Durable Cameras Built to Withstand Extreme Weather
When it comes to home security, having a camera that can endure both scorching summer heat and freezing winter chills is essential. Wyze offers a range of durable, weatherproof cameras designed to provide reliable protection year-round. Whether you need a wire-free solution or a solar-powered option, Wyze’s Battery Cam Pro lineup ensures your property stays monitored in any climate.
Wyze Battery Cam Pro: Ultimate Weatherproof Wireless Security
Rugged and Reliable for All Seasons
The
Wyze Battery Cam Pro is engineered with an IP65 weatherproof rating, making it resistant to dust, rain, and snow. This camera thrives in temperatures ranging from -4°F to 122°F (-20°C to 50°C), perfect for both blistering summers and freezing winters. Its durable build ensures continuous operation without the need for a power outlet or complex wiring.
High-Definition Video and Smart Detection
Capture every detail with 2.5K HDR video resolution and color night vision. The camera’s dual motion detection system combines radar and PIR sensors for precise alerts, reducing false alarms. Customize detection zones via the Wyze app to focus on what matters most.
Flexible Power Options
The Battery Cam Pro features removable, rechargeable battery packs that last up to six months on a single charge. Hot-swap batteries easily to avoid downtime. For extended use, pair it with the Wyze Battery Charging Dock to charge two batteries simultaneously.
“No wires. No hubs. The ultimate battery-operated go-anywhere, see-everything home security camera.”
Wyze Battery Cam Pro mounted outdoors, showcasing its weatherproof design.
Wyze Battery Cam Pro + Solar Panel: Continuous Power, Zero Hassle
Solar-Powered Security for Endless Monitoring
Take your Wyze Battery Cam Pro to the next level with the
Wyze Battery Cam Pro + Solar Panel bundle. The integrated solar panel converts sunlight into power, significantly reducing the need for manual recharging. This eco-friendly solution is ideal for remote locations or users seeking hassle-free, continuous surveillance.
Same Robust Features, Enhanced Endurance
Enjoy all the benefits of the Battery Cam Pro—2.5K HDR video, radar + PIR motion detection, IP65 weather resistance—plus the added advantage of solar power. The solar panel itself is also IP65 rated, ensuring durability in harsh weather conditions.
Easy Setup and Smart Connectivity
Supports dual-band Wi-Fi (2.4 & 5 GHz) and instant BluetoothⓇ setup for quick installation. Control the integrated 150-lumen spotlight and siren remotely via the Wyze app for added security during nighttime or low-light conditions.
Bird Feeder Wireless Camera Bundle: Security Meets Nature Watching
Weather-Resistant Bundle for Outdoor Enthusiasts
The
Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, Wyze Solar Panel, and a vibrant Wyze Bird Feeder. This bundle is perfect for those who want to secure their property while enjoying birdwatching. The bird feeder is designed with weather-resistant polycarbonate and holds up to 1 liter of seed, attracting a variety of birds.
Capture Every Feathered Visitor
Use the Wyze Battery Cam Pro’s 2.5K HDR video and color night vision to watch and record live footage of birds visiting your feeder. The camera’s IP65 rating ensures it withstands rain, snow, and heat, making it a reliable companion for all seasons.
Smart Home Integration
Compatible with Alexa, Google Assistant, and IFTTT, this bundle fits seamlessly into your smart home ecosystem. Monitor your yard and enjoy nature’s beauty without compromising on security.
Wyze Cam Floodlight Pro: Bright, Smart, and Weatherproof
Powerful Lighting Meets Advanced Security
For those who want to illuminate large outdoor areas while maintaining security, the
Wyze Cam Floodlight Pro offers a 180° wide-angle lens paired with 2.5K QHD video resolution. Its 3,000 lumens of adjustable LED light provide bright, clear visibility, deterring intruders effectively.
Weatherproof and Built to Last
Rated IP65 for water resistance and capable of operating in temperatures from -4°F to 140°F (-20°C to 60°C), this floodlight camera is designed to endure extreme weather conditions. Its matte finish and robust build make it a stylish yet tough addition to any home exterior.
Intelligent Motion Detection and Alerts
Equipped with AI-powered computer vision, the Floodlight Pro detects people and vehicles, activating lights and sirens only when necessary. This smart detection reduces false alarms and enhances your home’s security.
