Wyze Video Doorbell v2 with Local microSD Storage
The
Wyze Video Doorbell v2 is a top-tier wired video doorbell designed to keep your home secure with crystal-clear 2K video resolution and convenient local storage options. Perfect for homeowners seeking detailed video capture and reliable local backup, this doorbell offers a comprehensive security solution without relying solely on cloud services.
Stunning 2K Video Quality
Experience sharp and vibrant video with a resolution of 2048 x 1536 pixels, delivering more detail than standard 1080p cameras. The Wyze Video Doorbell v2 uses a 1/2.8" CMOS Starlight Sensor paired with an F2.0 aperture and 2.1mm focal length lens to capture clear images day and night. With a wide 135° horizontal and 103° vertical field of view, you get broad coverage of your front porch or entryway.
- Video Resolution: 2K (2048 x 1536)
- Frame Rate: 20 FPS (day), 15 FPS (night)
- Field of View: 135° horizontal, 103° vertical, 166.8° diagonal
- Night Vision: 6 x 940nm IR lights for clear nighttime monitoring
Local microSD Storage for Privacy and Convenience
One of the standout features of the Wyze Video Doorbell v2 is its support for local microSD card storage up to 256GB (FAT32 format). This allows you to save video footage directly on the device, ensuring you have access to your recordings even without an internet connection or cloud subscription.
- Local Storage: Supports microSD cards up to 256GB
- Flash Memory: 16MB onboard
- Memory: 128MB RAM for smooth operation
Essential Smart Features
Beyond video, the doorbell includes two-way audio with an ECM microphone and 8Ω 1W speaker, enabling real-time conversations with visitors. Motion-activated voice deterrence helps ward off unwanted guests by playing pre-recorded warnings. Real-time alerts notify you instantly when someone approaches your door.
- Two-Way Audio: Talk and listen through the Wyze app
- Motion-Activated Voice Deterrence: Scare off intruders automatically
- Connectivity: Wi-Fi 2.4GHz b/g/n (IEEE802.11 b/g/n)
- Integrations: Works with Alexa, Google Assistant, and IFTTT
Durable and Weather-Resistant Design
Built to withstand outdoor conditions, the Wyze Video Doorbell v2 features an IP65 weather resistance rating, making it suitable for all seasons and climates. Its polycarbonate body and resin lens ensure durability and longevity.
- Weather Resistance: IP65 certified
- Operating Temperature: -4°F to 122°F (-20°C to 50°C)
- Storage Temperature: -40°F to 176°F (-40°C to 80°C)
Included in the Package
The doorbell comes with everything needed for installation and operation:
- Wyze Video Doorbell v2 unit
- Wyze Chime Controller for indoor alerts
- Wall plate and 30° wedge for angled mounting
- Installation kit with screws, wire caps, and extension wires
- Quick Start Guide for easy setup
Refurbished Wyze Video Doorbell v2 – Same Features, Better Price
For budget-conscious buyers, the
Refurbished Wyze Video Doorbell v2 offers the same premium features as the new model but at a reduced price. Each refurbished unit is fully tested and guaranteed to work like new, providing excellent value without compromising on quality or functionality.
- Price Advantage: Lower cost with full warranty
- Same 2K Video and Local Storage: Up to 256GB microSD support
Includes Chime Controller and Installation Accessories
This option is ideal for those who want the best in home security technology while saving money.
"Answer your door from anywhere with Wyze Video Doorbell v2 — the clearest, most capable wired video doorbell with local microSD storage for peace of mind."
Alt text: Homeowner using Wyze Video Doorbell v2 to see visitor at front door
Why Choose Wyze Video Doorbell v2 for Local Storage?
- Privacy First: Store your video locally on a microSD card without mandatory cloud subscriptions.
- High-Resolution Footage: Capture every detail with 2K video quality.
- Smart Alerts & Communication: Receive instant notifications and talk to visitors remotely.
- Weatherproof & Durable: Designed to perform in all weather conditions.
- Easy Installation: Comes with all necessary mounting hardware and accessories.
Whether you want to monitor packages, screen visitors, or enhance your home security system, the Wyze Video Doorbell v2 with local microSD storage is a reliable and affordable choice.
What is the video resolution of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 features a stunning 2K video resolution (2048 x 1536 pixels), providing sharper and more detailed footage than standard 1080p cameras.Does the Wyze Video Doorbell v2 support local microSD card storage?
Yes, the Wyze Video Doorbell v2 supports local microSD card storage up to 256GB (FAT32 format), allowing you to save video footage directly on the device for privacy and convenience.Can I use the Wyze Video Doorbell v2 without a cloud subscription?
Absolutely. The Wyze Video Doorbell v2 allows you to store your video recordings locally on a microSD card, so you are not required to use a cloud subscription.Is the Wyze Video Doorbell v2 weatherproof?
Yes, the Wyze Video Doorbell v2 is IP65 weather-resistant, making it suitable for outdoor use in all seasons and climates.What smart features does the Wyze Video Doorbell v2 offer?
The Wyze Video Doorbell v2 includes two-way audio, motion-activated voice deterrence, real-time alerts, and integration with Alexa, Google Assistant, and IFTTT.What is included in the Wyze Video Doorbell v2 package?
The package includes the Wyze Video Doorbell v2 unit, Wyze Chime Controller, wall plate, 30° wedge for angled mounting, installation kit (screws, wire caps, extension wires), and a Quick Start Guide.What is the difference between the new and refurbished Wyze Video Doorbell v2?
The refurbished Wyze Video Doorbell v2 offers the same premium features as the new model, including 2K video and local microSD storage, but at a lower price. Each refurbished unit is fully tested, guaranteed to work like new, and comes with a full warranty.How does the Wyze Video Doorbell v2 perform at night?
The Wyze Video Doorbell v2 is equipped with 6 x 940nm IR lights for clear night vision, ensuring reliable monitoring and detailed video footage even in low-light conditions.What is the field of view for the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 offers a wide 135° horizontal, 103° vertical, and 166.8° diagonal field of view, providing broad coverage of your front porch or entryway.Is the Wyze Video Doorbell v2 easy to install?
Yes, the Wyze Video Doorbell v2 comes with all necessary mounting hardware and accessories, including a wall plate, angled wedge, and installation kit, making setup straightforward and hassle-free.
