Secure Your Home with Video Doorbells Featuring Cloud Storage and Two-Way Audio
When it comes to protecting your home’s entryway, a video doorbell with cloud storage and two-way audio is essential. These smart devices not only let you see who’s at your door in real-time but also allow you to communicate directly with visitors from anywhere. Whether you want to deter unwanted guests, receive package deliveries safely, or simply stay connected with your front porch, the right video doorbell can make all the difference.
Explore the top Wyze video doorbells designed for secure entry, offering crystal-clear video, reliable cloud storage, and seamless two-way communication.
Wyze Video Doorbell v2: Wired 2K Video with Local and Cloud Storage
Experience clear, detailed porch protection with Wyze Video Doorbell v2.
The Wyze Video Doorbell v2 is a wired smart doorbell that delivers stunning 2K video resolution, ensuring you never miss a detail at your doorstep. Equipped with a local microSD card slot, it supports continuous 24/7 local recording, so you can review footage anytime without relying solely on cloud storage.
Key Features:
- 2K HD Video Quality: Capture head-to-toe views with crystal-clear detail.
- Local microSD Storage: Continuous recording with no monthly fees.
- Two-Way Audio: Speak directly to visitors via the Wyze app.
- Motion-Activated Voice Deterrence: Automatically warns visitors they’re being recorded (requires Cam Plus subscription).
- Works with Existing Chimes: Includes a chime controller to keep your traditional doorbell sounds.
- Pre-Roll Motion Recording: Records 3-6 seconds before motion events for full context.
- Weatherproof (IP65): Durable in all weather conditions.
- Smart Home Integration: Compatible with Alexa and Google Home for voice commands and live feed viewing.
This doorbell is perfect for homeowners who want a wired solution with both local and cloud storage options, plus advanced AI-powered alerts through Cam Plus.
Wyze Video Doorbell Pro: Flexible Wired or Wireless Installation with HD Video
Install wired or wire-free in minutes with Wyze Video Doorbell Pro.
For those seeking installation flexibility, the Wyze Video Doorbell Pro offers both wired and battery-powered wireless options. This model boasts a wider ultra-wide viewing angle and HD video quality, making it easy to monitor your entire porch and beyond.
Highlights:
- Wired or Wireless: Choose the installation method that suits your home.
- Ultra-Wide Viewing Angle: See your entire front porch and even the street.
- Fast Notifications: Includes a dual-band Wi-Fi Extender chime for instant alerts.
- Two-Way Audio & Quick Responses: Talk to visitors or use preset voice replies.
- Motion-Activated Security Light: Blue glow alerts visitors they’re on camera.
- Multiple Chime Sounds: Select from 20 unique tunes, including dog barks to deter intruders.
- Smart Detection with Cam Plus: Person, package, vehicle, and pet detection.
- Smart Home Compatible: Works with Alexa and Google Assistant for voice control.
- Unlock Integration: Pair with Wyze Lock Bolt to remotely unlock your door.
Wyze Video Doorbell Pro is ideal for users who want a premium, versatile doorbell with advanced features and easy installation.
The Front Porch Security Bundle: All-in-One Smart Entry Solution
For comprehensive front porch security, the Wyze Front Porch Security Bundle combines a Wyze Video Doorbell, Wyze Lock, and Wyze Chime into one powerful package.
Bundle Benefits:
- 1080p HD Video Doorbell: View your porch clearly with two-way audio communication.
- Remote Lock/Unlock: Control your door lock from anywhere via the Wyze app.
- Lock History & Motion Events: Monitor who comes and goes with detailed logs.
- Works with Alexa & Google Assistant: Voice control your doorbell and lock.
- Weather-Resistant & Secure: Designed to withstand outdoor conditions with end-to-end encryption.
This bundle is perfect for homeowners looking to upgrade their entire front entry system with seamless integration and enhanced security.
Wyze Duo Cam Battery Doorbell: Dual Cameras and Advanced AI Detection
Dual camera views for complete porch and package monitoring.
The Wyze Duo Cam Battery Doorbell is the most advanced battery-powered option, featuring two cameras for comprehensive coverage: one facing forward and one looking down to monitor packages.
Standout Features:
- Dual 2K and 1080p Cameras: Front camera captures 2K video; bottom camera covers packages in 1080p.
- Two-Way Audio: Communicate with visitors instantly.
- Real-Time AI Alerts: Person, package, and motion detection with voice deterrence.
- Local and Cloud Storage: Supports up to 256GB microSD card for 24/7 local recording plus cloud backup.
- Battery or Hardwired Power: Flexible power options with removable battery pack.
