20ft Durable USB Extension Cable for Wyze Cam Power Protection
Durable Long USB Extension Cable for Wyze Cam
If you're looking to protect your Wyze Cam from power interruptions and extend its reach, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. This durable, long cable allows you to position your Wyze Cam exactly where you need it without worrying about short cable limitations or power disruptions.
Key Features of Wyze Cam USB Extension Cable - 20ft
  • Length: 20 feet of flexible, high-quality USB cable to extend your camera’s power source.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Durability: Designed to withstand everyday use, ensuring reliable power delivery and protection against interruptions.
  • Ease of Use: Simply plug in to extend your camera’s power without any complicated setup.
This cable is an essential accessory for anyone wanting to install their Wyze Cam in hard-to-reach places or areas where power outlets are not conveniently located.
Enhance Your Wyze Cam Setup with Compatible Accessories
While the 20ft USB extension cable is ideal for wired Wyze Cams, you might also consider other Wyze products that complement your security setup.
Wyze Battery Cam Pro – Wireless Freedom with Power Backup
For those who want to avoid cables altogether, the Wyze Battery Cam Pro offers a wire-free security solution with rechargeable battery packs and optional solar panel power. This camera delivers:
  • 2.5K HDR video resolution for crystal-clear footage.
  • Integrated spotlight and siren for enhanced security.
  • Radar + PIR motion detection for precise alerts.
  • IP65 weatherproof rating to withstand outdoor conditions.
  • Flexible power options including removable batteries and solar charging.
While the Battery Cam Pro doesn’t require a USB extension cable, it’s a great alternative if you want to avoid power interruptions without relying on wired connections.
Wyze Cam Pan v3 USB Cable – Replacement Option
If you own a Wyze Cam Pan v3 and need a replacement or additional USB cable, the Wyze Cam Pan v3 USB Cable is a compact and affordable option. It’s designed specifically for the Pan v3 model, ensuring compatibility and reliable power delivery.
Why Choose a Long USB Extension Cable for Your Wyze Cam?
Extending your Wyze Cam’s power cable with a durable 20ft USB extension means you can install your camera in the optimal location for security without being limited by outlet placement. This helps prevent power interruptions that could leave your home unprotected.
Using a long extension cable:
  • Provides flexibility in camera placement.
  • Helps avoid power outages caused by loose or short cables.
  • Ensures continuous monitoring with stable power supply.
  • Is cost-effective and easy to install.
Summary of Recommended Products for Power and Connectivity
Product NameTypeKey BenefitPrice (Approx.)
Wyze Cam USB Extension Cable - 20ftAccessoriesLong, durable cable for Wyze Cams$7.99
Wyze Battery Cam ProCamerasWire-free, rechargeable battery cam$89.98
Wyze Cam Pan v3 USB CableReplacement PartsReplacement USB cable for Pan v3$1.99
Home Security Setup with Wyze Cam Alt text: Home security camera installed outdoors with extended USB cable
Protect your Wyze Cam from power interruptions and enjoy flexible installation options with the Wyze Cam USB Extension Cable - 20ft. Whether you prefer wired or wireless setups, Wyze offers accessories and cameras to keep your home secure around the clock.
FeatureWyze Cam USB Extension Cable - 20ftWyze Battery Cam ProWyze Cam Pan v3 USB Cable
Product TypeAccessoriesCamerasReplacement Parts
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Std, OG TelephotoWyze Battery Cam ProWyze Cam Pan v3
Cable Length20 ftN/AReplacement USB cable (length not specified)
Price$7.99$89.98 (1 Pack)$1.99
WirelessNoYesNo
Power SourceUSBRemovable, Rechargeable Battery PacksUSB
Video ResolutionN/A2.5K HDR (2560 x 1440)N/A
WeatherproofNoIP65No
Motion DetectionNoRadar + PIR Motion DetectionNo
Spotlight & SirenNoIntegrated Spotlight & SirenNo
Battery LifeN/AUp to 6 MonthsN/A
Local StorageN/ASupports microSD cards up to 256 GBN/A
Price$7.99$89.98$1.99
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power source, allowing you to install your camera in hard-to-reach places or areas far from power outlets. It helps prevent power interruptions and ensures continuous monitoring.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
How durable is the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable is made from high-quality materials and is designed to withstand everyday use, providing reliable power delivery and protection against power interruptions.
Is the Wyze Cam USB Extension Cable easy to install?Yes, the Wyze Cam USB Extension Cable is very easy to use. Simply plug it in to extend your camera’s power—no complicated setup is required.
Can I use the Wyze Cam USB Extension Cable outdoors?While the cable is durable and suitable for everyday use, it is recommended to ensure proper weatherproofing if used outdoors, especially at connection points, to maintain reliable performance.
What are the benefits of using a long USB extension cable for Wyze Cam?Using a long USB extension cable provides flexibility in camera placement, helps avoid power outages caused by short or loose cables, ensures continuous monitoring with a stable power supply, and is a cost-effective, easy-to-install solution.
Is there a replacement USB cable for Wyze Cam Pan v3?Yes, the Wyze Cam Pan v3 USB Cable is available as a compact and affordable replacement or additional cable, designed specifically for the Pan v3 model to ensure compatibility and reliable power delivery.
What is the price of the Wyze Cam USB Extension Cable - 20ft?The Wyze Cam USB Extension Cable - 20ft is priced at approximately $7.99.
Are there wireless alternatives to using a USB extension cable with Wyze Cams?Yes, the Wyze Battery Cam Pro is a wireless security camera that operates on rechargeable battery packs and can be powered by an optional solar panel. It offers wire-free installation, 2.5K HDR video, integrated spotlight and siren, radar + PIR motion detection, and an IP65 weatherproof rating.
Do I need a USB extension cable for the Wyze Battery Cam Pro?No, the Wyze Battery Cam Pro does not require a USB extension cable, as it is a wire-free camera powered by rechargeable batteries and can also be charged with a solar panel.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Is the Wyze Cam USB Extension Cable compatible with all Wyze Cam models?Do you have any ongoing sales or discounts for Wyze products?
