Integrate Wyze Sense Hub & Motion Sensor for Home Monitoring
How to Integrate Wyze Sense Hub and Motion Sensor with Home Monitoring
Integrating the Wyze Sense Hub with the Wyze Sense Motion Sensor creates a powerful and reliable home monitoring system. This setup allows you to detect motion, receive instant alerts, and keep your home secure with ease. Below, we break down the key components and how they work together to enhance your home security.
Wyze Sense Hub: The Central Brain of Your Home Monitoring System
The Wyze Sense Hub acts as the central controller that connects all your Wyze monitoring devices, including motion sensors, entry sensors, and more. It is the "brains behind the brawn," coordinating communication and sending alerts directly to your smartphone.
Key Features:
  • Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication, ensuring stable and versatile connections.
  • Range: Communicates with sensors up to 500 feet (152 meters) away, allowing flexible placement throughout your home.
  • Battery Backup: Built-in rechargeable 3.7V, 2600mAh battery with up to 10 hours of backup power to keep your system running during outages.
  • Siren: Loud 88db siren at 2 feet to deter intruders.
  • Capacity: Supports up to 100 sensors, making it scalable for large homes or multiple rooms.
  • Design: Compact matte white base with a grey speaker top, measuring 4.5” x 4” x 1” (114.3 x 101.6 x 25.4 mm), designed for indoor use.
Included in the Box:
  • Wyze Sense Hub
  • Power Adapter
  • Ethernet Cable
  • Window Decals
  • Quick Start Guide
The Wyze Sense Hub is essential for integrating all your Wyze sensors into a cohesive home monitoring system, providing seamless communication and reliable alerts.
Wyze Sense Hub lifestyle Enhance your home security with Wyze Sense Hub integration
Wyze Sense Motion Sensor: Detect Movement with Precision
The Wyze Sense Motion Sensor is designed to detect motion within a 25-foot range and a 120° field of view. It requires the Wyze Sense Hub to function and is a vital component for real-time motion detection in your home.
Key Features:
  • Detection Range: Up to 25 feet with a wide 120° field of view.
  • Adjustable Sensitivity: Customize sensitivity settings to reduce false alarms or increase detection accuracy.
  • Installation: Easy to install with adhesive backing or screws for added security.
  • Battery Life: Long-lasting battery life of up to 18 months, minimizing maintenance.
  • Compatibility: Works exclusively with Wyze Sense v2 and Wyze Home Monitoring systems.
  • Indoor Use: Designed for indoor environments to monitor key areas like entryways, hallways, and living rooms.
When paired with the Wyze Sense Hub, the motion sensor instantly alerts you to any detected movement, helping you stay informed and secure.
Step-by-Step Integration Guide
1. Set Up the Wyze Sense Hub: Connect the hub to your home network via Ethernet or WiFi. Place it centrally in your home for optimal sensor communication. 2. Add the Motion Sensor: Install the Wyze Sense Motion Sensor in your desired location using the adhesive or screws. Ensure it covers the area you want to monitor. 3. Pair Devices: Use the Wyze app to add the Sense Hub and then pair the motion sensor. The hub supports up to 100 sensors, so you can expand your system as needed. 4. Customize Settings: Adjust motion sensor sensitivity and notification preferences in the app to suit your lifestyle and reduce false alerts. 5. Test the System: Walk through the sensor’s detection zone to verify alerts and siren functionality.
Additional Wyze Sense Sensors to Enhance Your Home Monitoring
While the Wyze Sense Hub and Motion Sensor form the core of your system, consider adding these complementary sensors for comprehensive coverage:
Wyze Sense Entry Sensor
  • Detects when doors or windows open or close.
  • Requires Wyze Sense Hub.
  • Ideal for monitoring entry points.
Wyze Sense Climate Sensor
  • Tracks temperature and humidity in any room.
  • Helps maintain comfortable and safe environments.
  • Works up to 500 feet from the hub.
Wyze Sense Keypad
  • Allows remote arming and disarming of your security system.
  • Includes an emergency button for quick alerts.
  • Requires Wyze Home Monitoring.
  • Alerts you to water leaks to prevent damage.
  • Compatible with Wyze Sense Hub and Home Monitoring.
Why Choose Wyze Sense for Home Monitoring?
