Wyze Sense Hub Sensor Support: Compatible Sensors & Features
Wyze Sense Hub Sensor Support: Comprehensive Guide to Compatible Sensors
If you're looking to enhance your home security and automation with Wyze Sense Hub, understanding the range of compatible sensors is essential. Wyze Sense Hub acts as the central controller for a variety of Wyze Sense sensors, enabling seamless communication and smart monitoring throughout your home. Below, we explore the key sensors supported by the Wyze Sense Hub, highlighting their features and how they contribute to a smarter, safer living environment.
Wyze Sense Sensors Compatible with Wyze Sense Hub
Wyze Sense Climate Sensor
Monitor your home's temperature and humidity with precision using the Wyze Sense Climate Sensor. Designed specifically to work with Wyze Sense v2 and the Wyze Sense Hub, this sensor helps you maintain optimal indoor conditions.
  • Range: Up to 500 feet from the hub, ideal for basements, attics, or distant rooms
  • Design: Sleek, matte white finish that blends unobtrusively into any room
  • Mounting: Peel-and-stick adhesive or optional screws for flexible placement
  • Battery Life: Long-lasting CR2032 battery with up to 1.5 years of operation
  • Indoor Use: Operates reliably between 32°F to 104°F (0°C to 40°C) with humidity tolerance up to 85%
  • Communication: Uses 915MHz RF for stable sensor-to-hub connection
This sensor is perfect for homeowners who want to keep tabs on climate changes that could affect comfort or even the integrity of their home.
Wyze Sense Motion Sensor
Detect movement instantly with the Wyze Sense Motion Sensor, a vital component for any home security setup connected to the Wyze Sense Hub.
  • Detection Range: Covers up to 25 feet with a wide 120° field of view
  • Sensitivity: Adjustable settings to reduce false alarms
  • Installation: Easy adhesive backing or screws for secure mounting
  • Battery Life: Up to 18 months on a single battery
  • Compatibility: Works exclusively with Wyze Sense v2 and Wyze Home Monitoring systems
  • Max Sensors per Hub: Supports up to 100 sensors, allowing extensive coverage
Ideal for monitoring entryways, hallways, or any area where motion detection is critical for security.
Wyze Sense Entry Sensor
Keep track of doors, windows, or cabinets with the Wyze Sense Entry Sensor, designed to alert you whenever something opens or closes.
  • Functionality: Detects open/close status with reliable accuracy
  • Compatibility: Requires Wyze Sense Hub and works with Wyze Sense v2 or Wyze Home Monitoring
  • Packaging: Available in convenient 3-packs for multiple entry points
  • Installation: Simple adhesive mounting for quick setup
  • Note: Not compatible with Wyze Sense v1 or standalone use
This sensor is essential for securing access points and ensuring you’re notified of any unexpected activity.
Protect your home from water damage with the Wyze Sense Leak Sensor & Probe, which alerts you immediately if leaks are detected.
  • Notification: Instant alerts via the Wyze app when leaks occur
  • Range: Up to 500 feet communication distance from the hub
  • Operating Conditions: Works indoors between 32°F to 104°F (0°C to 40°C) and humidity up to 85%
  • Compatibility: Requires Wyze Sense Hub and supports Wyze Sense v2 and Wyze Home Monitoring
  • Variants: Available with multiple probes and sensors for comprehensive leak detection
Perfect for basements, kitchens, bathrooms, or anywhere leaks might cause costly damage.
Wyze Sense Keypad
Control your home security system remotely with the Wyze Sense Keypad, a convenient accessory that integrates with the Wyze Sense Hub.
  • Functionality: Arm and disarm your system with ease
  • Emergency Button: Quickly send first responders in case of emergency
  • Installation: Permanent adhesive backing for secure placement indoors
  • Compatibility: Requires Wyze Home Monitoring and Wyze Sense Hub
  • Accessory Support: Can connect up to 100 accessories for a fully integrated system
This keypad adds an extra layer of control and peace of mind for your home security setup.
Why Choose Wyze Sense Hub and Sensors?
Wyze Sense Hub acts as the backbone of your home monitoring system, supporting a wide range of sensors that communicate reliably over long distances. Whether you want to monitor climate, detect motion, secure entry points, or prevent water damage, Wyze Sense sensors provide affordable, easy-to-install solutions that integrate seamlessly with the Wyze app.
Lifestyle Integration with Wyze Sense Hub
Wyze Sense Keypad in Home Setting Control your home security effortlessly with the Wyze Sense Keypad. Wyze Sense sensors are designed to blend into your home environment without disrupting your décor. Their compact, sleek designs and flexible mounting options make them ideal for any room or space. The Wyze app centralizes control, notifications, and settings, making it simple to customize your home monitoring experience.
Summary of Wyze Sense Hub Supported Sensors
Sensor TypeKey FeaturesBattery LifeRangeRequires Wyze Sense Hub
Climate SensorTemperature & humidity monitoring1.5 years500 ftYes
Motion SensorMotion detection, adjustableUp to 18 months25 ftYes
Entry SensorOpen/close detectionLong-lastingN/AYes
Leak Sensor & ProbeWater leak alertsLong-lasting500 ftYes
KeypadArm/disarm & emergency buttonN/AN/AYes
Conclusion
The Wyze Sense Hub supports a versatile lineup of sensors that empower you to monitor and protect your home efficiently. From climate control to security and leak detection, these sensors offer reliable performance, long battery life, and easy installation. Integrate them with your Wyze Sense Hub to create a smart, responsive home environment tailored to your needs.