- Weatherproof (IP65): Built to endure harsh outdoor environments.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This doorbell is perfect for those who want the latest technology with dual-camera views and advanced AI for maximum security.
Why Choose a Video Doorbell with Cloud Storage and Two-Way Audio?
A video doorbell with cloud storage ensures your footage is safely backed up offsite, accessible anytime from your smartphone. Two-way audio lets you interact with visitors, whether to greet guests, give delivery instructions, or deter suspicious activity. Together, these features provide peace of mind and enhanced control over your home’s security.
Enhance Your Doorbell Setup with Accessories
For Wyze Video Doorbell v2 users, the
Wyze Video Doorbell v2 Wedge Kit is a must-have accessory. It allows you to adjust the viewing angle perfectly, eliminating blind spots caused by angled door frames or stairs.
Summary of Featured Video Doorbells
Product | Video Quality | Power Type | Storage Options | Two-Way Audio | Special Features |
Wyze Video Doorbell v2 | 2K Wired | Wired | Local microSD + Cloud | Yes | Motion voice deterrence, pre-roll video |
Wyze Video Doorbell Pro | HD Wired/Wireless | Wired or Battery | Cloud (Cam Plus) | Yes | Ultra-wide view, security light, quick responses |
Front Porch Security Bundle | 1080p Wired | Wired | Cloud + Local | Yes | Includes Wyze Lock & Chime |
Wyze Duo Cam Battery Doorbell | Dual 2K + 1080p | Battery or Wired | Local microSD + Cloud | Yes | Dual cameras, AI detections, removable battery |
Invest in a Wyze video doorbell today to secure your home with crystal-clear video, reliable cloud storage, and seamless two-way communication — all designed to keep your front porch safe and connected.
What are the benefits of a video doorbell with cloud storage and two-way audio?
A video doorbell with cloud storage ensures your footage is securely backed up offsite and accessible from your smartphone anytime. Two-way audio allows you to communicate directly with visitors, greet guests, provide delivery instructions, or deter suspicious activity, giving you enhanced control and peace of mind over your home’s security.What features does the Wyze Video Doorbell v2 offer?
The Wyze Video Doorbell v2 provides 2K HD video quality, continuous 24/7 local recording via microSD card, cloud storage options, two-way audio, motion-activated voice deterrence (with Cam Plus), pre-roll motion recording, weatherproof IP65 rating, and compatibility with Alexa and Google Home for smart home integration.Can the Wyze Video Doorbell v2 work with my existing doorbell chime?
Yes, the Wyze Video Doorbell v2 includes a chime controller that allows it to work seamlessly with your existing traditional doorbell chimes.What installation options are available for the Wyze Video Doorbell Pro?
The Wyze Video Doorbell Pro offers both wired and wireless (battery-powered) installation options, making it easy to set up in any home.Does the Wyze Video Doorbell Pro support smart home integration?
Yes, the Wyze Video Doorbell Pro is compatible with Alexa and Google Assistant, allowing for voice control and live feed viewing.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a 1080p HD video doorbell with two-way audio, a Wyze Lock for remote locking and unlocking, and a Wyze Chime. It also offers lock history, motion event logs, weather resistance, and works with Alexa and Google Assistant.What makes the Wyze Duo Cam Battery Doorbell unique?
The Wyze Duo Cam Battery Doorbell features dual cameras—one 2K front-facing camera and one 1080p downward-facing camera for package monitoring. It offers two-way audio, real-time AI alerts for people, packages, and motion, local and cloud storage, flexible power options (battery or wired), and smart home compatibility with Alexa, Google Assistant, and IFTTT.Do Wyze video doorbells support local storage?
Yes, select Wyze video doorbells such as the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell support local storage via microSD cards for continuous 24/7 recording, in addition to cloud storage options.What is the Wyze Video Doorbell v2 Wedge Kit and why should I use it?
The Wyze Video Doorbell v2 Wedge Kit is an accessory that allows you to adjust the viewing angle of your doorbell, helping to eliminate blind spots caused by angled door frames or stairs for optimal coverage.Are Wyze video doorbells weatherproof?
Yes, Wyze video doorbells such as the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell are rated IP65 weatherproof, making them durable and reliable in all outdoor conditions.Can I receive instant notifications with Wyze video doorbells?
Yes, Wyze video doorbells provide fast notifications to your smartphone. The Wyze Video Doorbell Pro also includes a dual-band Wi-Fi Extender chime for instant alerts.Do Wyze video doorbells offer AI-powered alerts?
Yes, with a Cam Plus subscription, Wyze video doorbells can provide AI-powered alerts for people, packages, vehicles, and pets, as well as motion-activated voice deterrence.
