Wyze Duo Cam Doorbell: Secure Cloud & Local Storage Solutions
Secure Doorbell Cam with Cloud and Local Storage: Wyze Duo Cam Doorbell Solutions
When it comes to protecting your home entrance, having a reliable doorbell camera with secure cloud storage and optional local storage is essential. Wyze offers a standout option with the Wyze Video Doorbell v2, delivering crystal-clear 2K video, two-way audio, and flexible storage options that keep you connected and in control. Alongside, Wyze’s range of cameras like the Wyze Cam v4 and Wyze Cam Pan v3 complement your home security setup with advanced features and robust weather resistance.
Wyze Video Doorbell v2: The Ultimate Wired Doorbell Camera
Crystal-Clear 2K Video & Head-to-Toe Coverage
Wyze Video Doorbell v2 captures your porch activity in stunning 2K resolution, providing detailed video that lets you see visitors clearly from head to toe. This high-definition clarity ensures you never miss a moment, whether it’s a delivery or an unexpected visitor.
Dual Storage: Local microSD & Cloud Options
This doorbell cam is unique with its onboard microSD card slot, enabling 24/7 continuous local recording without relying solely on cloud storage. You can also opt for Wyze’s Cam Plus subscription for unlimited cloud video storage and AI-powered smart detections like person, package, and vehicle notifications.
Two-Way Audio & Motion-Activated Voice Deterrence
Communicate instantly with visitors using the built-in two-way talk feature via the Wyze app. Plus, activate motion-activated voice deterrence to warn off unwanted guests with an automated voice prompt, enhancing your porch security.
Easy Integration & Weatherproof Design
Wyze Video Doorbell v2 works seamlessly with your existing home chime thanks to the included chime controller, preserving the traditional doorbell sound. Rated IP65 weatherproof, it withstands rain, snow, and harsh weather conditions, ensuring reliable performance year-round.
“Answer your door from anywhere with our clearest and most capable wired video doorbell yet.”
Wyze Video Doorbell Lifestyle Stay connected to your front door with Wyze Video Doorbell v2.
Wyze Cam v4: High-Definition Security with Local and Cloud Storage
Stunning 2.5K QHD Resolution & Enhanced Color Night Vision
Wyze Cam v4 offers unmatched image clarity with 2.5K Quad HD video and enhanced color night vision, revealing vibrant details even in low-light conditions. This makes it perfect for monitoring your home day and night.
24/7 Local Recording & Wi-Fi 6 Support
Like the doorbell cam, Wyze Cam v4 supports continuous local recording to a microSD card (up to 256GB), so you never miss a moment without needing a subscription. It also supports Wi-Fi 6 for a stronger, more reliable connection.
Motion-Activated Spotlight & Siren
The integrated spotlight activates on motion detection to illuminate your property, while the built-in siren can be triggered to deter intruders, adding an extra layer of security.
Smart Home Compatibility & Easy Setup
Wyze Cam v4 works with Alexa, Google Assistant, and IFTTT, allowing voice control and automation. Its screw-free magnetic mount and Bluetooth setup make installation quick and hassle-free.
Wyze Cam Pan v3: 360° Coverage with Local Storage Flexibility
Full 360° Horizontal & 180° Vertical View
Wyze Cam Pan v3 offers dynamic pan and tilt capabilities, covering every angle with a 120° field of view and 8x digital zoom. This makes it ideal for monitoring large areas indoors or outdoors.
Continuous Local Storage & IP65 Weather Resistance
Supports microSD cards up to 256GB for local recording, ensuring your footage is stored securely without monthly fees. Its IP65 rating means it’s built to withstand rain, snow, and dust, perfect for outdoor use with the optional Wyze Outdoor Power Adapter.
Two-Way Audio & Smart Alerts
Communicate with visitors or family members through the built-in speaker and microphone with noise and echo cancellation. Receive push notifications for motion alerts directly on your phone.
“Wyze Cam Pan v3 is a versatile security camera that adapts to your home’s needs with 360° coverage and reliable local storage.”
Wyze Cam Pan v3 in Snow Robust outdoor security with Wyze Cam Pan v3, even in snowy conditions.
Why Choose Wyze for Your Doorbell Cam and Security Needs?
  • Flexible Storage Options: Choose between local microSD storage for continuous recording or cloud storage with smart AI detections.
  • High-Resolution Video: From 2K to 2.5K QHD, Wyze cameras deliver crisp, detailed footage.
  • Weatherproof & Durable: IP65-rated devices ensure reliable performance in all weather conditions.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless automation.
  • Two-Way Audio & Voice Deterrence: Communicate with visitors and deter unwanted guests remotely.
Wyze’s doorbell cam and security cameras provide a comprehensive, secure, and smart solution to protect your home with the convenience of both cloud and local storage.
