Wireless Entry Sensors Compatible with Wyze Sense Hub for Smart Security
Enhance your home security with Wyze’s smart wireless entry sensors designed to seamlessly integrate with the Wyze Sense Hub. These sensors provide reliable, real-time monitoring of your doors and windows, alerting you instantly when they are opened or closed. Perfect for smart homes, RVs, and any indoor environment, Wyze’s entry sensors offer peace of mind with easy installation and robust connectivity.
Wyze Sense Hub: The Smart Security Brain
The Wyze Sense Hub is the essential centerpiece of your Wyze home monitoring system. Acting as the communication bridge, it connects all your Wyze sensors and sends instant alerts to your smartphone.
- Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication.
- Range: Up to 500 feet to sensors, allowing flexible placement throughout your home.
- Battery: Built-in rechargeable 3.7V, 2600mAh battery with 10 hours backup.
- Capacity: Supports up to 100 sensors simultaneously.
- Siren: Loud 88db siren at 2 feet for immediate alert.
- Design: Compact matte white base with grey speaker top, measuring 4.5” x 4” x 1”.
Included with the hub are power adapter, Ethernet cable, window decals, and a quick start guide to get your system up and running quickly.
The Wyze Sense Hub is the brains behind your smart security, ensuring all sensors communicate flawlessly for comprehensive home protection.
Experience seamless smart home security with Wyze Sense Hub and sensors.
Wyze Sense Entry Sensor: Wireless Door & Window Monitoring
The Wyze Sense Entry Sensor is designed specifically to detect when doors or windows open or close, making it a vital component of your smart security setup.
- Compatibility: Works exclusively with Wyze Sense Hub (v2) and Wyze Home Monitoring.
- Functionality: Sends instant alerts when entry points are opened or closed.
- Pack Options: Available in convenient 3-packs for multiple entry points.
- Installation: Easy to mount with adhesive backing, no wiring required.
- Note: Not compatible with Wyze Sense v1 or standalone use.
This sensor is perfect for monitoring all access points in your home or RV, providing an extra layer of security and awareness.
Additional Wyze Sense Sensors to Complement Your Security System
Wyze Sense Motion Sensor
Add motion detection to your security system with the Wyze Sense Motion Sensor, which detects movement within a 25-foot range and a 120° field of view.
- Compatibility: Requires Wyze Sense Hub (v2) or Wyze Home Monitoring.
- Battery Life: Up to 18 months on a single battery.
- Installation: Adhesive or screw mounting options.
- Adjustable Sensitivity: Customize detection to reduce false alarms.
Wyze Sense Keypad
Control your security system remotely with the Wyze Sense Keypad, allowing you to arm or disarm your system conveniently.
- Features: Arm/disarm system, emergency button for first responders.
- Compatibility: Requires Wyze Sense Hub and Wyze Home Monitoring.
- Indoor Use: Designed for indoor placement with permanent adhesive.
Why Choose Wyze Wireless Entry Sensors for Your Smart Security?
Wyze offers a comprehensive, easy-to-install smart security ecosystem that integrates seamlessly with the Wyze Sense Hub. Their wireless entry sensors provide reliable, real-time monitoring of your home’s access points, ensuring you stay informed and protected at all times.
- Wide Sensor Support: Connect up to 100 sensors for full home coverage.
- Long Wireless Range: 500 feet RF range ensures sensors work even in large homes or RVs.
- Smart Alerts: Instant notifications on your phone for any entry activity.
- Expandable System: Add motion, climate, leak sensors, and keypads to customize your security.
Summary of Compatible Wyze Sense Products for Entry Monitoring
Product | Key Features | Price (USD) |
Wyze Sense Hub | Central hub, 500 ft range, 88db siren | 45.98 |
Wyze Sense Entry Sensor | Detects open/close, 3-pack, requires hub | 41.98 |
Wyze Sense Motion Sensor | Motion detection, 25 ft range, adjustable | 20.98 |
Wyze Sense Keypad | Arm/disarm remotely, emergency button | 27.98 |
By choosing Wyze Sense wireless entry sensors compatible with the Wyze Sense Hub, you invest in a smart, scalable, and reliable home security system that keeps you connected and protected effortlessly.
Control your home security with Wyze Sense Keypad.
What are Wyze wireless entry sensors and how do they enhance home security?
Wyze wireless entry sensors are smart devices designed to monitor doors and windows in real time. When integrated with the Wyze Sense Hub, they provide instant alerts to your smartphone whenever an entry point is opened or closed, enhancing your home security by keeping you informed of any activity.Are Wyze Sense Entry Sensors compatible with all Wyze Hubs?
Wyze Sense Entry Sensors are compatible exclusively with the Wyze Sense Hub (v2) and Wyze Home Monitoring. They are not compatible with Wyze Sense v1 or for standalone use.How do I install Wyze wireless entry sensors?
Wyze wireless entry sensors are easy to install using the included adhesive backing. No wiring is required, making them suitable for quick setup on doors and windows in homes, RVs, or other indoor environments.What is the wireless range of the Wyze Sense Hub?
The Wyze Sense Hub offers a wireless range of up to 500 feet to connected sensors, allowing flexible placement throughout large homes or RVs.How many sensors can the Wyze Sense Hub support simultaneously?
The Wyze Sense Hub can support up to 100 sensors at the same time, providing comprehensive coverage for your entire home.What types of alerts do Wyze entry sensors provide?
Wyze entry sensors send instant notifications to your smartphone whenever a connected door or window is opened or closed, ensuring you are always aware of activity at your home’s access points.Can I expand my Wyze security system with additional sensors?
Yes, the Wyze security system is expandable. You can add motion sensors, climate sensors, leak sensors, and keypads to customize and enhance your home security setup.What is included with the Wyze Sense Hub?
The Wyze Sense Hub package includes the hub itself, a power adapter, Ethernet cable, window decals, and a quick start guide to help you set up your smart security system quickly.What are the features of the Wyze Sense Motion Sensor?
The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view. It features adjustable sensitivity, up to 18 months of battery life, and can be mounted with adhesive or screws. It requires the Wyze Sense Hub (v2) or Wyze Home Monitoring.How does the Wyze Sense Keypad work with the security system?
The Wyze Sense Keypad allows you to arm or disarm your security system remotely and features an emergency button for first responders. It is designed for indoor use and requires the Wyze Sense Hub and Wyze Home Monitoring.Why should I choose Wyze wireless entry sensors for my smart home security?
Wyze wireless entry sensors offer reliable, real-time monitoring, easy installation, wide sensor support, long wireless range, and instant smart alerts. The system is scalable and integrates seamlessly with the Wyze Sense Hub, making it a smart choice for comprehensive home security.
