 weatherproof outdoor camera in action
Enjoy clear two-way audio communication with Wyze cameras
Summary of Products for Power-Extended Wyze Cam Protection
- Wyze Cam USB Extension Cable - 20ft: Durable, weatherproof cable to extend power reach for Wyze cameras.
- Wyze Cam v4: Wired 2.5K QHD camera with advanced night vision and Wi-Fi 6.
- Wyze Cam OG: Wired camera with built-in spotlight, siren, and fast notifications.
- Wyze Battery Cam Pro: Wireless battery camera with solar power option and integrated spotlight.
Ensure your Wyze Cam system is always powered and protected with the right accessories and cameras tailored to your needs.
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze cameras, ensuring a reliable and uninterrupted power supply. It allows you to connect your camera to power sources that are farther away, providing flexible installation options for both indoor and outdoor setups.Which Wyze cameras are compatible with the 20ft USB extension cable?
The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, OG Standard, and OG Telephoto models. It also works with Wyze Battery Cam Pro when used with charging docks or solar panels.Is the Wyze Cam USB Extension Cable weatherproof?
Yes, the Wyze Cam USB Extension Cable is rated IP67 weatherproof, making it suitable for outdoor use. It can withstand harsh conditions such as rain and snow, ensuring reliable power delivery to your cameras.How long is the Wyze Cam USB Extension Cable?
The Wyze Cam USB Extension Cable is 20 feet long, providing ample reach to connect your camera to distant power sources.What type of connectors does the Wyze Cam USB Extension Cable use?
The cable features USB Type A Male to Female connectors, allowing for easy plug-and-play installation with your Wyze cameras.Can I use the 20ft USB extension cable with Wyze Cam v4?
Yes, the Wyze Cam v4 comes with a 6-foot cable, but you can use the 20ft USB extension cable to extend its power reach, allowing for more flexible camera placement.Is the Wyze Cam USB Extension Cable suitable for outdoor cameras?
Absolutely. The cable's IP67 weatherproof rating and durable construction make it ideal for outdoor Wyze cameras, ensuring consistent power even in challenging weather conditions.Does the Wyze Cam USB Extension Cable support stable power delivery over long distances?
Yes, the cable uses AWG 18# wire to provide stable 5V 2A output power, minimizing voltage drops and ensuring your Wyze cameras receive consistent power even over the 20ft length.Can I use the Wyze Cam USB Extension Cable with the Wyze Battery Cam Pro?
While the Wyze Battery Cam Pro is primarily wireless, you can use the USB extension cable with charging docks or solar panels to maintain power continuity and reduce downtime.How easy is it to install the Wyze Cam USB Extension Cable?
Installation is simple and hassle-free thanks to the USB Type A Male to Female connectors. Just plug the cable into your camera and power source for immediate use.