Summary of Featured Products
Product NameVideo ResolutionStorage OptionsKey FeaturesWeatherproofPrice Range
Wyze Video Doorbell v22KLocal microSD + CloudTwo-way audio, voice deterrenceIP65$44.98+
Wyze Cam v42.5K QHDLocal microSD + CloudSpotlight, siren, Wi-Fi 6 supportIP65$35.98+
Wyze Cam Pan v31080pLocal microSD360° pan/tilt, two-way audioIP65$39.98+
FeatureWyze Video Doorbell v2Wyze Cam v4Wyze Cam Pan v3
TypeWired Video DoorbellWired Security CameraWired Pan & Tilt Security Camera
Video Resolution2K (approx. 2560x1440)2.5K QHD (2560x1440)1080p (1920x1080)
Field of View (FOV)Head-to-toe view (exact degrees not specified)115.8° DFOV, 98.5° HFOV, 53.1° VFOV120° FOV
Pan & TiltNoNo360° horizontal, 180° vertical
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night Vision4 IR LEDs (850 nm) B&W Night Vision
AudioTwo-way audioEnhanced two-way talk, 99dB waterproof speakerTwo-way audio with noise & echo cancellation
Motion DetectionYes, with motion-activated voice deterrenceYes, with motion detection zonesYes, push notifications
Local StoragemicroSD card slot (continuous local recording)microSD card up to 512GB (continuous local recording)Supports up to 256GB microSD (ExFAT format)
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Weather ResistanceIP65IP65IP65
Power SourceWiredWiredWired
Mounting OptionsDoorbell + Chime Controller includedStand, Wall, Ceiling, Magnetic wall mountScrew mount (1/4"-20), indoor/outdoor
Special FeaturesPre-roll motion recording (3-6 seconds), works with existing chime, motion-activated voice deterrenceMotion-activated spotlight, siren, Wi-Fi 6 support, AI auto-zoom tracking360° pan and 180° tilt, redesigned for indoor/outdoor use
DimensionsNot specified2in x 2in x 2 3/8in (approx.)124mm x 60mm x 63mm
WeightNot specified0.49 lb (222 g)11.29 oz (320 g)
ConnectivityWi-Fi (2.4 GHz)Wi-Fi 6, Bluetooth 5.2Wi-Fi 2.4 GHz (no 5 GHz support)
IntegrationsAlexa, Google HomeAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
WarrantyNot specified1 Year1 Year
What are the main features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 offers crystal-clear 2K video resolution, head-to-toe coverage, two-way audio, motion-activated voice deterrence, and flexible storage options including both local microSD and cloud storage. It is also IP65 weatherproof and integrates easily with your existing home chime.
Does the Wyze Video Doorbell v2 support both cloud and local storage?Yes, the Wyze Video Doorbell v2 supports dual storage options. You can use a microSD card for 24/7 continuous local recording or subscribe to Wyze’s Cam Plus for unlimited cloud video storage and AI-powered smart detections.
What is the video resolution of Wyze security cameras?Wyze security cameras offer high-definition video, with the Wyze Video Doorbell v2 providing 2K resolution, Wyze Cam v4 offering 2.5K QHD resolution, and Wyze Cam Pan v3 delivering 1080p video.
Are Wyze cameras weatherproof and suitable for outdoor use?Yes, Wyze Video Doorbell v2, Wyze Cam v4, and Wyze Cam Pan v3 are all rated IP65 weatherproof, making them suitable for outdoor use in rain, snow, and harsh weather conditions.
Can I use Wyze cameras without a subscription?Yes, you can use Wyze cameras without a subscription by utilizing local microSD card storage for continuous recording. However, subscribing to Cam Plus unlocks additional features like unlimited cloud storage and AI-powered smart alerts.
What smart home platforms are Wyze cameras compatible with?Wyze cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and seamless smart home automation.
How does the two-way audio feature work on Wyze cameras?The two-way audio feature allows you to communicate with visitors or family members through the Wyze app using the camera’s built-in speaker and microphone. This feature is available on Wyze Video Doorbell v2, Wyze Cam v4, and Wyze Cam Pan v3.
What is the storage capacity supported by Wyze cameras for local recording?Wyze Cam v4 and Wyze Cam Pan v3 support microSD cards up to 256GB for continuous local recording, ensuring you have ample storage for your security footage.
What security features are included in Wyze Cam v4?Wyze Cam v4 features 2.5K QHD video, enhanced color night vision, a motion-activated spotlight, a built-in siren, 24/7 local recording, Wi-Fi 6 support, and compatibility with major smart home platforms.
What makes Wyze Cam Pan v3 suitable for large area monitoring?Wyze Cam Pan v3 offers full 360° horizontal and 180° vertical pan and tilt capabilities, a 120° field of view, and 8x digital zoom, making it ideal for monitoring large indoor or outdoor areas.
How easy is it to install Wyze security cameras?Wyze cameras are designed for easy installation. Wyze Cam v4 features a screw-free magnetic mount and Bluetooth setup, while the Wyze Video Doorbell v2 includes a chime controller for seamless integration with your existing doorbell system.
What are the benefits of choosing Wyze for home security?Wyze offers flexible storage options, high-resolution video, weatherproof and durable devices, smart home integration, two-way audio, and advanced security features like voice deterrence and AI-powered alerts, providing a comprehensive and affordable home security solution.
What are the key features of the Wyze Video Doorbell v2?How does the local storage option work for the Wyze Video Doorbell v2?Are there any ongoing promotions or discounts for the Wyze Video Doorbell v2?