FeatureWyze Sense Climate SensorWyze Sense Motion SensorWyze Sense KeypadWyze Sense Leak Sensor & ProbeWyze Sense Entry Sensor
PurposeTracks temperature and humidityDetects motionDisarm home security remotelyGet notified of leaksDetects when things open/close
RequiresWyze Sense Hub, Wyze Sense v2, Wyze Home MonitoringWyze Sense Hub, Wyze Sense v2, Wyze Home MonitoringWyze Sense Hub, Wyze Home MonitoringWyze Sense Hub, Wyze Sense v2, Wyze Home MonitoringWyze Sense Hub, Wyze Sense v2, Wyze Home Monitoring
Standalone FunctionalityNoNoNoNoNo
Range500 ft25 ft (120° FOV)N/AUp to 500 ftN/A
InstallationPeel-and-stick adhesive or place on surfaceAdhesive back or screwsPermanent adhesiveIndoor use onlyAdhesive back or screws
DesignSleek, white, unobtrusiveSmall sensorKeypad with emergency buttonSensor with probeSmall sensor
Indoor/Outdoor UseIndoor onlyIndoor onlyIndoor onlyIndoor onlyIndoor only
Additional FeaturesTracks temperature and humidityAdjustable sensitivity, pet immunityArm/disarm system, emergency buttonOperating temp: 32-104°F (0-40°C)Detects open/close events
Pack Size / Price3 Pack / $41.981 Pack / $20.98Default / $27.982 Probes ($13.98), 3 Sensors + 1 Probe ($55.98)3 Pack / $41.98
What sensors are compatible with the Wyze Sense Hub?The Wyze Sense Hub is compatible with Wyze Sense v2 sensors, including the Climate Sensor, Motion Sensor, Entry Sensor, Leak Sensor & Probe, and the Wyze Sense Keypad. These sensors are designed to work seamlessly with the hub for comprehensive home monitoring and automation.
How does the Wyze Sense Climate Sensor work with the Wyze Sense Hub?The Wyze Sense Climate Sensor monitors temperature and humidity in your home and communicates with the Wyze Sense Hub using 915MHz RF. It has a range of up to 500 feet, a long-lasting CR2032 battery (up to 1.5 years), and is designed for indoor use. It helps you maintain optimal indoor conditions and is ideal for basements, attics, or distant rooms.
What is the detection range of the Wyze Sense Motion Sensor?The Wyze Sense Motion Sensor has a detection range of up to 25 feet with a wide 120° field of view. It features adjustable sensitivity settings to reduce false alarms and can be easily installed using adhesive backing or screws.
Can I use Wyze Sense Entry Sensors with the Wyze Sense Hub?Yes, Wyze Sense Entry Sensors are compatible with the Wyze Sense Hub and Wyze Sense v2. They detect the open/close status of doors, windows, or cabinets and are essential for securing access points in your home. Note that they are not compatible with Wyze Sense v1 or for standalone use.
How does the Wyze Sense Leak Sensor & Probe protect my home?The Wyze Sense Leak Sensor & Probe alerts you instantly via the Wyze app if a water leak is detected. It communicates with the Wyze Sense Hub up to 500 feet away and is suitable for indoor use in areas like basements, kitchens, and bathrooms. Multiple probes and sensors can be used for comprehensive leak detection.
What is the function of the Wyze Sense Keypad with the Wyze Sense Hub?The Wyze Sense Keypad allows you to arm and disarm your home security system easily. It features an emergency button to quickly alert first responders and supports up to 100 accessories for a fully integrated security setup. The keypad requires the Wyze Sense Hub and Wyze Home Monitoring.
How many sensors can I connect to the Wyze Sense Hub?You can connect up to 100 Wyze Sense sensors and accessories to a single Wyze Sense Hub, allowing for extensive coverage and customization of your home monitoring system.
Are Wyze Sense sensors easy to install?Yes, Wyze Sense sensors are designed for easy installation with peel-and-stick adhesive or optional screws. Their compact and sleek design allows them to blend seamlessly into any room without disrupting your décor.
Do Wyze Sense sensors require the Wyze app for operation?Yes, the Wyze app is required to control, monitor, and receive notifications from your Wyze Sense sensors. The app centralizes all settings and alerts, making it easy to customize your home monitoring experience.
What are the benefits of using Wyze Sense Hub and sensors for home security?Wyze Sense Hub and its compatible sensors provide reliable, long-range communication, easy installation, and affordable solutions for monitoring climate, motion, entry points, and water leaks. They integrate seamlessly with the Wyze app, offering a smart, responsive, and customizable home security system.
What are the key features of the Wyze Sense Climate Sensor?How does the Wyze Sense Motion Sensor work for home security?Do you have any deals, ongoing sales, discounts, or promotions?