Wyze Cam Floodlight Pro providing bright security lighting during nighttime.
Accessories to Maximize Your Wyze Battery Cam Pro Experience
Wyze Removable Battery Pack
Extend your camera’s uptime with a 6200mAh rechargeable battery pack. Designed for easy hot-swapping, it supports operation in temperatures from -4°F to 122°F and charges via USB-C in about 9 hours.
Charge two battery packs simultaneously with this compact dock. It’s perfect for keeping your cameras powered without interruption, ensuring your security system is always ready.
Why Choose Wyze Cameras for Extreme Weather?
Wyze cameras combine cutting-edge technology with rugged durability, making them ideal for users who demand reliable security in all climates. Their IP65 weatherproof rating, flexible power options including solar, and smart detection features provide peace of mind whether it’s the heat of summer or the chill of winter.
Protect your home with Wyze’s durable, high-performance cameras designed to withstand the elements and keep you connected no matter the season.
Are Wyze cameras weatherproof and suitable for extreme weather conditions?
Yes, Wyze cameras such as the Wyze Battery Cam Pro and Wyze Cam Floodlight Pro are engineered with an IP65 weatherproof rating. They are designed to withstand dust, rain, snow, and operate in temperatures ranging from -4°F to 122°F (-20°C to 50°C) for the Battery Cam Pro, and up to 140°F (60°C) for the Floodlight Pro, making them ideal for both hot summers and cold winters.What video quality do Wyze outdoor security cameras offer?
Wyze outdoor security cameras, including the Battery Cam Pro and Floodlight Pro, provide high-definition 2.5K HDR video resolution. This ensures clear, detailed footage both day and night, with features like color night vision for enhanced visibility in low-light conditions.How does the Wyze Battery Cam Pro detect motion and reduce false alarms?
The Wyze Battery Cam Pro uses a dual motion detection system that combines radar and PIR (Passive Infrared) sensors. This advanced setup allows for precise motion alerts and reduces false alarms. Users can also customize detection zones through the Wyze app to focus on specific areas.What power options are available for Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features removable, rechargeable battery packs that can last up to six months on a single charge. For continuous power, it can be paired with the Wyze Solar Panel, which converts sunlight into energy, or the Wyze Battery Charging Dock, which charges two batteries simultaneously for easy hot-swapping.Is the Wyze Battery Cam Pro easy to install and set up?
Yes, the Wyze Battery Cam Pro is designed for easy installation with no wires or hubs required. It supports dual-band Wi-Fi (2.4 & 5 GHz) and instant Bluetooth setup, allowing for quick and hassle-free installation.Can Wyze cameras be integrated with smart home systems?
Absolutely. Wyze cameras, including those in the Bird Feeder Wireless Camera Bundle, are compatible with Alexa, Google Assistant, and IFTTT. This allows seamless integration into your existing smart home ecosystem for convenient monitoring and control.What is included in the Wyze Bird Feeder Wireless Camera Bundle?
The Wyze Bird Feeder Wireless Camera Bundle includes the Wyze Battery Cam Pro, Wyze Solar Panel, and a weather-resistant Wyze Bird Feeder. This bundle is perfect for outdoor enthusiasts who want to enjoy birdwatching while maintaining property security.How does the Wyze Cam Floodlight Pro enhance outdoor security?
The Wyze Cam Floodlight Pro combines a 180° wide-angle lens with 2.5K QHD video resolution and 3,000 lumens of adjustable LED lighting. It features AI-powered computer vision for intelligent motion detection, activating lights and sirens only when people or vehicles are detected, which helps deter intruders and reduce false alarms.What accessories are available to extend the performance of Wyze Battery Cam Pro?
Wyze offers a removable 6200mAh rechargeable battery pack for extended uptime and a Battery Charging Dock that can charge two battery packs simultaneously. These accessories ensure your Wyze Battery Cam Pro remains powered and operational without interruption.Why should I choose Wyze cameras for home security in harsh climates?
Wyze cameras are built with rugged durability and advanced technology, including IP65 weatherproof ratings, flexible power options like solar charging, and smart detection features. They provide reliable, year-round security and peace of mind, regardless of extreme weather conditions.
