Best 1080p HD Wired Doorbells with Two-Way Audio and Live Feed
If you're searching for a reliable
1080p HD wired doorbell that offers
two-way audio and
live video feed, Wyze has you covered with smart, feature-packed options designed to enhance your home security and convenience. Whether you want a standalone doorbell or a complete front porch security bundle, these products deliver crisp video, seamless communication, and smart integrations.
Wyze Video Doorbell v2: Wired 2K Video Doorbell with Two-Way Audio
Experience crystal-clear video and real-time interaction with the
Wyze Video Doorbell v2, Wyze’s most advanced wired video doorbell yet.
Key Features:
- 2K HD Video Quality: Capture every detail on your porch with stunning 2K resolution, surpassing standard 1080p for sharper images.
- Two-Way Audio: Speak directly to visitors or delivery personnel from anywhere using the Wyze app.
- Local microSD Storage: Continuous 24/7 local recording with onboard microSD card slot, so you never miss a moment.
- Motion-Activated Voice Deterrence: Automatically warn unwanted visitors with a voice prompt when motion is detected (requires Cam Plus subscription).
- Works with Existing Chimes: Includes a chime controller to keep your traditional doorbell sound.
- Pre-Roll Motion Recording: Capture 3-6 seconds before motion events for full context.
- IP65 Weatherproof: Built to withstand rain, snow, and harsh weather conditions.
- Color Night Vision: Award-winning starlight sensor delivers clear color video even at night.
- Smart Home Compatibility: Works seamlessly with Alexa and Google Home for voice commands and live feed viewing.
- 30° Corner Kit Included: Adjust your doorbell’s angle for the perfect view, eliminating blind spots.
The Wyze Video Doorbell v2 is perfect for homeowners who want a wired doorbell with superior video quality and smart features that keep you connected to your front door anytime, anywhere.
The Front Porch Security Bundle: 1080p HD Doorbell with Lock Integration
For a comprehensive front porch security solution, the
Front Porch Security Bundle combines the Wyze Video Doorbell with a smart lock, giving you full control over your entryway.
Bundle Highlights:
- 1080p HD Video Doorbell with Two-Way Audio: View your front porch in crisp 1080p HD and communicate with visitors instantly.
- Wyze Lock Integration: Lock or unlock your door remotely via the Wyze app and monitor lock history for added security.
- Convenient Access Management: Control your door’s security from one app, combining video surveillance and smart locking.
- Ideal for Smart Homes: Perfect for those who want to upgrade their front door with both video and keyless entry technology.
This bundle is an excellent choice if you want to combine a wired video doorbell with smart lock capabilities for enhanced security and convenience.
Wyze Video Doorbell v2 Wedge Kit: Perfect Viewing Angle Accessory
Maximize your doorbell’s coverage with the
Wyze Video Doorbell v2 Wedge Kit, designed specifically for angled door frames or porches with stairs.
Features:
- Adjustable Viewing Angles: Includes a 15° horizontal bracket and two 7.5° vertical brackets to eliminate blind spots.
- Weather Resistant: Durable plastic construction built to withstand outdoor conditions.
- Easy Installation: Quick setup to improve your doorbell’s field of view.
- Compatible Only with Wyze Video Doorbell v2.
This accessory ensures your wired doorbell captures the best possible view of your porch and entryway.
Why Choose Wyze Wired Doorbells with Two-Way Audio?
"Answer your door from anywhere with crystal-clear video and instant communication."
Wyze wired doorbells stand out by offering:
- High-Definition Video: From 1080p HD to 2K resolution, see visitors clearly.
- Two-Way Audio: Talk and listen in real-time through your smartphone.
- Smart Alerts & Motion Detection: Receive instant notifications when someone approaches.
- Local and Cloud Storage Options: Choose between local microSD recording or cloud storage with Cam Plus.
- Weatherproof Durability: Designed to perform in all weather conditions.
- Smart Home Integration: Compatible with Alexa and Google Assistant for hands-free control.
Enhance Your Home Security Today
Investing in a wired video doorbell with two-way audio and live feed is a smart way to protect your home and stay connected. Whether you prefer the standalone
Wyze Video Doorbell v2 or the all-in-one
Front Porch Security Bundle, you get reliable, high-quality video and seamless communication at your fingertips.
Stay connected with your front door anytime, anywhere.
Secure your home’s entryway with smart video and lock control.
Adjust your doorbell’s angle for perfect coverage.
What are the key features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 offers 2K HD video quality, two-way audio, local microSD storage for continuous 24/7 recording, motion-activated voice deterrence (with Cam Plus), compatibility with existing chimes, pre-roll motion recording, IP65 weatherproof rating, color night vision, smart home integration with Alexa and Google Home, and a 30° corner kit for optimal viewing angles.How does the Wyze Video Doorbell v2 improve home security?
The Wyze Video Doorbell v2 enhances home security by providing crystal-clear 2K video, real-time two-way audio communication, instant motion alerts, pre-roll recording for full event context, and weatherproof durability. It also integrates with smart home systems for hands-free control and offers both local and cloud storage options.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a 1080p HD wired video doorbell with two-way audio and a Wyze smart lock. This bundle allows you to view your front porch in high definition, communicate with visitors, lock or unlock your door remotely, and manage access—all from the Wyze app.Can I use my existing doorbell chime with the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 includes a chime controller that allows you to keep your traditional doorbell sound when upgrading to this smart doorbell.Does the Wyze Video Doorbell v2 support local storage?
Yes, the Wyze Video Doorbell v2 features a microSD card slot for continuous 24/7 local recording, ensuring you never miss a moment at your front door.Is the Wyze Video Doorbell v2 weatherproof?
Yes, the Wyze Video Doorbell v2 is IP65 weatherproof, making it suitable for use in rain, snow, and harsh outdoor conditions.What smart home systems are compatible with Wyze wired doorbells?
Wyze wired doorbells are compatible with Alexa and Google Home, allowing you to use voice commands and view live feeds on supported devices.What is the Wyze Video Doorbell v2 Wedge Kit and why do I need it?
The Wyze Video Doorbell v2 Wedge Kit is an accessory that includes adjustable brackets to change the viewing angle of your doorbell. It helps eliminate blind spots, especially for angled door frames or porches with stairs, ensuring optimal coverage of your entryway.How does two-way audio work on Wyze wired doorbells?
Two-way audio on Wyze wired doorbells allows you to speak and listen to visitors in real-time through the Wyze app on your smartphone, providing seamless communication from anywhere.What are the storage options for Wyze wired doorbells?
Wyze wired doorbells offer both local storage via a microSD card for continuous recording and cloud storage through the Cam Plus subscription for additional features like motion-activated voice deterrence.Can I control my door lock and video doorbell from one app with Wyze?
Yes, with the Wyze Front Porch Security Bundle, you can control both your video doorbell and smart lock from the Wyze app, allowing you to monitor your entryway and manage access conveniently from one place.What is pre-roll motion recording on the Wyze Video Doorbell v2?
Pre-roll motion recording captures 3-6 seconds of video before a motion event is detected, giving you full context of what happened leading up to the alert.Is the Wyze Video Doorbell v2 easy to install?
Yes, the Wyze Video Doorbell v2 and its accessories, like the Wedge Kit, are designed for easy installation, making it simple to upgrade your home security.