Wyze Sense products offer an affordable, scalable, and easy-to-install home monitoring solution that integrates seamlessly with your smart home ecosystem. The combination of the Wyze Sense Hub and Motion Sensor provides reliable motion detection and instant alerts, giving you peace of mind whether you’re home or away.
By integrating the Wyze Sense Hub with the Wyze Sense Motion Sensor, you create a smart, responsive home monitoring system that keeps you connected and protected. Expand your setup with additional Wyze sensors to customize your security and environmental monitoring needs.
FeatureWyze Sense HubWyze Sense Motion Sensor
TypeHome MonitoringHome Monitoring
DescriptionConnects monitoring components and sends alerts. Core of Wyze Home Monitoring System.Detects motion up to 25 ft within 120° FOV. Designed to detect people, not pets.
RequiresN/ARequires Wyze Sense Hub (v2 or Wyze Home Monitoring)
Standalone FunctionalityYesNo (will NOT function standalone or with Wyze Sense v1)
Price$45.98 USD$20.98 USD (1 Pack)
InstallationN/AAdhesive back or screws for wall mounting
Sensitivity SettingsN/AAdjustable sensitivity, large pet installation instructions
Field of View (FOV)N/A120°
Detection RangeN/AUp to 25 ft
Quantity11 (1 Pack)
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Sense Hub and how does it work?The Wyze Sense Hub is the central controller for your Wyze home monitoring system. It connects all Wyze sensors, including motion, entry, climate, and leak sensors, and coordinates communication between them. The hub sends instant alerts to your smartphone and features a loud siren, battery backup, and supports up to 100 sensors for scalable home security.
How do I integrate the Wyze Sense Motion Sensor with the Wyze Sense Hub?To integrate the Wyze Sense Motion Sensor with the Wyze Sense Hub, first set up the hub by connecting it to your home network via Ethernet or WiFi. Then, install the motion sensor in your desired location using adhesive or screws. Use the Wyze app to pair the motion sensor with the hub, customize sensitivity and notification settings, and test the system to ensure proper functionality.
What are the key features of the Wyze Sense Motion Sensor?The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view. It offers adjustable sensitivity to reduce false alarms, easy installation with adhesive or screws, and a long battery life of up to 18 months. The sensor is designed for indoor use and works exclusively with Wyze Sense v2 and Wyze Home Monitoring systems.
How many sensors can the Wyze Sense Hub support?The Wyze Sense Hub can support up to 100 sensors, making it ideal for large homes or for monitoring multiple rooms and entry points.
What is included in the Wyze Sense Hub package?The Wyze Sense Hub package includes the Wyze Sense Hub, a power adapter, an Ethernet cable, window decals, and a quick start guide.
Can I use the Wyze Sense Motion Sensor without the Wyze Sense Hub?No, the Wyze Sense Motion Sensor requires the Wyze Sense Hub to function. The hub acts as the central controller, enabling communication and alerts between the sensor and your smartphone.
How do I customize motion detection sensitivity and notifications?You can customize the motion detection sensitivity and notification preferences for your Wyze Sense Motion Sensor through the Wyze app. This allows you to reduce false alarms and tailor alerts to your lifestyle.
What is the range of the Wyze Sense Hub and Motion Sensor?The Wyze Sense Hub can communicate with sensors up to 500 feet (152 meters) away, while the Wyze Sense Motion Sensor detects motion within a 25-foot range and a 120° field of view.
What additional Wyze Sense sensors can I add to my home monitoring system?You can expand your Wyze home monitoring system with additional sensors such as the Wyze Sense Entry Sensor (for doors and windows), Wyze Sense Climate Sensor (for temperature and humidity), Wyze Sense Keypad (for arming/disarming and emergency alerts), and Wyze Sense Leak Sensor & Probe (for water leak detection).
Why should I choose Wyze Sense for home monitoring?Wyze Sense offers an affordable, scalable, and easy-to-install home monitoring solution that integrates seamlessly with your smart home ecosystem. The combination of the Wyze Sense Hub and Motion Sensor provides reliable motion detection and instant alerts, helping you keep your home secure and giving you peace of mind.
What are the steps to set up the Wyze Sense Hub?How do I customize the sensitivity settings for the Wyze Sense Motion Sensor?Can I use the Wyze Sense Motion Sensor outdoors?
