Door Open Sensor with Wyze Sense Hub Integration
When it comes to smart home security, having reliable door open sensors integrated with a powerful hub is essential. Wyze offers a seamless solution with its Wyze Sense Hub and compatible Entry Sensors, designed to keep you informed whenever doors or windows open or close. This integration ensures you get instant alerts and enhanced home monitoring capabilities.
Wyze Sense Hub: The Central Brain of Your Security System
The Wyze Sense Hub acts as the command center for all your Wyze Sense sensors, including door open sensors. It connects each monitoring component and sends real-time alerts directly to your smartphone, making it the backbone of your home security setup.
Key Features:
- Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication.
- Range: Up to 500 feet (152 meters) to sensors, allowing flexible placement throughout your home.
- Battery Backup: Built-in rechargeable 3.7V, 2600mAh battery with up to 10 hours of backup power.
- Siren: Loud 88db siren at 2 feet to deter intruders.
- Capacity: Supports up to 100 sensors simultaneously.
- Design: Compact matte finish (4.5” x 4” x 1”) with a white base and grey speaker top, perfect for indoor use.
Included in the box are the Wyze Sense Hub, power adapter, Ethernet cable, window decals, and a quick start guide to get you up and running quickly.
The Wyze Sense Hub is the brains behind your smart home security, ensuring all sensors work in harmony for reliable monitoring.
Wyze Sense Entry Sensors: Detect When Doors Open or Close
Wyze offers two versions of entry sensors that work exclusively with the Wyze Sense Hub, providing accurate detection of door or window status.
Wyze Sense Entry Sensor v2
- Compatibility: Requires Wyze Sense Hub v2.
- Function: Detects when doors or windows open or close.
- Packaging Options: Available in 1-pack, 2-pack, or 3-pack bundles.
- Usage: Ideal for monitoring multiple entry points around your home.
- Note: These sensors do not function standalone or with Wyze Sense v1.
Wyze Sense Entry Sensor (Original)
- Compatibility: Works with Wyze Sense Hub (original) and Wyze Home Monitoring.
- Packaging: Available as a 3-pack.
- Function: Detects open/close status of doors and windows.
- Requirement: Must be paired with the Wyze Sense Hub to operate.
Both sensors provide peace of mind by alerting you instantly when an entry point is accessed, helping you stay aware of your home's security status at all times.
Enhance Your Home Security with Wyze Sense Integration
By combining the Wyze Sense Hub with Wyze Sense Entry Sensors, you create a smart, responsive security system that not only detects door openings but also integrates with other Wyze devices for a comprehensive home monitoring experience.
Benefits of Wyze Sense Hub Integration:
- Centralized control of up to 100 sensors.
- Instant notifications on your smartphone.
- Easy setup and management via the Wyze app.
- Expandable system with motion sensors and cameras for full coverage.
Secure your home with Wyze smart cameras and sensors working together.
Why Choose Wyze for Door Open Sensor Solutions?
Wyze’s ecosystem is designed for simplicity, affordability, and reliability. The Wyze Sense Hub and Entry Sensors provide a robust foundation for your smart home security, ensuring you never miss a door or window opening event. Whether you want to monitor your front door, back door, or any other entry point, Wyze’s sensors deliver accurate detection with seamless hub integration.
Summary of Products for Door Open Sensor with Wyze Sense Hub Integration
Product Name | Description | Price (USD) |
Wyze Sense Hub | Central hub connecting all sensors, alerts, and siren | $45.98 |
Wyze Sense Entry Sensor | Detects door/window open/close, 3-pack | $41.98 |
Wyze Sense Entry Sensor v2 | Updated sensor, available in 1, 2, or 3-pack | $14.99 - $41.98 |
By choosing Wyze Sense Hub and Entry Sensors, you ensure your home is equipped with smart, reliable door open detection integrated into a powerful monitoring system.
What is the Wyze Sense Hub and how does it work?
The Wyze Sense Hub is the central command center for your Wyze home security system. It connects and manages all Wyze Sense sensors, including door open sensors, and sends real-time alerts to your smartphone. The hub supports Ethernet, WiFi, Bluetooth, and RF communication, and can connect up to 100 sensors for comprehensive home monitoring.Which Wyze door open sensors are compatible with the Wyze Sense Hub?
Wyze offers two types of entry sensors compatible with the Wyze Sense Hub: the Wyze Sense Entry Sensor v2 (requires Wyze Sense Hub v2) and the original Wyze Sense Entry Sensor (works with the original Wyze Sense Hub and Wyze Home Monitoring). Both sensors must be paired with a Wyze Sense Hub to function.How do Wyze Sense Entry Sensors detect door or window openings?
Wyze Sense Entry Sensors use magnetic contact technology to detect when a door or window is opened or closed. When the sensor detects a change in status, it sends an instant alert to your smartphone via the Wyze app, helping you monitor your home's security in real time.Can I use Wyze Sense Entry Sensors without the Wyze Sense Hub?
No, Wyze Sense Entry Sensors require a Wyze Sense Hub to operate. They do not function as standalone devices and are not compatible with other hubs or previous versions unless specified.What are the key features of the Wyze Sense Hub?
The Wyze Sense Hub features Ethernet and WiFi connectivity, Bluetooth 4.1 + BLE 5.1, 915MHz RF communication, a range of up to 500 feet, a built-in rechargeable battery with up to 10 hours of backup, an 88db siren, and support for up to 100 sensors. Its compact design makes it ideal for indoor use.How many Wyze Sense Entry Sensors can I connect to one Wyze Sense Hub?
You can connect up to 100 Wyze Sense Entry Sensors (or a combination of compatible Wyze sensors) to a single Wyze Sense Hub, allowing you to monitor multiple doors and windows throughout your home.What comes in the box with the Wyze Sense Hub?
The Wyze Sense Hub package includes the hub itself, a power adapter, an Ethernet cable, window decals, and a quick start guide to help you set up your home security system quickly and easily.What are the benefits of integrating Wyze Sense Entry Sensors with the Wyze Sense Hub?
Integrating Wyze Sense Entry Sensors with the Wyze Sense Hub provides centralized control, instant smartphone notifications, easy setup and management via the Wyze app, and the ability to expand your system with additional sensors and Wyze cameras for comprehensive home security.Are Wyze Sense Entry Sensors available in different pack sizes?
Yes, Wyze Sense Entry Sensor v2 is available in 1-pack, 2-pack, or 3-pack bundles, while the original Wyze Sense Entry Sensor is available as a 3-pack. This allows you to choose the right quantity for your home’s needs.Why should I choose Wyze for door open sensor solutions?
Wyze offers a reliable, affordable, and easy-to-use ecosystem for smart home security. The Wyze Sense Hub and Entry Sensors provide accurate door and window open detection, seamless integration, and instant alerts, ensuring you never miss an important security event.
